AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (https://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   Denon AVR-x2200w vs Onkyo TX-NR646 (https://www.avsforum.com/forum/90-receivers-amps-processors/2263954-denon-avr-x2200w-vs-onkyo-tx-nr646.html)
soapboxpreacher 01-05-2016 09:30 PM
So I got both setup and tried the Denon for a Day and the Onkyo for a Day. Early observations are: The Denon produces significantly better video. My picture detail, sharpness, and so on have improved!!! This I was not expecting at all!! So that video processor is either not degrading via pass thru or it is processing. Either way my picture looks AMAZING going thru the Denon! Ill take it! As for the Onkyo the picture when passing thru the HDMI gets degraded.. huge disappointment. As a long time Onkyo owner and one that got stung by the HDMI issues in the past this is really frustrating. Not that the picture is bad but there is a noticable difference. All thru the same cables and Samsung 65" HDTV. Now on to the sounds early observations. Dialogue is better on the denon...you get more detail and clarity. It isnt a big difference like the video differences but it is noticeable. Bass the onkyo is nothing short of amazing. I replayed tron legacy light cycle scene about 20x on both! The scene where the two go guys sandwich the bad guys bike! It is a rumbler!! My FV12 really rolled the floor. It was also more apparent during Star Wars ep 2 of the nubian craft enters the atmosphere as well as the seismic charge sequence. Have lots more listening to do. I do not like the calibration of the Onkyo AccuEQ is complete garbage!! It crossed my main at 120hz...we are talking about Klipsch RF52. They arent bookself speakers!!! I believe they should be xover to something in the neighborhood of 60-80hz. Audessey is significantly more accurate and more comprehensive!! These are early observation but the where also the obvious ones. The AccuEQ takes a few minutes where as the Audessey takes 20 mins with multiple measure positions. AccuEQ...one location? It also didnt crossover my towers correctly! Level were also very goofy! They should not have cut this corner! The Onkyo does have more balls but it is more like a bull in a china shop than somes powerful yet refined! The Denon which I thought was going to be inferior is actually my early favorite. I just need to see how I cant get my sub to perform better with it. I am going to post another thread on how to config my sub with the denon. I hope this is a case of a bad LFE port on the denon where I lose all my dynamics. The guys over at SVS have said in the past to watch for this. Know how my sub performs I believe I need to take a deeper look. More to come!
Stangvert2000gt 01-05-2016 09:38 PM
I still like to play SACD and DVD-A discs, so I went with the Onkyo N646. No regrets. Plays everything great. Very punchy sounds for Atmos discs. I didn't try the higher model Denons, but I did try the AVR-S910W, but returned it for the Onkyo. The AVR-S910W wasn't more docile and didn't support SACD's or DVD-A.
Stangvert2000gt 01-05-2016 09:42 PM
I also didn't like that fact that I needed to turn the volume of the Denon almost all the way up to get decent volume for movies.
Prime316 01-05-2016 09:44 PM
I got a chance to do some more critical viewing with my X2200 earlier. I agree, the picture does seem sharper than with my Onkyo 809.
What jumped out at me more were that my subs seemed to performing better at lower levels than with the 809. Not that my subs need any help in any size room. I actually had to back them down a notch or two.
I threw in the original Iron Man where Stark builds the armor in the cave. When he was walking around in that thing, my subs made it sound as if that armor weighed thousands of pounds...lol.
Prime316 01-05-2016 09:48 PM
You're right about the volume deal when comparing Denoms and Onkyos. It seems that Denons while less powerful are a bit more refined. It's only a couple extra clicks of the volume button to get what I need out of the X2200.
nohcho 01-05-2016 10:06 PM
There are few reviews out there that knock denon x series for lack of any low end punch so im not sure if there is anything that could be done about that. Even my x3200 was quite lacking in the base department compared to vsx90. I have svs sb 12nsd sub btw.
spieg 01-05-2016 10:07 PM
Do you have a way to measure response? On my 646, AccuEQ didnt really do anything with the low end so I had some nasty peaks compared to audyssey. Some frequencies sounded a lot louder, for sure. But the overall bass response was smoother after running audyssey. Maybe Audyssey is pulling down some of your low end frequencies to level things out and that is what's making the bass less impactful on the Denon. Have you tried boosting your subwoofer levels a few DB's in the speaker settings? Audyssey will adjust the levels to hit reference and im not sure AccuEQ does. Audyssey also doesnt always get delay right. If the delay between your mains and subs isnt right that could potentially be affecting your low end as well. If you dont have a way to measure, just try increasing the distance setting for the sub on the denon 1ft at a time between tests and see if that helps.
