Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 292 - AVS Forum | Home Theater Discussions And Reviews
 13453Likes
post #8731 of 8802 Old 01-13-2020, 08:10 PM
John Frank's Avatar
Quoted: 83 Post(s)
Liked: 31
Originally Posted by Legairre View Post
Yes, works perfectly. The trigger on one of my Rotel amps stopped working so instead of sending it out to get it fixed I use this to turn it on. You first need to go into the Anthem menu system and setup the trigger.. To setup the trigger bring up the menu system and go to: Network/Remote Control >> Trigger Configuration (pages-27-29 of the manual).
Then set:
Trigger = Menu
Power = Main
Important: all inputs should be set to OFF in the Trigger Configuration screen.
Then when you turn on the 720 the trigger will fire and on the power strip it will turn on the outlets that are NOT always on and your amps will turn on.
Excellent. Yep, nice to save a few bucks with a work around.
John Frank is offline
post #8732 of 8802 Old 01-13-2020, 08:14 PM
WOKNROX's Avatar
Quoted: 454 Post(s)
Liked: 363
Originally Posted by mbroadus View Post
When running 5.2.2, is it possible to turn off the surround and height speakers and only have the fronts on? Curious because I don’t necessarily want to listen to the surround and heights while watching the news or sports.
Yes...just go into speaker setup and turn those speakers off on the profile you are using.
Orotund Desert Theater:14'x20'x10',100amp service, JVC RS620, 120" AT screen, Carada Masquerade Masking, OPPO-203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5 channel amplifiers, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Triad Gold, 4 Atmos 3 way Core5's, Subs-4 HSU VTF-15H-MK2, 2 Rows of 3 Seatcraft Excalibur Lx Seats and more.
WOKNROX is offline
post #8733 of 8802 Old 01-13-2020, 08:35 PM
mbroadus's Avatar
Quoted: 1128 Post(s)
Liked: 450
I see now, so I set up a profile for casual tv watching where I only have the fronts playing and another that is for movies and have all speakers playing?
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i, Focal Aria 936/CC900
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #8734 of 8802 Old 01-13-2020, 09:03 PM
WOKNROX's Avatar
Quoted: 454 Post(s)
Liked: 363
Yes..exactly.
I have one set up like this for vinyl.
I have left-right-subs and sometimes turn on the front Atmos.
mbroadus likes this.
WOKNROX is offline
post #8735 of 8802 Old 01-14-2020, 09:05 AM
Jonas2's Avatar
Quoted: 2941 Post(s)
Liked: 1904
Yeah, you can have up to four speaker profiles with any number of speakers active or not. I have a 2.2, 3.2, 5.2, and 7.2.4 going on. Then create an input for your TV watching, then assign whichever profile you want to that input.
Bill-99, mbroadus and WOKNROX like this.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #8736 of 8802 Old 01-14-2020, 10:00 AM
mbroadus's Avatar
Liked: 450
Good idea, thanks.
mbroadus is offline
post #8737 of 8802 Old 01-14-2020, 01:43 PM
Jonas2's Avatar
Liked: 1904
Good idea, thanks.
I watch cable TV the majority, so I created an input called, "X1 3.2" that I set to be the default startup input to give me L/R/C for my Xfinity box. You could do something similar (if you haven't already) so when you power on it'll just go right to that input with your associated fronts only speaker profile. Just a bit of a shortcut!
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #8738 of 8802 Old 01-14-2020, 01:55 PM
John Frank's Avatar
Quoted: 83 Post(s)
Liked: 31
Any way to run ARC with a 6.1 setup? I don't have a right, have a left back speaker and it stopped the run when it got to the right back surround.
post #8739 of 8802 Old 01-14-2020, 01:57 PM
mbroadus's Avatar
Liked: 450
Another great idea. I have X1 too. For some reason, I didn't associate the "Profile Name" in the input settings with speaker profile settings, I thought it was for ARC settings. How do you setup a default startup input? thanks
mbroadus is offline
post #8740 of 8802 Old 01-14-2020, 02:07 PM
MOberhardt's Avatar
Quoted: 1098 Post(s)
Liked: 783
I don't think so. Contact support and maybe they'll bother answering, and possibly add it. It is a pretty nonstandard setup though.
MOberhardt is online now
post #8741 of 8802 Old 01-14-2020, 02:13 PM
Jonas2's Avatar
Liked: 1904
Well, I'm not in front of the machine, but when you go to Setup - in that first screen, scroll down a bit to "Settings" or something like that? It'll have a "Power On Input" sub-setting in there - sorry, I can't recall the actual menu names from memory!
mbroadus and John Frank like this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #8742 of 8802 Old 01-14-2020, 02:31 PM
mbroadus's Avatar
Liked: 450
Found it...I have it on last used. Thanks again.
