Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 318 - AVS Forum | Home Theater Discussions And Reviews
 13990Likes
post #9511 of 10063 Old 05-07-2020, 05:56 AM
mbroadus's Avatar
Quoted: 1431 Post(s)
Liked: 624
Question on how to operate/setup my MRX-720 when connecting an integrated amp. Sorry for the length.
I've been looking at a Naim Uniti Nova Stereo/Integrated Amp ever since I heard it when I was buying my current Focal speakers. I would like to integrate it into my Home Theater system and need to figure out how its going to work before I buy it.
The connections are similar to a normal amp except the Nova does not have a normal Home Theater Bypass input. The Nova has what's called a AV fixed volume control that's turned on/off via their app and available only on the analog inputs. Here's a description (See 4.3.8 below), "AV Fixed Volume, if YES is selection on the input, it will operate at a fixed volume and the Nova's volume control will be disabled. This enables Nova to be used in multi-channel AV systems with volume control handled by the AV processor (MRX-720)."
Does this mean that I use the MRX-720 to control the volume?
From what I understand during research here's how it connects:
  • MRX-720 - main left and right main pre-outputs to the on the Nova's #1 Analog Input.
  • FL/FR speakers connect to the Nova while other stay connected to the MRX-720.
  • The Nova stereo amplifier will now power the main L/R when playing both movies and music.
  • Run ARC Genesis to adjust the levels of all channels.
How do I switch back and forth between movies and music?
What inputs do I setup in the MRX-720?
Thank you very much!!
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Naim Uniti Nova, Vintage Marantz Model 22, Oppo UDP-203, Bluesound Node 2i, TEAC A-4070 Tape Deck
Focal Aria 936/CC900, B&W M-1, SVS SB-3000, MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is online now
post #9512 of 10063 Old 05-07-2020, 07:56 AM
Tamas's Avatar
Quoted: 79 Post(s)
Liked: 48
@mbroadus . So if I understand the Naim is a streamer with a preamp and an amp built.
When your streaming from the Naim, the Anthem doesn’t have to be on.
And you use the built in volume control of the Naim to listen to your stereo stream.
When you turn the Anthem on for movies or TV and you have selected the AV Fixed Volume On option, the Naim will automatically switch to a fixed level and act as an amplifier only.
You don’t have to reconfigure anything in the Anthem.
Tamas is offline
post #9513 of 10063 Old 05-07-2020, 07:58 AM
blSwagger's Avatar
Quoted: 320 Post(s)
Liked: 302
I hard wired my MRX 1120 for a more reliable, stable connection. However, I couldn't connect to it. My solution was to unplug the ethernet cable and connect to WiFi, which worked immediately. Not ideal, but it worked easily enough.
I really love the Anthem app on the iPhone. I've been working from home at my kitchen island and it's so convenient being able to change the volume from my phone rather than having to walk over to the living room.
I also installed the Play-Fi app, which seems like a better solution than playing music through my AppleTV. I like that when you open the app, the receiver automatically switches the input to Play-Fi.
5.2.4 system: Anthem MRX1120 | Revel f226be L/R | c426be center (**ETA for delivery is 7/20**) | f206 surrounds | c763l (Atmos front and back) | dual Rythmik F18 subwoofers | miniDSP 2x4HD | Apple TV 4K | Panasonic UB820 | Sony XBR65x950g (will upgrade to 77" OLED) | Panamax M5400-PM | Salamander Oslo 237 AV cabinet
blSwagger is offline
post #9514 of 10063 Old 05-07-2020, 08:12 AM
nathan_h's Avatar
Quoted: 3038 Post(s)
Liked: 2129
Researching my next receiver and the MRX720 looks like the minimum model to get me something that can process 11 channels (plus sub) with Anthem Room Correction (ARC). Seems like ARC is available in some other products but that there is nothing "cheaper" than the MRX720 that can process 11 channels. Is that a correct statement?
(And, if so, is there a reliable source of b-stock or refurb units?)
(Any guesses about when the 720 gets replaced with a newer offering?)
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is offline
post #9515 of 10063 Old 05-07-2020, 08:35 AM
mbroadus's Avatar
Liked: 624
Thank you very much...
