Onkyo TX-NR656 Owner's Thread - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 719Likes
post #841 of 1054 Old 10-18-2018, 03:10 AM
provels's Avatar
Quoted: 32 Post(s)
Noticed new firmware on the US D/L page today https://www.onkyousa.com/Downloads/firmware.php
(10-11-2018)
We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver.
This update may be installed via USB or Network. We recommend USB installation.
TX-NR555, TX-NR656, TX-NR757, TX-RZ610, TX-RZ710, TX-RZ810 & HT-R695 (Current Version 2139-8050-7090-0010)
The 10/11/2018 update will address the following and includes previous updates:
1. Enhanced security.
Depending on the Firmware version, update will be needed 2 times.
2. Minor bug fixes and improvements stability.
Happy Flashing!
__________________________________________
"How do I know what you hear?" - Firesign Theatre
provels is offline
post #842 of 1054 Old 10-18-2018, 04:32 AM
JRock3x8's Avatar
Quoted: 1853 Post(s)
Liked: 618
Based on all the horror stories that you guys tell I will never update my receiver. Ever.
JRock3x8 is offline
post #843 of 1054 Old 10-18-2018, 06:38 AM
UHD Addict
aaronwt's Avatar
Quoted: 9295 Post(s)
Liked: 5980
I hadl an update last week and all is well. I guess it was the one just posted.
Sent from my Nexus 7(16GB) using Tapatalk
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #844 of 1054 Old 10-18-2018, 11:01 AM
Quoted: 93 Post(s)
Originally Posted by JRock3x8 View Post
Also plex won’t play more than 5.1 on Xbox
I don't have the speakers to get to that dilemma.
Sent from my Moto Z (2) using Tapatalk
noobtv likes this.
Ortizer is offline
post #845 of 1054 Old 10-18-2018, 05:08 PM
noobtv's Avatar
Quoted: 593 Post(s)
Liked: 304
Definitely.
Do not buy an xbox one x For anything other than games... I have suffered so Much buyers remorse over that stupid thing over the last 2 years
What problems have you been having, other than the 5.1 limit?
Living Room: Kef Q900/Q600c/Q100, SVS SB2000, Denon AVR-X3500H.
PC Setup: Infinity R152, Sunfire XTEQ8, DIY 3e-Audio TPA3255 amp.
noobtv is offline
post #846 of 1054 Old 10-18-2018, 05:21 PM
JRock3x8's Avatar
Liked: 618
Originally Posted by noobtv View Post
Definitely.
Wont stream 4k
JRock3x8 is offline
post #847 of 1054 Old 10-18-2018, 05:33 PM
UHD Addict
aaronwt's Avatar
Liked: 5980
Wont stream 4k
From which app? I know it works for Netflix. SInce I used it for a while to watch Netflix UHD/HDR content with Atmos audio.
Which sounded good with the Onkyo receiver.
aaronwt is offline
post #848 of 1054 Old 10-19-2018, 05:26 AM
JRock3x8's Avatar
Liked: 618
I am only ever interested in watching rips of discs. Unless there is no other way to watch the content I will never use Netflix or the like.
JRock3x8 is offline
post #849 of 1054 Old 10-19-2018, 07:33 AM
Quoted: 93 Post(s)
Is that an Xbox limit or plex limit? I noticed in my server settings on the shield that it won't let you go above 5.2, at least for h264
Ortizer is offline
post #850 of 1054 Old 10-19-2018, 11:13 AM
UHD Addict
aaronwt's Avatar
Liked: 5980
I use a couple of Shield TVs to stream my UHD BD MKV 1:1 rips. It will bitstream the advanced audio codecs. Although the Shield TV is limited to HDR10. Plus you can't have DV in an MKV anyway.
aaronwt is offline
post #851 of 1054 Old 10-19-2018, 04:25 PM
JRock3x8's Avatar
Liked: 618
Xbox. Plex on shield plays 7.1 and up
JRock3x8 is offline
post #852 of 1054 Old 10-19-2018, 04:38 PM
Quoted: 93 Post(s)
Interesting. Guess the setting is only for that container then.
Ortizer is offline
post #853 of 1054 Old 10-19-2018, 04:46 PM
drew64's Avatar
Quoted: 90 Post(s)
Quick question. Is there a way to use Bluetooth headphones with the 656 using a Bluetooth transmitter/receiver plugged in. I was told by onkyo you can’t pair headphones with the receiver as is
drew64 is offline
post #854 of 1054 Old 11-02-2018, 08:51 AM
Quoted: 12 Post(s)
Liked: 0
parts
Originally Posted by khidbz View Post
Just by way of update,,,,,,Onkyo ask that I send in the receiver to a service center.