On my Denon I had to adjust subwoofer levels (audyssey makes things very flat, most people prefer a boost in the 20-100hz range), and adjust delay a little bit. After doing so, there certainly isnt a lack of punch. And everything is a lot smoother overall. Just my $.02 for what its worth.
soapboxpreacher 01-05-2016 11:12 PM
I didnt find this at all. The output was higher then my 2311CI and that is rated 10 watts per channel more. I do have Klipsch RF52 which have a sensitivity of 96db so they do tend to sound louder with any amp. I was pleasantly surprised with the output of the X2200W, when I ordered it I was nervous about its rating. The Transformer is smaller than my 2311CI and only slightly smaller than the 747 but the capacitors are bigger on the X2200W than the 747.
soapboxpreacher 01-05-2016 11:19 PM
Spieg you might have something here!! I never thought of this but it is possible. The 747 seems to produce a ton of boomy bass at times. Exaggerates some of the frequencies that the denon and Audyssey smooth out or possibly smooth out too much. AccuEQ I believe doesnt do what you are describing. I will give it a shoot. I have an older FV12 Rythmik hooked up to the X2200W. As for a meter...dont laugh I only have an old Radio Shack SPL. Not sure how it would be used in this or if it could even help.
spieg 01-06-2016 03:54 AM
Using a mic and REW or something similar would be the easiest way to check it. You could probably use a frequency generator at specific frequencies with your SPL meter and then plot out the response for a similar result. I posted a REW graph of my accueq vs audyssey results back in post #22 . I intentionally left off all EQ on the subs and tried to make it as close of an "out of the box" type of comparison to remove other variables and just show the differences between the two for my room. There was a difference of ~9db at 50hz (higher on the Onkyo), but the entire 40-60hz range was quite a bit higher on the Onkyo. Adding a few db to the subwoofer channel on the Denon after running audyssey brought things up to more comparable levels without having the boomy peaks as with accueq. If your system/room responds similarly, I think that could definitely explain why the bass is louder on the Onkyo for you. Neither AccuEQ or Audyssey are perfect, but I definitely like what Audyssey is doing a lot more than what AccuEQ did (or didnt do).
jdsmoothie 01-06-2016 04:48 AM
Denon uses a logarithmic volume scale such that after running Audyssey, which sets reference movie volume level to 80/0db, average volume levels for most will be about 50-70/-30db to -10db.
jdsmoothie 01-06-2016 04:56 AM
For the best sub performance, ideally you'll want to perform a "Subwoofer Crawl" (google it) which will identify the best places in your room to place the sub which will result in the best performance at the main listening position (ie. mic position 1). Also, when taking the Audyssey mic positions, after doing the mic 1 position, the remaining 7 mic positions should all be within a 1-2' radius around that first mic position (ie. not where others actually sit, rather focusing only on the main listening position). The sub gain knob should be set to about 10 o'clock prior to running Audyssey such that the subwoofer level after Audyssey results in a setting between about -8db and -4db. Most will find the result to be rather weak, which can be resolved by going into the Manual Setup - Test Tones - Subwoofer and simply raising the level up about +3db to +5db (eg. if sub is set to -6db after Audyssey, bump it up to about -2db).
For more helpful information on the Denon X2200W, review posts 3-6 in the 2015 Denon AVR Owner's thread ....
https://www.avsforum.com/forum/90-rec...dcp-2-2-a.html
soapboxpreacher 01-06-2016 03:52 PM
I think I have found that audyssey can do this not the AVR. I reran mine and did the manual adjustments that seemed to really fix the issues.
