The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 194 - AVS Forum | Home Theater Discussions And Reviews
 281229Likes
post #5791 of 17254 Old 04-11-2017, 12:44 PM
Liked: 0
Can a Denon x1300w drive my speakers?
Hello.
I have a Marantz sr7005 that is starting to die, sometimes the audio isn't working, or video, Or loud static noises from a random speaker. so I'm looking to get a new one.
The recent Audyssey app is very interesting for me and I would love to have it.
My speakers are: b&w pm1, (front A) jamo cornet 80ii (front b) b&w htm2 and b&w 685 with A sub by definitive pro 800.
I also have a receiver by advent model 300
My budget is $500 for a new receiver and my options are:
Denon x1300w (new)
Denon x2300w (referb)
Denon x3200w (no app, referb)
Marantz sr 5010 (no app referb)
Now, the questions: the pm1 sensitivity is 84dB, so can the x1300 drive them well enough to medium high volume?
Will the x2300 be any better? only as far as sound goes (an extra 15W)
Is it worth it to "lose" the app for the x3200? as far as sound goes for an extra 30W and xt32
The marantz looks like the x3200 so same question here.
Thank you!!
ngold is offline
post #5792 of 17254 Old 04-11-2017, 01:11 PM - Thread Starter
jdsmoothie's Avatar
Quoted: 22591 Post(s)
Liked: 12294
Hello.
Denon x1300w (new)
Thank you!!
The answer hasn't changed from your other post ....
If you like to tweak the EQ curve, purchasing a 2016 model is in your best interest in order to use the new Audyssey MultEQ Editor app. None of the models you list use XT32, rather the 2016 X3300W is the lowest model that uses XT32. Any of the models listed would likely allow you to achieve med high volume levels.
jdsmoothie is offline
post #5793 of 17254 Old 04-11-2017, 02:04 PM
Liked: 0
I know it's the same, I just put the question in the right place. (as you suggested..)
Do you think I should buy the x2300? For an extra $40 I get 4k upscale and 15w more power (that I probably don't need) but Lose 2 years of warranty (only 1 year in a refurb.)
Or should I forget about the app and go with the x3200 for more power?
ngold is offline
post #5794 of 17254 Old 04-11-2017, 03:09 PM
adrift02's Avatar
Quoted: 46 Post(s)
So I read that it's recommended to NOT use the sub level adjust (issue 4 / 4), but just wanted to make sure I understand the reason. It's not recommended because turning it on sets the level to 0, negating whatever Audyssey set (in my case -11.5), right? However, if I know that it does this, can I still use the feature correctly? For example, if I turn SLA on and set it to -11.5, that's the same as not having it on, right? The reason I ask, is that in my case it's easier to have a quick toggle for changing up the sub level -- I use a computer to play music AND watch movies, so I can't set level adjustments per device.
Thanks for the info!
Panasonic TC-P60VT60 plasma
Denon x3300 receiver w/ B&K EX442 for mains
Polk RTi A7 mains
Polk CSI A6 center
Dual SVS PC-2000 subs
adrift02 is offline
post #5795 of 17254 Old 04-11-2017, 03:28 PM
prowler5150's Avatar
No work around, rather the X3300W is the lowest model that has this feature.
I just purchased an X2300 also in preparation for getting a 4k TV. What are the ramifications of not supporting the GUI in 4k? The receiver I'm replacing only shows a GUI when I get into the menus, not in normal use (when I switch sources, change volume, etc.). Is this one different? Should someone with a 4k TV not get anything below the X3300?
prowler5150 is offline
post #5796 of 17254 Old 04-11-2017, 05:43 PM
Quoted: 16 Post(s)
Liked: 8
Anytime you bring up the osd while watching 4k content it goes goofy and switches to a lower resolution. Then the entire background is black with the osd displayed. It is rather annoying. But luckily the Android app allows you to change most of the settings.
