Dts:x - Page 69 - AVS Forum | Home Theater Discussions And Reviews
 2262Likes
post #2041 of 3952 Old 06-08-2016, 04:01 PM
vollans's Avatar
Quoted: 209 Post(s)
Liked: 150
Originally Posted by Movie78 View Post
DTS:X could be slow, but we have been waiting for years for you to purchase an immersive audio equipment.
And there those of us who have, and are still waiting for DTS/Denon to pull their fingers out and release the DTS:X firmware "later in 2015".
New Home Cinema: Sony VPL-VW760, Anthem MRX 1120, Q Acoustics 30x0 series speakers fronts, SVS Prime Elevation surround speakers, Proficient C791 Atmos, SVS PB2000 sub, Panasonic DMP-UB820, Apple TV, Pioneer CLD-D5V laserdisc, FetchTV, eeColor 3D LUT & Radiance XD-3D and ScreenTechnics CinemaSnap Hi Contrast 130" screen
vollans is offline
post #2042 of 3952 Old 06-08-2016, 06:13 PM
tom703's Avatar
Quoted: 83 Post(s)
Liked: 84
There are a lot of us still waiting!
vollans likes this.
Samsung UN55HU8550/SEK-3500U 4K TV, and UBD-K8500 BR Player. Receivers: Denon AVR-X4300H - 5.1.4., JBL Spearkers: Center Studio 235C, 2 - Studio 590 - L&R, ES250PBK Sub, 2 - ES90 Towers - L&R surround, 2 - Studio 230 - front height, 2 - ES20 - rear height. Video production: Resolve Studio 15, Windows 10 Pro, CPU i9 9940X, MSI X299 Carbon MB, EVGA RTX 2080, 64GB (4x16)Corsair Vengeance LPX DDR4 3200, GH5 camera, Zhiyun Crane 2 Gimble
tom703 is offline
post #2043 of 3952 Old 06-08-2016, 06:20 PM
petetherock's Avatar
Quoted: 1679 Post(s)
Liked: 879
Let's hope they don't scam us and only put the update into the 2016 models..
petetherock is offline
post #2044 of 3952 Old 06-08-2016, 06:23 PM
vollans's Avatar
Quoted: 209 Post(s)
Liked: 150
If they do, it'd actually be quite good; instant refund from my credit card for goods not being as ordered, and then I could buy a 2016 model of something that already has it.
vollans is offline
post #2045 of 3952 Old 06-08-2016, 07:40 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3561
Originally Posted by CBdicX View Post
Think i am the only one on the planet, but can DTS:X (Neural) do a down mix to 2.1.2 like Dolby Surround and Atmos will do ?
Hi CB,
I've read your earlier posts on this subject; it is very rare indeed a 2.1.2 setup and you did mention that it works with Dolby Surround up-mixer but not with DTS Neural:X - Manni had a reply that I thought was the best: https://www.avsforum.com/forum/90-rec...l#post44561289
You are the first person on the planet who is experimenting with a 2.1.2 immersive audio setup, from my very restricted readings on DTS:X and its upmixer in that type of setup with only two main channels (Stereo Left and Right), and two overheads (plus the sub).
Perhaps the definitive answer is with the DTS:X developer people? Did you consider emailing them, and then relate to us what you learn from them?
Cheers,
Bob
* BONUS: http://www.highdefdigest.com/news/sh...sneuralx/32382
NorthSky is offline
post #2046 of 3952 Old 06-08-2016, 09:30 PM
CBdicX's Avatar
Quoted: 1615 Post(s)
Liked: 383
Originally Posted by NorthSky View Post
Hi CB,
Cheers,
Bob
Hi Bob,
I am doing what Manni suggested, the incoming signal is Multi channel, it only needs to be down mixed to 2.1.2
He thinks i am using a stereo signal and then go to stereo + Heights, but its not up mixing, its down mixing.
