The "OFFICIAL" Yamaha 1050/2050/3050 Owner's thread. - Page 125 - AVS Forum | Home Theater Discussions And Reviews
 23040Likes
post #3721 of 10698 Old 01-13-2016, 05:53 PM
scape111's Avatar
Quoted: 50 Post(s)
Originally Posted by mmmmmmbacon View Post
If you are using your smart TV to access apps like Netflix, Hulu, etc and want audio out of your avr instead of your TV speakers, then yes, arc is how you achieve it. Personally, I use a Roku 4 for that content, instead of my Samsung un75hu8550, and skip arc altogether. The Sammies are notoriously sketchy with their arc functionality though. Like you, I have everything through my 3050 and use Harmony...it has been great.
Sent from my SM-G925V using Tapatalk
Great- thanks! We go through the Xbox one now for Amazon prime - were thinking about getting Netflix again... Was thinking the smart TV app might be more user friendly for the missus - so that's what got me thinking....
Appreciate it.
scape111 is offline
post #3722 of 10698 Old 01-13-2016, 06:32 PM
steveting99's Avatar
Quoted: 1849 Post(s)
Liked: 651
Originally Posted by bwillcox View Post
I don't disagree that my situation with this particular system may be different from others (I presented it as an extreme example), but I feel that to say one should always set their speakers to "small" is misleading, at best. I have 5 other systems with Yamaha AVRs from 5 to 11 channels (all with more conventional speakers) and as I previously said, I find it best to set the sizes according to the actual response capabilities of the speakers. I've not run into power problems (significant or even noticeable distortion) with this approach yet.
Setting speakers to 'SMALL' has nothing to do with the physical size of the speakers, how much one spent on them, how intelligent the individual is or any other 'misleading' connotations. Setting speaker(s) either 'SMALL' or 'LARGE' is very specific in a pre/pro/receiver and that is to implement bass management or not. 'SMALL' means implementing bass management while 'LARGE' means no bass management. Another way to look at is: enabling re-direction of the bass frequencies.
There are significant benefits to implementing bass management in a 5.1/7.1 system, as well as with the new object audio formats of Atmos and DTS:X. The vast majority of users would benefit with bass management set to ON (i.e. speakers set to 'SMALL'). There will be exceptions such as yourself, but there are few things to ask when setting the fronts to 'LARGE'.
Is one comfortable that the 0.1 channel is being re-directed to the fronts if there is no sub? The reason being is that this sub channel is mixed +10dB hotter than the other channels. I.e. in terms of sound reproduction at the same SPL and frequency, a +10dB increase means 10x more power that the fronts will have to carry. In some movie soundtracks, the 0.1 channel can go down to low single digit frequencies - are the fronts capable of cleanly reproducing this? Try the opening scene of the blu-ray title called Live,Die, Repeat (Edge of Tomorrow) at below reference level and slowly increase up to reference level if possible. When other channels are set to 'SMALL', the bass frequencies below the crossover will also be re-directed to the fronts. If the house curve has a low frequency gain of +XdB due to preference, is there sufficient headroom available in the system?
The question one should be asking is within the listening room and the particular setup, at the desired volume level is the system capable of reproducing the full range of frequencies in the movie soundtrack when the fronts are set to 'LARGE'? If one has done the homework, verified this through tests and can honestly say yes the system can handle it, then by all means set the front speakers to 'LARGE'. The majority would be better off with implementing bass management and set the fronts to 'SMALL', so this is not a wrong recommendation.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #3723 of 10698 Old 01-13-2016, 07:56 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I agree completely..Always have my ML Aerons set to small, cause I have a wonderful ML Sub, so its a really nice combo..
And, if you know ML, you know those aren't "small" speakers..
wase4711 is offline
post #3724 of 10698 Old 01-13-2016, 08:32 PM
bwillcox's Avatar
Quoted: 932 Post(s)
Liked: 540
Is one comfortable that the 0.1 channel is being re-directed to the fronts? The reason being is that this sub channel is mixed +10dB hotter than the other channels. I.e. in terms of sound reproduction at the same SPL and frequency, a +10dB increase means 10x more power that the fronts will have to carry. In some movie soundtracks, the 0.1 channel can go down to low single digit frequencies - are the fronts capable of cleanly reproducing this? Try the opening scene of the blu-ray title called Live,Die, Repeat (Edge of Tomorrow) at below reference level and slowly increase up to reference level if possible. When other channels are set to 'SMALL', the bass frequencies below the crossover will also be re-directed to the fronts. If the house curve has a low frequency gain of +XdB due to preference, is there sufficient headroom available in the system?
I never said that setting speakers to 'small' is wrong, only that I don't agree with ALWAYS setting them to small. Clearly you wish to devote much more energy to this discussion than I.
