Help - Denon S710W outputting stereo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-05-2015, 01:59 PM - Thread Starter
balestrom's Avatar
My receiver is playing some of my blue ray discs as stereo.
Example, Star Trek 2009 is True HD 5.1. But my Denon only plays it on my front speaks. So far, the only way I can change it is to hit movie/surround but it's clearly not outputting a quality signal like my old retired Onkyo.
Any suggestions?
balestrom is offline
post #2 of 5 Old 12-05-2015, 03:39 PM - Thread Starter
balestrom's Avatar
So I have tried to play dolby digital 2.0 and True HD 5.1. I have confirmed via my blue ray audio display that it is outputting both, but my Denon display says stereo and plays only front speaks.
When I put in DTS-HD Audio 7.1 my screen shows as 7.1 and it works as it should.
On a different note, my receiver does detect my Direct TV Digital and throws that into surround sound just fine. This has me confused.
Out of curiosity, I tried a different HDMI port in on my receiver and nothing changed.
I called the Denon help desk and the lady is stumped. After a half hour on the phone she said she'd have to research and call me back. However, since she was reading out of the user's manual, my confidence is shaky that they will find a solution.
Has anyone had this problem with the Denon or know how to correct? Thanks!!!
post #3 of 5 Old 12-05-2015, 03:45 PM
Selden Ball's Avatar
Quoted: 4815 Post(s)
Liked: 2850
The problem is in the player's settings, not in the receiver. It needs to be set to "bitstream" on and "secondary audio mix" off.
Your symptoms are consistent with having "secondary audio mix" still enabled in the player. Having it enabled forces the player to decode the audio so it can mix in the menu sounds and any secondary audio stream. Many recent Blu-ray players can only decode Dolby TrueHD into stereo (and many current generation players can only decode DTS-HD MA into stereo). Their manufacturers didn't want to pay the extra license fees to provide multichannel decoders.
Selden
Selden Ball is online now
post #4 of 5 Old 12-05-2015, 04:21 PM - Thread Starter
balestrom's Avatar
Okay, you are awesome! I would have never thought about that. The closest thing I have BD Audio Mix Setting. So I set that to off. DD/DTS is already set to bitstream. Seems to have worked. Out of curiosity and on a different note, now that I am looking at the Blue Ray player menu..should I have my "Downmix" set to surround? (It is currently set to stereo and it says it is to apply Dolby surround to the output signal.
post #5 of 5 Old 12-05-2015, 04:45 PM
Liked: 2850
I don't think that setting matters. As best I can determine, that setting seems to be only for the coax or optical digital audio output, not for the HDMI output. (I'm assuming you have a Sony player.)
Selden
