Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 206 - AVS Forum | Home Theater Discussions And Reviews
 13254Likes
post #6151 of 8427 Old 09-30-2018, 08:12 PM
Roger Dressler's Avatar
Quoted: 3003 Post(s)
Liked: 1765
Originally Posted by Swatdude1 View Post
The concern is using the variable L/R output on the Anthem to feed the crossover since I think that is always active and can't be disabled specific to an input.
When the 720 runs any sources through bass management, there will be no bass from the main outputs, just the redirected bass + LFE through the Sub out.
I just did a search and audiophile grade low pass filters are scarce.
I use a MiniDSP for 2-ch bass processing. It works great, and there's lots of filtering and EQ flexibility. Ideally they would have a 4-in 4-out unit, but alas not.
As far as the splitter, would the 2 female to one male BlueJeansCable work fine?
Only if you added series resistors in line with each input. Then it would be fine.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #6152 of 8427 Old 10-01-2018, 12:23 PM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 317
Hello all, proud to be part of the Anthem owners group!
Yesterday I ran into a setup question I was hoping I could get some help with.
I have the 1120 with the projector on HDMI Out 1 and the TV connected to HDMI Out 2. Sources Input 1 Odroid C2, Input 2 satellite receiver and Input 3 PS3.
I was testing with Input 2
What I am trying to get is the video and audio to the TV (on board speakers) without audio to the theater speakers
At the moment I was able to do it with the Standby HDMI Bypass enabled to Last Input but that seams very kludgy and the harmony remote won't let me program an off command in the start up sequence.
I also need to be able to change the input to 1, 2 or 3 as needed
Hope that explains it ok
Any recommendations?
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #6153 of 8427 Old 10-01-2018, 10:22 PM
cr500guy's Avatar
Quoted: 66 Post(s)
Liked: 24
Sony 4K player not likin Anthem?
I just did a firmware update on my Sony UBP-X800 4k blu ray player and now it will not work when connected to my Anthem MRX 720. It does work when connected directly to the display, taking the Anthem out of the chain. As a result Sony says the issue isn’t the player.
Has anyone any idea as to what to suggest?
Thanks in advance.
JVC DLA-X750R projector, Panasonic DP-UB820 4k Bluray player, Anthem MRX-720 receiver, 5.1.4 Atmos, Klipsch Reference II Speakers, Dual Sealed 18” UXL Subwoofers - Inuke 6000dsp Sub amp, Buttkicker LFE, Vizio P-65 TV.
cr500guy is offline
post #6154 of 8427 Old 10-01-2018, 11:32 PM
Swatdude1's Avatar
Quoted: 66 Post(s)
Liked: 27
Roger, I so appreciate your help on this. I just got sick to my stomach when I thought I had spent all that money on the 205 for nothing. I just checked out the 2.1 info for the MiniDSP... pretty slick.
However, my background is mechanical engineering and I barely made it through the required EE classes. You lost me with the resistor comment. Is there a different splitter actually made for two signals into one which is just plug and play? Also, would you know how I find the crossover and slope my ARC setup determined for my sub?
Swatdude1 is offline
post #6155 of 8427 Old 10-02-2018, 12:00 AM
Liked: 1765
Take a look at this post. Soldering is mechanical, not electrical, so you should be right at home.
For the crossover frequencies below which each main speaker's bass is redirected to the sub, look in the ARC program Target page after the calculations are done. They label it "Equalization Cutoffs." I think that is what you are asking.
ARC uses 4th-order crossovers for bass management.
post #6156 of 8427 Old 10-02-2018, 09:20 AM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 317
Update to my previous post.....
Anthems wonderful technical support responded to me and provided the following explanation...... hope it helps some one else.
"With our current MRX x20 and AVM 60 models the audio is only sent out via the HDMI outputs when the main zone is off and you’ve enabled Standby HDMI bypass in the general configuration menu.So if the main zone is turned on, then it will stop sending the audio out both the HDMI output 1 & 2."
"The zone 2 is limited to just audio, the unit does not support separate video for Zone 2. You could run separate audio the the second display via the RCA preouts of the MRX 1120 itself, this would send 2 channel content to that location."
To get it working for my use I have created a harmony remote sequence that turns on the main, sets it to the input I want, turns on the input device, then turns the main off.