Even his tip for 4.1.2 will not work, DTS seems also in "need" of a center, so the setup has a minimum of 5.1, then Heights will be addet.
Very stange that both Dolby an Auro can do this "stereo" immersive down mix trick of Multi Channel to 2.1.2, not DTS.
Even with 2.1.2 Dolby shows Dolby Atmos (with Atmos content) in the display
I mailed DTS 2 days ago, no relpy yet........
CBdicX is offline
post #2047 of 3952 Old 06-08-2016, 10:30 PM
Liked: 879
FYI
If you don't use a centre speaker, you can't activiate Neural X..
post #2048 of 3952 Old 06-09-2016, 12:33 AM
CBdicX's Avatar
Liked: 383
Originally Posted by petetherock View Post
FYI
Well, i can activate Neural X on a 2.1.2 setup (it is active) but it will only use the fronts and the sub, not the Heights.
So DTS never thought people want to use just the fronts, a sub or not, and 2 or 4 Heights ?
Ok, 99% will use immersive in a surround setup, but think this is a mistake of DTS.
Dolby and Auro did made this setup option possible in the software, and why not ?
If DTS will not, or can not, change this, i will stick with Dolby and let Dolby down mix a DTSX track what i will sent as Multi Channel PCM to 2.1.2
It would be nice to see DTS will change this.......
CBdicX is offline
post #2049 of 3952 Old 06-09-2016, 08:42 AM
skinnydoggy's Avatar
Quoted: 45 Post(s)
I'm thinking of getting a Marantz SR7010. I've got no room for rear sl sr, can I use front wides as well as four ceiling speakers? Basically, 5.1 plus 6 height speakers?
skinnydoggy is offline
post #2050 of 3952 Old 06-09-2016, 09:00 AM
jdsmoothie's Avatar
Quoted: 22040 Post(s)
Liked: 11953
Yes, however, Front Wide are floor speakers, so the configuration would still be 7.1.4.
jdsmoothie is offline
post #2051 of 3952 Old 06-09-2016, 09:02 AM
NorthSky's Avatar
Liked: 3561
Your receiver can operate twelve channels simultaneously: 7.1.4
If you substitute Rear surround speakers for Front Wides you still have seven main (floor) channels:
Then four overhead speakers can run simultaneously with those seven main 'floor' channels, and the sub (numb. 8), for still a total of twelve (7.1.4).
{You can install two more overheads to make it six above, but only four can be running; having six permits you to alternate between different setups.}
And not all surround modes, I believe, can run the front wides. The insider experts will tell you more about...
VideoGrabber likes this.
NorthSky is offline
post #2052 of 3952 Old 06-09-2016, 10:23 AM
Quoted: 45 Post(s)
Cool! Can they also be front heights? Like 2 monitor speakers above the floorstanders?
post #2053 of 3952 Old 06-09-2016, 10:52 AM
sdurani's Avatar
Quoted: 6972 Post(s)
Liked: 5953
Max number of heights is 2 pairs. The Wides cannot be used as a 3rd pair of heights.
Sanjay
sdurani is offline
post #2054 of 3952 Old 06-09-2016, 11:25 AM
NorthSky's Avatar
Liked: 3561
You have five main floor channels; no rear surrounds and no front wides.
You are asking now if in addition to the normal four overheads you can install a pair of front heights...like a la Audyssey DSX and Dolby Pro LogicIIz.
Me, if I was you, I would simply use a 5.1.4 Atmos setup (dts:X). And that way you won't need to use your additional separate stereo amp.
Yeah, keep your immersive audio experience simple...and effective.
And if you can move your couch away from your back wall...that would be swell. Then you can add that pair of rear surrounds and have the full 7.1.4 setup.
If not...like I said...5.1.4 is what I would do.