Roosatemyroses likes this.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #3725 of 10698 Old 01-13-2016, 09:48 PM
Liked: 651
In post number 3688, the reply to wase4711 and your reason for setting the speakers to 'LARGE' based on physical size of the speaker is the part that needed clarification. Perhaps there is a typo/terminology in the post and I misread it? Easy to do around here at AVS.
The basic concept that wase4711 had is correct in that bass management / redirection is when speakers are set to 'SMALL'. It has nothing to do with the physical size of the speaker, which is where the terminology and setting confusion comes in for most.
Now that you've set your fronts to 'LARGE' how loud were you able to play the intro scene of Edge of Tomorrow (Live,Die,Repeat on the blu-ray title)?
Last edited by steveting99; 01-13-2016 at 09:59 PM. Reason: typo and link provided
post #3726 of 10698 Old 01-13-2016, 10:03 PM
virtualrain's Avatar
Quoted: 845 Post(s)
Liked: 319
While I agree with you about the use of bass management, this particular point is incorrect. The .1 LFE channel is always directed to the sub. Small or Large settings only determine what to do with the bass in that particular channel, not the LFE channel.
Anyway, I use to subscribe to the thinking that a main L/R channel speaker capable of low frequency extension was best utilized full range... Until I started measuring the room response. It became immediately clear that the mains were constructively and destructively interfering with each other, the subs, and the room at different frequencies creating radical peaks and valleys in the frequency response below 120Hz. My bass response was a mess and running mains full range was the main culprit.
It's simply a result of the physics of sub-bass frequencies having wavelengths that don't play well in typical room sizes used for home theater.
The key to good low-end frequency response is careful placement of those drivers. That's a big advantage to using subs... They can be placed anywhere to optimize the response at the MLP. You clearly cannot move your main L/R channels around in this manner.
So even if you have full range mains, you're almost always better off redirecting their sub-bass to sub woofers. And getting at least two subs and using an RTA spectrum analyzer to monitor the response while you find the ideal placement for them.
Craig Mecak likes this.
SONY 75X850C | YAMAHA RX-A2050 | 5 DAYTON AUDIO APA150 | KLIPSCH RP 5.2.4
virtualrain is offline
post #3727 of 10698 Old 01-13-2016, 10:43 PM
Liked: 651
Agree with you on this one. The post has been corrected to say if there is no sub, the 0.1 channel is re-directed to the mains. If a sub is present, the 0.1 channel is directed to the sub as well as any other channels set to 'SMALL'. Having some push back is good.
...Anyway, I use to subscribe to the thinking that a main L/R channel speaker capable of low frequency extension was best utilized full range... Until I started measuring the room response. It became immediately clear that the mains were constructively and destructively interfering with each other, the subs, and the room at different frequencies creating radical peaks and valleys in the frequency response below 120Hz. My bass response was a mess and running mains full range was the main culprit.
Yeah, via REW measurements I also found out the hard way that setting full range on the mains are not that great. Whilst the bass interference patterns for one channel is good, when combined with another channel, turned out to be bad. This is after applying room correction.
Like you said, the better concept is redirection of the bass frequencies and having a high crossover. This provided a smoother response and this resolved the issue for me. But that meant setting the mains to 'SMALL' even though the in room F3 response of each main channel can go down to 18Hz. C'est la vie as the saying goes.
virtualrain likes this.
post #3728 of 10698 Old 01-14-2016, 01:57 AM
ronzino's Avatar
Originally Posted by LowTech1 View Post
THE NEW 2015 LINE OF RECEIVERS ARE SHIPPING TO STORES RIGHT NOW.
I'll only concentrate on the big 3. Here is the comparison link.
http://usa.yamaha.com/products/audio..._&mode=compare
They are largely unchanged except for HDCP 2.2,HDR(High Dynamic Range),DTS-X and DTS Neural-X(With a future firmware update).
The 2050 now has 2 dac's instead of 1.
All 3 receivers have DSU(Dolby Surround Upmixer)
are those A/V receivers capable to upscale the following
HDMI 1080p 60hz -> HDMI 4K 60 hz ????
please note that i am speaking about 60hz and that in the user manual the capability of the upscale processor are not reported: actually the manual just speak about the input/output resolution/speed possibility like 4k60p 4:4:4 but, again, it doesn't mention if the receiver can upscale at 60hz
ronzino is offline
post #3729 of 10698 Old 01-14-2016, 04:17 AM
Bond 007's Avatar
Quoted: 3252 Post(s)
Liked: 2559
I dont understand this statement. Seems as if youre stating that the ".1 LFE channel" and "LFE channel" are 2 different things.
Also if small or large only determine what to do with the bass in that particular channel when does the AVR crossover become meaningful?
What purpose does the "Extra Bass" option serve?
