Denon X3200W - Confused about Zone 2 w/Atmos on mains - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jdsmoothie
post #1 of 14 Old 01-17-2016, 11:52 PM - Thread Starter
vvume's Avatar
Liked: 0
I have configured my X3200W in 5.2.2 front height configuration. I have Zone 1 connected to a TV and Zone 2 connected to a projector with the AVR being common between the two (so it is not a two room setup; its simply a 2 display setup). However, when I turn on Zone 2, I am only able to get 5.2 on the mains and Atmos doesn't work. Zone 2 is marked as pre-outs. How do I get the audio to remain 5.2.2 on the main zone, while only sending the video to Zone 2?
vvume is offline
post #2 of 14 Old 01-21-2016, 05:42 AM
jdsmoothie's Avatar
Quoted: 22735 Post(s)
Liked: 12381
Unfortunately you have selected the wrong AVR model for your use case, as the X3200W Zone 2 HDMI monitor output is designed to send HDMI audio/video to a display in another room. Rather you need either the X2200W or the X4200W both of which have a 2nd main zone HDMI monitor output that is designed for a TV+PJ in the main zone. To make the X3200W work for you, if AMP ASSIGN = "Front Height" then you will need to use a 2CH external amp connected to the Zone 2 pre-outs to power another set of speakers for Zone 2 audio only.
For more information on the 2015 Denon AVR models, refer to posts 1-6 in the 2015 Denon AVR Owner's thread linked below ....
https://www.avsforum.com/forum/90-rec...l#post34728793
jdsmoothie is offline
post #3 of 14 Old 01-21-2016, 02:31 PM - Thread Starter
vvume's Avatar
Liked: 0
WoW! So a higher model number is that ~$400 more cannot do what its preceding model can do? The only reason I bought the X3200W was for the potential need for 4K60p up scaling. I guess I have to go back to using a HDMI switch.
Why is the X3200W much bigger in size compared to the X2200W? What does it have to require a much larger depth?
vvume is offline
post #4 of 14 Old 01-21-2016, 02:40 PM
jdsmoothie's Avatar
Liked: 12381
No reason to have the AVR do the upscaling, as the TV can likely do just as good of a job. The X3200W can however, overlay the GUI on 4k/60Hz video whereas the X2200W cannot. Not sure the reasoning, but the X3200W uses the same chassis as the X4200W.
post #5 of 14 Old 09-23-2016, 01:37 PM
CincyisHome's Avatar
Quoted: 64 Post(s)
Liked: 9
I have the same set up but only run 7.1 audio. Will this unit send video out to both main output and and zone 2 output (not simultaneously) with 7.1 audio in the same room? I hav a dual PJ setup.
CincyisHome is offline
post #6 of 14 Old 09-23-2016, 02:13 PM
jdsmoothie's Avatar
Liked: 12381
Similar setup to the OP ... so no, rather you will need to connect an HDMI splitter to the main zone monitor output to connect both the TV and PJ.
post #7 of 14 Old 09-23-2016, 03:54 PM
Quoted: 64 Post(s)
Liked: 9
Okay, but I hear that a 4K display and a 1080 display both running off the splitter will make the 4K PJ only display 1080 signal. It's like the source finds the lowest common denominator on the chain and only sends that.
post #8 of 14 Old 09-23-2016, 03:56 PM
Quoted: 64 Post(s)
Liked: 9
So zone 2 audio is 5.1 surround at the best?
post #9 of 14 Old 09-24-2016, 02:59 AM
jdsmoothie's Avatar
Liked: 12381
Yes, that is correct and would also be the case when passing the same source to both the main zone and Zone 2 monitor outputs which would be required if you wanted to get audio from the main zone speakers, otherwise, passing a signal only to the Zone 2 HDMI monitor output would pass both audio and video (ie. no audio to the main zone speakers).
No, rather it depends on the capability of the HDMI sync which is connected to the Zone 2 HDMI monitor output (could be full Atmos/DTS:X audio if another X3200W is connected to it).
post #10 of 14 Old 09-24-2016, 05:58 AM
Quoted: 64 Post(s)
Liked: 9
Both PJs point to the same screen, so I will always have one turned off when the other is running. However, based on what I'm hearing, The only way to get full passtrough video and audio to either PJ is to physically disconnect the HDMI from the PJ not being used or I go buy a more expensive receiver with 2 main outs. There is no splitter or switcher on the market that will do this for me? There must be plenty of AVS members in my situation.
post #11 of 14 Old 10-26-2016, 05:42 AM
Thee One's Avatar
OK, so I'm confused. Can I send HDMI output to two displays in the same room showing different content with this receiver? I'm fine with Zone 2 being just stereo, will probably just be headphone audio on it.
Is this possible?
Who will lead them? I cannot. I am a prophet. I bring chaos and unrest to the foolish and wicked.
I am no fit Prince for the Damned, and I am no fit shepherd for the souls of man. - Anatole the Mad
Thee One is offline
post #12 of 14 Old 10-26-2016, 09:23 AM
jdsmoothie's Avatar
Liked: 12381
Is this possible?
Yes, although Zone 2 can be multi-channel as well if connected to another multi-channel AVR, otherwise, if simply connected to another TV, then likely only stereo audio being passed to the TV with the headphones connected to the Zone 2 TV headphone jacks.
Thee One likes this.
post #13 of 14 Old 12-01-2017, 09:21 PM
xyzz's Avatar
Quoted: 21 Post(s)
sorry to bump an old thread but I am having the exact same problem and its not clear to me what the answer is.
My setup is 5.2.2 atmos, I have a TV and a PJ in the same zone (they will never be on at the same time). Can i get 5.2.2 audio for both my TV and my PJ using a denon 3200w? (or x3300h?)
xyzz is offline
post #14 of 14 Old 12-02-2017, 02:34 AM
jdsmoothie's Avatar
Liked: 12381
For the X3300W, best asked in the Owner's thread ---> https://www.avsforum.com/forum/90-rec...hread-faq.html