NorthSky is offline
post #2055 of 3952 Old 06-09-2016, 11:47 AM
Quoted: 45 Post(s)
Hmm, so would the Marantz SR6010 ($1150) be good enough for this setup? I have external amplification... Or am I better with the Denon X4200 ($1299)? 5.1.4 sounds ideal for a 14.5x14.5 room, right?
post #2056 of 3952 Old 06-09-2016, 12:35 PM
Quoted: 1008 Post(s)
Liked: 802
Dts:x
Both the Denon & Marantz are expandable but need external amp for 5.1.4. Your choice as these AVRs are very close and sisters in same company. I'd personally get the Marantz.
Fyi... I just purchased this week a refurb Yamaha A2050 for less $$ and it's a true 9 channel amp. Good luck
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 500NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #2057 of 3952 Old 06-09-2016, 12:51 PM
NorthSky's Avatar
Liked: 3561
Both the Marantz 6010 and Denon 4200 can do 5.1.4 (or 7.1.2) when adding a stereo amp, which you already have.
If you are certain that you won't need the 7.1.4 setup in a near future, yes either one above would do the job for you.
http://us.marantz.com/us/products/pa...oductId=SR6010
https://usa.denon.com/us/product/hom...vers/avrx4200w
* Your room's dimension (14.5 by 14.5); is fine for either setup...5.1.4 or 7.1.4
But you don't want to install the rear surrounds, because your couch is against the wall.
If you won't move your couch forward into your room, then 5.1.4 is good. ...Even 5.1.2 - but because you have the additional amplification experiment with four overheads.
NorthSky is offline
post #2058 of 3952 Old 06-09-2016, 08:51 PM
CBdicX's Avatar
Liked: 383
I can say from experians, Denon has more bottom power (bass) then Marantz.
Also like the Denon receivers better, as with Marantz you get the silly small porthole, or must leave the Display door fliped down :-(
Marantz sound is a bit layed back, Denon has more muscles......
Madmax67 likes this.
CBdicX is offline
post #2059 of 3952 Old 06-10-2016, 02:26 AM
gt9450's Avatar
Quoted: 28 Post(s)
The Denon 4200w is upgradeable to Auro3D. You can't with the Marantz 6010.
gt9450 is offline
post #2060 of 3952 Old 06-10-2016, 09:43 AM
Quoted: 45 Post(s)
I may be looking into the Yamaha A-2060 now... it actually eq's for axis, so sounds like it could be better than Audyssey for Atmos and DTS. Should be interesting, but it seems I have more research to do before jumping head first into a new endeavour
post #2061 of 3952 Old 06-12-2016, 02:53 PM
jgslima's Avatar
Quoted: 32 Post(s)
Thumbs up
Originally Posted by krichter1 View Post
FWIW and for those still with the D&M DTS-7/X "bug" on Sony BDP's (and changers), I found a workable fix…
I found a solution I tested last night to success (including DTS:X)! I bought a $60 HDMI 4x2 matrix switch off Amazon that had some EDID mgmt dip switches and found by forcing 1080p or 4K2K 7.1 output it seemingly bypasses the DTS bug on the Denon
krichter1, that's fantastic. Thank you.
Question: when using this solution, were you able to find a specific combination of the EDID switches that work well with all track sources? What I mean is: do you need to keep changing the EDID switches when you change from a DTS track to a DolbyTrueHD track?
Thank you
jgslima is offline
post #2062 of 3952 Old 06-12-2016, 09:04 PM
CBdicX's Avatar
Liked: 383
Never received an answer from DTS why it can not do a downmix to 2.x.2
Asked again but think this may not be very importent for them, to bad......
CBdicX is offline
post #2063 of 3952 Old 06-12-2016, 10:16 PM
NorthSky's Avatar
Liked: 3561
It's not very important for roughly 99.99999999999999999999999999999999999999999% of the dts:X customers.
It is mainly important for the rest, you. ...Who wants to set a 2.1.2 dts Neural:X immersive audio system setup? ...Only @CBdicX
* Did you try 3.1.2 dts Neural:X ?
deano86 likes this.
