Xpa-200 stereo power amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-30-2015, 07:52 AM - Thread Starter
eljr's Avatar
Quoted: 1377 Post(s)
Liked: 11916
Pros and Cons??????
I am very weary of going with Emotiva, anyone have a positive story to relay?
Anyone own this model?
Has this been on sales previous for $399? (it's now $499)
eljr is offline
post #2 of 11 Old 08-30-2015, 09:59 AM
DonH50's Avatar
Quoted: 3308 Post(s)
Liked: 3410
"Leery"? Why not just get a different amp, like a pro amp, if you do not trust Emotiva? And yes it has been on sale recently. Probably not again until later this year for their Holiday Sale. I have not heard the XPA-200 and wonder how much of a boost (if any) it would be over a decent AVR's amplifiers, though if you have lower-sensitivity 4-ohm speakers and like it loud it could benefit.
Edit for disclosure: I do own a number of Emotiva products (XPA-2, XPA-3, XPA-5, XMC-1, various accessory items) and am generally pleased with them. No problems with any of the power amps.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 11 Old 08-30-2015, 10:28 AM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
I haven't bought a power amp from them, but my XDA-2 has excellent build quality, lots of thoughtful features and a remote that's built like a tank.
The XPA-200 is one of a rapidly diminishing number of power amps that use traditional Class AB design that has been time tested and most refined over the years. That makes for a relatively big, heavy and costly power amp, but IMO the benefit is worth the sacrifice. If I hadn't gone with powered speakers, I'd probably have an XPA amp right now.
Hope that helps a little.
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
post #4 of 11 Old 08-30-2015, 10:38 AM
wes182's Avatar
Quoted: 56 Post(s)
Liked: 30
Owner of an XPA-3 and previously an XPA-2. Nothing but good things to say. If you are concerned regarding power then consider the XPA-2 as that definitely has more to it than the XPA-200.
What is your usage going to be? If you have a strong AVR then I don't see the XPA-200 providing much of a bang.
wes182 is offline
post #5 of 11 Old 09-10-2015, 07:17 AM - Thread Starter
eljr's Avatar
Liked: 11916
because it's cheap.
This is for a 3rd system where I experiment. If it's a know problem as many Emotiva products have been I'd avoid it. If it's a solid amp, for them, I'd go with it.
thanks for the reply
eljr is offline
post #6 of 11 Old 09-10-2015, 07:22 AM - Thread Starter
eljr's Avatar
Liked: 11916
Seems it's really a [email protected]/[email protected] amp if rated as the better amp rate their products.
Still, this meets my minimun requirements for this system.
I don't like that it has no sensor turn on. Have to use a trigger wire.
eljr is offline
post #7 of 11 Old 09-10-2015, 07:30 AM - Thread Starter
eljr's Avatar
Liked: 11916
I am just gonna use it as a simple two channel set up. Running everything into an Oppo 103 or 105, depending on which system I decide to put it in. Then from the 105 (as a pre) direct to it or to a pre amp to it. (HA-1)
I have options to play with. After all, it's a hobby not anything I need.
eljr is offline
post #8 of 11 Old 09-10-2015, 07:34 AM
DonH50's Avatar
Liked: 3410
The little Fusion amp from Emotiva has auto-on if you want to try that... It was on sale over Labor Day, not sure you can still get the sale price.
DonH50 is offline
post #9 of 11 Old 11-06-2015, 06:14 PM
wse
wse's Avatar
Quoted: 2207 Post(s)
Liked: 814
Pros and Cons?????? I am very weary of going with Emotiva, anyone have a positive story to relay? Anyone own this model? Has this been on sales previous for $399? (it's now $499)
I would not touch them
wse is offline
post #10 of 11 Old 11-07-2015, 06:19 AM - Thread Starter
eljr's Avatar
Liked: 11916
why?
eljr is offline
post #11 of 11 Old 11-07-2015, 06:26 AM - Thread Starter
eljr's Avatar
Liked: 11916
Well, I waited and got the thing when it went to the $400 price again a couple weeks ago.
It really did not work out as I was going to use it BUT has worked great in another application.
The OPPO could not drive th sub when used as a pre and the lack of trigger from the OPPO to the amp made it not worth any more effort.
So, I threw it in another system and am very happy.
So far so good.
eljr is offline