Jonas2 likes this.
mbroadus is offline
post #8743 of 8802 Old 01-14-2020, 02:32 PM
John Frank's Avatar
Quoted: 83 Post(s)
Liked: 31
Thanks. Until I can get another back made and installed I just did the run as a 5.1 setup.
I'll write Anthem.
post #8744 of 8802 Old 01-14-2020, 04:04 PM
madrac's Avatar
Quoted: 102 Post(s)
Liked: 67
Curious - any advantage (audio wise) in setting up different profiles like this versus just setting the mode for stereo / multi channel as appropriate. I use different profiles, but main difference is EQ level.
LG OLED65E6P, Anthem MRX720, Rogue Atlas Magnum II, UPA7, Ascend Acoustics Sierra Towers with RAAL, Luna Duo center, Sierra 2 surrounds, and HTM200SE front & rear heights, Rythmik E15HP (1, but plan on adding a 2nd), VPI Classic 1+ (VTA Tower, 3D arm), VAS NOVA and Soundsmith Paua cartridges, Manley Chinook, Oppo 103D, Oppo 203. Audio Sensibility and Blue Jeans cabling, Symposium & Isoacoustics isolation products
madrac is offline
post #8745 of 8802 Old 01-14-2020, 04:40 PM
MOberhardt's Avatar
Liked: 783
Just note regards the speaker usage, it also depends on the listener mode you have it in. Eg if you have it with a 7.1.4 speaker setup, if you have it set to Dolby Surround (upmix) or DTS-X Neural X, it will upmix stereo, mono etc to all channels - BUT that said it is pretty smart in that it doesn't just needlessly duplicate dialog to all channels. So Personally I'd always run in DTS-X Neural X.
Other than those modes, there are plenty that don't upmix. Like Anthem Logic Music, AnthemLogic Cinema, None (in which case it just does stereo for stereo, etc. I can't recall all of them but some are described in the manual. I haven't really looked at it since setup and initial use (when I moved from Dolby upmix to DTS upmix and never looked back.
post #8746 of 8802 Old 01-14-2020, 06:23 PM
Jonas2's Avatar
Liked: 1904
Don't know other than the individual speaker levels that can/do indeed change with the different profiles as you mentioned if there is another audio advantage? I'm sure there is one to just this aspect alone that ARC figures out, I'm guessing based on assumptions about how the various speakers will interact with each other as more and more get added, but I don't know at all. For me, it's more of a convenience thing - I don't always feel the need nor desire to run all speakers. 7.2.4 is for serious stuff. Casual, I'm good at 3.2, maybe 5.2 if I'm feeling adventurous...and always nice having a stereo only config.
For music people, they might want to have different profiles, maybe one with subs, one without?
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #8747 of 8802 Old 01-14-2020, 06:30 PM
Jonas2's Avatar
Liked: 1904
How do mean Anthem Logic doesn't upmix? I mean, it'll use any and all speakers (minus the center for music) if selected. Do you just mean how the info gets processed? (Which does differ from Dolby and DTS.) Sorry, I'm likely misinterpreting the statement!
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #8748 of 8802 Old 01-14-2020, 06:34 PM
MOberhardt's Avatar
Liked: 783
Sorry, I mean there are other modes that don't upmix. And some do less than others or different. So might be better suited than disabling speakers in a speaker config
Jonas2 likes this.
post #8749 of 8802 Old 01-14-2020, 06:57 PM
Roger Dressler's Avatar
Quoted: 3078 Post(s)
Liked: 1836
Yes. IMHO. I have a "TV" mode that drops the height speakers, and activates Dolby Surround, so it can use the full 7.1 base layer without any puffery from the overheads. I prefer to safe the height speakers for movies.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #8750 of 8802 Old 01-15-2020, 02:35 AM
madrac's Avatar
Quoted: 102 Post(s)
Liked: 67
Thanks, all, who replied to my question on different speaker profiles versus mode selection on audio quality. I may do a bit of experimenting to see if I can hear any differences. Mainly interested in stereo source (turntable in 2.1 profile versus 5.1.4 profile w/ stereo source set to no processing mode)
madrac is offline
post #8751 of 8802 Old 01-15-2020, 06:34 AM
BGLeduc's Avatar
Quoted: 2679 Post(s)
Liked: 2588
No, unfortunately. ARC assumes you have 2 backs, and halts when it gets to the missing channel. That was lesson #1 the day I installed my 720. :-)
John Frank likes this.
