Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 13179Likes
post #1891 of 8169 Old 09-11-2016, 06:47 AM
Quoted: 60 Post(s)
Liked: 29
Originally Posted by BrianXBoru View Post
You might want to consider the Arcam AVR 550 as an alternative to the Anthem MRX 1120. The Arcam uses Dirac room correction, which is preferred by many who have heard both Dirac and Anthem's ARC. I have also seen the AVR550 advertised at under SGD$3700, although it seems to list around SGD$4900.
Problem is....i want a one box solution for 7.2.4, so the arcams are out.
Sent from my SM-N910G using Tapatalk
lampsy is offline
post #1892 of 8169 Old 09-12-2016, 08:22 AM
BrianXBoru's Avatar
Quoted: 30 Post(s)
I saw the avr550 advertised on HiFiShark, with the low price from audioweb.ro.
BrianXBoru is offline
post #1893 of 8169 Old 09-12-2016, 11:08 PM
Sammie2980's Avatar
Quoted: 241 Post(s)
Liked: 191
So I finally received my 1120. Wow I am honestly blown away. I can only count 2 times I have been blown away by a piece of AV equipment and this makes the 3rd and the only time it was a piece of audio equipment. This is by far one of the most robust, full sounding AVR's I have ever heard. It breaths new life into my system to the point it doesn't even sound like mine. It took what I had thought way a pretty solid system and made it amazing.
So happy with this unit. Price of entry was questionable to me at first but it's definitely worth the price of admission.
LivingRoom: LG OLED77C8P /Oppo UDP-203/Denon X8500H/SVS SB16 ULTRA/M5300-PM/Paradigm 85F, 45c, Mythos Gem XL x4, SVS Prime Elevation x4 /PS4 Pro/X1X/Switch/AppleTV 4K
Bedroom: LG OLED65E6P / Oppo BDP103D / AppleTV // Office: Sony 55A9F / X1X
ISF Level I Certified, CalMan VideoPro, ChromaPure, i1D3 Pro, i1Pro, C6 HDR 2000, VideoForge Pro, Lightspace
Sammie2980 is offline
post #1894 of 8169 Old 09-12-2016, 11:46 PM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
Congrats. I definitely have to agree with you there. This was my 2nd AVR ever that really woowed me as an improvement.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #1895 of 8169 Old 09-13-2016, 06:09 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
Anthem new Receiver and Processor support Dolby Atmos and DTS:X
[...]Wow I am honestly blown away. [...] This is by far one of the most robust, full sounding AVR's I have ever heard. It breaths new life into my system to the point it doesn't even sound like mine. It took what I had thought way a pretty solid system and made it amazing.
So happy with this unit. [...]
Is your review based on initial setup or post ARC2 results, just curious?
My equipment: JVC RS-55, SI Performance 120" 1.3 gain, OPPO BDP-105, ANTHEM MRX-1120, QNAP 469L NAS, ROKU 4.
MartinLogan speakers and subs. M/ASlim5 Rack, CalMAN 5 Enthusiast/C6 meter.
bigdogaxis is offline
post #1896 of 8169 Old 09-13-2016, 08:19 AM
akopperl's Avatar
Quoted: 65 Post(s)
Does the 720 provide information on the video signal it's receiving, particularly the color space such as BT.2020? With today's new formats, I think that information is helpful.
Sent from my Nexus 6P using Tapatalk
akopperl is online now
post #1897 of 8169 Old 09-13-2016, 12:46 PM
hery19's Avatar
Quoted: 29 Post(s)
Congratulations! Glad you're happy with your new toy, I should have my 720 delivered this Saturday! A couple of questions:
1. If I connect sources with HDMI will the audio come thru Zone 2 as stereo?
2. Can you guys explain to me the Volume scale, I'm used to 0 to 75.
Thanks, can't wait!!
TV: Mitsubishi WD 73833, Receiver: Anthem MRX 720, Bluray: OPPO BDP-93, Conditioner: Panamax M4300-PM, Speakers: B&W CM4 Fronts, CMC center, CM2 Surrounds, Sub: SVS PB1-ISD & Remote: Harmony One
hery19 is offline
post #1898 of 8169 Old 09-13-2016, 02:14 PM
Carbo's Avatar
Quoted: 295 Post(s)
Liked: 165
I just hooked up a 520.
I updated the software, and ran ARC2 and it's sounding pretty nice. Quick question, do I have to set the speaker distances with ARC2 myself?