soapboxpreacher 01-06-2016 04:10 PM
So I ran the Audyssey this AM and then did some manual adjustments to it. For starters I spoke with Rythmik and asked about what I should do prior to calibration. My FV12 has an older amp with a bass extension section on the amp. On there you have Freq and Damping. They said set it at 14hz for Freq and Low for Damping. I also set the level at 12 o'clock. And finally on the sub set the freq crossover at 120hz...its highest so the AVR would do the crossover. Then ran Audyssey. It set the speakers to full which they told me is a no no. So I manually adjusted it to small and set the crossover at 60hz for the fronts however I worry about the EQ...for it is set for what audyssey room calibration...not sure how I can get around it. LFE was on 100Hz on the denon in the bass section. Did a listen and the Denon is much better and dynamic more controlled and lower...and tons of power/punch. It hits lower then the Onkyo. The onkyo seems to have a hair more authority but that seems to be because it exaggerates the boomy section of bass more then the denon which some HT listener might find good...I dont because it overwhelms the other tracks making those details absent!! So as it stands...the denon in my subjective opinion is the better piece. AccuEQ is a failure! It made so many mistakes. To the untrained ear...not that mine is, might find it ok. I do not like it when doing back to back listening. I have more to do. So stay tuned.
jdsmoothie 01-06-2016 04:58 PM
Exactly the case .. and as you learned, can be very easily improved up with some minor adjustments. :)
soapboxpreacher 01-09-2016 09:38 AM
Did more tweaking and the Denon looks to be staying. AccuEQ is just flat out bad! It exaggerated certain low frequencies after listening a number of times that it would overwhelm other parts of a movies track. I tried to adjust it out but then you would end up the other way. It is just a poor calibration tool. I did try calibrating it a few more times...and once again, would always get my towers in front incorrect. The 747 is not bad by any means I just found the denon to be better in my opinion. It has significantly better imaging, dialogue is more distinct, and overall cleaner. I will say this onkyo has came a long way from my older piece I had 7 years ago. This is a significantly improved product. If they went back to Audyssey I believe this would be very close. However I cant recommend the 747 from a picture standpoint. Seeing both back to back a number of time, the denons video handoff left the picture very nice. The 747 there was some loss. That is what put me over the edge. As for bass once I got the audyssey set right the bass on the denon was deeper and less intrusive. So the power was there without ruining the other parts of the movies soundtrack.
spieg 01-09-2016 10:47 AM
Glad to hear you got things dialed in!
Prime316 01-09-2016 11:20 AM
Glad I went for the X2200 instead of the 646. I had my suspicions about AccuEQ so I stayed with what I knew...Audyssey.
soapboxpreacher 01-10-2016 04:59 AM
Unfortunately discovered a small problem (major!!)...sad day! So I am not certain what the deal is but when I play certain Blu-rays via my xbox one the denon does something strange. It will dim the screen 50%!!! It is random in nature and only happens with the xbox one and denon x2200w combination. For example, I was playing the matrix revolution and when a scene switches to a dark area the screen dims 50% and stays there. If I unplug and replug in the HDMI while it is still going it will go back to full but will not stay. So I hooked up the 747...doesnt do this! I also tried the old 2311ci...doesnt do this either. I can duplicate the issues everytime and it doesnt just happen with the matrix, when my sons started a game of NHL 15 it did it as well. If I switch from the blu-ray source to the CBL/SAT it is bake to normal but doesnt stay. I believe to either have a bad unit or denon has a problem on their hands here! Once again I cannot tell you how much I like the sound better on the Denon but this is a major problem. Some background and why I believe this is pointing to the new denon is this. I have had the Xbox One hooked up to my old Denon 2311Ci for over a year, it has seen 100s of Blu-rays. All the cabling is the same (Xbox came with a 4k xbox one cable) so It is not a cabling issues not to mention it does NOT exhibit this with the 747 either. My trouble shooting has been power cycling on the xbox one, power cycle on the denon. I have tried different HDMIs on the X2200W as well. Still the same dimming issues. I have scoured google for this issue with no avail. It only does this with the xbox one. I might grab another blu-ray player to see if that is the case. Either I have a defective x2200w or this is a design issue. Either way it really breaks my heart!! Its a sad day!
soapboxpreacher 01-14-2016 02:56 PM
Originally Posted by jsb75 (Post 40341002)
So how do they sound?
