The "OFFICIAL" Yamaha 1050/2050/3050 Owner's thread. - Page 285 - AVS Forum | Home Theater Discussions And Reviews
 23014Likes
post #8521 of 10583 Old 10-30-2016, 05:56 AM
Liked: 0
Originally Posted by showmak View Post
Is it something to do with Audio Return Channel (ARC)? I'm not sure.
Thanks for the answer!
So if I understand it correctly, I should be able to fix it by turning of ARC. Because I dont want the sound signal to go to the projector , and I dont want any sound signals from the projector aswell right ?
Or have I missunderstood all of this ?
kanin is offline
post #8522 of 10583 Old 10-30-2016, 05:57 AM
showmak's Avatar
Quoted: 288 Post(s)
Liked: 117
I told you I'm not sure but you can try turning it off or on.
Sony BRAVIA XBR55HX929, Yamaha Aventage RX-A3050, Front Mains: Jamo C109, Surrounds: Jamo C103, FH/RH: Jamo C93, Center: Jamo C10 CEN and Subwoofer: Jamo J112 SUB (5.1.4)
showmak is offline
post #8523 of 10583 Old 10-30-2016, 07:56 AM
chicago66's Avatar
Quoted: 69 Post(s)
ok...
so i have a question.. i own a 3050 in the basement theater.. works great.. want to replace my pioneer upstairs.. will this work
for my system upstairs..
i have a 5.1 in the greatroom, i have two speakers each room in dinning room , kitchen and study.. total of six in the ceiling for really use when quests are over at party..
then have two speakers on the patio.
currently use a pionner for the 5.1 in the great room.. use an old receiver to power the rest of the speakers.. the dinneing room, kitchen and study and patiro are controlled by a speaker swithc with volume controlls ont he walls..
can the 3060 yamaha power all that.. idea is 5.1 is zone 1. zone 2 is the dinning room, kitchen and study ... split is ok.. do not need a lot of power..,, and zone 3 is the patio speakers..
sugggestions welcome.. do i need an additional amp.. i have a few amps around.. thanks
chicago66 is offline
post #8524 of 10583 Old 10-30-2016, 08:03 AM
FizzGiGG's Avatar
Quoted: 31 Post(s)
Originally Posted by chicago66 View Post
ok...
The 3060, someone correct me if I am mistaken, can power and feed different sources to 4 zones. It's fantastic. I have a 2050 that can do 5.1.2 in my main zone, while also powering zone 2 and zone 3. Zone 4 can be fed a signal for an amp or hdmi to a TV.
The MusicCast app / system that yamaha has is awesome, I use it every day. Look it up. MusicCast, not MusicCAST. Yamaha has had multiple iterations of it, so make sure you're looking into the new one.
Edit: You'll need to pay attention to the ohm load if powering more than one set of speakers per zone. You can use impedance matching volume controls, a speaker selector that also does impedance matching, or be careful with how you wire the speakers (e.g. in series or parallel). You have 5 separate zones, I believe that you can individually power 4 of them with the 3060. So on one of the zones , wire two rooms on it (pay attention to impedance).
Sent from my Nexus 5X using Tapatalk
Madmax67 likes this.
The AV hodgepodge:
Yamaha RX-A2050 AVR (5.1.2) - XBOX One - QNAP TS-453A NAS (DLNA/Plex)
A/D/S L400e FR/FL - Boston Acoustics VR12 CC - A/D/S MS3/u LFE
Polk Audio RC60I in-ceiling HT - Yamaha NS-AW392 outdoor SR/SL
Samsung LED LCD 60" UN60H6203
FizzGiGG is offline
post #8525 of 10583 Old 10-30-2016, 08:54 AM
chicago66's Avatar
Quoted: 69 Post(s)
thank you.. that is what i thought.. i believe my speaker selector will take care of the indpendence ohm when dividing the signal into the three rooms.. at least it does now.. currently using a 25 year old yamaha as the power source..
