Low Audio On STR DH750 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-23-2015, 07:04 PM - Thread Starter
Liked: 1
I have hooked this unit up to all my speakers and with the volume at "Max", the TV volume is medium at best. My old Sony would rock the house at 50% volume. Did I hook something up wrong?
qtband is offline
post #2 of 6 Old 12-23-2015, 07:22 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4795
Maybe, how is it hooked up specifically (the tv)? Did you adjust speaker levels/delays or run the auto setup in the avr ?
ps They may have had different volume scales, too.
lovinthehd is offline
post #3 of 6 Old 12-23-2015, 08:06 PM - Thread Starter
Liked: 1
I used HDMI to the TV from the receiver. The instructions are non-existent so maybe there is a limiter or something that needs adjusting.
qtband is offline
post #4 of 6 Old 12-23-2015, 08:09 PM
lovinthehd's Avatar
Liked: 4795
There's this thing called the manual....https://docs.sony.com/release/STR-DH...0_guide_en.pdf
You might look for an input level adjustment. Does your model have DCAC? I'd use that to set it up.
If you're simply comparing volume "numbers" you may not even have an issue, just different volume scales (and Sony doesn't do what most others do in that regard).
post #5 of 6 Old 12-31-2015, 07:24 AM - Thread Starter
Liked: 1
I wasn't concerned with the numbers, only the volume that I heard.
There must have been an issue because the volume was getting weaker and weaker without any adjustments.
I ended up taking it back for a replacement and the new one is working very good. I learned my lesson about buying an "open box" item.......but I'll probably do it again.
qtband is offline
post #6 of 6 Old 12-31-2015, 10:44 AM
Prime316's Avatar
Quoted: 190 Post(s)
Liked: 207
Lol
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
