Need opinions bet. Denon x4200w and Marantz SR6010. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By nohcho
post #1 of 7 Old 10-15-2015, 01:12 AM - Thread Starter
areyes926's Avatar
Liked: 0
May I ask your opinion which of the 2 will serve me better?
I have a 5.1 setup right now (B&W CM8 S2 l/r, B&W CM center S2, B&W 601 S2 rear, 1 Klipsch
Synergy Sub-12) I also have another sub (the same model) that I could to add to my current setup.
The room is about 15'x 20' and will mostly be used to watch Bluray live concerts and movies. I am picking these 2 models in particular base on my budget and having Audessey MultiEQ XT32/ HDMI 2.0A/HDCP 2.2.
Also if I decide to maintain a 5.1 setup, can I use the other 2 channels to bi-amp my L/R speakers?
Thanks and I am also open for other suggestions.
Abelardo
areyes926 is offline
post #2 of 7 Old 10-15-2015, 05:58 PM
fastman's Avatar
Quoted: 12 Post(s)
FWIW, I like the Denon unit as it suits my needs, duel subs, so I will be going with that one.
fastman is offline
post #3 of 7 Old 10-16-2015, 02:41 AM
Quoted: 587 Post(s)
Liked: 167
Youll have your sub dueling?
jleroy68 likes this.
nohcho is offline
post #4 of 7 Old 10-16-2015, 04:14 AM
jdsmoothie's Avatar
Quoted: 22771 Post(s)
Liked: 12419
Both models feature Audyssey Sub EQ HT (dual sub level/delay), however, the X4200W features an upgraded 32 bit DAC as well as 3 zone capability while the SR6010 features a full set of 7.1 EXT IN jacks if using a multi analog SACD player. Although with either model, using the passive "bi-amp" feature is possible when only using a 5.1 setup, doing so isn't likely to provide any benefit. Either model would be an excellent choice, so select the model that best meets your feature/input/output and budget requirements.
jdsmoothie is online now
post #5 of 7 Old 10-16-2015, 11:27 AM - Thread Starter
areyes926's Avatar
Liked: 0
"Youll have your sub dueling? "
If I need to once I get the setup going.
post #6 of 7 Old 10-16-2015, 11:40 AM - Thread Starter
areyes926's Avatar
Liked: 0
JDsmoothie, thanks for your response. Since I don't any analog source like SACD player would you think the Denon will better for my purpose of watch live concert performances and movies? Regarding bi-amping my L/R not getting any benifit since I have not done it before and based on what I have read I got the impression that it will drive the B&W CM8 (L/R) speaker better.
post #7 of 7 Old 10-16-2015, 08:47 PM
jdsmoothie's Avatar
Liked: 12419
1. Yup.
2. Sorry, but no.