Thanks to friends wisdom I tricked the harmony by "fixing" a unused command to be the off command, I used the number 9. This got an off signal in the start sequence that harmony does not normally have available.
There is a lot of clicking and on/off going on but it gets me where I need to be till a better solution presents itself.... maybe speakers for the TV.... new project lol
Hope that makes sense.
Family Cave Theater
post #6157 of 8427 Old 10-03-2018, 08:32 PM
Swatdude1's Avatar
Quoted: 66 Post(s)
Liked: 27
Roger already stated this but I did confirm today with Anthem that the use of a high-end DAC with the Anthem, without full range front speakers, is pretty useless. All the DSP is done in the digital domain and the sound will only be as good as the Anthem DACs. With that said, I guess this is common to every new receiver out there now.
post #6158 of 8427 Old 10-04-2018, 11:19 AM
PGriff1051's Avatar
Quoted: 25 Post(s)
Liked: 30
There is a solution. You can run speaker wire from the L/R Front speaker terminals on the Anthem to Speaker Line Inputs on your subwoofer (if it has them) You then need to set the crossover on the subwoofer to say 80HZ. You then need to recalibrate ARC because doing it this way will bring the sub into play with the front speaker.s ARC needs to adjust the low end of the front for this.
I did it this way with my Velodyne DD-15 and set up 2 Presets. One when listening to Music via the 205 with the 80HZ Crossover and lower volume setting and one for everything else with no crossover set in the Velodyne - ARC is doing all the work based on what I recalibrated with the sub now involved with the fronts.
In all honesty, I can't tell the difference between using it with the process analog input on and doing this way. To me, both ways sound a bit more engaging and less congested than sending music from my Mac Mini via USB to SPDIF Converter to the Anthem's digital input.
PGriff1051 is offline
post #6159 of 8427 Old 10-05-2018, 07:14 PM
rondongon's Avatar
Quoted: 169 Post(s)
Liked: 59
Sporadic shutdown!
My MRX720 shutdown by itself few times this week, once was listening to very low level music (-45dB), other time was watching a movie. In neither occurrence was there an overload msg. Just wondering if other HDMI CEC enabled equipment could without user request shutdown other equipment.
Anthem weren’t much of help, saying to take the unit to my dealer and have them reproduce the issue before sending it on.
rondongon is offline
post #6160 of 8427 Old 10-05-2018, 08:29 PM
Bill-99's Avatar
Quoted: 870 Post(s)
Liked: 548
Curious. Haven't seen a shutdown but did get random input change caused by a Roku telling the AVM 60 to do so. A CEC filter fixed that.
Sent from my Pixel 2 using Tapatalk
Bill-99 is offline
post #6161 of 8427 Old 10-06-2018, 03:53 AM
Delija's Avatar
Quoted: 417 Post(s)
Liked: 287
This happened to me once on the very beginning and it didn't occur again since then.
I'm not using remote at all - mobile application works great.
Originally Posted by Delija View Post
Second day of owning and I've already had to pull the power cord - it got stuck/frozen.
I fell a sleep listening to the music and when I woke up I've tried to lower the volume on mobile application (I was using it for couple of hours without problems) - it wasn't working. But, remote control and all buttons on AVR were also not working. Completely stuck/frozen.
Not a great way to start...
I had Yamaha AVRs for more than 15 years and not even one issue.
Anthem MRX 720 | Parasound Halo A21
Dynaudio Contour 60 | Dynaudio Excite X28 | Dynaudio Emit M20 | 2x SVS SB16-Ultra
LG OLED65C7V
Delija is offline
post #6162 of 8427 Old 10-06-2018, 05:11 AM
rondongon's Avatar
Quoted: 169 Post(s)
Liked: 59
Yeah, I recall you having that issue and I had that too in the past, disabling CEC usually helps, but I’ve seen that even if I disable CEC in MRX for turning on/off, then unplug all equipment, sometimes either end of the chain does turn on or off occasionally when I power On or Off either equipment. I only leave the CEC option enabled for ARC, and disable the other two, but somehow it still happens. Hence why I thought the sporadic shutdowns may be caused by the TV over HDMI...
post #6163 of 8427 Old 10-06-2018, 06:23 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5838 Post(s)
Liked: 8329
^ If you are using a programmable remote, such as Harmony, this can also be due to incorrect setup of that remote. For example, it could be sending PowerToggle to the Anthem in the mistaken belief that’s actually PowerOn.