Sent from my SAMSUNG-SM-N920A using Tapatalk
drivinfast247 is offline
post #5797 of 17254 Old 04-11-2017, 05:59 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12294
Simply depends on whether you want to see the GUI overlayed or not. If not, no reason not to get a lower level model.
post #5798 of 17254 Old 04-11-2017, 06:00 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12294
Correct.
adrift02 likes this.
post #5799 of 17254 Old 04-11-2017, 06:02 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12294
Only you can decide what features/inputs/outputs you require.
post #5800 of 17254 Old 04-11-2017, 07:04 PM
HDTVDoug's Avatar
Originally Posted by afrogt View Post
Most like a problem with the firmware on your 4K genie. I have the non 4K genie and don't have the problem at all. I have both a the x2300 and x3300 and neither has issues with DirecTV.
Well, could be I suppose. @disneyfun1 , @Milenkod , Do you guys have the 4K genie?
HDTVDoug is offline
post #5801 of 17254 Old 04-11-2017, 09:20 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
My 6300 is downloading a new FW. Download; update failed. Now downloading again...
EDIT
Now updating
EDIT 2
60% 4 min
blairy is offline
post #5802 of 17254 Old 04-11-2017, 09:34 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
Well that's completed...not sure what it did. Now there's another update for saving settings to USB. Installing as I type....
EDIT
And I now have the Save and Load to/from USB function
FW now shows as:
Version: 0330-2926-2391-7493
-DTS Version 3.90.35.00
muzz and rec head like this.
blairy is offline
post #5803 of 17254 Old 04-11-2017, 10:02 PM
JJ7
JJ7's Avatar
Quoted: 170 Post(s)
Liked: 104
EDIT
Now updating
EDIT 2
60% 4 min
Trying the same update for X4300H now...
muzz likes this.
JJ7 is online now
post #5804 of 17254 Old 04-11-2017, 10:18 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
Saved a config file to USB. Once completed it simply goes back to the menu. No message advising successfully saved and it's safe to remove USB blah blah blah (unless it flashed up quickly and I missed it).
blairy is offline
post #5805 of 17254 Old 04-11-2017, 11:25 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
Now reset AVR, reset wifi connection, reloaded config. Worked as expected and provided message advising config reloaded successfully.
Have been keen to do reset for some months as I have had 'pops' whenever pausing, restarting video and changing inputs. These seem to all be gone now.
rec head likes this.
blairy is offline
post #5806 of 17254 Old 04-11-2017, 11:49 PM
jconjason's Avatar
Quoted: 1277 Post(s)
Liked: 2118
EDIT
FW now shows as:
Glad it's finally here! Been waiting to save my config.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #5807 of 17254 Old 04-12-2017, 12:19 AM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 812
Originally Posted by Shawn Barrere View Post
second, I currently have both the avr and my pc in a built in cabinet next to my fireplace where the tv is mounted.
So far, LOVING this avr....and i will admit its the first one ive ever owned. Always made due with computer sound systems till now, logitech z680, klipsch promedia, which i always thought were great...till i got this and the kefs. Thanks for any help.
My 6300H is also hooked up to a PC via HDMI. The ability to drop & drag anything from web pages to movies or YouTube vids cannot be underestimated. It is an older laptop, but oddly it appears I can now play Youtube 4k videos and Atmos whereas before the Windows 10 Pro creators update version 1703 I could not. It is somewhat wonky until I got over the learning curve, but shockingly sounds & looks stunning! A higher sample rate is better than a low sample rate AFAIK, but itunes & Windows must match otherwise it's moot. 24 bit & 192000 Hz works fine & is the top sound choice available.
I have found some settings that can improve music though my 6300H in Windows & itunes sound settings. The default settings do not do sound justice. Once tweaked the quality improves dramatically, as you can see in the pics I took the time to post below. It is very important you use the itunes EQ as well to your taste. Doing so makes your music go from so so to oh my oh my. In itunes you can choose many different EQ or just do it manually to taste.
Regarding the "hum" I was getting it appears to be lessened to where I do not notice it since the Creators update that previously I easily noticed from the PC. After uploading the pics I seen the X32 was off so I turned it back on. Am now doing the 6300H update to save settings via USB which I would not of known about without my AVS buds so ty for that y'all.
