Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 13222Likes
post #2431 of 8308 Old 11-05-2016, 10:02 AM
pedroalonso's Avatar
Quoted: 27 Post(s)
Liked: 7
Originally Posted by gce View Post
Reading this review I now understand how the Play-Fi streaming works. Quoted below.
"will stream files of resolutions up to 24/96 with bit-perfect accuracy. It downsamples 24/192 files to 16/48 for reliable wireless streaming."
Thanks for finding this review.
Don't miss this part of the review: "DTS Play-Fi’s Critical Listening Mode permits native playback of 24/96 files with no downsampling."
To a single play-fi supported device you can stream 24/96 files without downsampling. You select the device like the mrx720 and then click the critical listening mode toggle.
I think they limit to one device at this sample rate to avoid issues with streaming over wifi.
For multiple room/device in sync listening they do down sample.
pedroalonso is offline
post #2432 of 8308 Old 11-05-2016, 10:07 AM
gce
gce's Avatar
Quoted: 49 Post(s)
I've never been a fan of wifi streaming. It will be interesting to see how good Play-Fi works with my NAS.
gce is offline
post #2433 of 8308 Old 11-05-2016, 10:17 AM
designmule's Avatar
Quoted: 66 Post(s)
Liked: 34
Originally Posted by e30cabrio View Post
I had not tried using Play Fi until this conversation. I can stream from the apps but when I try to access my music library on a HTPC (with PLEX) the Play Fi app only sees my router as a server and finds no content, because I have no media on my USB storage that the router has.
Do you have DLNA/UPNP enabled on your PLEX server?
e30cabrio likes this.
designmule is offline
post #2434 of 8308 Old 11-05-2016, 10:43 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
I didn't and turning it on fixed it, thanks!
Denon AVR-X7200WA, SVS Prime Tower & Ultra Center, Klipsch R-2650 HSU VTF-15H MK2, Sony XBR 75X940D & 75X910C, OPPO BDP-93, Panasonic DP-UB820, Sony UBP-X800, Samsung UBD K8500, Roku Ultra, Hopper 3, HTPC, Technics SL-BD22D
e30cabrio is offline
post #2435 of 8308 Old 11-05-2016, 12:36 PM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
I use Jriver straight from the HTPC as it adds many more features and benefits.
nickbuol likes this.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #2436 of 8308 Old 11-05-2016, 01:13 PM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
Odds are I'll run it direct from PLEX instead of streaming, I just wanted to see another feature I was not using.
I like PLEX because I get access to my media when I am not home.
post #2437 of 8308 Old 11-05-2016, 09:59 PM
nickbuol's Avatar
Quoted: 831 Post(s)
Liked: 856
Topic derailment coming...
I use JRiver as well. Everything was working perfectly until a couple of months ago. I never upgraded to the latest version that came out around the same time, and I am experiencing playback issues. I can start a movie from my HTPC from a file on my media server (both overpowered machines), and it happens pretty much every time. I get a few minutes into the movie, and then it stutters.. BADLY. I stop the movie and restart playback and then I am good for the rest of the movie and for any additional movie I might want to watch.
I've never figured it out, and getting support for an odd issue on a "non-current" version of JRiver has been tough. Doesn't happen on my phone or elsewhere via the Roku app, but those get transcoded at the server so not an apples-to-apples comparison.
Very temped to try to install something like KODI for kicks to see if I can replicate it via a different playback software. If it does it with that as well, then it is an O/S or hardware issue.
Anyway, back on track to the topics at hand. I am going to finally re-run ARC using the latest software to see if that impacts by Anthem "thump" at shutdown sound since it seemed to start when I ran ARC after the last update a little while back.
nickbuol is offline
post #2438 of 8308 Old 11-06-2016, 12:13 AM
Bandyka's Avatar
Liked: 1422
I too experince stutters sometimes and only a reboot resolves it. Try to experiment by switching video processing engines (Red october or normal). As for the "thump" I am now experiencing quite severe "popping" since on the latest FW. It comes when the system is at idle for a while.
Bandyka is offline
post #2439 of 8308 Old 11-06-2016, 11:52 AM
Sammie2980's Avatar
Quoted: 241 Post(s)
Liked: 191
Since the most recent firmware update has anyone experienced a very random or intermittent OSD appear for the volume? What I am experiencing is it seems like the OSD appears on screen as if the volume was increased by just one.