Thank you for your input and confirming my thoughts.
another question as apple tv on the recent one has only hdmi ... how do we get apple tv to play musing throught the 3050?
post #8526 of 10583 Old 10-30-2016, 03:28 PM
iang153's Avatar
Quoted: 152 Post(s)
Liked: 48
Excited to be soon receiving a 3050 as a replacement for my Onkyo 929 (was probably unnecessary, but I've been reading reviews of the 3050 and found one for a good price). I have a simple setup and now just have 3 questions.
1. I'm only driving a 5.1 system in Zone 1. I've been using Zone 2 to play the same source (iphone) as Zone 1 to a parasound amp feeding 4 sets of ceiling speakers. I assume I simply need to use the zone 2 out RCA outputs into the parasound (which then feeds a speaker selector box) and choose zone 2 on the 3050. Do I need to pay any attention to Party Mode (again - playing the same iphone source as zone 1)?
2. I'd like to add a couple of additional smaller speakers downstairs (all of the other zone 1 and 2 speakers are on the main floor). Can I use MusicCast to add those additional speakers? Again, will almost always be playing the same music as zone 1.
3. The Onkyo has a pass-through HDMI input - I run my xfinity box through that - just one onkyo output to my TV - and I can then either use the TV speakers or the receiver - does the 3050 also allow this?
Thanks for bearing with me - this is a really helpful thread!
Ian
iang153 is offline
post #8527 of 10583 Old 10-31-2016, 12:14 AM
EPlay's Avatar
Quoted: 167 Post(s)
Liked: 73
iang,
For No. 3, all the HDMI inputs can do pass-through on standby.
EPlay is offline
post #8528 of 10583 Old 10-31-2016, 05:02 AM
iang153's Avatar
Quoted: 152 Post(s)
Liked: 48
Originally Posted by EPlay View Post
iang,
great, thank you - (more flexible than the onkyo, for which only 1 input can do that)...
iang153 is offline
post #8529 of 10583 Old 10-31-2016, 02:41 PM
Liked: 7
Cool New to the Yamaha world
I just bought my first Yamaha receiver and I cant wait until it arrives.
I picked up a 2050 with a MusicCast WX-030 speaker.
I'm really excited!
jpco, EPlay, bluemoon737 and 4 others like this.
Benjamin Williams is offline
post #8530 of 10583 Old 11-03-2016, 11:56 AM
sgranger45's Avatar
Quoted: 14 Post(s)
Liked: 9
Best solution for monitor out
Hi all,
I have all my components in another room in a stereo rack. When I go in there to adjust my Yamaha 1050, I obviously can't see the screen. I have a small flat panel left over from another project that accepts composite or HDMI. I am trying to set it up to duplicate what I am seeing in the main zone (mirror I guess) and have plugged it in to both the monitor out composite jack as well as zone 2 HDMI.
In both cases, I can't get any signal to show up on it. Can someone please guide me as to what I am doing wrong or if there is another, better solution. I have an HDMI splitter but I don't think it will support HDR so I am hesitant to split the signal.
sgranger45 is offline
post #8531 of 10583 Old 11-03-2016, 12:40 PM
Carter D's Avatar
Quoted: 403 Post(s)
Liked: 180
Page 41 of the manual? Not sure if there is something in the setup menu you need to do as well. It does mention that HDMI control is not available in zone 2. Someone here who is way more knowledgeable than me can help I'm sure.
LG 65 EF 9500,Yamaha 3050,Oppo 203
Directv C61 4K box, Apple TV, SONOS Connect
Triad Bronze Center, Triad Bronze LR-H Atmos, Elan inwall surrounds, Velodyne Subs,
Savant Remote, Harmony Ultimate Home remote
"It ain't 4K if it ain't shot in 4K"
Carter D is offline
post #8532 of 10583 Old 11-04-2016, 02:39 PM
iang153's Avatar
Quoted: 152 Post(s)
Liked: 48
I have a 3060-3050 Zone 2 question - I've searched this and the 3050 thread and can't see an answer.