NorthSky is offline
post #2064 of 3952 Old 06-13-2016, 02:57 AM
CBdicX's Avatar
Liked: 383
Indeed, also 3.1.2 will not work for DTS !
It seems they "need" surround and center to work with Heights.
Also 4.1.2 is not working.
So DTS can not downmix to 2.x.2 where Dolby and Auro have no problems, strange desision from DTS and can not see why.......
CBdicX is offline
post #2065 of 3952 Old 06-13-2016, 05:48 AM
smurraybhm's Avatar
Quoted: 2296 Post(s)
Liked: 3132
Let's be fair, you are probably the only one trying to do this as Bob mentioned, most folks getting into immersive sound are adding speakers, not taking them away as you've done over the past year
Give DTS some time (maybe), we all know the issues with getting DTS:X rolled out and a few manufacturers have still not made it available and its summer (norther hemisphere).
There is no perfect display, quit looking for faults and enjoy
LG OLED 65” B7 and 55” C8
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 and other stuff
smurraybhm is offline
post #2066 of 3952 Old 06-13-2016, 05:55 AM
CBdicX's Avatar
Liked: 383
Fair enough, i hope they will reply.
Dolby and Auro seem to see that also 2.x.2 would be an option for some
CBdicX is offline
post #2067 of 3952 Old 06-13-2016, 07:53 AM
bigdogaxis's Avatar
Quoted: 134 Post(s)
Liked: 97
Maybe there is a way for you to apply DTS:X headphone technology to your setup.
My equipment: JVC RS-55, SI Performance 120" 1.3 gain, OPPO BDP-105, ANTHEM MRX-1120, QNAP 469L NAS, ROKU 4.
MartinLogan speakers and subs. M/ASlim5 Rack, CalMAN 5 Enthusiast/C6 meter.
bigdogaxis is offline
post #2068 of 3952 Old 06-13-2016, 05:59 PM
krichter1's Avatar
Quoted: 2096 Post(s)
Liked: 2365
Thank you
Most welcome.
Been solid so far although I did come across one issue (fix one thing; break another), in that this switch apparently doesn't support Sony's x.v.color discs, so that's a bit of a bummer (although I can still play as a normal BD; just not with the expanded ycc colorspace which my JVC PJ supports). When I want to play a Sony "SuperBlu" disc I have to go direct from my Sony changer #1 (where all my x.v.color discs are loaded), but then if it also has a DTS track I'm pooched.
The EDID only needs to be setup once (haven't touched it since setup day), and #3 works best…
EDID Selector: Select HDMI output signal format via EDID Selector.
Number / EDID Dip Selector / Description
1 0000 1080P,Stereo Audio 2.0
2 0001 1080P,Dolby/DTS 5.1
3 0010 1080P,HD Audio 7.1
4 0011 1080I,Stereo Audio 2.0
5 0100 1080I,Dolby/DTS 5.1
6 0101 1080I,HD Audio 7.1
7 0110 3D,Stereo Audio 2.0
8 0111 3D,Dolby/DTS 5.1
9 1000 3D,HD Audio 7.1
10 1001 4K2K,Stereo Audio 2.0
11 1010 4K2K,Dolby/DTS 5.1
12 1011 4K2K,HD Audio 7.1
13 1100 Reserve
14 1101 Reserve
15 1110 Reserve
16 1111 Auto mode(default)
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #2069 of 3952 Old 06-13-2016, 10:39 PM
CBdicX's Avatar
Liked: 383
Hi, can you please explain a but more what you exact mean ?
CBdicX is offline
post #2070 of 3952 Old 06-14-2016, 06:06 AM
smurraybhm's Avatar
Liked: 3132
He's messing with you I believe due to your speaker limit - thus why not try just using headphones. Logitech has some headphones that support the tech right now, not aware of any others jumping on wagon.
http://dts.com/headphonex?gclid=CLnm...FdgGgQod8RoC9w
