Phono preamps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-14-2015, 11:51 AM - Thread Starter
Liked: 0
Phono preamps
Looking for advice on choosing a phono preamp.
I have a Audio Technica AT-LP60 turntable,
MartinLogan Motion 15 speakers,
all powered by Yamaha RX-A740
receiver which does not have a phono preamp, I couldnt justify paying the additional 300 for the 2040. I know my record player is cheap compared to the rest of my set up but for the occasional use it sounds fine. I'd like not to pay more than $120 for the preamp solely because it would be worth more than my turnable. Also probably could upgrade the needle if the preamp is going to make a noticeable difference in quality.
Co0s is offline
post #2 of 3 Old 09-14-2015, 12:02 PM
M Code's Avatar
Quoted: 1127 Post(s)
Liked: 733
Have U tried the phono preamp built into the LP60...
Most phono preamps today are done by a single IC..
Unless U spend some bigger $ for an estoteric separate phono preamp, but in this case U will need to upgrade ur cartidge/needle to enjoy the full sonic benefits. Also to use a higher grade needle/cartridge, U will need a better tone arm that can track lighter. If U only play a few vinyls stick with what U have..
Just my $0.02...
M Code is offline
post #3 of 3 Old 09-14-2015, 07:46 PM
DonH50's Avatar
Quoted: 3304 Post(s)
Liked: 3403
There are a number of inexpensive phono preamps available, some good, most bad... A good inexpensive phone preamp is the little Emotiva unit: https://emotiva.com/products/pres-and-pros/xps-1 It is a little over your budget but will probably be on sale before Christmas.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
amplifier advice , phono preamp , preamp , receiver , turntable