ID:	2079961   Click image for larger version
ID:	2079969   Click image for larger version
ID:	2079977   Click image for larger version
ID:	2079985   Click image for larger version
ID:	2080009   Click image for larger version
If you always do what you always did, you'll always get what you always got.
timc1475 is offline
post #5808 of 17254 Old 04-12-2017, 05:27 AM
rec head's Avatar
Quoted: 296 Post(s)
Liked: 268
For those of you intrepid firmware soldiers that just did the update and save/load: How long did it take? Just curious if it is faster than the old way. It sounds like it is working well which is great to hear.
rec head is offline
post #5809 of 17254 Old 04-12-2017, 06:05 AM
Spinal Tap's Avatar
Quoted: 47 Post(s)
Not possible on the X3300W, rather only only on the X4300H and X6300H.
So my X3300 asked to update and I went ahead and updated using WIFI. Is this the normal way to update these AVR's.
I read about issues with new firmware?
What kind of changes did this make and also, do I have to do a reset to activate the new update?
Spinal Tap is offline
post #5810 of 17254 Old 04-12-2017, 07:37 AM
Milenkod's Avatar
Quoted: 34 Post(s)
its the firmware on something....it started sometime after the firmware update on the X3300...I suppose there was one for the x2300 too. however, there has since been a D* update too. So one of them is the culprit. I suspect its the Genie since I don't have this issue with other sources.
Milenkod is offline
post #5811 of 17254 Old 04-12-2017, 07:42 AM
Quoted: 12 Post(s)
Liked: 4
How large is the saved config file?
bsbd is offline
post #5812 of 17254 Old 04-12-2017, 08:14 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12294
The best way to update in order of reliability would be: (1) USB, (2) wired ethernet, (3) wireless.
post #5813 of 17254 Old 04-12-2017, 08:37 AM
Quoted: 275 Post(s)
Liked: 192
I have had my X6300H on all morning, about 4 hours now, with no indication that there is a firmware update available. After reading the previous comments, I had the receiver check for a new firmware. Came back telling me my unit is up to date. Current firmware version on my AVR is 9330-5885-1380-2483 and DTS version is 3.90.35.00. Are both of these the most up to date versions available for the 6300?
Also, I went to the Denon website to see about downloading myself but could not find the correct page. The only download area I could find was for manuals, not firmware.
What the heck am I doing wrong?
Spoiler!
RetiredandLovingIt is online now
post #5814 of 17254 Old 04-12-2017, 08:53 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12294
I have updated post 6 with the firmware change log items for the recent firmware update released to the X6300H and X4300H models.
timc1475, Terminader, bmcn and 1 others like this.
post #5815 of 17254 Old 04-12-2017, 09:01 AM
kematt's Avatar
Quoted: 118 Post(s)
Liked: 48
Originally Posted by FootSoldier View Post
Because of where my AVR sets, the Audessey microphone won't reach the farther test locations in the room. I'd like to find an "extension" cable for it.
Would this work?
https://www.monoprice.com/product?c_...seq=1&format=2
I may be wrong but I've read all remaining 7 mic positions should be within ~2ft (18"?) of position 1
kematt is offline
post #5816 of 17254 Old 04-12-2017, 09:13 AM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 812
I went to page 6 and did not see the change logs.
Then I went to "post" #6...lol
timc1475 is offline
post #5817 of 17254 Old 04-12-2017, 09:17 AM
kematt's Avatar
Quoted: 118 Post(s)
Liked: 48
'Configuration Saved' flashed briefly when complete
kematt is offline
post #5818 of 17254 Old 04-12-2017, 09:19 AM
kematt's Avatar
Quoted: 118 Post(s)
Liked: 48
890kb
kematt is offline
post #5819 of 17254 Old 04-12-2017, 09:24 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12294
This is correct. When running Audyssey, you really only want to focus on the main listening position which means the 1st mic position is where "your" head would be (as long as it's at least a few inches higher than the back of the couch otherwise raise the mic a few inches so it is a few inches higher than the back of the couch) and then the remaining mic positions would be randomly placed no more than 1-2' from that 1st mic position.
post #5820 of 17254 Old 04-12-2017, 09:24 AM
Quoted: 12 Post(s)
Liked: 4
Even though I have my X6300H configured to auto-update, I saw the reports of a new release here and checked my firmware version number -- it was the same as yours, meaning it hadn't updated on it's own yet. A forced check came back saying that new firmware was available. I updated and now have the same version as blairy reported earlier in this thread (0330-2926-2391-7493). The DTS Version doesn't change. You should probably just keep trying every so often.
RetiredandLovingIt likes this.
bsbd is offline
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
