Arcam AVR-850 & Arcam AVR-550 - Page 107 - AVS Forum | Home Theater Discussions And Reviews
 3254Likes
post #3181 of 3364 Old 04-19-2019, 08:32 AM
Kal Rubinson's Avatar
Quoted: 1354 Post(s)
Liked: 1287
Originally Posted by 2000m2 View Post
With the receiver set to “Display” I’m not getting any sound. I feel like I’m missing something in being able to tell the receiver to process the sound coming through the HDMI connection.
Any ideas?
Hmmm. I do not have an Arcam at the moment but, typically, that setting is to route audio processing and you probably do not want your Display doing that. What is the alternative?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3182 of 3364 Old 04-19-2019, 01:52 PM
2000m2's Avatar
Not sure, but seemed like the Digital Optical cable did the trick. Part of the reason for all these upgrades was to get all the cables in the wall though.
Sound was working until I updated the software today since the app stopped working. Back to no sound again . Challenging to work through this with the remote being intermittent and the app no longer connecting either.
I've contacted Arcam via email and the sales rep I worked with locally. We'll see what they can come up with. Otherwise, I'm open to any suggestions.
2000m2 is offline
post #3183 of 3364 Old 04-19-2019, 03:54 PM
Liked: 1287
Digital optical is not nearly the equivalent of HDMI.
Kal Rubinson
post #3184 of 3364 Old 04-19-2019, 04:00 PM
2000m2's Avatar
In terms of sound quality?
I got sound back via Optical Digital by disconnecting everything and reconnecting. The other issues with remote and app still remain.
2000m2 is offline
post #3185 of 3364 Old 04-19-2019, 05:09 PM
Liked: 1287
It cannot support lossless multichannel.
Kal Rubinson
post #3186 of 3364 Old 04-19-2019, 05:20 PM
richardsim7's Avatar
Quoted: 1400 Post(s)
Liked: 1830
nor can ARC
richardsim7 is offline
post #3187 of 3364 Old 04-19-2019, 06:51 PM
Liked: 1287
Originally Posted by richardsim7 View Post
nor can ARC
Ah. I just looked back and saw that he was intending to use the eARC HDMI as an input. Read it too fast and that never occured to me.
Kal Rubinson
post #3188 of 3364 Old 04-19-2019, 07:05 PM
2000m2's Avatar
What is the preferred connection?
2000m2 is offline
post #3189 of 3364 Old 04-19-2019, 07:33 PM
Liked: 1287
Well, it depends on what your sources are. What is the source that the TV supposed to be sending to the Arcam?
(I've never used any source through HDMI-ARC but I've never had a need to.)
Kal Rubinson
post #3190 of 3364 Old 04-20-2019, 03:06 AM
philipbtz's Avatar
Quoted: 318 Post(s)
Liked: 165
I have to retract my precious experience with Dirac v2 where I thought the bass had a more tactile feel vs v1. After more testing it turns out it was just due to nearfield sub placement. Recommended
Room| Treated | Sound| Front: Ino Audio i32s, Center: Ino Audio i16s, Surrounds: 6 x Ino a2, 6 x Ino a1, Subs: 6 x Ino Infra-Y|
Picture | Epson TW9300, Seymour Center Stage UF 130.4" retractable 2.35:1 |
Electronics | Arcam AVR390(Dirac Live), 3x Ncore nc400 monoblocks, Emotiva XPA-2 Gen2, EP4000, Panasonic UB700, Allo Katana + Isolator 1.2(Roon bridge/DAC), ATV 4K |
philipbtz is offline
post #3191 of 3364 Old 04-20-2019, 07:31 AM
2000m2's Avatar
Just the smart TV at this point. We decided to see how the apps ran straight from the TV vs. using some other box connected to the receiver. Seems to be working well, but I don’t know what I don’t know.
2000m2 is offline
post #3192 of 3364 Old 04-20-2019, 08:53 AM
Liked: 1287
Me, too. My video monitors have no apps.
