Denon S910w question.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-22-2015, 06:41 PM - Thread Starter
sandcracker21's Avatar
Quoted: 21 Post(s)
My old onkyo receiver bit the dust, so after much research, I decided on a Denon s910w due to it having hdmi 2.0 and full 4k ability.
We'll I hooked it all up and it works great. However, half the time when I start it up the volume is super low. I have to turn it off then back on for it to work normally again.
Anyone know why this is happening??
sandcracker21 is offline
post #2 of 6 Old 12-23-2015, 10:41 AM
jdsmoothie's Avatar
Quoted: 22743 Post(s)
Liked: 12384
Average volume would be about 40-60. The AVR should remember the last volume used when it was powered off unless you are using a Quick Select button to power on the AVR, then it will always start at 40 unless you change it to another value.
For more helpful information on the S910W, review posts 3-6 in the 2015 Denon AVR Owner's thread.
https://www.avsforum.com/forum/90-rec...l#post34728921
jdsmoothie is offline
post #3 of 6 Old 12-23-2015, 02:07 PM - Thread Starter
Quoted: 21 Post(s)
No, I mean it's whisper quiet and the volume level doesn't effect it at all. It's definitely not normal
post #4 of 6 Old 12-24-2015, 08:01 PM - Thread Starter
Quoted: 21 Post(s)
Anyone?
It works fine but must be turned on, turned off, then turned on again
post #5 of 6 Old 12-24-2015, 08:20 PM
John Sully's Avatar
Quoted: 249 Post(s)
Liked: 172
Originally Posted by sandcracker21 View Post
Anyone?
This sounds like a problem I have noted with my X3000. If you send a command to it before the power light has stopped blinking it will come up in a muted state (not always, but often enough). In my case the only fix is to unplug it and plug it back in after a few minutes since the front panel controls are usually unresponsive. I have never experienced this problem if I wait until the unit is fully "booted up".
BTW, the setup screens allow you to choose what turn on volume you want and you can also do this via the web application embedded in your receiver.
Receiver: Denon AVR X3400H/Display: Vizio P65-E1
Blu-Ray: Sony UBP-X700/LaserDisc: Panasonic AG-LD20/Streamer Amazon FireTV 4K
Satellite: Dish Hopper w/Sling
Speakers: SVS Prime Tower/SVS Prime Center/SVS Prime Surround/Velodyne HGS-15
John Sully is offline
post #6 of 6 Old 12-25-2015, 02:11 AM
jdsmoothie's Avatar
Liked: 12384
Anyone?
Try doing a soft reset by simply unplugging the power cord for 10 minutes. If still no joy, reset the microprocessor as noted in post 5 of the Owner's thread ...
https://www.avsforum.com/forum/90-rec...l#post34728977