I curious if my sub will work when using the Nova and the AVR is off?
Since the fixed volume would always be on, I would just have to switch to the RCA 1 input on the Nova each time I want to watch TV.
I guess the other option is to use it as a preamp/streamer and connect it directly to the MRX-720 RCA input but that's a lot of money to spend on a streamer and not use the amp section.
post #9516 of 10063 Old 05-07-2020, 08:46 AM
Jonas2's Avatar
Quoted: 3323 Post(s)
Liked: 2202
I believe so...
Check Crutchfield, they do sell open box, but it still may not be the best deal.
Only Anthem knows....
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #9517 of 10063 Old 05-07-2020, 09:17 AM
Tamas's Avatar
Quoted: 79 Post(s)
Liked: 48
Have you tried DTS Play-Fi, that is what I am using and It does a great job with Internet Radio, Tidal and SiriusXM.
And the Anthem sounds great.
Less hassle than having to add an extra box.
Tamas is offline
post #9518 of 10063 Old 05-07-2020, 09:23 AM
Tamas's Avatar
Quoted: 79 Post(s)
Liked: 48
Hi,
If you can stretch to an 1120, it’s a one box solution.
And they sound really well balanced. Even without room correction.
But a 720 is great as well. Just not as flexible as the marantz if you are using external amps.
The Anthem amp is not reassignable. Originally bought a 720 and returned it for the 1120.
Removed my 5 channel Rotel amp and I haven’t looked back since.
And the rack looks better too.
Tamas is offline
post #9519 of 10063 Old 05-07-2020, 09:27 AM
bad1550's Avatar
Quoted: 119 Post(s)
Liked: 52
I'm interested in the 1120, how does it compare to the Marantz SR8012?
I am 50/50 HT and music
bad1550 is online now
post #9520 of 10063 Old 05-07-2020, 09:38 AM
mbroadus's Avatar
Liked: 624
Yes but I'm not a fan of Play-Fi, sounds a little lifeless and muted to me. I have a bluesound node 2i that I'm using to stream via coax to the Anthem and its fine, not nearly on the same level as the Nova, it the Nova is a lot more expensive. I may just add a external DAC (Chord Qutest) and Sonore streamer and call it a day.
post #9521 of 10063 Old 05-07-2020, 09:52 AM
nathan_h's Avatar
Liked: 2129
Thanks. Not sure that the 1120 has anything I need. The internal power of the 720 is fine for my speakers and room.
Not a giant fan of Audyssey or Marantz / Denon though I will continue to use one in my casual tv viewing space.
I’ve been impressed by ARC and don’t mind using external amplification for the overhead speakers, so the 720 should have everything I "need." I was just hoping I was missing an obvious way to get what I "need" for notably less than 2.5k.
Hi,
My current setup.
nathan_h is offline
post #9522 of 10063 Old 05-07-2020, 11:55 AM
cissado's Avatar
Quoted: 60 Post(s)
Liked: 30
Mbroadus, I've been looking to add a higher quality dac to my existing mrx 720 receiver. I have a 5.2 system and looked at many integrated amps and preamps. Im also using a Node 2. My only goal was to get Qobuz into a better dac. Lumin t2 or Cary dms600 etc.. but I did not want to lose room correction if I bypassed the 720. Same result with the Anthem str integrated or Anthem str preamplifier.
Are you using RC and you will just forego the RC if you go that route?
To me, the price of everything added up just for Qobuz was not 2orth it for the upgrade. I may ultimately forego RC to have more choices of preamps, integrateds.
I'm also wondering how the subs work with the ht bypass. I'd like to use them with 2 channel as well as SS.
Good luck
cissado is offline
post #9523 of 10063 Old 05-07-2020, 12:47 PM
mbroadus's Avatar
Liked: 624
Good luck
No, I’m not using room correction for my 2-channel audio. I’m streaming Qobuz and Tidal via coax from the Node 2i to the 720 with no correction. I’m going back to my original thought of implementing a Sonore streamer into a Chord Qutest to the 720. Yes, I love the sound of the Nova but didn’t want to lose my sub.
post #9524 of 10063 Old 05-07-2020, 01:37 PM
cissado's Avatar
Quoted: 60 Post(s)
Liked: 30
So you're using the dac in the 720 instead of the Node2i? I believe with the coax, you're bypassing the Node's dac. Some people seem to like the dynamics in 2 channel more with no room correction. Personally, I'm using the 720 dac, again, for RC of the 720.
