Denon 6200W vs 7200WA - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #61 of 72 Old 07-26-2016, 07:39 AM
Moderator
rboster's Avatar
Quoted: 1648 Post(s)
Liked: 2296
Originally Posted by smiddleton5401 View Post
Any configuration problem using the 6200 with an external 5 channel amp for the main 5 speakers while using the remaining amps for the surrounds and 4 atmos overhead speakers?
JD is the man when it comes to Denon in particular, so you have the answer. I'll chime in only to say, I am using a 7 channel amp + 2 channel amp and powering two of atmos speakers through the Denon. Works perfectly.
rboster is offline
post #62 of 72 Old 09-29-2016, 03:56 PM
Quoted: 184 Post(s)
Any forum sponsor here selling close out AVR 6200s?
titanle likes this.
Ziba Ji is offline
post #63 of 72 Old 10-12-2016, 10:18 AM
tephlon's Avatar
I am also interested, in case there are any who may see this.
tephlon is offline
post #64 of 72 Old 12-08-2016, 02:18 PM
lightbox's Avatar
Quoted: 42 Post(s)
Liked: 41
Originally Posted by highfigh View Post
Another feature for those who would be using different amplifiers, the 7200 amplifiers can be shut off, so it uses less energy.
Not "shut off", no, rather simply the signal is simply shunted from getting to the on board amps in "Pre-amp" mode. The amps themselves still remain on.
According to the Denon webinar yesterday, Jeff Cowan said the power is cut off from those channels.
Originally Posted by nohcho View Post
The power is cut off from the speaker posts, however amps still remain on
Originally Posted by gurkey View Post
Would like to correct: the signal is cut off from the corresponding channel power amps, but the amps themselves are still powered on in a sort of "standby mode".
You can't switch them completely "off" really, meaning disconnecting them from the internal power supply.
By using a Kill-A-Watt power consumption meter with the X7200, it was easy to verify that the internal amps are NOT shut off when the AVR is switched to preamp mode. With the AVR idling (i.e. no audio playing), the power consumption doesn't change at all when preamp mode is switched on and off. In preamp mode relays apparently disconnect the input signals from the amps, as noted by jdsmoothie and gurkey. I went through a similar test, with the same result, when Denon's AVR-4311ci came out years ago.
titanle likes this.
lightbox is offline
post #65 of 72 Old 12-09-2016, 01:17 AM
jdsmoothie's Avatar
Quoted: 22930 Post(s)
Liked: 12545
Correct. How Pre-Amp mode works, hasn't changed going from the 4311CI --> 4520CI --> X7200WA.
jdsmoothie is offline
post #66 of 72 Old 12-12-2016, 10:58 PM
titanle's Avatar
Quoted: 91 Post(s)
Liked: 31
Very informative thread, I'm currently debating between the 6200, 7200 or the new 6300. the 6300 is on close out at best buy, not sure if they carry the 7200. i want to be future proof so 4k and HDR is something i need since i'll eventually get a 4K projector once the prices come down a bit.
titanle is offline
post #67 of 72 Old 08-17-2018, 09:12 AM
nowknown's Avatar
Quoted: 217 Post(s)
Liked: 192
I used to be able to control my X6200 from a web page using the ip address. Now all it shows is the web page background. Did they disable this functionality?
Learn all about me in my profile and take it all very seriously.
nowknown is offline
post #68 of 72 Old 08-17-2018, 11:21 AM
jdsmoothie's Avatar
Liked: 12545
Web Control was only disabled on the 2015 - 2017 "H" series models.
nowknown likes this.
post #69 of 72 Old 08-17-2018, 06:08 PM
KMFDMvsEnya's Avatar
Quoted: 311 Post(s)
Liked: 625
I used the Web Control for the first time last week with no issue on my x6200.
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is offline
post #70 of 72 Old 09-17-2018, 01:24 PM
PMA
PMA's Avatar
Quoted: 136 Post(s)
Liked: 44
Question for other 6200 owners. When source material (for example a Blu Ray) has DTS 5.1 audio does the display show Multi-channel or DTS? When I first set up the 6200, I believe it would display DTS but now the same Blu Ray disc shows Multi-channel on the AVR display. Maybe that changed with past firmware updates but I just wasn't sure and wanted to see what others may know.
PMA is offline
post #71 of 72 Old 09-17-2018, 01:36 PM
Quoted: 139 Post(s)
Liked: 50
Mine still shows DTS, maybe you have to press the sound mode button while playing a source and scroll through until you get DTS surround. Don't know if this will help but I remember having to do it once in awhile, especially when setting up a new player.
Hawks07 is offline
post #72 of 72 Old 09-17-2018, 03:02 PM
jdsmoothie's Avatar
Liked: 12545
This is a comparison thread of two models. X6200W specific questions are better posted in the 2015 Denon AVR Owner's thread linked below.
https://www.avsforum.com/forum/90-re...dcp-2-2-a.html
