The "Official" Yamaha CX-A5100 AVP Owners thread - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 4229Likes
post #2071 of 4425 Old 05-23-2016, 05:40 PM
Quoted: 29 Post(s)
Liked: 1
Anyone driving their 5100 with the Crown XLS series?
Anyone using 4 subs with the 5100? If so. How did you connect them. Is it possible to use both the RCA:s and the XLR:s at the same time?
Regards!
/ Imaginaerum
IMAGINAERUM is offline
post #2072 of 4425 Old 05-23-2016, 05:45 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5986 Post(s)
Liked: 5117
I wouldn't use RCA's and XLR's for the same content (subwoofer output) but I don't even know for sure if that is allowed. If it is, I would avoid doing so (totally different voltage range).
You can get more outputs by simply purchasing y-adapters for either RCA or XLR or the other option is using some outboard processor that has additional outputs.
Scott Simonian is offline
post #2073 of 4425 Old 05-23-2016, 06:59 PM
Quoted: 29 Post(s)
Liked: 1
XLRs and RCA
My thought was to connect one woofer in the back with the RCA:s back output and one sub in the back with XLRs back output. No mix of cables in the same woofer so to speak.
Same with the front subs. One feed from RCA and other front woofer feeds from the front xlr output.
Anyone?
post #2074 of 4425 Old 05-23-2016, 07:08 PM
Quoted: 29 Post(s)
Liked: 1
Shutting off?
Anyone?
Maybe the 5100 shuts the RCAs signal off when using XLR and vice versa?
post #2075 of 4425 Old 05-23-2016, 07:25 PM
Bass Enabler
Liked: 5117
Anyone?
Yeah. Don't do that.
Get a y-splitter. They are very affordable.
post #2076 of 4425 Old 05-24-2016, 12:01 AM
Gurba's Avatar
Quoted: 419 Post(s)
Liked: 194
Anyone?
I just checked the manual and I couldn't find anywhere saying this can't be done. But maybe you can daisychain the subs?
Gurba is offline
post #2077 of 4425 Old 05-24-2016, 05:00 AM
gurkey's Avatar
Quoted: 289 Post(s)
Liked: 181
Originally Posted by Carbo View Post
"Note, this is only for manual PEQ function. YPAO correction is still limited to 31Hz which is likely due to limitations of the accuracy of microphone being used."
This is what Audioholics is saying.
Because there is no "absolute" accurate microphone, there is no reason of not using that supplied microphone for going down below 20 Hz as long as there is any well defined output down there. One just has to know the deviations and use these in his calculations. A "calibrated" microphone is not a microphone with non-existent deviations from linearity but one, where the deviations are "exactly" known and can be corrected afterwards. Thus it wouldn't pose a problem just to use those non-linearities and adjust correspondingly for them.
The Avantage microphones which are been used in the new series are certainly not "much" better than those used by the existing units. They might even be the same once used right now.
Nemesis.ie likes this.
gurkey is offline
post #2078 of 4425 Old 05-24-2016, 05:32 AM
Norixone's Avatar
Quoted: 175 Post(s)
Liked: 104
It is in the manual and it states not to connect XLR at the same time you have RCA connected to the same output. I do not have time to check the page now. Will do so later.
Norixone is offline
post #2079 of 4425 Old 05-24-2016, 05:34 AM
Norixone's Avatar
Quoted: 175 Post(s)
Liked: 104
Does anyone know where I can find a tutorial on how to use the equiliser based on the data I get from raw? In other words, what I must and must no do when fiddling with PEQ, etc. trying to get a better curve out of REW?
Thanks for the help.
Norixone is offline
post #2080 of 4425 Old 05-24-2016, 08:03 AM
Gurba's Avatar
Quoted: 419 Post(s)
Liked: 194
Ok. I still can't find it but that doesn't mean you're wrong.
I have an old Denon PRA-1500 preamp and I used both xlr and RCA at the same time with no issues. That doesn't mean it can be done on the Yamaha however.
Gurba is offline
post #2081 of 4425 Old 05-24-2016, 08:14 AM
jdsmoothie's Avatar
Quoted: 22882 Post(s)
Liked: 12508
"Connected to the same output" being the operative word here. There is no issue connecting RCA to one sub and XLR to another sub.
promike, Dragnet, dwaleke and 1 others like this.
jdsmoothie is offline
post #2082 of 4425 Old 05-24-2016, 09:38 AM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
I don't think you can use both XLRs, and both RCAs at the same time though...to give you 4 subs, can you? I would assume you need to use a Y connector for each XLR or RCA.
ellisr63 is offline
post #2083 of 4425 Old 05-24-2016, 09:41 AM
Gurba's Avatar
Quoted: 419 Post(s)
Liked: 194
Why would this be an issue? As I mentioned earlier I've used both xlr and RCA outputs on a stereo preamp.
dwaleke likes this.
Gurba is offline
post #2084 of 4425 Old 05-24-2016, 09:50 AM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
If you use all 4 of the outputs...wouldn't it be the same as using say the front 3 channels outputs to feed 6 channels of audio. I would think the Yamaha would not have been designed to run both at the same time... I am all for it if it works though, as I would like to move to 4 subs down the road too.
ellisr63 is offline
post #2085 of 4425 Old 05-24-2016, 10:18 AM
jdsmoothie's Avatar
Liked: 12508
Correct. RCA Sub 1 - Y - 2 subs, XLR Sub 2 - Y - 2 subs
You don't want the same sub signal going to both the RCA and XLR as adjusting levels would be difficult.
post #2086 of 4425 Old 05-24-2016, 11:39 AM
Norixone's Avatar
Quoted: 175 Post(s)
Liked: 104
My bad. It was on the Onkyo manual not to connect the RCA and XLR at the same time.