Also, I think something like the Anthem str integrated amp or str preamp which has ht bypass and sub outs can surely allow one to use a subwoofer in both stereo and HT use. I don't know, it's just a shame if you can't do that. I haven't gotten that far in my research. Ha!
Good luck
mbroadus likes this.
cissado is offline
post #9525 of 10063 Old 05-07-2020, 03:24 PM
mbroadus's Avatar
Liked: 624
Good luck
Yes, using the DAC in the 720 rather than the Node 2i. With the sale, now is a good time to buy an integrated or amp...an amp is never outdated and holds value. The STR integrated is considered one of the best so now is a good time to buy.
post #9526 of 10063 Old 05-08-2020, 08:00 AM
mbroadus's Avatar
Liked: 624
Need your help experts...I'm currently looking to buy a Naim Uniti Nova and have run into a problem with how to integrate my sub (SVS SB-3000). The Nova is a stereo amplifier, pre-amp, streamer that will be connected to my Anthem multichannel AVR via FL/FR pre-outs and Nova RCA 1 which has a AV fixed volume input that works similar to a home theater bypass. So, when I play my home theater Anthem AVR, everything would work as normal with the SB-3000 but when when I play the Nova for 2 channel, a signal would not pass through my Anthem AVR so I'm not able to use my sub. Is there a way to be able to use my SB-3000 while playing the Nova? The Nova has a sub out and I thought of using a RCA splitter but hear that's not a good idea. Thoughts?
I found this on sound & vision but I'm not smart enough to figure it out - "incorporating a subwoofer for both movies and music in such a setup is more problematic. One recommendation would be to buy a high-quality surround receiver — one from Anthem’s MRX Series, for instance — that provides preamp outputs to connect a more powerful stereo amp for the main left/right channels and lets you store multiple bass management/EQ configurations. With such a setup, you could create one preset optimized for 5.1 movie playback and another tailored specifically for music listening using your front left/right speakers plus subwoofer."
Link to S&V Q&A
Nova - Naim Uniti Nova
Anthem - MRX-720 AVR
post #9527 of 10063 Old 05-08-2020, 03:45 PM
bad1550's Avatar
Quoted: 119 Post(s)
Liked: 52
Just setup my MRX 1120 trying to figure out all the controls,I am used to Audyssey setup and not the Genesis setup just want to make sure I get my dual 15 Monolith subwoofers calibrated correctly and also is there a function that I can help put on auto so the surround sound mode would go into Auto based on the movie playing appreciate any help is I'm a newbie to non Audyssey set up
post #9528 of 10063 Old 05-08-2020, 05:20 PM
Legairre's Avatar
Quoted: 1418 Post(s)
Liked: 837
For the auto surround hit setup on the remote then navigate to:
1) Input Setup
2) Toggle down to "Mode Preset for Stereo Source" and "Mode Preset for Multi-Ch Source".
3) Change both to "Dolby Surround" or "DTS Neural:X" (I prefer Dolby Surround).
You'll have to do this for all the inputs you have setup.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is offline
post #9529 of 10063 Old 05-08-2020, 06:04 PM
bad1550's Avatar
Quoted: 119 Post(s)
Liked: 52
1) Input Setup
Thank you
post #9530 of 10063 Old 05-08-2020, 07:52 PM
Quattro's Avatar
Quoted: 160 Post(s)
Liked: 37
Good luck
So, using an external DAC eliminates ARC room correction? In other words, you need to feed a digital signal in to get ARC or subwoofer? If yes, that will probably keep me from buying an external DAC. I guess a phono wired in with RCA's also doesn't.
Quattro is offline
post #9531 of 10063 Old 05-08-2020, 08:12 PM
nathan_h's Avatar
Liked: 2129
If you use ARC, then the unit is re-digitizing the analog output from the external DAC and you are relying on the Anthem's DAC for the end result -- effectively nullifying the external DAC in most ways.
