The "OFFICIAL" Yamaha 1050/2050/3050 Owner's thread. - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 23036Likes
post #4441 of 10689 Old 02-07-2016, 06:44 AM
drriddhish's Avatar
Quoted: 82 Post(s)
Liked: 53
Originally Posted by dlca1 View Post
I'm exploring options. Audio is more important, but would be interested in both as well.
Audio is easier depending on what set up you are running on main zone and how many zones you want to distribute audio.
1. If running 7/5.1.2/4 you can get zone 2 to out for audio-->directly to zone or as I out to whole house audio distributor like one from monoprice or HTD. Then use app to control which zone and source you want to hear. You would need amp also if using multiple zone to give power to pre out from receiver.
2. Only zone 2 can out audio and video but remember hdmi runs should not be too long otherwise signal can degrade
3 you can look into other whole house audio video distribution methods but they are expensive and complex I.e using cat 5/6 to distribute them and control them
Yamaha RX-3050 5.2.4 JBL studio 1 (front, center, sorround) Tannoy Di8 DC (four on ceiling ATMOS)
Google NSZ-GT1 player
EPSON PowerLite Home Cinema 3010
drriddhish is offline
post #4442 of 10689 Old 02-07-2016, 10:43 AM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 145
I'm using Yamaha 3050 with 11.2 setup. But I also have Minidsp 88-a with Dirac in the chain. I calibrate all my floor speakers with Dirac. Therefore, I have to keep the YPAO disabled. Is there any way I can have YPAO enabled for ceiling speakers only?
SherazNJ is offline
post #4443 of 10689 Old 02-07-2016, 11:19 AM
jpco's Avatar
Quoted: 654 Post(s)
Liked: 303
You can have PEQ for the ceiling speakers, but not Reflected Sound Control Settings. You just need to use the Manual setting in PEQ and adjust. Here is an easy way to do it if you want to measure with YPAO.
  • Run YPAO with Dirac engaged
  • Save measurement, ignoring phase error
  • Log in to AVR using Web Browser (IP address/setup)
  • Go to System > Speaker Preout > Pattern 1 > PEQ > Front_Data
  • On the AVR, go to Parametric EQ > Manual
  • Enter the settings from Front in the web browser into the Manual settings on the AVR for the channels you want to adjust
The PEQ settings you enter if you use Front will be YPAO's attempt to match your front speakers, which were set by your Dirac target curve.
Before running YPAO, check your Dirac speaker distances so you can set them back if (when) YPAO changes them.
jpco is offline
post #4444 of 10689 Old 02-07-2016, 11:41 AM
SherazNJ's Avatar
Liked: 145
Thx John. Did you find any difference in sound before/after for ceiling speakers? I asked because it looks like a rather long process and if the difference is not observable then it might not be worth it to go thru this process.
Also, I'm not familiar with how to lon in using browser? Any guide on it?
Thx.
SherazNJ is offline
post #4445 of 10689 Old 02-07-2016, 01:24 PM
jpco's Avatar
Quoted: 654 Post(s)
Liked: 303
Thx.
I did not really hear a difference. I just had to recalibrate last week and did not bother with any of this. I may get a second 88A in the future for the tops, but from a purely objective standpoint, it's a lot of work and money for the difference it might make.
To login on a browser, look in the information section of the AVR for the AVR's IP address on your home network. Type that into a web browser for the basic web control of the AVR. If you put /setup after it, you'll have access to all the settings in the unit.