So I never sent in the receiver....I'm not even in the US and so it would not be cost worthy to mail it and have it mailed back...that would be the price of a new receiver. I had an independent technician check it out and he thinks it's the hdmi board. Now I have two receivers with hdmi board problems....the 609 and the 656. Can anyone advise me where I can buy hdmi board for these units? Cheers.
khidbz is offline
post #855 of 1054 Old 11-02-2018, 08:54 AM
Quoted: 12 Post(s)
Liked: 0
Never tried it....but as is the receiver just receives a bluetooth signal..it does not transmit. I would suspect the bluetooth extender you are talking about plugs into a usb port, so just try that and see
khidbz is offline
post #856 of 1054 Old 11-03-2018, 05:54 AM
Lord Android's Avatar
I just noticed yesturday that when I'm playing games on the XB 1 X the audio out isn't Dolby Digital like it used to. I know it because the little red dolby logo isn't there. In the console audio settings I have it set to uncompressed 5.1 I'd like to know if there is a way to get back to dolby digital out like I had it before. Not sure if the last update that was pushed to the Xbox or the update that was pushed to the receiver changed this. But prior i was able to play in DD. Any one out there? Thanks in advance
Sent from my SM-N960U using Tapatalk
"Your either all in or Your all out...!"
Lord Android is offline
post #857 of 1054 Old 11-03-2018, 06:01 AM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 846
I had to set mine to bitstream. Otherwise, it just played in Multichannel PCM
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is offline
post #858 of 1054 Old 11-03-2018, 06:04 AM
Thats what's going on now its playing the audio in PCM and I'd like to change that
post #859 of 1054 Old 11-03-2018, 06:15 AM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 846
Try setting to Bitstream and see what happens, and set the AVR to match the source audio format (DD/DD, DTS/DTS, Etc.) instead of setting it for Direct.
d-rail34 is offline
post #860 of 1054 Old 11-03-2018, 06:17 AM
Let me try that
post #861 of 1054 Old 11-03-2018, 06:19 AM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 846
Let me try that
You responded before I finished editing my previous post. Lol
SO...set the AVR to match the source audio format (DD/DD, DTS/DTS, Etc.) instead of setting it for Direct if you haven't already.
d-rail34 is offline
post #862 of 1054 Old 11-03-2018, 06:23 AM
I believe I have those audio formats turned on when I navigate to game input in the AVR settings
d-rail34 likes this.
post #863 of 1054 Old 11-03-2018, 06:31 AM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 846
I use them for all inputs. Sometimes Direct seems to have a different response. Or, it could all be placibo effect. Lol
d-rail34 is offline
post #864 of 1054 Old 11-03-2018, 06:37 AM
Lol I'll look
post #865 of 1054 Old 11-04-2018, 07:50 AM
Let me try that
Thank you sir...! That worked Dolby Digital is working perfectly! My gaming experience is complete
post #866 of 1054 Old 11-12-2018, 04:51 PM
JRock3x8's Avatar
Liked: 618
Hey what do you guys use for listening to music? I have 7 speakers and two subs in my theater and most of the time the back 4 speakers are off.
Need to fix that.
Any tips on programming a listening mode into my harmony remote?
JRock3x8 is offline
post #867 of 1054 Old 11-13-2018, 11:45 AM
Pennhaven's Avatar
Quoted: 70 Post(s)
Liked: 64
Need to fix that.
Do you have your receiver configured for 7.2 surround or Dolby Atmos 5.2.2?
In either case Dolby Surround or DTS Neural:X should play two channel digital music source to all speakers.
How good the surround effect sounds will vary depending on the recording. So you might experiment.
My RZ710, which is a cousin to the NR656, is set up for Atmos, and I find generally the best mode for 2 channel music source is THX Music, even though it does not use the two Atmos height channels. I think THX is exclusive to the RZ series though.
I have a Harmony Hub but generally use the Onkyo Android tablet app or hardware remote to change listening modes. Never bothered to configure the hub for this. Not really a big fan of it in some respects.
Pennhaven is online now
post #868 of 1054 Old 11-13-2018, 03:53 PM
UHD Addict
aaronwt's Avatar
Liked: 5980
Yes. The Onkyo is not THX certified so it doesn't have the THX sound fields.
aaronwt is offline
post #869 of 1054 Old 11-13-2018, 06:19 PM
noobtv's Avatar
Quoted: 593 Post(s)
Liked: 304
I prefer Dolby Surround for two channel music listening.
aaronwt and evena like this.
noobtv is offline
post #870 of 1054 Old 11-14-2018, 04:12 PM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 846
Just saw your reply. Glad it worked out!! I know it made a huge difference for my setup.
BTW...what type of setup are you running (i.e., 5.1, 7.1, Atmos)?
d-rail34 is offline
7.2 to 9.2 , apple tv , atmos , cox dvr , external amp , external amplifier , Onkyo , onkyo tx-656 , TX-NR656
