Dts:x - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 2261Likes
post #3571 of 3946 Old 02-19-2018, 09:45 AM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 230
So far, I'm not very impressed with DTS:X, which just sounds like a blurred mess of sound vs. the amazing experience that is Atmos. I thought it was just the movies, but I bought the Independence Day 4K disc, which seems to be one of the best and came away unimpressed.
After reading a blog the other day, it seems that it may have a lot to do with DTS' overly flexible speaker placement options. When I play the DTS:X Object Emulator, there's very little going on with the overhead panning in 7.1.2 set up, which uses Atmos front speakers (due to ceiling placement issues). Is this a common experience when using Atmos speakers?
Preamp/Amps: Anthem AVM60, Emotiva XPA-2, XPA-5, A-300
Speakers: (7.1.2): Klipsch Reference Premiere / Power Sound Audio S3000i sub
Video: LG OLED65B7A, Oppo UDP-203, Roku Premiere+, Nvidia Shield TV
Room: GIK Acoustics treatments
MackGuyver is offline
post #3572 of 3946 Old 02-19-2018, 10:14 AM
T-Bone's Avatar
Quoted: 457 Post(s)
Liked: 269
I used that same clip, and heard a lot going on in my Atmos speakers. I have a 7.x 4... TF and TR.
I've always wondered... Since my receiver allows for many different 3D speaker configs, like FH/RH, FH/TR, TF/RH, and TF/TR, does my receiver do any of the steering? It does it just defer that to the built in algorithms from Atoms and DTS X?
-T
T-Bone is offline
post #3573 of 3946 Old 02-19-2018, 10:28 AM
Dan Hitchman's Avatar
Quoted: 4339 Post(s)
Liked: 2441
Actually, DTS: X has far less flexibility than Atmos. Part of your issue may be in using Atmos enabled bounce speakers. Your second best option apart from using ceiling speakers (ideal) is going with height speakers aimed toward the MLP. Either place them front wall/rear wall per Atmos angle requirements or side walls in the recommended overhead locations as per Atmos requirements.
Also, ID4 had a fairly tame immersive remix compared to the film's scene content. I was a bit disappointed.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
post #3574 of 3946 Old 02-19-2018, 10:46 AM
sdurani's Avatar
Quoted: 6816 Post(s)
Liked: 5760
Receiver manufacturers license technologies from Dolby and DTS. Those technologies determine which sounds go to which speakers. The only time a receiver is doing any of the steering is when proprietary processing (like Yamaha's Cinema DSP modes) is applied.
Sanjay
sdurani is offline
post #3575 of 3946 Old 02-19-2018, 10:49 AM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 230
Perhaps I'll try a few more movies, but the Atmos configuration is ideal, so I don't think I'll mess that up for the (thus far) small number of DTS:X releases.
post #3576 of 3946 Old 02-19-2018, 11:08 AM
Liked: 2441
What I recommended in terms of heights if you cannot do ceilings, would help Atmos tracks as well. Enabled speakers are faaaaaaaaaar down my list of viable alternatives to reproduce immersive mixes effectively.
mrtickleuk likes this.
post #3577 of 3946 Old 02-19-2018, 12:01 PM
galonzo's Avatar
Quoted: 1274 Post(s)
Liked: 1573
So far, I'm not very impressed with DTS:X, which just sounds like a blurred mess of sound vs. the amazing experience that is Atmos. I thought it was just the movies, but I bought the Independence Day 4K disc, which seems to be one of the best and came away unimpressed...