To test, try using only the regular remotes for everything for a while.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #6164 of 8427 Old 10-06-2018, 08:26 AM
Bill-99's Avatar
Quoted: 870 Post(s)
Liked: 548
^Bob, my experience may be a bit different.
My scenario:
1) Turn on the TV.
2) Change immediately to my blu ray player or HTPC input.
The result was unpredictable. About half the time, there'd be a behind the scenes switch to Roku because of CEC data it was passing. Playing with timing delays in the remote didn't work. Eventually I gave up and installed a Lindey CEC filter between the Roku and AVM 60. It prevents CEC data from being passed, and in my system, it solve the problem. YMMV as always.
Bill-99 is offline
post #6165 of 8427 Old 10-06-2018, 10:06 AM
rondongon's Avatar
Quoted: 169 Post(s)
Liked: 59
—Bob
I am not using any programmable remote, but it’s all pointing to my LG Tv acting crazy before it died, and maybe it was being nutso over HDMI... I’ve quarantineed the LG now (disconnected), and using the MRX for music, so far it’s been playing for four hours.
post #6166 of 8427 Old 10-06-2018, 10:19 AM
Read the FAQ!
Liked: 8329
My scenario:
1) Turn on the TV.
The Roku takes a LONG time to boot, and tries to seize the attention of the rest of your system after it finishes booting. That's likely why your experience with it was so annoying.
--Bob
post #6167 of 8427 Old 10-06-2018, 10:21 AM
Read the FAQ!
Liked: 8329
The LG tries to use HDMI CEC to establish ARC audio output (audio sent back out from the TV on the HDMI cable normally used to feed video to the TV). It also senses new devices as the come live on its inputs.
So it is definitely twiddling its HDMI CEC thumbs. It could be the settings in the LG (such as enabling ARC output), or it could be the TV failing as you suggested.
--Bob
rondongon likes this.
post #6168 of 8427 Old 10-06-2018, 10:28 AM
Bill-99's Avatar
Quoted: 870 Post(s)
Liked: 548
--Bob
The Roku boot process is kind of a mystery to me. In my HT, the AVM 60 starts in warm standby but the Roku is always on... just kind of hanging out sipping electricity. It's almost like the Roku detects that the AVM 60 has been turned on and starts shrieking "Hey! I'm here! Pay attention to me! I'm the center of this HT universe! Here's some CEC data to prove it!" But whatever.
And yeah, pretty annoying!
Bill-99 is offline
post #6169 of 8427 Old 10-06-2018, 11:04 AM
rondongon's Avatar
Quoted: 169 Post(s)
Liked: 59
--Bob
This HDMI CEC is a can of worms, yes I use ARC, but I have disabled both CEC power control on/off in MRX menu, unplugged unit and HDMI cable, and sometimes the LG still manages to turn on the MRX, or the MRX manages to turn on the LG, like once ... very bizarre.
I can't recall if DD+ is supported over optical connection, but if not maybe I'll ditch ARC and wire an optical cable. I only use audio out of my TV for OTA TV local news... I've checked the Lindy ARC filter and it does not allow ARC as it disables CEC control.
Name:	Screen Shot 2018-10-06 at 12.57.25 PM.png
post #6170 of 8427 Old 10-06-2018, 02:06 PM
Bill-99's Avatar
Quoted: 870 Post(s)
Liked: 548
Good call, rondongon, I completely missed the "ARC requires CEC" aspect of this. I also use OTA TV but my TV is Samsung and luckily doesn't have this issue.
Bill-99 is offline
post #6171 of 8427 Old 10-08-2018, 01:14 AM
Quoted: 534 Post(s)
Liked: 124
Originally Posted by Legairre View Post
From the MRX or AVM go to: Setup Menu >> Level Calibration At the top of the menu is the "Dolby Offset/Calibration Level". I've never changed it but I know it works for the test tones so it may work for the ARC tones as well. Try changing it for a given profile and then run ARC and look in the target window for that profile's level tab and see if the Calibration Level is higher than 0.