I have seen it 4 times now. Cannot figure out whats going on just curious if anyone else has seen or experienced this.
LivingRoom: LG OLED77C8P /Oppo UDP-203/Denon X8500H/SVS SB16 ULTRA/M5300-PM/Paradigm 85F, 45c, Mythos Gem XL x4, SVS Prime Elevation x4 /PS4 Pro/X1X/Switch/AppleTV 4K
Bedroom: LG OLED65E6P / Oppo BDP103D / AppleTV // Office: Sony 55A9F / X1X
ISF Level I Certified, CalMan VideoPro, ChromaPure, i1D3 Pro, i1Pro, C6 HDR 2000, VideoForge Pro, Lightspace
Sammie2980 is offline
post #2440 of 8308 Old 11-06-2016, 12:58 PM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
Are you using the IOS app? I had that on previous firmware with the app.
post #2441 of 8308 Old 11-06-2016, 02:00 PM
Bandyka's Avatar
Liked: 1422
Yes I did get that on the beta FW after I installed it and the language also changed to French. It cured itself after a few days. Weird.
Bandyka is offline
post #2442 of 8308 Old 11-06-2016, 04:09 PM
Sammie2980's Avatar
Quoted: 241 Post(s)
Liked: 191
No I'm on android. I have the app installed but never use it. At first I was thinking it was my harmony maybe sending a command but I put it out of LOS and I don't have blasters anywhere. The only thing that has taken place recently is a changed 2 hdmi cables for Sammy bluray player to fix some dropouts. Not using any sort of CEC. Haven't seen it happen since earlier though.
We'll as funny as it sounds it reassuring that I know I'm not crazy lol. It's very infrequent. Seen it 4 times total for the past few days. I think the volume does actually increase by one. I'm keeping an eye on it.
Thx guys
Bandyka likes this.
post #2443 of 8308 Old 11-06-2016, 05:25 PM
blastermaster's Avatar
Quoted: 601 Post(s)
Liked: 765
Stop sitting on the remote!
nickbuol and Bandyka like this.
Gear: The Brains: Anthem MRX 720. The Brawn: Outlaw 7700. The Fun: Custom PC w/ Logitech 27 & reverse mount pedals, Nintendo Switch, Playstation PS4 Pro. The Visuals: Oppo 203, Darbee Darblet, Optoma HD3300, Panamorph UH480, DIY 138" Curved screen using Semour Centerstage XD AT material. The Audio: 7.1.4: LCR: Tannoy DC12i. Sides: Tannoy IW63DC. Rears: Tannoy DC8i. Ceilings: Tannoy CMS 603/601 DCBM. Subs: 3X Micro Marty and 1X Full Marty.
blastermaster is offline
post #2444 of 8308 Old 11-06-2016, 09:01 PM
Bandyka's Avatar
Liked: 1422
or just turn off OSD like I did, I hate it when it pops up anytime during a movie. I have the display on the unit turned off as well it only lights up when I adjust something otherwise I see no point, mind you mine is in a complete bat cave.
Bandyka is offline
post #2445 of 8308 Old 11-12-2016, 09:12 AM
gce
gce's Avatar
Quoted: 49 Post(s)
I finally pulled the trigger and ordered the 720. Would it be ok if I downloaded ARC and Play-Fi to get them installed on my laptop before or would this cause a problem with the software finding the 720 once I get it and it's on my network?
gce is offline
post #2446 of 8308 Old 11-12-2016, 09:15 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
Congratulations, I am sure you will love it.
During set up it asks for the Mic serial number, I don't remember if that is a step you can skip, I did it in February.
post #2447 of 8308 Old 11-12-2016, 10:00 AM
gce
gce's Avatar
Quoted: 49 Post(s)
I'll wait then. How about Play-Fi?
gce is offline
post #2448 of 8308 Old 11-12-2016, 10:01 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
No problem for play fi, you just can't access anything until it sees a device it's compatible with. You may be able to install ARC & then do the MIC SN.
post #2449 of 8308 Old 11-12-2016, 11:47 AM
HeffeMusic's Avatar
Quoted: 460 Post(s)
Liked: 194
Hello,
Congrats on your purchase. You download ARC from Anthems website. The only way to access the download is with your mic's serial #. The older models came with a CD.
