Denon s710w Audysssey vs Manual settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-06-2015, 06:06 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 6
I've setting up this receiver over the last couple days and am really enjoying it however I am confused about the speaker settings. I did the Audysssey calibration and have been using those settings including multi EQ etc. If I look in the manual set up settings I can see all of the calibrated speaker settings which is good. However, on my remote there is an 'option' button which brings up a channel level select option. From there I can pull up speaker level settings as well. However, those settings do not match my calibration settings at all. I can adjust these as well but I have not. So this leads to my confusion. If I've already done the calibration do I touch these settings as well??? Please help alleviate my confusion. I assuming those with the s700 have a similar experience??
Sent from my mobile device using Tapatalk
tamon77 is offline
post #2 of 6 Old 09-06-2015, 07:54 PM
jdsmoothie's Avatar
Quoted: 22903 Post(s)
Liked: 12526
The Channel Level Adjust settings can be set independently for each source from +/-12db from what is listed in Manual Setup.
Also, review posts 3-6 in the 2015 Denon AVR Owner's thread for more helpful information.
https://www.avsforum.com/forum/90-rec...l#post34728921
jdsmoothie is online now
post #3 of 6 Old 09-06-2015, 09:34 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 6
So the channel level adjust is just a finer adjustment of the manual settings then??? Looks like I will just set the manual settings, turn on the Audyssey reference and be done with it???
tamon77 is offline
post #4 of 6 Old 09-07-2015, 04:16 AM
jdsmoothie's Avatar
Liked: 12526
Correct. Manual Setup settings are "global" for all sources, while the Channel Level Adjust are additional fine tuned adjustments for a specific source.
post #5 of 6 Old 09-07-2015, 08:07 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 6
Excellent. Thanks for this clarification.
tamon77 is offline
post #6 of 6 Old 01-06-2016, 05:24 PM
Liked: 0
I'm a newbie here. I just bought the S710 for my home (upgraded from AVR 1713).
So I'm using MANUAL settings for the speaker levels, and I have the subwoofer level a bit high (for some punch) so I can feel the bang from Hulk in Avengers more than ever. But this setting is too high for music when played from Spotify or any other source.
Can I ....
1) Have different Subwoofer levels for different inputs (HDMI vs Spotify)?
and/or
2) Have different Subwoofer levels for MULTI-CH Stereo (for my music) and DOLBY/DTS (for my movies)?
Also, I'm not super happy with using the Multi-Channel Stereo for music. I have tried the Pioneer VSX-90 and it gave me an option for EXT. STEREO which sounded amazing for my music.
Thanks in advance.
sanjuvarma is offline