I just got a 3050 - upgraded from an Onkyo 929. I have a simple 5.1 main system, but used zone 2 in my onkyo to go to a Parasound amplifier that drives 4 sets of ceiling speakers (using a speaker selector). On the Yamaha I connected the Parasound amp to the Zone 2 RCA pre-outs, but turning zone 2 on, there's no sound being passed (using my iphone as usb input).
So 2 questions: 1) I can't for the life of me see the setting I need to change to use this setup?
2) if I connect my speaker selector directly to the 3050 "zone 2/ extra sp1" speaker outputs, can I bypass the parasound completely? My zone 2 is really only used for playing the same main source music through the house for gatherings.
Thanks for any help!
Ian
iang153 is offline
post #8533 of 10583 Old 11-04-2016, 05:15 PM
Quoted: 1007 Post(s)
Liked: 787
I'm really excited!
Great receiver and I also have a WX-030 speaker for outside & our covered sunroom. Was pleasantly surprised the sound quality & richness of it and the casting feature is great; love it!! Enjoy when u receive
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 500NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #8534 of 10583 Old 11-04-2016, 07:58 PM
Shadowed's Avatar
Quoted: 935 Post(s)
Liked: 903
Originally Posted by sgranger45 View Post
Hi all,
Best solution might be a smart phone or tablet with the Yamaha app installed.
dianebrat likes this.
Shadowed is offline
post #8535 of 10583 Old 11-05-2016, 01:55 AM
Surfdrifter's Avatar
Quoted: 135 Post(s)
Liked: 66
Guys, I have a problem with the A3050.
It started this morning (i have latest firmware) and I wanted to raise the volume. As soon as I pressed volume up the volume was going up by itself like I was pressing continuously the button. I pressed the volume down same thing happened.
So, it seems that whenever I press a button, the amp thinks that I press that button continuously, which I don't. The remote is not "stuck" in any way, since I have tried with my Harmony Elite (where I can see lights blinking when sending IR commands), plus the original remote.
I tried factory reset, change the remote ID and I even reflashed the firmware and still the same problem. Via network/Wifi it works fine (i used the Yamaha App), but IR seems broken. Do you think that this is a firmware or hardware issue?
any ideas?
EDIT: Does anyone know where I can get the previous firmwares?
Surfdrifter is offline
post #8536 of 10583 Old 11-05-2016, 02:09 AM
jdsmoothie's Avatar
Quoted: 21891 Post(s)
Liked: 11866
any ideas?
If the issue presents using either the Yamaha remote or the Harmony remote and is not resolved after resetting the microprocessor (try doing a few times in a row), warranty repair is your next option.
jdsmoothie is offline
post #8537 of 10583 Old 11-05-2016, 02:11 AM
Quoted: 135 Post(s)
Liked: 66
How do I reset the microprocessor?
post #8538 of 10583 Old 11-05-2016, 02:18 AM
jdsmoothie's Avatar
Liked: 11866
Ian
1. As noted on p. 181 (Owner's manual), unless the USB audio is DSD, it should play to Zones 2/3 without issue (although most likely must be stereo). Ensure the volume of the iPhone is raised sufficiently high enough.
2. Although possible, not recommended, as doing so may shut the AVR down in protection mode.
post #8539 of 10583 Old 11-05-2016, 02:19 AM
jdsmoothie's Avatar
Liked: 11866
Factory reset
post #8540 of 10583 Old 11-05-2016, 05:23 AM
iang153's Avatar
Quoted: 152 Post(s)
Liked: 48
Thanks - after a while with Yamaha chat support, it looks like putting the unit in party mode sends the signal to zone 2 - can't get it to do that otherwise.
I've now read here that sending directly to a speaker selector switch is bad:
http://faq.yamaha.com/us/en/article/...k__u/5119/4103
"The EXTRA SP speaker terminals of this unit should not be connected to a Passive Loudspeaker Selector Box or more than one loudspeaker per channel. Connection to a Passive Loudspeaker Selector Box or multiple speakers per channel could create an abnormally low impedance load resulting in amplifier damage."
iang153 is offline
post #8541 of 10583 Old 11-05-2016, 01:30 PM
showmak's Avatar
Quoted: 288 Post(s)
Liked: 117
any ideas?