Bond 007 is offline
post #3730 of 10698 Old 01-14-2016, 04:21 AM
Bond 007's Avatar
Liked: 2559
Dont you mean if a sub is present, the .1 channel is directed to the sub as well as any other channels set to LARGE?
Bond 007 is offline
post #3731 of 10698 Old 01-14-2016, 05:34 AM
benso37's Avatar
Quoted: 57 Post(s)
I just picked up a brand new 3050 yesterday from an online retailer for a very good price ($1550). I hope to get it in the mail soon.
For those using Atmos with this receiver. Are you using in-ceiling speakers or Atmos enabled speakers (module). I currently don't have any in-ceiling speaker and probably won't be able to add any so, I'm curious about the best Atmos enabled speakers out there. I had my eye on the Klipsch Atmos modules.
benso37 is offline
post #3732 of 10698 Old 01-14-2016, 05:49 AM
Quoted: 22 Post(s)
Liked: 31
Congrats on the purchase! You may want to check this thread...lots of good info and suggestions. https://www.avsforum.com/showthread.php?t=1649609
Best in ceiling speakers for Atmos?
Depending on your room and ceiling height, I think most will agree, in ceiling is preferred and provides an exceptional experience (especially .4 vs .2).
Yamaha Aventage RX-A3060 | (3) DefTech UIW RLS II (LCR) | (4) DefTech RSS II (Side and Back Surrounds) | (4) DefTech Di8r in-ceilings for Atmos/DTS:X | (2) SVS PB-3000 Subs, 7.2.4
Seymour 119" 2.37:1 AT Neo Enlightor with 16:9 AT Masking Panels | JVC DLA-X790R projector
mmmmmmbacon is offline
post #3733 of 10698 Old 01-14-2016, 06:43 AM
Liked: 651
That's not how bass management works.
If the sub is present and if any speaker is set to 'SMALL', frequencies below the crossover is sent to the sub. If the speaker is set to 'LARGE' then the full range signals for that channel is sent to the speaker. See picture below for a 5.1 system.
If there is no sub, then the 0.1 LFE channel is re-directed to the front mains. I.e. the front left and front right channels.
virtualrain and AbbyDaddy like this.
post #3734 of 10698 Old 01-14-2016, 07:39 AM
Ccondo1's Avatar
Quoted: 174 Post(s)
Originally Posted by Blackman View Post
i'm using Straight for Atmos movies. Anything else I'm using DSU.
To make use of the YPAO calibration, does it need to be running in Cinema DSP HD3? Then I'd guess it would run in "Standard" or some other sound program...? Or does DSU take all calibration information into account?
Ccondo1 is offline
post #3735 of 10698 Old 01-14-2016, 07:50 AM
AbbyDaddy's Avatar
Quoted: 206 Post(s)
Liked: 50
I believe that once YPAO has been calibrated, it applies across the board. Someone correct me if I am wrong.
Yamaha RX-3050A Receiver (Powering C, R L/R, S L/R, FH L/R, and RH L/R) + (2) Emotiva XPA-100 (Powering F L/R)
(2) BIC Acoustech PL-980II,(4) BIC Acoustech PL-89II,BIC Acoustech PL-28II (C),(4) BIC Acoustech HT-8C (Ceiling/Atmos),(2) PL-200 subs
Samsung UN65F8000 1080P
Sony PS4 as Blu-Ray Player + Nvidia Shield for Kodi/Various Streaming
AbbyDaddy is offline
post #3736 of 10698 Old 01-14-2016, 08:00 AM
Quoted: 845 Post(s)
Liked: 319
I'm not sure why it seems like I'm saying that... but regardless, the LFE channel is the .1 in 5.1 or 7.1 and that is the sub channel.
I think steveting99 addressed your second question about the role of the cross-over in his post above.
The "Extra Bass" feature will send sub-bass from your L/R mains to the sub while also running them full range... thus the bass sent to the L/R channels ends up being doubled. This is likely to cause even more havoc with room nodes and nulls.
post #3737 of 10698 Old 01-14-2016, 08:16 AM
Stanton's Avatar
Quoted: 1775 Post(s)
Liked: 899
In this generation of Aventage, the "Extra Bass" option simply does that: boosts low frequencies (whether main or LFE). Previously it did things like re-direct low frequencies between mains<-> LFE (I don't use it...or a sub). The cross-over frequency determines which (low) frequencies are re-directed to the sub, and should be set depending on the frequency response of the speakers in question (when set to "small").
Everything else is correct (nice diagram).