Regards
Jeff
HeffeMusic is online now
post #2450 of 8308 Old 11-12-2016, 11:59 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
My 720 had a CD that was already outdated. lol
post #2451 of 8308 Old 11-12-2016, 02:27 PM
gce
gce's Avatar
Quoted: 49 Post(s)
Originally Posted by HeffeMusic View Post
Hello,
Regards
Jeff
I already downloaded it here but now I see on the Anthem site that I will have to give my S/N to get the right download for my mic. I'll delete the one I just downloaded. Thanks for your help!
gce is offline
post #2452 of 8308 Old 11-12-2016, 03:02 PM
Dmega's Avatar
Liked: 1
Hi everyone. I'm thinking about getting the avr1120. Are there any problems I should know about or maybe anything I should be aware of before I take the plunge? I got to page 20 b4 I gave up. Also if anyone knows of a good place to listen to it / buy it at a good price in the Mississauga/Toronto area please pm me.
Thanks in advance.
Home Theater
TV: Vizio M70 C3 AVR: Anthem MRX 1120 Speakers: LCR - Polk RTiA9 x2, CSiA6 Sub - Polk PSW 125 & SVS PB 2000, Over head - Polk SC60 x4 Surrounds - HK SAT-TS14 x4 UHD Player: Phillips BDP7501 Gaming: Sony PS3 Seating: Abbyson Living Andria 3-piece Top Grain Leather Power Media Recliners - Black
Dmega is offline
post #2453 of 8308 Old 11-12-2016, 03:27 PM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
Thanks in advance.
http://www.anthemav.com/locator/index.php
I put in L4T 0A1 got this:
Dmega likes this.
post #2454 of 8308 Old 11-12-2016, 03:29 PM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
My mic sn is 6 digits starting with a 3, you could get the program, then get the file you need using your sn when you get it.
post #2455 of 8308 Old 11-13-2016, 08:16 AM
gce
gce's Avatar
Quoted: 49 Post(s)
I'm searching for info on ARC 2. I've found a lot of articles on ARC 1 but nothing for ARC 2. You guys know of any articles with setup, tip and tricks, mic positions...etc. for ARC 2 or would the in depth articles on ARC 1 have the same info that would relate to ARC 2?
gce is offline
post #2456 of 8308 Old 11-13-2016, 08:21 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2388
Thanks in advance.
I've had my 1120 nearly since it came out, it's been great. I'm still using the v39 firmware that was released at about that same time. No problems to report, very happy with it.
About the only things to know are, we're still waiting on the DTS-X firmware (seems it's currently in private beta). Some folks have networking issues.
All that's basically the same as ARC1. I believe the changes to ARC2 are mostly GUI related and under the hood stuff to deal with the newer AVR/SSPs and how they communicate over IP rather than RS232.
Dmega likes this.
stanger89 is offline
post #2457 of 8308 Old 11-13-2016, 09:02 AM
designmule's Avatar
Quoted: 66 Post(s)
Liked: 34
this is the best write up on ARC that I have read.
http://hometheaterhifi.com/reviews/a...system-part-1/
and this one is kind of ok
http://www.audioholics.com/room-acou...m-eq-interview
bigdogaxis likes this.
post #2458 of 8308 Old 11-13-2016, 12:23 PM
gce
gce's Avatar
Quoted: 49 Post(s)
Thanks, something to read up on while am waiting for it to get here.
gce is offline
post #2459 of 8308 Old 11-13-2016, 03:26 PM
Kris Deering's Avatar
Quoted: 3987 Post(s)
Liked: 6934
I know Dr. Rich is working on a new article for ARC 2, so look for that at some point in the future. Having used ARC 2 a few times now, I would say follow the same guidance that is around for ARC 1. While the interface may look different, they function very much the same.
Marc Alexander and HT-Eman like this.
My Home Theater UPDATED DEC 2017
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #2460 of 8308 Old 11-14-2016, 10:05 AM
sshearer's Avatar
Quoted: 12 Post(s)
Is anyone using RS232 (serial) connection to control their MRX-1120? My unit was working fine until I updated the firmware to 1.062 and now the serial control is not working at all. I have a Crestron processor providing the serial control. Other than updating the firmware on the MRX-1120 there were no other changes to my system. I am currently in contact with Anthem support and waiting a further response from them. The only functions I am controlling with the serial control are volume up/down, mute and power on/off, none of which are working any more. Thank you for any suggestions.
Scott
Scott Shearer
sshearer is offline
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