Scarriere likes this.
jpco is offline
post #4446 of 10689 Old 02-07-2016, 09:50 PM
prophcy0's Avatar
Quoted: 41 Post(s)
I just recently got my 2050 hooked up. I'm enjoying the receiver so far, but I have a potentially dumb question. How do I get the 2050 to display a different source on each HDMI out?
prophcy0 is offline
post #4447 of 10689 Old 02-08-2016, 02:04 AM
jdsmoothie's Avatar
Quoted: 22557 Post(s)
Liked: 12277
The HDMI Out 2 Assign (p. 149 Owner's manual) setting defaults to "Main", so you must change that to either "Zone 2" or "Zone 4" depending on your use case.
jdsmoothie is offline
post #4448 of 10689 Old 02-08-2016, 07:26 AM
faulkton's Avatar
Quoted: 220 Post(s)
Liked: 71
well it looks like the go fund me page is DOA, i got 4 infraction points for following that advice lmao.
I knew it was a mistake to have faith in the goodness of mankind
On a positive note at least a charity got $37 after fees and a few more people will have access to clean drinking water in Africa. Way to go to the two people who donated
The campaign is still up, so you can still donate if you want..
javanpohl and mmmmmmbacon like this.
faulkton is offline
post #4449 of 10689 Old 02-08-2016, 07:31 AM
prophcy0's Avatar
Quoted: 41 Post(s)
Thanks. If set up the separate zone is there an easy way to switch back and forth the independent zone and cloning a source between both screens? I'm guessing the best way is to set up two different scenes for these activities.
prophcy0 is offline
post #4450 of 10689 Old 02-08-2016, 07:46 AM
Bond 007's Avatar
Quoted: 3246 Post(s)
Liked: 2551
I saw that coming.
This isnt Facebook or a charity raising campaign forum. They dont even want you posting things you have for sale unless its in the Classified section.
Bond 007 is offline
post #4451 of 10689 Old 02-08-2016, 08:32 AM
Stanton's Avatar
Quoted: 1775 Post(s)
Liked: 899
Anyone know how to update/change the Pandora account settings? There's nothing in the manual!
I changed my stations (on a PC) and now I want to propagate those changes to my AVR, but there's no way to "update" (or even log out and log in).
Yamaha RX-A2050 AVR [v1.81], LG 65EF9500 4K OLED [v4.26.00]
5.0.2 set-up: (4) Polk Monitor 10B's, (2) Polk Monitor 4's, Polk CS300 center
B&O TX2 Turntable, Nakamichi Cassette Deck 1
Pioneer CLD-99 LD, Panasonic DMP-UB900 UHD [v1.80]
Stanton is offline
post #4452 of 10689 Old 02-08-2016, 08:51 AM
scape111's Avatar
Quoted: 50 Post(s)
If you go into the settings menu on Pandora - you can add/delete accounts. I was going all through this menu when I was having my connection issues. If I remember correctly- from the input selection screen, you may push "UP" to get into the root settings/options menu. Not exactly sure on this- don't remember off hand without sitting in front of the unit- but there was that access as I added my wife's account and deleted mine thinking maybe there was an issue with my account during that troubleshooting phase.
scape111 is offline
post #4453 of 10689 Old 02-08-2016, 09:37 AM
faulkton's Avatar
Quoted: 220 Post(s)
Liked: 71
Originally Posted by Bond 007 View Post
I saw that coming.
yeah it was a stupid joke that raised a few bucks for charity. Now had it actually worked i would have bought a pre-pro and used my tax return to donate the same amount to charity ... however unlikely that scenario actually is.
I still think its stupid when forums take themselves too seriously.. if someone is not going to bother to read the million posts where i said i cant afford a new pre-pro at the moment, and responds with 'just get the 3050 brah' replying with a go fund me link is not only appropriate but quite comical.
Nonethe less, i have three differnt ways to turn the speaker level atmos outputs into RCA or XLR ... a couple different DI boxes and the audio control i mentioned. If figure ill try them out, find out which works/works the best and return the rest.
mmmmmmbacon likes this.
faulkton is offline
post #4454 of 10689 Old 02-08-2016, 09:39 AM
drriddhish's Avatar
Quoted: 82 Post(s)
Liked: 53
Stations exist linked to account on Pandora server. There is nothing to update from avr unless there is change in account login or name.
post #4455 of 10689 Old 02-08-2016, 10:40 AM
geomatic's Avatar
Quoted: 18 Post(s)
Hey all, I'm having a couple issues with a "new used" Rx-1050 I purchased thru Amazon Warehouse deals. This unit looks to be brand new with all packaging sealed and the unit in pristine condition. I took apart my audio/video cabinet and reorganized for the new AV unit so would rather not have to exchange but can if needed thru Amazon. Hoping ya'll can help.
