Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 231 - AVS Forum | Home Theater Discussions And Reviews
 13129Likes
post #6901 of 7885 Old 04-03-2019, 01:39 PM
buggs1a's Avatar
Quoted: 383 Post(s)
Liked: 51
Originally Posted by Legairre View Post
Even with other receivers you can’t turn a 2.0 signal into DD 5.1. What you can do with older receivers is up mix a 2.0 signal to like PLIIx to make the receiver use all your speakers, though it’s still not DD 5.1 it’s just an up mix. With the MRX and other modern receivers you have Dolby Surround and Dolby Surrounds can up mix 2.0 or any other format to use all your speakers.
One thing to note is that the MRX display shows the format being input to the MRX that’s why I say you are getting 2.0 from xfinity. If you want to see the format of what is being output to your speakers you have to hit the “mode” button on the remote and then you use the up/down arrows on the remote to cycle through the different output modes that are available.
Go into the input setup menu (for each input) and set the “Preset for Stereo” and the “Preset for Multichannel” to Dolby Surround so that by default the MRX will up mix audio all your speakers. Never use “Last Used”, because that will make the MRX always default that input to whatever the last format used was .
By having it set to last used you are getting the last used(probably 2.0) all the time until you change it manually with the remote to something else. If you set the inputs to Dolby Surrounds 2.0 then everything else will always get up mixed to all your speakers. So go into the inputs and set it up as Dolby Surrounds for all your inputs.
I agree. My guess is Xfinity streaming is only pcm 2.0. There are no settings for audio in the iOS or Android Xfinity stream app and there are no audio settings at the Xfinity stream web site. So that and the fact that computers don’t have settings like that and the Anthem shows pcm multichannel or similar says to me that Xfinity streaming just doesn’t have native sound. Something I have to complain about.
But in the input menu for sound on the Anthem it is set for Dolby Surround yet I still only have sound from 2.0. No center.
buggs1a is offline
post #6902 of 7885 Old 04-03-2019, 01:47 PM
Legairre's Avatar
Quoted: 1154 Post(s)
Liked: 630
Can you hit the mode button on the remote just one time to see what the mode is. It should say Dolby Surround. If it doesn't keep hitting it until it says Dolby Surround. Even though you have it set in the setup menu to Dolby Surround the mode button overrides the input setup menu and maybe for some reason yours is in 2.0.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is offline
post #6903 of 7885 Old 04-03-2019, 02:00 PM
buggs1a's Avatar
Quoted: 383 Post(s)
Liked: 51
I’ll try tomorrow as I just got in bed. Zzzzzzz.
buggs1a is offline
post #6904 of 7885 Old 04-03-2019, 09:33 PM
OzHDHT's Avatar
Quoted: 1215 Post(s)
Liked: 732
So we're into April. I had a tiny hope that ARC Genesis might be out by the weekend so I could have a play with it and the 1120 while at my weekender but that hope is fading fast.. It will probably turn up next week after I've been lol.
Don't suppose anyone has any inside info from Anthem on the release?
OzHDHT is offline
post #6905 of 7885 Old 04-04-2019, 10:36 AM
Roger Dressler's Avatar
Quoted: 2903 Post(s)
Liked: 1672
Mr. Google agrees with you.
https://forums.xfinity.com/t5/XFINIT...d/td-p/3176108
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win7 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #6906 of 7885 Old 04-04-2019, 01:20 PM
BGLeduc's Avatar
Quoted: 2504 Post(s)
Liked: 2340
We will ship no ARC before its time - Paul Masson Anthem
OzHDHT likes this.
#JB17
BGLeduc is online now
post #6907 of 7885 Old 04-04-2019, 03:40 PM
Nugget's Avatar
Quoted: 204 Post(s)
Liked: 200
I hope Anthem is more like that and less like this:
BGLeduc and OzHDHT like this.
I like cars, airplanes, running, and coding || current gear: two eyes, two ears, one brain, and some other junk.
