Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 13225Likes
post #2791 of 8335 Old 12-11-2016, 10:55 AM
pedroalonso's Avatar
Quoted: 27 Post(s)
Liked: 7
Originally Posted by dwaleke View Post
Not in the linked picture. They are two pictures.
Ah yeah... That's weird
pedroalonso is offline
post #2792 of 8335 Old 12-11-2016, 12:16 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
Originally Posted by ebr9999 View Post
Strange. I have MRX510 (same sw version, but it is different due to number of profiles and speakers type). Attached what I get. You should ask Anthem support ....
Yeah. I've contacted them. How strange.
ph3ng is offline
post #2793 of 8335 Old 12-11-2016, 12:18 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
Originally Posted by HT-Eman View Post
And why is the couch not centered in the pic on ARC ?
Great question. I don't have the slightest idea. I will see what Anthem support comes back with....which can be awhile....
ph3ng is offline
post #2794 of 8335 Old 12-11-2016, 02:07 PM
ebr9999's Avatar
Quoted: 228 Post(s)
Liked: 92
Anyhow try reinstalling the program ... It is the first thing I expect the will ask you to do
TV: LG 55E8PLA, Pana TX-L37ET5E BD/DVR: Panasonic BMR-BWT735 Media player: Teufel Connector 2, HT Rec: ANTHEM MRX 510,
Front: Woofer&Tweeter, Center: 2Woofer&1Tweeter, Surround: Bose acoustimass 5 series II, Sub: SVS SB2000
ebr9999 is offline
post #2795 of 8335 Old 12-11-2016, 08:47 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
That's a fair assumption to make. I've reinstalled. But it's still the same.
ph3ng is offline
post #2796 of 8335 Old 12-11-2016, 09:54 PM
Blaumph's Avatar
Quoted: 14 Post(s)
Same problem here. When I first got my 720 a couple months ago and ran arc, I saw the option to select more than 5 positions. When the latest version of arc was released shortly afterwards, the option for number of mic positions was gone. I tried uninstalling and reinstalling several times and have tried both manual and auto mode when installing. Still no option for more than 5 positions.
Blaumph is offline
post #2797 of 8335 Old 12-12-2016, 07:16 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
Perhaps Anthem decided 5 positions are enough?
My equipment: JVC RS-55, SI Performance 120" 1.3 gain, OPPO BDP-105, ANTHEM MRX-1120, QNAP 469L NAS, ROKU 4.
MartinLogan speakers and subs. M/ASlim5 Rack, CalMAN 5 Enthusiast/C6 meter.
bigdogaxis is offline
post #2798 of 8335 Old 12-12-2016, 07:24 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
When I'm going it 5 seems like about as many as I want to do.
lol
bigdogaxis likes this.
Denon AVR-X7200WA, SVS Prime Tower & Ultra Center, Klipsch R-2650 HSU VTF-15H MK2, Sony XBR 75X940D & 75X910C, OPPO BDP-93, Panasonic DP-UB820, Sony UBP-X800, Samsung UBD K8500, Roku Ultra, Hopper 3, HTPC, Technics SL-BD22D
e30cabrio is offline
post #2799 of 8335 Old 12-12-2016, 12:36 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
Well in any case, I've contacted support. And if 5 is the maximum that can be done, the OM should be updated.
ph3ng is offline
post #2800 of 8335 Old 12-12-2016, 04:34 PM
Carbo's Avatar
Quoted: 295 Post(s)
Liked: 171
Hi guys,
Quick question. I had the 520 but returned it when the Marantz 7702mkii went onsale for $1100 and added my old Amp to it. I'm thinking about returning it and getting a 720 instead.
The question I have is. When using ARC on the Marantz I have to use TV Audio input to get the OLED55B6 sound from the TV through the Receiver, what do you have to do on the Anthem units for ARC sound and is anyone having(are they any known issues with) ARC or 4k HDR? I didn't have the OLED when I had the Anthem 520 and wasn't using any ARC.
Thanks in advance,
Carbo is offline
post #2801 of 8335 Old 12-12-2016, 04:42 PM
drhankz's Avatar
Quoted: 143 Post(s)
Liked: 94
Originally Posted by Carbo View Post
Hi guys,
Thanks in advance,
The only question I can answer is ARC works fine. It is NOT on every HDMI channel. The manual clearly says which HDMI channels handle ARC. I never use that feature but I have tested it and it works fine. You had some other questions which I am not qualified to answer since I have NO 4K.
drhankz is offline
post #2802 of 8335 Old 12-12-2016, 11:29 PM
ebr9999's Avatar
Quoted: 228 Post(s)
Liked: 92
I can still run 10 positions. The program is the same, but the input screen is different depending on the model. On new models it was possible with the previous release.