It's possible that you may have additional "Neural:X processing" added onto your DTS:X tracks; it's on by default on my Denon, and the setting is only available during playback of said format under Setup>>Audio>>Surround Parameters (see attached)
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #3578 of 3946 Old 02-19-2018, 12:23 PM
Erod's Avatar
Quoted: 1138 Post(s)
Liked: 683
If Atmos or DTS:X is on the disc and in play, the DSU and Neural X modes are disengaged altogether.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: Jamo 626k4 in-wall mains, Jamo 631k4 bi/dipole surrounds, DefTech DI6.5R heights
Erod is offline
post #3579 of 3946 Old 02-19-2018, 12:26 PM
galonzo's Avatar
Liked: 1573
If you look at the screenshot in my post (from the manual), this surround parameter setting is only available when the incoming signal is DTS:X or DTS: X MSTR (this is for D&M AVRs)
galonzo is offline
post #3580 of 3946 Old 02-19-2018, 12:42 PM
Erod's Avatar
Liked: 683
Correct, but Neural X is completely overridden if you are receiving a DTS:X signal. You can't play DTS:X and Neural X at the same time.
Just like DSU is overridden when Atmos is being received.
DSU and Neural X can be applied to any other Dolby or DTS signal otherwise and can be cross-matched (at least on my Anthem, it can).
Erod is offline
post #3581 of 3946 Old 02-19-2018, 12:46 PM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 230
I understand they are far from ideal...but I actually tried other speakers mounted as front heights and compared them and found the enabled speakers to work better in my room. I have a lot of acoustic treatment on the walls and none on the ceiling, so it actually works quite well.
post #3582 of 3946 Old 02-19-2018, 12:56 PM
galonzo's Avatar
Liked: 1573
From our D&M resident expert, @jdsmoothie , here's the post from two years ago regarding this setting that only applies to the object-based DTS:X tracks (otherwise, why wouldn't the setting be available when using the Neural:X upmixer on any other type of signal)?
galonzo is offline
post #3583 of 3946 Old 02-19-2018, 12:56 PM
SuperFist's Avatar
Quoted: 1236 Post(s)
Liked: 4650
Andrew Jones seems to think so, too... and I agree!
kokishin and MackGuyver like this.
Subwoofers: PSA S3000i x 2 | L+R Front: Onkyo SKF-200F | Center: Onkyo SKC-200C | L+R Surround: Onkyo SKM-200S | Atmos: Pioneer SP-T22A-LR | AVR: Yamaha RX-A660BL | HTPC: Lenovo Q190
SuperFist is offline
post #3584 of 3946 Old 02-19-2018, 01:04 PM
Erod's Avatar
Liked: 683
OK. Wow, what a horrifically stupid design decision that was. My Anthem completely disengages those modes when either Atmos or DTS:X is present.
That's like having to turn off the Dolby 5.1 mode in order for Dolby TrueHD to work.
galonzo and SuperFist like this.
Erod is offline
post #3585 of 3946 Old 02-19-2018, 01:12 PM
galonzo's Avatar
Liked: 1573
Right, now that we're on the same page, this whole discussion was to help @MackGuyver with what he was hearing ("sounds like a blurred mess of sound vs. the amazing experience that is Atmos"); this setting may be ON by default in his case (should now be the default setting for more recent firmware), thus up-mixing non-object-based audio to all of his speakers
galonzo is offline
post #3586 of 3946 Old 02-19-2018, 01:13 PM
Erod's Avatar
Liked: 683
Yuck, so he's basically getting two different tracks sent to the same speakers.
That needs to be fixed with a firmware update.
Erod is offline
post #3587 of 3946 Old 02-19-2018, 02:19 PM
sdurani's Avatar
Liked: 5760
When that parameter is On, the wides get a centre output extracted from the front & side channels. When that parameter is Off, wides get a copy of the side channels. Matrix scaling is part of decoding a DTS:X track. When the bitstream is unpacked, channels and objects are sent down separate paths. Channels are scaled (up or down) to your speaker layout while objects are mapped/rendered to that same layout. Once everything is conformed to your layout, the two paths are combined for output. The scaling is done using Neural:X. It can't be disengaged since it is built into the decoder. This is separate from the Neural:X mode that is applied to legacy (non-immersive) soundtracks.
