Onkyo TX-RZ1100 and TX-RZ3100 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2534Likes
post #181 of 2579 Old 03-31-2016, 06:02 AM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
If this will sound at least as good as the 3030 which I just love to bits it will be a winner for sure.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #182 of 2579 Old 03-31-2016, 06:21 AM - Thread Starter
gene4ht's Avatar
Quoted: 1968 Post(s)
Liked: 2657
With the naming convention apparently now being RZ1100 and RZ3100, suggest you ask a mod to edit the thread title accordingly.
@moderators as per jd's suggestion, please revise the title of this thread to reflect the actual Onkyo model numbers as seen above...thanks in advance!
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #183 of 2579 Old 03-31-2016, 06:26 AM - Thread Starter
gene4ht's Avatar
Liked: 2657
I'm definitely hoping this will be the case! If so, will you be upgrading?
ramcharger1979 likes this.
gene4ht is offline
post #184 of 2579 Old 03-31-2016, 10:26 AM
m3incorp's Avatar
Quoted: 234 Post(s)
Liked: 111
I will hehe
m3incorp is offline
post #185 of 2579 Old 03-31-2016, 01:46 PM
wackid's Avatar
Quoted: 330 Post(s)
Liked: 75
And while we are counting the days...
What do you guys think of the negative responses on the AccuEQ? Read a review thst it's compared with Dirac?? A little bit over saturated I think.
I have a TX-NR709 with Audyssey at the moment.
AccuEQ is the only thing I am a bit "worried" about.
As i have a difficult room with reflections.
Panasonic TX-P65VTW60 | Panasonic DMP-BDT500 | Asus Chromebox OpenELEC triple boot | Pioneer SC-LX89 | 6 X Monitor Audio Apex 10 | Canton Chrono SL 590 black | Klipsch R-115W | BK Sub XXLS400 | Zalman HTPC | Harmony Ultimate
wackid is offline
post #186 of 2579 Old 03-31-2016, 01:47 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
Originally Posted by m3incorp View Post
I will hehe
We'll be in the same line!
gene4ht is offline
post #187 of 2579 Old 03-31-2016, 02:47 PM
m3incorp's Avatar
Quoted: 234 Post(s)
Liked: 111
I currently have the RZ900 in my living room. I'd say that the AccuEQ has been greatly improved. I still had to make some minor manual adjustments after running it BUT I also had to do that with my past receivers that had Audyssey. Most people that own the RZ900 and RZ800 and kept them have found that AccuEQ would not be a reason to pass over the receiver.
m3incorp is offline
post #188 of 2579 Old 03-31-2016, 04:58 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
Unfortunately, I don't have much input for you. I've been lucky in that my room acoustics have not been problematic so Room Correction (EQ) has never been a "must have" feature for me. And although I've used MultiEQ, XT, XT32, and AccuEQ (2014)...after calibration, my preference more often than not was to disable RC.
gene4ht is offline
post #189 of 2579 Old 03-31-2016, 06:47 PM
Quoted: 83 Post(s)
Liked: 34
I think the accuEQ on the rz900 does a darn good job vs manual eq for the LCR channels, it just sounds so much more balanced than any setting I can come up with.
This thread should not exist! Should make an official thread with the proper model names and not re-use this thread so people don't have to read pages of misinformation and speculation.
Moses760 is offline
post #190 of 2579 Old 03-31-2016, 06:53 PM
ramcharger1979's Avatar
Quoted: 107 Post(s)
Liked: 503
I think this thread is just fine if they just change the name.
Sent from my XT1575 using Tapatalk
ramcharger1979 is offline
post #191 of 2579 Old 04-01-2016, 01:07 AM
Anderslober's Avatar
Quoted: 104 Post(s)
Liked: 30
Will these new bombers be THX certified? I for one sure hope so........
All we need now is some spy photos!
Anderslober is offline
post #192 of 2579 Old 04-01-2016, 01:36 AM
Bandyka's Avatar
Liked: 1422
Well in that case it will just leave my with no choice will it?
Running a separate cable for HDR is a major pain so that will be my excuse
BrandonH likes this.
Bandyka is offline
post #193 of 2579 Old 04-01-2016, 02:54 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
I see Onkyo actively participating in these threads...a good thing...hope it continues!
mn2422 likes this.
gene4ht is offline
post #194 of 2579 Old 04-01-2016, 05:01 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
Found this from @Defcon in a different thread...which I tend to agree with.