Kal Rubinson
post #3193 of 3364 Old 05-10-2019, 08:37 AM
marco1975's Avatar
Quoted: 321 Post(s)
Liked: 238
First time using dirac live v2 and i'm realy getting weird result for the channel level/speakers distances , coming from denon with audyssey xt32, my large front speakers level would be normaly set at -7 (which is correct if I measure with spl meter set at 75db) and distance at 3 meter (which is spot on correct ) now dirac live set the same speakers level at +5 and distance 6 meter. my surround speaker are only 2 meters away from me and dirac set them at 10 meters, my subs 4 meters away from me , and dirac set them at 0... i'm I missing something here? thanks
marco1975 is offline
post #3194 of 3364 Old 05-10-2019, 08:51 AM
Liked: 1830
ms = miliseconds
time is the inverse of distance when it comes to audio
the speakers closest to you have a longer delay so all the audio arrives to your ears at the same time
wouldn't worry too much about levels either, trust Dirac to do its job
post #3195 of 3364 Old 05-10-2019, 09:32 AM
marco1975's Avatar
Quoted: 321 Post(s)
Liked: 238
ms = miliseconds
yes correct i'm also aware of that dirac measure the time delay and not the actual distance, audyssey also does it in the same way. but audyssey gets it right, and the channel levels don't make much sense to me either ,I mean setting my surround speakers at +10. when they should be at -2.
post #3196 of 3364 Old 05-11-2019, 12:53 AM
marco1975's Avatar
Quoted: 321 Post(s)
Liked: 238
Trying to turn ON the Dolby Volume feature but it's greyed out and locked on all input...any idea? thanks
post #3197 of 3364 Old 05-11-2019, 07:10 AM
PGriff1051's Avatar
Quoted: 25 Post(s)
Liked: 30
How many channels are you using? Are you using Dirac? If you are using more than 7.1 channels (like atmos) or Dirac it cannot be turned on. Same with the Lexicon RV-6 that I have. Hope the next update allows Dolby Volume to be an option under those circumstances. That said, hasn't been a big issue with Xfinity as Dirac does a nice job of making it all hang together without large fluctuations in volume.
marco1975 and alexbarbel like this.
PGriff1051 is offline
post #3198 of 3364 Old 05-11-2019, 09:47 AM
marco1975's Avatar
Quoted: 321 Post(s)
Liked: 238
True -I have atmos 7.2.4 channels setup, and using Dirac.
by the way, do u find dirac channels level and distance to be accurate? because it's realy adding too much +DB and distance/delay
post #3199 of 3364 Old 05-11-2019, 02:55 PM
PGriff1051's Avatar
Quoted: 25 Post(s)
Liked: 30
I haven't noticed anything being off and the bass is smoother in more locations than it was when I had the Anthem MRX-720/1120's. It's so good in fact, I may sell my Oppo 205 because stereo using Logic 7 is great.
post #3200 of 3364 Old 05-12-2019, 06:59 AM
marco1975's Avatar
Quoted: 321 Post(s)
Liked: 238
have anyone actually measure with Rew or any measuring kits after customizing/editing the Curve and sending it to AVR.? I Edited the Subwoofers Curve and saved the changes Dirac V2. went through the whole process filters design and export , transferred the file to the AVR. after that I was measuring with REW to confirm the changes, and it turn out that Dirac is not applying the changes that i have made to the Curve...
post #3201 of 3364 Old 05-15-2019, 12:07 AM
Liked: 0
I was wondering if anyone is using an external amp that is not an Arcam Amp? Am considering an Emotiva A-500 to handle high channels.
sheraz_uk is offline
post #3202 of 3364 Old 05-15-2019, 01:09 AM
flax's Avatar
Quoted: 191 Post(s)
Liked: 318
Dirac Live's update 2.2.2 is now available: https://live.dirac.com/download/
SteveC356 likes this.
Warning: My posts might be biased even if in good faith, I work for Dirac Research :-)
flax is offline
post #3203 of 3364 Old 05-15-2019, 01:12 AM
Quoted: 790 Post(s)
Liked: 610
In the past I did use a two channel integrated Cambridge Audio amp. It worked perfectly. Then I went to an Arcam FMJ P7 and of course that works perfectly too with the added bonus of seven channels and more power.
