Running Audyssey with denon x3200w with 2.subwoofers. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jdsmoothie
post #1 of 7 Old 03-12-2016, 11:13 AM - Thread Starter
cutthatcity's Avatar
Quoted: 291 Post(s)
Liked: 49
I know this model cannot have the subwoofers "speak" to each other. I remember reading somewhere you're better off running audyssey using a y splitter instead of the 2 sub outs. Anyone know why this may be? Also do you have advice for setting up the subs properly without having audyssey x32? Thanks!
cutthatcity is offline
post #2 of 7 Old 03-12-2016, 11:14 AM
torii's Avatar
Quoted: 3625 Post(s)
Liked: 2059
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #3 of 7 Old 03-12-2016, 11:52 AM
jdsmoothie's Avatar
Quoted: 22748 Post(s)
Liked: 12392
The dual sub feature you are referring to is not XT32 but rather Sub EQ HT which independently sets the level and delay of each sub before XT32 EQ's them together. With the X3200W you're best served placing identical subs equidistant from the main listening position.
jdsmoothie is offline
post #4 of 7 Old 03-12-2016, 12:10 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
Are there any systems with Audyssey XT32 which do not have the Sub EQ? I suspect many people lump them together, perhaps suggested from the vendors labeling the groups of features as "Audyssey Platinum" vs "Gold", "Silver", etc.
Anyway, @cutthatcity , I believe your X3200 has an internal Y splitter, so using an external one isn't likely to help.
But go right ahead if you want to. Using an external Y splitter is not going to hurt the signal quality, at least so long as it works properly. The amp should have a fairly low output impedance and be fine to drive many high impedance inputs for dual or even quad subs, which could be done using two external Y splitters.
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is offline
post #5 of 7 Old 03-12-2016, 01:06 PM
jdsmoothie's Avatar
Liked: 12392
Yup. Onkyo 818 and 929.
cswiger likes this.
post #6 of 7 Old 03-12-2016, 04:12 PM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
Are your subs identical or different?
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990 -- HD990 -- Klipsch RF-7ii's
dmb12679 is offline
post #7 of 7 Old 03-13-2016, 04:54 AM - Thread Starter
Quoted: 291 Post(s)
Liked: 49
Hi! Identical pb2000