Nugget is online now
post #6908 of 7885 Old 04-04-2019, 04:00 PM
OzHDHT's Avatar
Liked: 732
https://www.youtube.com/watch?v=oSs6DcA6dFI
Originally Posted by Nugget View Post
I hope Anthem is more like that and less like this: Maaaahhaaaaaaaa. . . the. . . French.
That's gold. My god I remember those ads from when they were on TV when I was kid!
OzHDHT is offline
post #6909 of 7885 Old 04-04-2019, 04:11 PM
desray2k's Avatar
Quoted: 461 Post(s)
Liked: 217
Hopefully before this weekend? Very excited.
desray2k is online now
post #6910 of 7885 Old 04-04-2019, 05:24 PM
OzHDHT's Avatar
Liked: 732
Yeah would be great however my weekend starts from today as its Friday here. So doesn't exactly leave much time lol.
OzHDHT is offline
post #6911 of 7885 Old 04-04-2019, 05:59 PM
dean122601's Avatar
Quoted: 82 Post(s)
Liked: 52
I am trying to run ARC and on the last speaker I get the error message
Measurement not able to acquire a proper response. Code 0X03.
Anyone know what this is
dean122601 is offline
post #6912 of 7885 Old 04-05-2019, 02:05 AM
glangford's Avatar
Quoted: 701 Post(s)
Liked: 611
When I bought my 520, I had a similar error, maybe the same one. I called Anthem and he suggested running test tones. I got no response from one speaker. Then I discovered a speaker wire had come loose. I felt pretty dumb! Check your wiring.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #6913 of 7885 Old 04-05-2019, 02:37 AM
dean122601's Avatar
Quoted: 82 Post(s)
Liked: 52
Test tones are working on all speakers.
The mobile app works fine. Getting error message when I use computer and microphone
post #6914 of 7885 Old 04-05-2019, 02:45 AM
nucky's Avatar
Quoted: 185 Post(s)
Liked: 91
Anthem must be updating the website as I can't get on it. I've been checking everyday. So hopefully the new room correction will be out soon.
Legairre and dean122601 like this.
AV Lexicon GX 7, Anthem MRX-720, Oppo 203, Panasonic UB420, Xbox one x, PS4 pro, TV LG 55C6, 65 C8,OLED. HD projector 106 Jvc X5000 X550, Sub Paradigm signature sub1, Speakers monitor audio platinum PL200 PLC150, Dali phantom ikon in wall & 4 phantom kompas 6m in ceiling speakers, 5.1.4 Atmos
nucky is online now
post #6915 of 7885 Old 04-05-2019, 02:50 AM
dean122601's Avatar
Quoted: 82 Post(s)
Liked: 52
Just let me on. No genesis
post #6916 of 7885 Old 04-05-2019, 03:06 AM
nucky's Avatar
Quoted: 185 Post(s)
Liked: 91
I've been on everyday. But still can't get on. Weird
nucky is online now
post #6917 of 7885 Old 04-05-2019, 04:01 AM
desray2k's Avatar
Quoted: 461 Post(s)
Liked: 217
Yep. Seems like the software release is imminent as the website team is preparing the changes. Haha
post #6918 of 7885 Old 04-05-2019, 07:29 AM
Legairre's Avatar
Liked: 630
I've had this and I replaced my USB cable from the computer to the mic and it worked fine after that.
Legairre is offline
post #6919 of 7885 Old 04-05-2019, 07:59 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5748 Post(s)
Liked: 8212
You'll get this if you mistakenly tell ARC you have more speakers than you actually have. Make sure you've got the right check boxes selected for the speakers you actually have wired before you start the ARC Measurement pass.
--Bob
dean122601 likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #6920 of 7885 Old 04-05-2019, 08:10 AM
Liked: 1
Cant seem to find much info out there so I figured I was ask the question here. Building a house with media room and plan on using mrx 1120. My question is do I need any kind of dsp for the subs? I can get a great deal on a dbx driverack 260 but I am just wondering if its really neccesary.
nucky likes this.