First issue:
Everything's connected, using airplay and sound is good except nothing coming from center speaker. Go into menus, activate the front speaker and sounds great. The problem is the volume does not adjust, meaning I turn it up and down from level 40ish to mute with no change at all. Sound is at a constant level until mute. Weird thing is once I raise the level past 40, only the surround rear speakers go up. No control of any speaker volume levels except the surround above 40. The next thing is to check all connectors which were set up correctly. I figure a factory reset is in order so followed Yamaha's directions and reset the unit:
Second issue:
I now have rumbling coming from subwoofer and muffled sound coming from surround speakers. Nothing coming out of two front speakers nor the center channel. It was late so didn't to a tone/channel test. Three front speakers are active in menus. Any thoughts on what could be causing this? Maybe I just got a bad AVR but figured I'd see what people thought on here before packing it up.
Thanks in advance!
geomatic is offline
post #4456 of 10689 Old 02-08-2016, 10:53 AM
PioManiac's Avatar
Quoted: 3338 Post(s)
Liked: 8434
First issue:
Second issue:
Thanks in advance!
This may be obvious or redundant,
But did you run the YPAO setup after you hooked everything up?
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #4457 of 10689 Old 02-08-2016, 11:05 AM
urbeenjammin's Avatar
Quoted: 66 Post(s)
It might not seem like a significant information but I just love how you can go in the receiver's menu and click on disc info and see the audio level. It is crucial in a way that let's you listen to the audio track at the right level and also evaluate it accordingly. My question is, is there any ONE button that you can just press and get to the disc info without having to go thru the menu and bypass all of the steps? Thanks in advance.
urbeenjammin is offline
post #4458 of 10689 Old 02-08-2016, 11:33 AM
geomatic's Avatar
Quoted: 18 Post(s)
Not redundant at all...I planned on doing that tonight so no, not yet. But either way an AV receiver should be usable straight out of the box. Certainly not to it's full capability but usable none the less.
geomatic is offline
post #4459 of 10689 Old 02-08-2016, 11:38 AM
Ccondo1's Avatar
Quoted: 160 Post(s)
So on my 3050, if I run YPAO and then go back and change crossovers to 80hz, is that considered the best calibration? By manually adjusting those crossovers, am I messing up the rest of the "advanced" calibration?
Also, what is the consensus best YPAO mode (i.e. natural, etc)?
Ccondo1 is offline
post #4460 of 10689 Old 02-08-2016, 11:42 AM
Stanton's Avatar
Liked: 899
Then how come they don't update on the AVR app? Either way, there has to be a way to "refresh" your stations and/or account info. I can't believe there is nothing in the user manual.
Stanton is offline
post #4461 of 10689 Old 02-08-2016, 11:44 AM
PioManiac's Avatar
Liked: 8434
I guess the main reason I inquired was that's usually my first step,
and would reveal immediately whether something was wrong as it ran test tones around your room 1 speaker at a time
post #4462 of 10689 Old 02-08-2016, 11:48 AM
PioManiac's Avatar
Liked: 8434
Provided you have a powered sub(s) that can handle your <80Hz, set all speakers to "small" and crossed at 80Hz.
Yes that is highly recommended, It wont mess up any other calibrations for distance/delay etc.
Most have found "Flat" to be the most desirable PEQ setting, but you can certainly try all of them and judge for yourself.
post #4463 of 10689 Old 02-08-2016, 12:19 PM
Bond 007's Avatar
Liked: 2551
Turn it off and back on. Every time it reconnects to Pandora it should refresh.