Carbo is offline
post #1899 of 8169 Old 09-13-2016, 02:41 PM
hery19's Avatar
Quoted: 29 Post(s)
I was just reading the manual and it states you set distances in the setup menu
hery19 is offline
post #1900 of 8169 Old 09-13-2016, 02:58 PM
nickbuol's Avatar
Quoted: 821 Post(s)
Liked: 846
Correct, you have to manually set them. I too was kind of baffled by this since cheaper receivers claim to do this for you, but it makes sense in the end because depending on your room, echos, etc, even the best technology can get it wrong. Setting it manually eliminates that guess work.
nickbuol is offline
post #1901 of 8169 Old 09-13-2016, 03:38 PM
hery19's Avatar
Quoted: 29 Post(s)
Can you guys answer these questions in reference to a 720?
hery19 is offline
post #1902 of 8169 Old 09-13-2016, 03:42 PM
Bandyka's Avatar
Liked: 1422
The beauty of these AVR is that they don't mess with the signal so no info there its the job for the display device.
Bandyka is offline
post #1903 of 8169 Old 09-13-2016, 05:54 PM
akopperl's Avatar
Quoted: 65 Post(s)
Thanks - I was hoping it could report additional info since my TV doesn't report anything other than the resolution for the input signal and my source devices don't state the output video format. Therefore, you can't determine what color space is being output, the frame rate, etc. if you select Auto in the settings.
post #1904 of 8169 Old 09-13-2016, 06:58 PM
Carbo's Avatar
Quoted: 295 Post(s)
Liked: 165
After setting would you have to rerun ARC2 again?
Carbo is offline
post #1905 of 8169 Old 09-13-2016, 07:12 PM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
Setting what Carbo? If you're talking about distance, set it and you're finished. No need to rerun ARC
post #1906 of 8169 Old 09-13-2016, 07:49 PM
Carbo's Avatar
Quoted: 295 Post(s)
Liked: 165
Yes, I should have been more clear. I wasn't sure if I needed to rerun ARC2 after changing the speaker distances. Gotcha.
Carbo is offline
post #1907 of 8169 Old 09-13-2016, 08:15 PM
storm028's Avatar
Quoted: 49 Post(s)
Can I know for the manual setting of the speaker distances, it is to what level of resolution? E.g. 0.5 ft?
I always thought that the distance setting is a function of time alignment. I'm quite surprised that with ARC2, the auto calibration does not account for the aforementioned. I may be wrong though.
storm028 is online now
post #1908 of 8169 Old 09-13-2016, 09:18 PM
Sammie2980's Avatar
Quoted: 241 Post(s)
Liked: 191
Both, initial impression was very very positive before are, then I ran it and was blown away.
I'm still messing with it and trying to get AVR and Harmony Elite squared away and I do not use Zone 2 yet...but I plan on it in a specific input setting just haven't gotten around to it yet. So right now I'm not sure. the volume scale is -90 > 0
The only thing I am wondering about is if there is an ECO setting. This thing has my panamax all over the place. Trying to figure that out right now.
post #1909 of 8169 Old 09-14-2016, 04:44 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2384
Resolution is 1 foot, which is more than enough for audio.
Distance is time alignment, ARC does not do time alignment. It's not possible for ARC to compute delay due to unknown time delays due to the PC, and it's not necessary either, it's easy to measure and set it yourself, and more accurate.
nickbuol and bigdogaxis like this.
stanger89 is offline
post #1910 of 8169 Old 09-14-2016, 05:25 AM
hery19's Avatar
Quoted: 29 Post(s)
Thanks for your help Sammie, I'm expecting my 720 delivered Saturday, can't wait Good to see you're enjoying your 1120, I did a blind buy without auditioning, Hope I made the right decision.
Eddie
hery19 is offline
post #1911 of 8169 Old 09-14-2016, 06:10 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
You made the right decision
post #1912 of 8169 Old 09-14-2016, 06:14 AM
nickbuol's Avatar
Quoted: 821 Post(s)
Liked: 846
Eddie
Yeah, I had a bad experience at CEDIA last year and the Anthem booth. I wasted about an hour at the booth trying to get a demo... Every time I stopped, either the demo guy was on break, or they "just closed the door," or the worst was the one time I stood there with some lady at the booth (who seemed to be more interested in talking with her coworker), and I even told her that I was back, again, to try to get a demo. I waited, and finally said "I am going over 'here' to look at some Anthem products closer, let me know when I can go in." I was still in their booth area, and she was so absorbed in her chit chat that she didn't tell me when I could go in. There was never a line for the demo room, so it seemed pointless to keep standing at an unmarked door (there were 2 doors, if I remember correctly, and neither were marked, but it seemed like only 1 was used and I never saw anyone ever go in or out). Anyway, I pretty much said screw it. Never buying one of their products... I knew that other companies were still just getting things started for upcoming, but not announced, 11.2 receivers, so I just figured that I would be waiting until mid-2016 to upgrade...
Flash forward to Late January/early February 2016. People were raving about the Anthem products and how great they sound. I jumped in, feet first, product unheard (despite many efforts to hear them at CEDIA 2015) and paid more than I ever imagined I would on a receiver.... It was worth it.