Pretty sure it is only a sw bug Anthem will fix as soon as they realize it.
ebr9999 is offline
post #2803 of 8335 Old 12-13-2016, 12:27 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
I think you're probably right. But I'm still waiting for support to get back to me.
In the mean time, I'm trying to setup the remote control codes on my Pronto. It seems that the Anthem takes a little while to get ready before it can actually take another IR code. My current setup requires a 6.7 second delay before the input can be switched.
This is a pretty long time to wait whilst everything else is ready to go (i.e. the TV and other components like a bluray player). Anyone know if this is just how it is or is there a way to make the Anthem startup faster?
Cheers,
ph3ng is offline
post #2804 of 8335 Old 12-14-2016, 12:54 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
Anthem support has gotten back to me. They are trying to recreate the issue on their end. Re: the image of the couch, that has no bearing on the actual processing - they think/hope. Which makes sense, As I'm assuming it's just an image.
I also raised some questions re: mic placement and distances from the MLP. And from what they've said, it doesn't matter if you have more than one listening position.
You are to measure from the MLP and from there create a X 2ft away from the MLP. It does not matter if it doesn't cover the entire couch (all the listening positions). This is quite different from say Dirac or Audyssey - so it's interesting to me.
ph3ng is offline
post #2805 of 8335 Old 12-14-2016, 09:44 PM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
Alright so we have 2 more weeks until our Xmas gift DTS:X
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #2806 of 8335 Old 12-15-2016, 05:06 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
tick tock
post #2807 of 8335 Old 12-15-2016, 05:16 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
Originally Posted by bigdogaxis View Post
tick tock
Holding my breath.
post #2808 of 8335 Old 12-15-2016, 05:37 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2388
tick tock
I'm so glad to be getting email notifications for such useful posts
stanger89 is offline
post #2809 of 8335 Old 12-15-2016, 05:55 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
Stop notifications? Ignore the email? Read the post in the email/determine it is not helpful & ignore?
Also, though they told me the new IOS app was coming soon it's still not out.
post #2810 of 8335 Old 12-15-2016, 06:10 AM
nickbuol's Avatar
Quoted: 831 Post(s)
Liked: 857
I'm subscribed to so many active posts that I turned off email notifications. I just know that when I have some time each day, I head over to AVS and it shows me a listing of all of the threads that I've subscribed to. That way there are no annoying emails when I don't have time to check them out anyway.
Just a thought, then again, I just spawned another email alert for you. Sorry about that. Not criticizing, just stating that I was in your shoes a few years back and made the switch to not get email notifications.
dwaleke likes this.
nickbuol is offline
post #2811 of 8335 Old 12-15-2016, 06:32 AM
stanger89's Avatar
Liked: 2388
It's the same difference either way, I check my subscribed threads and see that there's activity, only to find pointless whining.
No prob, doesn't really bother me that much, just wonder sometimes if folks really think those sort of posts actually accomplish anything... It's not like the folks at Anthem are just out playing hockey or something, until they see some random post whining about DTS:X, and think "Hey, yeah, we forgot to release that didn't we"
post #2812 of 8335 Old 12-15-2016, 06:41 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
So whining about promised features that are not released is bad, whining about whining is ok?
Bandyka likes this.
post #2813 of 8335 Old 12-15-2016, 09:06 PM
Bandyka's Avatar
Liked: 1422
No one forces you to read them mate it's an open forum and it's more than relevant and waay overdue.
...and you know what I bet certain they scan these forums and they bloody well should and give us the feature we paid for many months ago which other MF have released long ago and no I no longer care of explanations why it has not been released, they took my money long ago.
e30cabrio likes this.
Bandyka is offline
post #2814 of 8335 Old 12-15-2016, 09:07 PM
Bandyka's Avatar
Liked: 1422
Haha that's funny
Bandyka is offline
post #2815 of 8335 Old 12-15-2016, 09:08 PM
Bandyka's Avatar
Liked: 1422
I do the same and saves a lot time and effort deleting emails.
Bandyka is offline
post #2816 of 8335 Old 12-16-2016, 04:43 AM
stanger89's Avatar
Liked: 2388
I was just trying to make a point, that do you really think a off hand post here is going to speed up Anthem's QC process? Do you think Anthem is just sitting on the DTS:X update waiting for someone to post on a forum to remind them to release it? Do you think they forgot we're waiting impatiently for it?