Sanjay
sdurani is offline
post #3588 of 3946 Old 02-19-2018, 03:11 PM
SoundChex's Avatar
Quoted: 391 Post(s)
Liked: 327
Yes. When DTS:X is being decoded, it looks like Neural:X is described as "the DTS:X spatial remapping engine" in some product literaature.
However, the only reason I can see to disable Neural:X remapping during DTS:X decoding is if the input 7.-.2 channel spaceframe is part of a DTS:X AV stream (and NOT from a DTS:X BD) for which the 7.-.2 channel component of the DTS:X input stream is NOT in DTS:X BD "HOA|G-format"(?) but rather already remapped into the actual N.-.M speaker format emplaced on the AVR. One example of this might be an external BD player with on-board Auro3D decoding plus AuroMax style post processing directly optimized for the actual speaker layout, and delivering 'finished' AV content transcoded into DTS:X to the AVR.
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #3589 of 3946 Old 02-19-2018, 03:47 PM
sdurani's Avatar
Liked: 5760
It's basically parts of Neural:X that do 2 in 3 out and 2 in 4 out. When upmixing 5.1 to 7.1, the 2 surround channels are converted to 4 surround outputs. When upmixing a 2-channel signal, the two main inputs are converted to 3 front outputs. These parts of Neural:X are used during DTS:X decoding whenever the soundtrack lacks channels for any of the speakers in your layout (e.g., wides, top middles, etc).
I'll have to consult my SoundChex to English dictionary to parse the above text. Higher Order Ambisonics, Auro3D, Auro-Max; what, no mention of your fave Hamasaki 22.2 format?
Mashie Saldana likes this.
Sanjay
sdurani is offline
post #3590 of 3946 Old 02-19-2018, 07:28 PM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 230
I checked and it's just DTS:X, no Neural:X, so we're good there, and after running through the demos again, it seems that DTS is more focused on the ambient soundfield and less on the overhead pans and directionality. At least that's what I've gleaned from their demos, and it makes sense for the home format. I listened to those and several of my discs.
In that regard, I think DTS:X works quite well and Ex Machina and Atomic Blonde do a great job. For the Fate of the Furious and Independence Day, I didn't think it did as good of a job with pans and overhead effects as Atmos, though, but that may be more an effect of the sound mixes themselves vs. the tech.
Thanks for all of the input!
post #3591 of 3946 Old 02-20-2018, 06:59 AM
Quoted: 750 Post(s)
Liked: 114
@Nalleh @Manni01 @jpco @whitetrash66 @Scott Simonian Hey guys, i was reading through the beginning of this thread, which was in about 2016 from the beginning to about page 30, and tbh i really dont have the patience to continue reading to find the solution. There was a big issue at the time about the DTS:X firmware update, it messed up alot of things, such as you would have to switch the settings from TF and TR to FH and FR in order to get the dts:x soundtrack working properly, but that would mess up the dolby atmos tracks and they wouldn't sound nearly as good. Especially for the overhead sound. And also there was alot of sound leaking into other speakers, i think there was also center channel distortion e.t.c e.t.c There were many problems after the dts:x update. @fbrighi contacted denon on fb and they said they are investigating the issues. So since it's 2018 now i'm hoping it has all been figured out? Can someone please inform me what the solution ended up being? Did denon or someone release a firmware fix or something? Are all problems with dts:x and atmos fixed now on all recieverS? Do atmos and dts:x co-exist nicely now? Can we now use TF and TR for both atmos as well as dts:X?
And also something i was curious about, during that time there was talk about how it was not possible to use neutral x for a dolby soundtrack, and that it was not possible to use DSU for a dts soundtrack. Is that still the case? Or is there more freedom now in using whichever you want on any track?
sahil0909 is online now
post #3592 of 3946 Old 02-20-2018, 09:15 AM
noah katz's Avatar
Quoted: 1710 Post(s)
Liked: 605
I'd like to know the answer to this too; I have AV7702MkII.