Yamaha RX-A2050 AVR [v1.81], LG 65EF9500 4K OLED [v4.26.00]
5.0.2 set-up: (4) Polk Monitor 10B's, (2) Polk Monitor 4's, Polk CS300 center
B&O TX2 Turntable, Nakamichi Cassette Deck 1
Pioneer CLD-99 LD, Panasonic DMP-UB900 UHD [v1.80]
Stanton is offline
post #3738 of 10698 Old 01-14-2016, 08:19 AM
showmak's Avatar
Quoted: 288 Post(s)
Liked: 117
I'm a new owner of the RX-A3050 and I have the same question in my mind.
Sent from my iPhone6s+ using Tapatalk
Sony BRAVIA XBR55HX929, Yamaha Aventage RX-A3050, Front Mains: Jamo C109, Surrounds: Jamo C103, FH/RH: Jamo C93, Center: Jamo C10 CEN and Subwoofer: Jamo J112 SUB (5.1.4)
showmak is offline
post #3739 of 10698 Old 01-14-2016, 08:47 AM
Stanton's Avatar
Liked: 899
Correct.
So by those standards a part of the LFE signal is always going to the fronts unless youre using a xover of 120 or higher.
Only if you don't select "LFE" in the system config; otherwise it doesn't matter what you set as a XO (if your speakers are set to "small"). Once you select "LFE", then all the bass management kicks in.
For example, I set my speakers = "large", set LFE = "on", but don't actually use a sub-woofer. The result is: I get all of the bass present in the "main" channels (which is plenty) and none of the LFE (which means no buzzing/shaking/etc that my family hates).
Stanton is offline
post #3740 of 10698 Old 01-14-2016, 08:55 AM
Bond 007's Avatar
Liked: 2559
I dont have an LFE option.
Maybe some of the confusion is calling "LFE management" "bass management". LFE management is just part of bass management.
Bond 007 is offline
post #3741 of 10698 Old 01-14-2016, 08:58 AM
Bond 007's Avatar
Liked: 2559
Correct.
Only "Through" or Pure Direct will disable it. Even then such things as speaker distances and possibly levels will still apply.
Bond 007 is offline
post #3742 of 10698 Old 01-14-2016, 09:02 AM
showmak's Avatar
Quoted: 288 Post(s)
Liked: 117
I need to run the YPAO now and want to be sure I'm running it correctly, could somebody reply to these questions?
showmak is offline
post #3743 of 10698 Old 01-14-2016, 09:04 AM
Stanton's Avatar
Liked: 899
If you own these AVRs you have an LFE option: it's called "Subwoofer 1/2" on page 135 of the manual. This determines how LFE material is handled (like the .1 channel). Just because you tell the system you have a sub (which routes .1 info to the sub) doesn't mean you have to connect one.
Stanton is offline
post #3744 of 10698 Old 01-14-2016, 09:04 AM
Bond 007's Avatar
Liked: 2559
Place the mic properly.
Set proper sub settings.
Run YPAO.
dianebrat likes this.
Bond 007 is offline
post #3745 of 10698 Old 01-14-2016, 09:05 AM
Bond 007's Avatar
Liked: 2559
Thats a new option for Yamaha. Been in Denons for years.
I have a 2030.
Bond 007 is offline
post #3746 of 10698 Old 01-14-2016, 09:07 AM
Ccondo1's Avatar
Quoted: 174 Post(s)
Correct.
What about more detailed information than basic distances and frequencies? What about the room reflections, etc that HD3 is supposed to take into account?
Ccondo1 is offline
post #3747 of 10698 Old 01-14-2016, 09:10 AM
dholmes54's Avatar
Quoted: 531 Post(s)
Liked: 145
The large-small setting that ypao does is confusing since Ive always been use to running a test tone setting spks to 75db spks small and that's it.I thought ypao measured the postion of the SPK which tells the 2050 its large,I know if you put a SPK near a wall or boundary of a room it changes the sound,put that same SPK in the middle of a room it will sound different.One more the test tone on the 2050,I can hardly hear it,should you set the volume to 0 and then run a test tone.
dholmes54 is offline
post #3748 of 10698 Old 01-14-2016, 09:14 AM
Bond 007's Avatar
Liked: 2559
I believe room reflection calculations still apply. They are used for distance settings.
The frequencey PEQ settings are the first to go when using Through or Pure Direct.
Bond 007 is offline
post #3749 of 10698 Old 01-14-2016, 09:16 AM
Stanton's Avatar
Liked: 899
I have a 2030.
Well, that explains it: I assume someone commenting in a xx50 owner's thread actually owns one. I'm sure there are several "new" things in the last 2 generations (not to mention new sound formats).
Stanton is offline
post #3750 of 10698 Old 01-14-2016, 09:19 AM
Bond 007's Avatar
Liked: 2559
Very very few changes.
Dont have to own one to know most everything about them. Im sure I know more than many owners in this thread. Owned Yamaha for years.
stevew24963 likes this.
Bond 007 is offline
lip sync , lipsync , scenes