I like the sound better on the X2200W. Imaging is better and depth is better. The Sub initially was more present on the 747 but once I redid the calibration on the Denon the denon is less muddy and more accurate. The Low frequency tracks would nearly wash out some of the mid subtle details on the 747. Video was significantly better on the Denon. It is cleaning and sharper with more depth as well. Power wise...I thought the 747 would have way more power...not the case. The 747 is good but I like the denon way better. AccuEQ is terrible! It cant as I have already mentioned get the fronts right. I have larger Klipsch REF52s and it would pick them up as 120Hz??? Terrible! I tried a ton of times and it would never get it right! I am an onkyo fan but this was an average offering from them. My 626/560 is a significant yet older improvement.
spectorcz 01-19-2016 04:40 PM
Soapboxpreacher,
did you figure out that issue with diming on Denon? That would be no go for me, if it has such bug. My local dealer recommended me Denon AVR-x2200w with Klipsch RF 52 II 5.0 set ? Is that reasonable set ? Yet considering Magnat Supreme 1002 5.0
nohcho 01-19-2016 07:44 PM
I would avoid klipsch RF if possible, they are pretty bright and get fatiguing after a period of time.
soapboxpreacher 01-20-2016 11:35 AM
Originally Posted by spectorcz (Post 40796474)
Soapboxpreacher,
That is my set (klipsch). I like it however audyssey can make or break any speaker. In my case they didnt quite get my klipsch right because the horn can over power the highs and they EQ out a ton of stuff that caused my klipsch mains to get lost or less impactful. Once I adjusted some of audyssey misconfiguration my klipsch came alive such as going from reference to flat. As for recommending or not, speaker sound is subjective...some prefer a brighter, some prefer a warmer..etc. Dont let anyone ever talk you out of a speaker until you listen and make your own determination. No one typically has the same listen preferences...and when you factor audyssey in the mix it can alter a speaker that you might normal like so a speaker you dont like!! Audyssey is such a critical tool but one that needs to be watched and adjusted right! I think in most cases it can get you close and then you can make tweaks as I have.
spectorcz 01-21-2016 02:00 AM
thanks! It's good to know. Btw, what about the issue with brightness diming when you use Xbox One? You said that the issue stays also when you then switch to another source. It's quite dissapointing.
soapboxpreacher 01-21-2016 09:33 PM
Factory/manufacturer reset took care of it. I have not yet seen the dimming issue since then. I retested the media I was having the issue with it and nothing since. Happy to say it works well.
spiroh 01-23-2016 08:18 AM
Good timing of this thread as I was about to buy a X2200W over others. Denon has been very good to me throughout the years so I'm glad to hear the audio still sounds great on them. Thanks
dingleberries 03-14-2016 06:27 PM
Purchased the Denon AVR 710W, X2200, and Onkyo NR-646. Here are thoughts of what may have already been mentioned. I owned and listened to each receiver for at least one week.
Denon Pros:
- Detailed clarity during movies.
- More available options: Eco mode, Audyssey, Dialog level adjust
- Better looking screen layout.
Denon Cons:
- Consistently lacked bass while watching movies. Although I made adjustments, I could not reproduce decent bass and thus the movie watching experience felt hollow.
- Volume needed to be turned up significantly.
- Speaker crossover could only be set in intervals of "20". ex: 40hz, 60hz
Onkyo Pros:
- Detailed clarity, bass, sounds were full and didn't lack anything.
- Volume levels were more consistent.
- Speaker crossover's could be set in intervals of "10". ex. 40hz, 50hz
- Ability to manually adjust treble, and bass.
Onkyo Cons:
- Lackluster screen layout, but manageable.
- Only 3, 2.2 HDMI compliant outputs.
Final Decision: I will be returning the Denon X2200 and re-purchasing the Onkyo 646. Should have stayed with the Onkyo but wanted to make sure I wasn't missing out on anything with the x2200.
jdsmoothie 03-14-2016 08:07 PM
Originally Posted by dingleberries (Post 42393841)
Denon Cons:
1. Many owners find the bass to be a little weak after running Audyssey, which simply requires boosting the subwoofer level about 3-5db to suit one's preference.
2. Speaker crossovers vary from 10db to 50db depending on where the crossover is situated. The general recommendation after running Audyssey is to raise any crossover set to 40Hz or 60Hz up to 80Hz to let the subwoofer handle the lower end and any crossover set >80Hz leave alone.
dingleberries 03-14-2016 09:55 PM
I guess, I find it counter productive to run Audyssey, then raise the subwoofer 3- 5db. During setup, I'm allowing the software to complete it's computations and measurements to determine the best sound quality. Of course, "the best sound quality" is subjective from person to person.
Thanks for the recommendation. I'll try the changes tomorrow. One last push to keep the X2200.
jdsmoothie 03-15-2016 05:28 AM
The Audyssey process simply provides for the same volume level for each speaker/sub at the main listening position. Most owners prefer a louder boom boom which is easily accomplished as previously discussed.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