7702 does it, not sure about other brands/models
Noah
noah katz is online now
post #3593 of 3946 Old 02-20-2018, 10:08 AM
T-Bone's Avatar
Quoted: 457 Post(s)
Liked: 269
Onkyo RZ920 (2017 model) allows mix and match of up-mixers.
Regarding TF and TR, I have my onkyo setup that way. I always assumed that my onkyo would do the right thing with DTS X if it allowed me to choose a TF/TR configuration.
-T
T-Bone is offline
post #3594 of 3946 Old 02-20-2018, 11:27 AM
noah katz's Avatar
Liked: 605
My memory is fuzzy, but I believe that was not the case, at least for Marantz.
Not sure if it was fixed by f/w update.
Anyone?
Noah
post #3595 of 3946 Old 02-20-2018, 11:35 AM
jdsmoothie's Avatar
Quoted: 21684 Post(s)
Liked: 11705
Yup. Note however, that using TF+TR is considered more ideal with Atmos while using FH+RH is more ideal with DTS:X. Making this speaker configuration change on the fly is now much easier (~1 min) with the more current 2016 and newer Denon/Marantz models that are able to use the Audyssey MultEQ Editor app or SAVE to a USB stick. Additionally, those using Auro 3D/AuroMatic will generally just use a FH+RH setup as this can be utilized by all three 3D codecs (Atmos/DTS:X, Auro 3D).
You'll note on p. 324 of the AV7702MKII Owner's manual it indicates as such for both Atmos and DTS:X.
fredxr2d2 likes this.
jdsmoothie is offline
post #3596 of 3946 Old 02-20-2018, 11:55 AM
fredxr2d2's Avatar
Quoted: 349 Post(s)
Liked: 223
jdsmoothie dives in with the great info, as always.
however, that is slightly overselling the speed of the app in uploading info to the AVR - the last time I tried it took nearly 20 minutes (AVR is hardwired and network is gigabit).
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas (circa 2012)
Currently watching on: JVC X790, 106" 0.8 Gain Screen, FireTV Stick 4K, PS4, Oppo 203, w/Marantz SR6011, 2 Outlaw M2200, Outlaw Model 5000, SVS Subs, Def Tech Speakers
fredxr2d2 is offline
post #3597 of 3946 Old 02-20-2018, 12:04 PM
jdsmoothie's Avatar
Liked: 11705
I'd suggest there is an issue with your network as it only takes about 1-2 minutes for me using either method with an X6300H (7.2.4) setup using the wireless connection to my router.
post #3598 of 3946 Old 02-20-2018, 12:30 PM
Quoted: 823 Post(s)
Liked: 644
I don't know about Denon, but Lyngdorf has a remapping option for DTS:
"When enabled -will decode TOP speakers as Height speakers, when in DTS."
With it on, it sounds pretty weird to have fairly loud L/R sounds coming out of the tops. I wonder if some receivers default to this option(or don't have the option to turn it off).
Might explain some negative user experiences with DTS:X/Neural:X.
Lyngdorf MP-50 | Yamaha MX-A5200 | Ascend Sierra Towers | Ascend Sierra Horizon | Ascend Sierra Lunas | Ascend HTM-200SE | SVS SB-13 x4
duckymomo is offline
post #3599 of 3946 Old 02-20-2018, 12:50 PM
fredxr2d2's Avatar
Quoted: 349 Post(s)
Liked: 223
I don't' want to like this post, so I will just say that maybe my GF was doing something else on the network at the same time...
I do remember it going faster when no one else was home.
Always helpful, though, and I appreciate that.
Tim S.
post #3600 of 3946 Old 02-20-2018, 01:12 PM
noah katz's Avatar
Liked: 605
Yes, I know it can be configured either way; the question is, with TF/TR configured, are there weird steering effects when using DTS.
Noah