Do you have the same issue when using the volume knob on the receiver?
showmak is offline
post #8542 of 10583 Old 11-05-2016, 01:37 PM
Quoted: 135 Post(s)
Liked: 66
I tried the knob and it didn't had any issues and after that the Yamaha didn't have any issues after that. But later on my Oppo was having the same behavior which points exactly to IR interference of some sort, which probably is caused by Harmony.
I then open the drawer with my original remotes AND the Harmony Companion (a secondary remote) and moved them. Couple years ago, I had a similar issue where he secondary's remote volume was being pressed by something heavy in the drawer and was making me crazy. Hope that it was the same issue.
Now I don't seem to have any issues with the amp. I'm listening some music and the amp works as intended with my IR commands.
post #8543 of 10583 Old 11-05-2016, 02:55 PM
showmak's Avatar
Quoted: 288 Post(s)
Liked: 117
This is a big relief, enjoy the beast
Surfdrifter likes this.
showmak is offline
post #8544 of 10583 Old 11-05-2016, 04:30 PM
shortyg83's Avatar
Quoted: 1064 Post(s)
Liked: 955
Guys if I have a 4k tv with HDR I know I need to set video mode to 1. But should I have the video set to processing or direct? And how much lag would it add in gaming?
shortyg83 is offline
post #8545 of 10583 Old 11-06-2016, 06:01 AM
dianebrat's Avatar
Quoted: 358 Post(s)
Liked: 318
Direct, there's no reason not to use direct, that lets your set upscale as needed.
Haiej likes this.
dianebrat is online now
post #8546 of 10583 Old 11-06-2016, 06:55 AM
Stanton's Avatar
Quoted: 1757 Post(s)
Liked: 892
It depends.
If you have a 4K source (like UHD player), you can go "direct" since there's nothing more the AVR can do.
For all other (non-4K) sources, you should compare the AVR "processing" to the TV "processing". Unless you can tell the difference, it's best to let the AVR up-convert everything, especially when you have standard-def and analog (like LD/VCR) sources.
Bottom line: I set the AVR on "processing" for all sources that aren't 4K (only my UHD player is on "direct").
Breddy, shortyg83 and Haiej like this.
Yamaha RX-A2050 AVR [v1.81], LG 65EF9500 4K OLED [v4.25.70]
5.0.2 set-up: (4) Polk Monitor 10B's, (2) Polk Monitor 4's, Polk CS300 center
B&O TX2 Turntable, Nakamichi Cassette Deck 1
Pioneer CLD-99 LD, Panasonic DMP-UB900 UHD [v1.80]
Stanton is offline
post #8547 of 10583 Old 11-06-2016, 12:49 PM
shortyg83's Avatar
Liked: 955
Originally Posted by Stanton View Post
It depends.
Will that setting save per input or will I have to change it everytime?
post #8548 of 10583 Old 11-06-2016, 12:58 PM
PioManiac's Avatar
Quoted: 3093 Post(s)
Liked: 7478
Ideally you want every Scene's parameters optimized/customized for each input.
I have all my video un-processed straight through the Yamaha
My Panasonic UB-900 4K player is set to upscale 1080 Bluray
and 4K UHD to 4K/24p 4:4:4/12Bit.
anything else gets up-scaled in the display only.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #8549 of 10583 Old 11-06-2016, 01:30 PM
shortyg83's Avatar
Liked: 955
Yea I figured that would be best. I don't see much of a difference between the 4k upscaling between tv and avr. So now I am just using Direct.
post #8550 of 10583 Old 11-06-2016, 02:01 PM
Stanton's Avatar
Liked: 892
...and I noticed that my TV doesn't do well with sources < 1080p (like 1080i cable), so it depends. Use the "Scene" function to save input settings (like video processing).
Stanton is offline
scenes