Bond 007 is offline
post #4464 of 10689 Old 02-08-2016, 01:08 PM
geomatic's Avatar
Quoted: 18 Post(s)
Agreed. If it wasn't 10pm with sleeping kiddos I would've ran it. I'll do it this evening. I just figured the YPAO probably wouldn't affect the volume level issue.
Thanks for the reply!
geomatic is offline
post #4465 of 10689 Old 02-08-2016, 01:13 PM
wyattroa's Avatar
Quoted: 168 Post(s)
Liked: 118
If I opt for the 2050 instead of the 3050 and run a 5.2.4 setup, I wont be able to have a zone 2 out for music correct?
Sub build https://www.avsforum.com/forum/155-di...et-r-done.html
Center - JBL LC2
Mains - JBL L820
Surrounds - JBL L820
Sub - Dual UXL'18 enclosures,iNuke6000dsp
wyattroa is offline
post #4466 of 10689 Old 02-08-2016, 01:35 PM
Quoted: 22 Post(s)
Liked: 31
Hey, we gave it a try! It was light hearted and gave a few of us a good chuckle anyway :-)
Sent from my SM-G925V using Tapatalk
Yamaha Aventage RX-A3060 | (3) DefTech UIW RLS II (LCR) | (4) DefTech RSS II (Side and Back Surrounds) | (4) DefTech Di8r in-ceilings for Atmos/DTS:X | (2) SVS PB-3000 Subs, 7.2.4
Seymour 119" 2.37:1 AT Neo Enlightor with 16:9 AT Masking Panels | JVC DLA-X790R projector
mmmmmmbacon is offline
post #4467 of 10689 Old 02-08-2016, 03:20 PM
dianebrat's Avatar
Quoted: 361 Post(s)
Liked: 335
Keep in mind if it's gone through Amazon Warehouse deals it may have been a return and may not have the speakers set up to default, it could have options like speakers turned off in the amp, bi-amp, etc, I'd go through and check that also.
dianebrat is offline
post #4468 of 10689 Old 02-08-2016, 05:24 PM
IK84's Avatar
Quoted: 24 Post(s)
Ive been having this problem which is really bothering for a 2000 dollar piece of equipment ( actually be bothering for a 300 dollar piece)
Sometimes when I'm either turning on receiver or switching between modes, sound will play only from the tv, and only fix is to just shut off the receiver and turn it back on. Is it possible its just a fluke with this particular tv?
Anyone had this problem as well? If not then maybe I have a screwy receiver I need to get replaced. I have 60 days with who I got it from.
EDIT btw I have a 3050.
IK84 is offline
post #4469 of 10689 Old 02-08-2016, 07:18 PM
wiyosaya's Avatar
Quoted: 107 Post(s)
Liked: 68
Do you have Audio Return Channel on in the receiver? I do not have a TV that accepts audio via HDMI, but if you do and ARC is on, this may be the cause.
I've contacted Yamaha support about other issues, and they are very responsive to owners. I'll suggest that you might try contacting them directly and asking them about it as even if ARC is on, this might be a problem with the receiver.
wiyosaya is offline
post #4470 of 10689 Old 02-08-2016, 08:56 PM
showmak's Avatar
Quoted: 288 Post(s)
Liked: 117
First issue:
Second issue:
Thanks in advance!
I will try to Restore the default settings. Refer to page 159 of the manual.
Sent from my iPhone6s+ using Tapatalk
Sony BRAVIA XBR55HX929, Yamaha Aventage RX-A3050, Front Mains: Jamo C109, Surrounds: Jamo C103, FH/RH: Jamo C93, Center: Jamo C10 CEN and Subwoofer: Jamo J112 SUB (5.1.4)
showmak is offline
lip sync , lipsync , scenes
