Marantz SR7010 - "Quick" Video Output Switching - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-07-2016, 05:49 PM - Thread Starter
loganross's Avatar
Quoted: 221 Post(s)
Liked: 76
Hi,
I am a new SR7010 owner (currently using a Harmony Remote). I have it connected to both a TV and a Projector. I know I can go into the menu to change the output from one to the other. Is there a quicker way to do this with either the included remote or a Harmony remote?
In addition, If I wanted to set up the Marantz to do the following every time I use the projector, how would I go about this:
1) Change Marantz Video Output to Projector's HMDI port
2) Turn Marantz On/Off Video Upscaling
Thank you in advance!
loganross is offline
post #2 of 2 Old 01-07-2016, 11:33 PM
jdsmoothie's Avatar
Quoted: 22200 Post(s)
Liked: 12059
1. There are 4 Smart Select buttons (p. 182 Owner's manual) on the Marantz remote. You can use one for the Monitor 1 output and another for the Monitor 2 output.
2. This would have to be done within the menu, although most likely just best to leave the upscaler set to OFF and let the display do the upscaling.
Also note that AVR specific questions are best posted in their respective Owner's threads .. in this case, the 2015 Marantz Owner's thread linked below ...
https://www.avsforum.com/forum/90-rec...-s-thread.html
jdsmoothie is offline