BGLeduc is offline
post #8752 of 8802 Old 01-15-2020, 06:51 AM
mbroadus's Avatar
Liked: 450
Do you guys feel that ARC provides good results for a sub that is not located in its optimal location?
mbroadus is offline
post #8753 of 8802 Old 01-15-2020, 07:12 AM
John Frank's Avatar
Quoted: 83 Post(s)
Liked: 31
Doesn't look like it. Feel free to see this new post. First run of ARC and I have a huge suck out at 80 Hz. https://www.avsforum.com/forum/90-re...l#post59102204
MOberhardt likes this.
post #8754 of 8802 Old 01-15-2020, 07:18 AM
Bittermidget's Avatar
Quoted: 94 Post(s)
Liked: 94
That's sort of a loaded question because there's different situations that make the placement non-optimal. Room correction in general can only do so much to overcome the physics of the speaker, the room, and the placement in the room. For example, if you place the sub in a location that produces a pretty flat response with only a narrow peak, then room correction can usually be pretty effective at cutting that peak. But place the sub in a position that produces a deep null due to room interaction, and room correction and all the amplification you can throw at it will not be able to adequately smooth that response. The sub would have to be moved to improve this.
In addition, room correction can be tricked by a non-optimal sub placement and choose crossover frequencies and slopes that don't line up with what you believe your speakers are capable of producing. This especially happens when there's a big null. This usually requires moving speakers and re-running sweeps or manually setting crossovers in ARC.
I'm sure you'll get a lot of opinions from others.
JVC DLA-X790R, Seymour AV Centerstage UF 2.40:1 tensioned electric screen w/ motorized masking, Anthem AVM 60, Jim Holtz Statements L/C/R, SVS SB-16 Ultra (X2), Oppo UDP-203, Parasound Halo A-21, Parasound Halo A-51, Bluesound Node 2i, miniDSP 2X4 HD, NVIDIA Shield 2015, QNAP 453Pro
Bittermidget is offline
post #8755 of 8802 Old 01-15-2020, 07:21 AM
John Frank's Avatar
Quoted: 83 Post(s)
Liked: 31
Per my link to the official ARC Genesis thread, how about that suckout at 80 Hz! https://www.avsforum.com/forum/90-re...l#post59102204
post #8756 of 8802 Old 01-15-2020, 07:45 AM
Quoted: 94 Post(s)
Liked: 94
John...I took a look at your room images from the other thread. Nice speakers...I'm a DIY speaker guy as well.
The first thing I'll say is don't get discouraged or frustrated by your first couple of Genesis runs. Use these runs to get used to the program settings and more importantly use quick measure first on each speaker and sub independently to get a baseline response in your room from your primary seat. These measurements will give you some honest measurements and might surprise you.
Second, if you see response from any speaker that looks bizarre, move it a few feet in any realistic direction and quick measure again. In your dual purpose, untreated room, you will see a drastically different measurement. This will probably start planting the seed that small movements of speakers in the room can make large changes in response.
Many of us (me included) get used to where we have everything placed in a room, or we are very limited in where we can actually place speakers. When the measurements start showing us that these locations are not optimal, we can either accept the compromise, or start to change some things to see improved results.
SO a couple thing I see in your room that may help: If you want a lower L/R crossover point, you will almost certainly have to unplug the ports to get better bass extension. I have very large towers and have run Genesis with and without the ports plugged and Genesis selected a crossover a full octave lower running ported.
Second, you look to have a ton of front wall space to experiment with sub placement. Get out those MTM stands and start moving/measuring your subs in some different locations. Do one at a time. Get a decent response from one, then turn on the second and observe the contribution of the second.
Have some fun with this! You might be amazed at how much better sound you can get by making some small changes in your room.
post #8757 of 8802 Old 01-15-2020, 07:47 AM
mbroadus's Avatar
Liked: 450
Will running dual subs and performing REW before ARC help minimize peaks and valleys?
mbroadus is offline
post #8758 of 8802 Old 01-15-2020, 08:00 AM
Quoted: 94 Post(s)
Liked: 94
In almost every case, dual subs have the "potential" to produce a smoother in-room response in one or more seating positions and can help Genesis do its job. The caveat being that placement of subs, proper delay between subs, etc. must be done properly to achieve this. You don't want them cancelling each other out by poor placement or playing out of phase.
When you say performing REW, I assume you're talking about using REW to integrate the dual subs together so they have a better response than the single sub. If that's the case, then absolutely it should help.
post #8759 of 8802 Old 01-15-2020, 08:20 AM
mbroadus's Avatar
Liked: 450
Yes, this is exactly what I mean...thank you.
mbroadus is offline
post #8760 of 8802 Old 01-15-2020, 08:22 AM
John Frank's Avatar
Quoted: 83 Post(s)
Liked: 31
Thanks for the GREAT advice and your time Bittermidget. Will heed your advice.
What is REW?
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