Also since it's just a test to see if it works just run ARC for the minimum number of speakers which is the two fronts. That way you don't waste you time. Then if it works you can run it for real.
Way too late in responding to this, but I just tried this, I set the Dolby Offset to -10 for the first config and all speaker levels I also set to 0 (though not sure if the later matters), and running Arc after, it set the trims to more reasonable levels (comparable to what I had with the other receivers), i.e. around -2 to +2, instead of +10 etc like it did before.
Though there was also a newer version of Arc that I updated to, but really not sure if that had to do anything with this.
alextr75 is offline
post #6172 of 8427 Old 10-08-2018, 10:31 PM
Swatdude1's Avatar
Quoted: 66 Post(s)
Liked: 27
So I bought the MINIDSP and mic, and I bought the EDCOR SM2 because I didn't want to solder. Should have it all in two weeks and will let you know how it sounds.
post #6173 of 8427 Old 10-09-2018, 12:16 PM
PGriff1051's Avatar
Quoted: 25 Post(s)
Liked: 30
So I bought the MINIDSP and mic, and I bought the EDCOR SM2 because I didn't want. Should have it all in two weeks and will let you know how it sounds.
Please do. I was thinking of doing something similar but added more cables and devices between the equipment seemed like the point where diminishing marginal returns starts to become negative - like cramming 500 manufacturing people on a manufacturing floor built for 400 people.
post #6174 of 8427 Old 10-11-2018, 04:47 AM
Hostility's Avatar
Quoted: 42 Post(s)
Switching from a mrx 300 to 720 in a few weeks. I’m going to run a 7.2.4 setup. Does the Atmos speakers need to be connected all to an external amp or can you use internal? My front 3 speakers are amped already and I believe I need to amp another 2 channels but sure curious on how the internal amp works with adding in the Atmos
Hostility is offline
post #6175 of 8427 Old 10-11-2018, 06:07 AM
Read the FAQ!
Liked: 8329
In the 720, with 7 ear-level speakers, you will need to use the pre-amp outs for your 4 height speakers, which means you will need amplification for all 4 of those.
If you'd prefer to use the internal amp in the Anthem, you might want to look at the 1120 instead of the 720.
--Bob
post #6176 of 8427 Old 10-11-2018, 06:13 AM
Hostility's Avatar
Quoted: 42 Post(s)
--Bob
I had a feeling that was the case.. I guess I’ll need to keep an eye out for a cheap 4 channel amp and keep that under the table from the wife lol thanks!
post #6177 of 8427 Old 10-11-2018, 11:30 AM
Hostility's Avatar
Quoted: 42 Post(s)
My other option is do a 5.1.2 setup and leave 7.1.4 for down the road. Just not sure if 5.1.2 would be better then 7.1 right now
post #6178 of 8427 Old 10-11-2018, 05:35 PM
eyecatcher127's Avatar
Quoted: 79 Post(s)
Liked: 38
Has anyone had an issue with ARC when enabled introduces distortion? I thought I had a blown midrange, there is a strange noise that sounds like break up but it is only on the right channel. If it swap the speaker main outs, the noise appears on the left so it is not my speakers thankfully. It goes away when ARC is disabled. I tried different input sources and uploading a different measurement and same results. Also reoccurs after a reset of the unit.
eyecatcher127 is offline
post #6179 of 8427 Old 10-11-2018, 05:39 PM
Quoted: 140 Post(s)
Liked: 40
Do you see any unexpected curve pattern on the ARC panel?
Could it be some noise impacting the calibration process?
You may rerun the ARC and try again.
Sent from my Pixel 2 XL using Tapatalk
Dick_Lai is offline
post #6180 of 8427 Old 10-11-2018, 05:39 PM
Legairre's Avatar
Quoted: 1245 Post(s)
Liked: 685
Being fully surrounded with 7.x.4 is much better than 5.x.2 if you have the space and budget. A 50wpc amp for the height speakers will work great so I'd get two of these. https://www.amazon.com/OSD-Audio-XMP...5%3A2470955011 They are stereo amps and are 50 wpc with 8 ohms speakers and you can run the trigger wire and they will turn on/off with the MRX 720. A pair will run you about $200.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is online now
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