With the phono input, like any analog input, you can choose whether to apply the ARC.
My current setup.
nathan_h is offline
post #9532 of 10063 Old 05-08-2020, 08:25 PM
bad1550's Avatar
Quoted: 119 Post(s)
Liked: 52
1) Input Setup
Thank you
I was able to make the changes. A question regarding streaming anthem logic music, says 2.0 PCM
Is that correct for listening in 2 channel with subs stereo?
post #9533 of 10063 Old 05-09-2020, 09:12 AM
BGLeduc's Avatar
Quoted: 2778 Post(s)
Liked: 2687
2.0 PCM is what the Anthem is seeing from your source. Whether or not you are hearing 2.1 is a function of you profiles and the selected mode.
A few examples....if your source were sending 2.0 PCM, your speaker profile had a basic 5.1 setup, and you selected None for the mode, you would be hearing 2.1. If you choose Anthem Music, you would be hearing 4.1 (Anthem music does not use the center channel). Dolby Surround would be giving you full 5.1.
BGLeduc is online now
post #9534 of 10063 Old 05-09-2020, 11:15 AM
Legairre's Avatar
Liked: 837
2.0 PCM is whats coming into the Anthem. If you want to see whats coming into the Anthem combined and what you're hearing it as hit the mode button on the remote. The top is the incoming signal and the bottom is what's going out to your speakers based on your listening mode.
You can also change the listening mode on the fly by hitting the mode button then pressing the up/down buttons in the center of the remote.
Legairre is offline
post #9535 of 10063 Old 05-10-2020, 10:22 AM
Quattro's Avatar
Quoted: 160 Post(s)
Liked: 37
Thanks. another reason to get a pair of full range floor standers for the front left and rights if I ever want to venture down that road of an external DAC (and/or an external pre-amp with home theater bypass).
Quattro is offline
post #9536 of 10063 Old 05-10-2020, 10:30 AM
nathan_h's Avatar
Liked: 2129
Yeah, I guess if one doesn't care much about bass accuracy in the room, that works fine.
My current setup.
nathan_h is offline
post #9537 of 10063 Old 05-10-2020, 12:18 PM
mbroadus's Avatar
Liked: 624
You will...it never stops!
Quattro likes this.
post #9538 of 10063 Old 05-10-2020, 12:44 PM
nathan_h's Avatar
Liked: 2129
Sure feels that way sometimes. Though after 30 years of chasing perfection, it can become more clear what matters and what doesn't.
Quattro likes this.
My current setup.
nathan_h is offline
post #9539 of 10063 Old 05-10-2020, 03:09 PM
Hyralak's Avatar
I setup a raspberry pi 4 with volumio (no dac) connected via hdmi out using DSD Direct playback.
My MRX720 shows 2.0 PCM/none during playback of 2 channel stereo sourced flac.
I assume that i am using the 720's dac and I have bit perfect playback? Or do I need to make some configuration changes?
Hyralak is offline
post #9540 of 10063 Old 05-11-2020, 02:34 PM
Bittermidget's Avatar
Quoted: 131 Post(s)
Liked: 122
Although I understand what you're getting at here and don't necessarily disagree in many cases, running full range speakers for 2 channel music does not mean you necessarily are sacrificing bass accuracy. Depends on the room, the speakers, and the low frequency content of the music you're playing. There are advantages and disadvantages to going full range vs. mains + sub(s) and both can work well depending on the above.
2-Channel: PrimaLuna EVO 400 tube preamp, Bluesound Node 2i, Topping D90 DAC Theater: JVC DLA-790, Seymour AV Centerstage UF 2.40:1, Oppo UDP-203, NVIDIA Shield, Anthem AVM-60
Speakers: Selah Audio Illuminismo, SVS SB-16 Ultra (x2), Dayton RSS390 HF, Definitive technology surround and Atmos, miniDSP 2x4 HD Amplification: PS Audio BHK250 amplifier, D-Sonic M3a-2800 7-channel amplifier
Bittermidget is offline
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