Now tomorrow, at CEDIA 2016, I WILL get that demo (even though I own the 1120)..... I WIIIILLLLLLL...
nickbuol is offline
post #1913 of 8169 Old 09-14-2016, 06:14 AM
hatlesschimp's Avatar
Quoted: 505 Post(s)
Liked: 541
Where's the 13ch version LOL!
nickbuol likes this.
hatlesschimp is offline
post #1914 of 8169 Old 09-14-2016, 06:24 AM
hery19's Avatar
Quoted: 29 Post(s)
You should've reported those employees to Anthem for such bad service.
Thanks, I was hoping for a professional review before my purchase but Ive been following Anthem for a while and reading previous generation reviews and owner forums and it seems like the vast majority is satisfied with their receivers. My concern is the 720 without a toroidal transformer and will it be a good match for my B&Ws?
hery19 is offline
post #1915 of 8169 Old 09-14-2016, 06:27 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
@Sammie2980 I did the same, listening for quite a while prior to running ARC2 to erase my Audyssey ears. My room's midrange is harsh because I don't yet have treatments.
I did five different measurement files to determine how best to use ARC2. I started with near field measurements within two feet of my ears. As I expanded the measurements distance, I found the bass management mellow which was more pleasant for me.
I highly recommend using quick measure to dial in your sub response, then taking measurements for the room. Also, make sure you have the latest ARC2 version as it is improved sonically.
Sammie2980 likes this.
post #1916 of 8169 Old 09-14-2016, 06:30 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
I did five different measurement files to determine how best to use ARC2. I started with near field measurements within two feet of my ears. As I expanded the measurements distance, I found the bass management mellow which was more pleasant for me. I use the file where I measured ear height in each seat (6 measurements).
post #1917 of 8169 Old 09-14-2016, 06:33 AM
nickbuol's Avatar
Quoted: 821 Post(s)
Liked: 846
Yeah, I figured that they lost a potential buyer and even possible "advocate" for them, and that was punishment enough, but in all honesty, me being upset and telling myself that I would never buy Anthem really meant nothing. That said, I wonder how many other people, of more importance than me, had a similar experience and they were turned off to the product line as well.
Also, keep in mind that this was Day 1 of the CEDIA show floor being open. It wasn't like I tried to get a demo as things were winding down. Usually you get a little extra attention, more smiles, etc on the first day as the vendors aren't quite exhausted yet.
Somewhere I did a report of CEDIA 2015, and even posted pictures of the Anthem products and told my story about not getting a demo. I will have to find what website I posted that on and see just how angry I worded things, vs today being a big fan of the product line.
Maybe I just don't hold a strong enough grudge. LOL
nickbuol is offline
post #1918 of 8169 Old 09-14-2016, 07:43 AM
Liked: 0
It’s all about the music for me. Home theater is secondary.
About a month ago I bought a pair of Goldenear Triton Two+ speakers. After a 2 week break in period, they sound amazing. I love them and could not be happier. So then I thought it was time to upgrade my receiver.
I went from a Marantz SR6006 (using Amazon FireTV to stream music with Plex) to the Anthem MRX 720. One of the main reasons for upgrading was for ARC. The other was that I wanted the ability to stream FLAC above 24/48kHz (FireTV & Plex) with DTS Play-Fi. The Anthem marketing material and the user guide says it can handle 24/192 FLAC. But after my own experiments & contacting support, they tell me it’s currently limited to 24/96. They said Play-Fi would eventually do 24/192, but they did not have a timeline.
The 720 is ok. But for $2500 I expected the Anthem to be a clear winner over Marantz. It has only been a minimal improvement.
A colleague suggested disabling ARC for music, but I haven't had a chance to try it out.
Any other suggestions? With ARC disabled, would you expect the Anthem to be a clear winner over the Marantz?
chrisg76 is offline
post #1919 of 8169 Old 09-14-2016, 08:00 AM
hery19's Avatar
Quoted: 29 Post(s)
Have fun tomorrow at CEDIA and don't forget about us less fortunate folks and gives a round down of your experience especially at the Anthem booth.
hery19 is offline
post #1920 of 8169 Old 09-14-2016, 08:53 AM
Sammie2980's Avatar
Quoted: 241 Post(s)
Liked: 191
Eddie
I did the same thing bought sight unseen unheard and was really questioning it due to the price and the fact that the Denon X6300H was announced and is cheaper and has bluetooth/airplay. But since I ordered it I decided to wait to it came in and make a decision. SOOOO glad I did. You made the right call imho. I figure I wanted something that just excelled at audio, I don't need all the little bells and whistles, thats is what chrome cast and apple tv's are for. That's what made me even start looking at Anthem and after listening to it with various content I knew I made the right choice.
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