LG 77C8 (UK) - Arcam AVR 850 - Arcam FMJ P7 - 7.2.4 Atmos setup.
alexbarbel is offline
post #3204 of 3364 Old 05-15-2019, 05:14 AM
Liked: 0
Looking at the Preamplifier outputs on the Nominal output level = 1V RMS Output impedance = 560Ω
The Emotiva A 500 Input Sensitivity = (for rated power; 8 Ohm load): 1.2 V. Input Impedance = 27 kOhms.
The impedance looks good, but i'm unsure how much of an issue will be on the Sensitivity 1V -> 1.2V ?
post #3205 of 3364 Old 05-15-2019, 06:03 AM
Quoted: 790 Post(s)
Liked: 610
I'm sorry but I can't help you there.
I already had the Cambridge amp and took a suck it and see approach. I hooked it up to run two uppers, set the gain to twelve o'clock and then ran Dirac. When I was done all seemed in balance when I checked levels with my SPL meter and so I just used it.
post #3206 of 3364 Old 05-15-2019, 08:29 AM
2000m2's Avatar
In case this helps someone else down the road, this is what I received from Arcam via email, which got ARC and the remote working:
"the problem of the remote control not fully working may be that the remote is trying to work another device such as a blu-ray player this may have happened accidentally by pressing the "BD" button too make sure the remote is working with the AVR550 press the AMP button on the left just above the coloured buttons and this should bring back the functionality of your remote.
Too address the problem with the App and to eliminate any possible network problems can you try and plug the AV550 directly in to your router via Ethernet cable and make sure on your phone or tablet make sure it is connected to the same network the App should then connect if you are having problems after this please let us know as more troubleshooting may be necessary.
For ARC to work on the AVR550 go to Menu>General setup> CEC on/ARC on then providing the source device has the correct setting ARC should work."
I haven't tried this for the app yet, as I don't want to mess up the other items that are functioning properly.
"In order for the control app to connect to the AVR, you need to ensure that IP control is enabled, and that the standby mode is set to HDMI+IP. Both these settings can be found in the General Setup menu of the AVR."
2000m2 is offline
post #3207 of 3364 Old 06-06-2019, 08:11 AM
Quoted: 790 Post(s)
Liked: 610
Hi,
Just had an issue with my 850 where upon loading in a new project everything would seem to go in OK apart from the speaker levels which would be retained as the old levels before the new project was loaded in.
I did find that performing a factory reset and then putting in the new project would result in the correct levels being loaded but of course that's a pain. My dealer contacted Arcam on my behalf (none of the email contacts work) and they suggested that after a project is loaded I should toggle Dirac On/Off/On with the remote's Audio button.
Happy to say this did the trick and I am just reporting it here in case anyone finds themselves with the same issue.
post #3208 of 3364 Old 06-06-2019, 08:34 AM
Liked: 1830
Hi,
I found a full power cycle usually did the trick (button on the front of the AVR)
alexbarbel and SteveC356 like this.
post #3209 of 3364 Old 06-06-2019, 09:14 AM
hasta666's Avatar
Quoted: 507 Post(s)
Liked: 178
I was not aware of this, thanks. I rarely do a full power cycle and rarely toggle with the Audio button so I will take care of that now. By the way the user shouldn’t have to do that. I hope they’ll fix this in a future firmware update.
I’m still in touch with Dirac because I am not able to make Dirac 2.0 work. I bought a new mic (UMIK-1) as a replacement for the Arcam mic v1 (which works fine with Dirac legacy but who knows where lies the problem). I will miss Dirac legacy GUI though...
hasta666 is offline
post #3210 of 3364 Old 06-06-2019, 09:52 AM
Liked: 1830
Agreed, but if they didn't fix it when we reported it 2 years ago, they're probably not gonna fix it now
Arcam , avr 550 , AVR-850 , b&w 600 series , bi-amo , bi-wiring