I'd think if you really wanted to show them that you're impatiently waiting, an email directly to them would be far more effective than a post in an internet forum.
I just don't see what such posts add to the discussion here. We all know it's not here yet, we all are impatiently waiting for it, we all wish their first estimate had been right, but there's nothing a post on a forum can do to help.
post #2817 of 8335 Old 12-16-2016, 05:14 AM
e30cabrio's Avatar
Quoted: 432 Post(s)
Liked: 183
It takes them days to respond to actual support requests. For me, posting here is an escape valve & commiserating with like minded enthusiasts helps it not feel so bad, kind of like when I am last in a long line and someone gets behind me. I'm not last anymore & feel better.
post #2818 of 8335 Old 12-16-2016, 12:26 PM
Nugget's Avatar
Quoted: 206 Post(s)
Liked: 211
  • New anthem ARC-2 Software v1.5.4872
  • New anthem MRX 1120/720/520/AVM60 Software Upgrade v67
http://www.anthemav.com/support/latest-software.php
The firmware filename indicates it's dated 14 December, and it loaded just fine on my MRX1120.
Firmware changelog:
1. (AVM 60 and MRX 1120/720) Added dtsX decoding and Neural:X upmixing, including compatibility with Dolby Enabled upfiring speakers.
Info:
DTS:X dialog level control - this applies only to dtsX sources making use of the function. To raise or lower the level of the dialog (actor voices), use the PG/PR up/down buttons on the remote. The range is 0-6 dB, default 3 dB.
DTS Neural:X uses all speakers in a DTS:X system for an immersive audio experience, creating separation by placing sounds at different points in the sound field. This mode does not apply to DTS:X Master Audio, DTS:X, Dolby Atmos, Dolby TrueHD, and Dolby Digital Plus sources
DTS Neural:X setup (input setup menu) - When the source is a DTS stream, Direct mode plays the audio channels as they were recorded, whereas Non-Direct mode (default) adapts the audio to your speaker layout if it is different from the content creator’s.
2. Updated HDMI code library.
3. Improvements to CEC power-on.
4. Headphone downmix wasn't working properly - fixed.
5. Fix for odd input setup display when exactly 8 inputs were configured.
6. (AVM 60 and MRX 1120/720) If Dolby Volume was enabled before running ARC, height channels weren't producing test tones - fixed.
7. Fix for too many characters in IP feedback.
8. Removed Control4 ID Tx from setup menu.
ARC-2 Changes:
1. Improved subwoofer cutoff frequency selection for cases with extreme response dips.
2. Fixed issue where ARC could crash if connection attempts were not acknowledged.
3. Graph range increased to 20 kHz, but note that as always measured result above 5 kHz is often unreliable.
4. Q range when loading certain older files adjusted for compatibility. If you are loading a file that was created quite a while ago, clicking Targets, Auto-Detect, OK, Calculate, Upload is recommended before uploading the file.
5. Changes related to in-development powered speakers which use ARC.
I like cars, airplanes, running, and coding || current gear: two eyes, two ears, one brain, and some other junk.
Nugget is offline
post #2819 of 8335 Old 12-16-2016, 01:02 PM
Sammie2980's Avatar
Quoted: 241 Post(s)
Liked: 191
Damn received my Oppo 203 yesterday and now Anthem is delivering. Good times coming this weekend for sure.
LivingRoom: LG OLED77C8P /Oppo UDP-203/Denon X8500H/SVS SB16 ULTRA/M5300-PM/Paradigm 85F, 45c, Mythos Gem XL x4, SVS Prime Elevation x4 /PS4 Pro/X1X/Switch/AppleTV 4K
Bedroom: LG OLED65E6P / Oppo BDP103D / AppleTV // Office: Sony 55A9F / X1X
ISF Level I Certified, CalMan VideoPro, ChromaPure, i1D3 Pro, i1Pro, C6 HDR 2000, VideoForge Pro, Lightspace
Sammie2980 is offline
post #2820 of 8335 Old 12-16-2016, 01:03 PM
dlinsley's Avatar
Quoted: 556 Post(s)
Liked: 441
As Noddy Holder says, "It's Christmas!"
So the same limitation, in respect to Dolby tracks, as Marantz/Denon (or did D&M fix that?). Excellent news overall though!
dlinsley is offline
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