[email protected] is offline
post #6921 of 7885 Old 04-05-2019, 03:17 PM
vollans's Avatar
Quoted: 209 Post(s)
Liked: 150
*wince* No software developer in their right mind releases new software on a Friday afternoon.
New Home Cinema: Sony VPL-VW760, Anthem MRX 1120, Q Acoustics 30x0 series speakers fronts, SVS Prime Elevation surround speakers, Proficient C791 Atmos, SVS PB2000 sub, Panasonic DMP-UB820, Apple TV, Pioneer CLD-D5V laserdisc, FetchTV, eeColor 3D LUT & Radiance XD-3D and ScreenTechnics CinemaSnap Hi Contrast 130" screen
vollans is offline
post #6922 of 7885 Old 04-05-2019, 04:11 PM
desray2k's Avatar
Quoted: 461 Post(s)
Liked: 217
Haha. U r right. But it’s good to be always optimistic. Alrighty. Next week I have a good warm and fuzzy vibe that we will get our hands on the new ARC Genesis software.
mbroadus and vollans like this.
post #6923 of 7885 Old 04-05-2019, 04:13 PM
desray2k's Avatar
Quoted: 461 Post(s)
Liked: 217
No you don’t. ARC will take care of it. Besides you should run the Anthem ARC first to see what’s the issue, if any in your room before committing to purchase additional gears which not be used after all.
post #6924 of 7885 Old 04-05-2019, 04:19 PM
dean122601's Avatar
Quoted: 82 Post(s)
Liked: 52
--Bob
This is exactly what I was doing.
Bob Pariseau likes this.
post #6925 of 7885 Old 04-05-2019, 07:33 PM
Liked: 1
Thank you very much thats what i needed to know.
post #6926 of 7885 Old 04-06-2019, 04:10 AM
glangford's Avatar
Quoted: 701 Post(s)
Liked: 611
I got on the website fine this morning. Doesn't look any different. Still the same ARC Genesis "coming soon' banner.
post #6927 of 7885 Old 04-06-2019, 06:13 AM
desray2k's Avatar
Quoted: 461 Post(s)
Liked: 217
Definitely coming soon.
post #6928 of 7885 Old 04-06-2019, 11:15 AM
cargen's Avatar
Quoted: 71 Post(s)
Liked: 85
What IR receiver cable for the "IR IN" on back of AVM-60 ???
I thought this "Infrared (IR) Receiver Extender Cable" might work and tried it without success:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The AVM-60 manual provides no help.
Can anyone educate me as to what IR Receiver cable to use and provide a vendor source, hopefully with a hyperlink?
JVC RS3000 in AeroLift 150, Paladin DCR lens, Lumagen Radiance Pro, Two Screens: Stewart ElectiScreen StudioTek 130G 153” 240:1 and Screen Innovations Motorized Series 5 Slate 1.2 120" 16:9, Rack: Anthem AVM-60, Oppo 203, Sony CX-7000ES BD Changer, two Anthem A-5's, Rotel 1075, Atmos 7.2.4: 7 Thiel PowerPoint 1.2's, 2 SVS SB-16 Ultra's, 4 Thiel PowerPlane 1.2's. Projector cabling: FIBBR + RUIPro 10M, Remote: URC MX-990.
cargen is offline
post #6929 of 7885 Old 04-06-2019, 12:18 PM
Norris Kasey's Avatar
Quoted: 119 Post(s)
Liked: 65
Are you using this with a harmony remote just for you avm60? If so maybe you can get a 2.5mm mono to 3.5 mono cable and plug it to the back of the avm60. I am going to try this when I get back home from vacation.
Sent from my Pixel 3 XL using Tapatalk
Norris Kasey is offline
post #6930 of 7885 Old 04-06-2019, 12:44 PM
dean122601's Avatar
Quoted: 82 Post(s)
Liked: 52
Anyone ever have the volume stuck in the wide open (loud) position?
Have an AVM 60 that I can turn down
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