Yamaha does not state that it is not possible, so you could drive the two front subs using the RCA and XLR 1 output and the RCA and XLR 2 for the rear and then assign as front + back in the sub setting menu.
However, I guess that volume matching will be a little difficult as xlr runs at 2V while the RCA runs at 1V not to mention that 0.06THD over XLR is achieved at 13V while through the RCA at 6.5V. Not sure how that would work.
If I were you, I would use a splitter. I use it for the two surround chanels to have speakers on both seating rows.
Norixone is offline
post #2087 of 4425 Old 05-24-2016, 11:51 AM
Gurba's Avatar
Quoted: 419 Post(s)
Liked: 194
Is anybody willing to try? My subs only have RCA so... :-)
Gurba is offline
post #2088 of 4425 Old 05-24-2016, 12:13 PM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
As i am reading it...you can't use all 4 sub outs at the same time. You can only use 2 subouts with "Y" cables to do more than 2 subs. JDSmoothie posted right above your post stating this.
ellisr63 is offline
post #2089 of 4425 Old 05-24-2016, 06:30 PM
mattboyer's Avatar
Quoted: 32 Post(s)
Liked: 52
I successfully used 2x RCA outputs and 1x XLR output for the subs on my 5100. There were no issues doing this. It works just fine if that's how anyone wants to run them.
Now I'm using a Anti-Mode DC w/ a diff sub arrangement so I don't need/want to use RCA+XLR outputs anymore, but it can be done.
ellisr63, Gurba and Nemesis.ie like this.
Enjoying Atmos, DTS:X, & a quad dose of PSA these days.
mattboyer is offline
post #2090 of 4425 Old 05-24-2016, 08:48 PM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
Thanks for the info... I am surprised that they allow that feature without documenting it. I didn't think the circuitry would allow that.
ellisr63 is offline
post #2091 of 4425 Old 05-25-2016, 04:23 AM
Gurba's Avatar
Quoted: 419 Post(s)
Liked: 194
I would be more surprised if xlr and rca couldn't be used at the same time and the manual didn't say it.
dwaleke likes this.
Gurba is offline
post #2092 of 4425 Old 05-25-2016, 09:23 AM
Surfdrifter's Avatar
Quoted: 135 Post(s)
Liked: 66
Has anyone emailed/contacted YAMAHA to ask if the new update (i.e 15hZ PEQ) would be applied to the cx-a5100?
mikejedi123 likes this.
Surfdrifter is offline
post #2093 of 4425 Old 05-25-2016, 09:27 AM
jdsmoothie's Avatar
Liked: 12508
Yup ..... the rep said to don't expect it.
post #2094 of 4425 Old 05-25-2016, 10:20 AM
Bass Enabler
Liked: 5117
How about letting us in on that new 'Enhanced' DSP action, eh?
C'mon Yamaha.
ellisr63 likes this.
post #2095 of 4425 Old 05-26-2016, 12:09 AM
Nemesis.ie's Avatar
Quoted: 164 Post(s)
Liked: 80
Regards!
/ Imaginaerum
I'm not sure this is overly useful given all the other responses, but this is how I am running things.
I'm using phono via a 1>2 splitter for my front pair. The XLR on the 2nd output driving the rear pair via a snake and XLR splitter.
It works perfectly.
Using both outputs of each channel for one pair will likely work fine, but as mentioned by Scott, the output levels will be different so a splitter might be better/easier to match them. Make sure to get good splitters e.g. the split cable type for the phono connections though, I've had issues with cheap
"box" type ones where the connection were not firm or the internal wiring was poor leading to pops and thumps.
I'm also using an XLR transformer into the subs at the back of the room (15m cable) to eliminate a very small bit of hum that is still present even though it's an XLR run.
Nemesis.ie is offline
post #2096 of 4425 Old 05-26-2016, 02:26 AM
Quoted: 135 Post(s)
Liked: 66
That's a little bit strange, unless they plan to offer a new CX pre-amp this year too. If they don't, I don't understand, why wouldn't they update their unit to make it current and relevant.
I'm planning to buy a preamp this summer and "forcing" me to get a 3060 as a preamp, instead of their current CX-a5100, seems strange.
post #2097 of 4425 Old 05-26-2016, 02:31 AM
jdsmoothie's Avatar
Liked: 12508
Likely would if possible.
post #2098 of 4425 Old 05-26-2016, 03:22 AM
Quoted: 135 Post(s)
Liked: 66
Without being an expert, I would assume it's not the same case as with the CX-A5000 and the Atmos upgrade that required different hardware. Adding the new PEQ, seem to me a simple software upgrade.
Anyway, 1st world problems, I guess!
dwaleke likes this.
post #2099 of 4425 Old 05-26-2016, 09:20 AM
Quoted: 29 Post(s)
Liked: 1
Thanks for the input regarding xlr and the rca outputs. Seems like There is two options. Y-split in eiter of them to drive 4 subs. OR. You can also connect the four subs in each of the four sub outputs. Signal is sent in all four at the same time.
Another question is if anyone have problems with sending UHD (4k) content thru the 5100. Anyone bought the panasonic or samsung uhd-player that has any issues regarding getting signals thru it? Hdr signals and high hz pictures? Or is it a none problem?
post #2100 of 4425 Old 05-26-2016, 09:34 AM
jdsmoothie's Avatar
Liked: 12508
With the understanding that level matching Sub pre-out 1 with a sub connected to each of the RCA and XLR pre-outs will be more challenging than simply using a "Y" connector.
CX-A5100