"From what I've read, the new AccuEQ focuses on LFE and leaves midrange and HF untouched. If you read the Audyssey FAQ, that's exactly what XT32 does (but not MultiEQ) and is considered the 'right' thing to do. So I'm not sure if AccuEQ is still worse than Audyssey, would like to see a detailed review of both."
gene4ht is offline
post #195 of 2579 Old 04-01-2016, 05:09 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
If the TX-RZ710 and TX-RZ810 are THX certified and Onkyo is targeting the "discerning audiophile" with the RZ series, one would expect the 1100/3100 to follow suit?
gene4ht is offline
post #196 of 2579 Old 04-01-2016, 05:11 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
Well...we all have choices...but
gene4ht is offline
post #197 of 2579 Old 04-01-2016, 05:20 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
Thanks for the input...I'm personally ambivalent/neutral on the matter...maybe revisit when definitive information/data/specifications are released and closer to when product hits the streets.
gene4ht is offline
post #198 of 2579 Old 04-01-2016, 10:39 PM
Quoted: 104 Post(s)
Liked: 30
Man, I was 4.2 seconds away from buying a 8802a........until all this new info.
I am beginning to get the 'desperate-jitters' towards these new and upcoming units.
The rz3100 and the new processor......they should be awesome!
Now.....Can a tech in the Onk' factory please sneak down to production line and snap a few!:-)))
post #199 of 2579 Old 04-02-2016, 12:42 AM
wackid's Avatar
Quoted: 330 Post(s)
Liked: 75
How and where?
wackid is offline
post #200 of 2579 Old 04-02-2016, 03:03 AM - Thread Starter
gene4ht's Avatar
Liked: 2657
How and where?
https://www.avsforum.com/forum/search...chid=108678722
gene4ht is offline
post #201 of 2579 Old 04-02-2016, 04:00 AM
gurkey's Avatar
Quoted: 289 Post(s)
Liked: 181
No longer exists...
gurkey is offline
post #202 of 2579 Old 04-02-2016, 04:50 AM - Thread Starter
gene4ht's Avatar
Liked: 2657
Oops try this link...
https://www.avsforum.com/forum/search...chid=108691178
gene4ht is offline
post #203 of 2579 Old 04-02-2016, 06:37 AM
wackid's Avatar
Quoted: 330 Post(s)
Liked: 75
No matches it says.... are you on Tapatalk? Because sometimes copying links don't work.
wackid is offline
post #204 of 2579 Old 04-02-2016, 09:33 AM - Thread Starter
gene4ht's Avatar
Liked: 2657
Originally Posted by gurkey View Post
No longer exists...
Hmm...strange...works for me when I first post...but then later doesn't.
OK...this link goes directly to one of his post (#21 & #24)...for more, click on his name...scroll down to "find other posts by OnkyoUSA."
https://www.avsforum.com/forum/90-rec...vr-x4200w.html
gene4ht is offline
post #205 of 2579 Old 04-02-2016, 05:24 PM
coolcat4843's Avatar
Quoted: 284 Post(s)
Liked: 111
I hope the RZ3100 has MCACC Pro calibration and four independent subwoofer outputs.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #206 of 2579 Old 04-03-2016, 05:43 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
Almost too much to hope/wish for...but I wouldn't mind being surprised! You and Tom would love four sub outs!
gene4ht is offline
post #207 of 2579 Old 04-04-2016, 12:27 PM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
FOR SHURE the new tx-rz1100 and tx-rz3100 have all news cans from video and hifi ,dont forget suppose receiver tx-nr1000 and tx-nr3000,why not comming ,because onkyo see something not correct,may be dts-x or something ,I think onkyo wait and make new receiver whit all the best componants inside this machine I am shure this news receivers tx-rz1100 and tx-rz3100 is the best receiver never make.will see.
marantz av 8805, 13 chanels, emotiva 2 xpa 5 gen1,1 emotiva xpa3 gen3, 7.4.6,4 speakers monitor 11 ,2 paradigm studio 100 v2,4 ceillings speakers ss82w sweet spot earthquake ,2 earthquake ecs-8.0,1 center Paradigm cc390,4 subs klipsch r-sw112 sw.antimod 8033 perfect bass kit paradigm, Buttkicker amplificateur lfe 1000 watts, , tv oled 65e6p,, room 12x25x7,bluray player oppo bdp 203,4coolers ac infinity s9 fan.
zimmo is offline
post #208 of 2579 Old 04-04-2016, 01:09 PM
m3incorp's Avatar
Quoted: 234 Post(s)
Liked: 111
It's coming. The question to ask is if they will have the DTS:X software by then.
m3incorp is offline
post #209 of 2579 Old 04-04-2016, 01:15 PM - Thread Starter
gene4ht's Avatar
Liked: 2657
+1
Hey zimmo! Who did you say you worked for???
gene4ht is offline
post #210 of 2579 Old 04-04-2016, 01:16 PM
wackid's Avatar
Quoted: 330 Post(s)
Liked: 75
I think it's going to be a fully loaded receiver.
Hope it will looks a little heavier/luxurious/bigger than the RZ900. But as the history tells us. I think it will.
Love the idea of having Google cast on the receiver. And the only brand having Deezer on board.
Some salesman says Onkyo only goes for the bells and whistles and doesn't goes for the sound quality.
Funny that those are always the salesman who doesn't sells Onkyo.😀
wackid is offline
TX-RZ1000
