RX-A750 vs TX-NR737 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-22-2015, 12:53 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 2
RX-A750 vs TX-NR737
Hi,
I currently have a Yamaha RX-750. I had purchased it with
2x DefTech 8020STs
2x DefTech 8080BPs
1x DefTech ProCenter 1000
Because I can't help myself, I just swapped out my 8020s for 8040s, and my PC1000 for a ProCenter 2000. 8080s haven't arrived yet. For now, I'm planning on a 5.0 setup (foregoing a sub for the moment, I think the 8040s may be enough for my size room [162"x141"x89"]). My primary reason for the upgrade was future-proofing as I have a fairly small living room at the moment. I was considering buying an Atmos capable receiver for the same reason, but for Yamaha, the next level up was $800. I had only paid $569 for my A750. I was just going to let it go until I searched around a bit and found Onkyo-TX-NR737.
I had initially narrowed my receiver down to a Denon and the Yamaha, but I liked the sound of the Yamaha more in the show room. I don't know anything about Onkyo, nor did I get to listen to one and that's where my question lies. Are they a good receivers, and do they have similar sound properties to the Yamaha? I thought the Denon sounded a little warm. Crutchfield still has the AX-750 for $650, so I'm a little concerned that the Onkyo is still cheaper considering it is Atmos, and has a higher wattage rating per channel. I'll pose the question two ways:
1. Take Atmos out of the equation. Is the Onkyo a better receiver? If no, is it a better receiver for the money?
2. If no to #1 , does the fact that it allows for Atmos change your answer? Also, unless I'm misreading does this particular receiver only allow for Atmos in a 5.2.2 setup?
If there are any significant differences I'm missing, please let me know.
Thank you!
Brono87 is offline
post #2 of 4 Old 11-22-2015, 01:10 PM
Quoted: 587 Post(s)
Liked: 167
A750 is current model while 737 is last years model, if you can spring for 747, it is superior in every way to a750
nohcho is offline
post #3 of 4 Old 11-23-2015, 07:06 AM - Thread Starter
Quoted: 38 Post(s)
Liked: 2
For my current setup I want to just verify that my RX-750 is sufficient enough to power what I have. Also, in the interest of future proofing, I have done some reading on running separates. Is this a romanticized idea for such a low-end setup? Am I better off just running with the receiver I currently have (or upgrading if power insufficient) or is it worth buying amps that will likely last long past my current set up in hopes of one day building a monster theater? In the interest of ease, my setup below:
Yamaha RX-A750
2x DefTech 8040STs
2x DefTech 8080BPs
1x DefTech ProCenter 2000
Side note - Is Atmos worth it if only using an up-firing application? I'm highly unlikely to run in-ceiling speakers with my current setup.
Brono87 is offline
post #4 of 4 Old 11-23-2015, 02:55 PM
Kini62's Avatar
Quoted: 2796 Post(s)
Liked: 2675
Yamaha RX-A750
2x DefTech 8040STs
2x DefTech 8080BPs
Your AVR should have plenty of power since the DT have their own powered woofers.
As for the up firing modules there is a thread on them. Mixed results at best.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
