The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 282 - AVS Forum | Home Theater Discussions And Reviews
 281473Likes
post #8431 of 17922 Old 08-07-2017, 10:53 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 24235 Post(s)
Liked: 13466
Originally Posted by HYPURR DBL NKL View Post
What volume scale is most everyone using on the X3300W? Relative or Absolute. I would assume Relative, as it would us "0" as the reference volume point, correct?
Most owners with a wife/children also accessing the setup likely prefer the "Absolute" scale (1-99) as it just makes more sense to them; however, if you are the primary user, you are more likely to use the "Relative" scale.
HYPURR DBL NKL likes this.
jdsmoothie is offline
post #8432 of 17922 Old 08-07-2017, 10:56 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13466
Originally Posted by MillerTimeISU View Post
Just picked up the X4300H and have a question about the PRE OUT connectors in the picture below. I am setting up a 7.2.4 system for the first time and looking to buy Monolith 7x200 to use with it. Based on the PRE OUT diagram I believe I can use this to connect my LCR, surrounds and rear sounds to the amp and RCA that to the X4300H. Then use the X4300H to power the (4) Atmos speakers? Is this correct and available in the settings?
Also this being a 2016 X4300H what issues am I going to run into video wise if I plan on using a UHD60 4k projector or LG OLED tv to send signal too?
1. You need only identify the pre-outs being used to expand the AVR from 9CH --> 11CH which for your use case are the FRONT L/R.
Assign Mode: 11.1
Floor
- Layout
: 5ch & SB
Height
– Height Sp
: 4ch
- Layout: Top Front + Top Rear (or whatever HT1 + HT2 configuration you are using)
- Pre-out: Front
2. Minimize issues by purchasing "Premium" certified HDMI cables (ie. 4k/18gbps).
Madmax67 likes this.
post #8433 of 17922 Old 08-07-2017, 11:22 AM
HYPURR DBL NKL's Avatar
Quoted: 397 Post(s)
Liked: 466
Thanks jdsmoothie, yes I am the only user, my wife doesn't use it.
HYPURR DBL NKL is offline
post #8434 of 17922 Old 08-07-2017, 11:49 AM
bigapp's Avatar
Quoted: 75 Post(s)
Liked: 75
It will pass 4k and HDR10 but will not DV until an update, late 2017 or early 2018 is their target for DV.
MillerTimeISU likes this.
LG 65" C7 OLED. Oppo 203. Denon 4300. Klipsch RP280af, 260f, 440c, 140AF. HSU 15-mk2. Layer 3 TV, Shield and a Blue Tick Healer
bigapp is offline
post #8435 of 17922 Old 08-07-2017, 12:08 PM
rsonnens's Avatar
Quoted: 897 Post(s)
Liked: 709
Out of curiosity what is the ratio of male to female customer you sell to?
rsonnens is offline
post #8436 of 17922 Old 08-07-2017, 12:12 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13466
99% male/1% female, although normally just a wife buying the item for her husband
post #8437 of 17922 Old 08-07-2017, 12:38 PM
confinoj's Avatar
Quoted: 1426 Post(s)
Liked: 1312
That darn Y chromosome constantly putting a voice in our heads saying "you need more/better gadgets and electronics".
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2 | miniDSP 2x4 HD
confinoj is online now
post #8438 of 17922 Old 08-07-2017, 06:57 PM
Quoted: 189 Post(s)
Liked: 38
How hot is too hot for these things? I went to switch one of the inputs in the back and noticed the unit was pretty hot to the touch. I have it set in a slot in my entertainment center that isn't open in the back other then the hole for all of the HDMI and power cords. Should I worry about ventilation?
Jbran23 is offline
post #8439 of 17922 Old 08-07-2017, 07:56 PM
mecmec's Avatar
Quoted: 535 Post(s)
Liked: 220
Yes, you SHOULD worry. Buy a squirrel cage fan set and sleep easier at night knowing you aren't killing your receiver early...
mecmec is offline
post #8440 of 17922 Old 08-07-2017, 08:14 PM
jconjason's Avatar
Quoted: 1419 Post(s)
Liked: 2349
Yes, you should. That's not enough ventilation. Check out ACInfinity for fans that you could use. I cut out enough space for my fan to fit into my floating shelf.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #8441 of 17922 Old 08-08-2017, 01:13 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13466
Suggest you invest in an IR temp gun to know the exact temp; however, if you can't leave your hand on top of the unit for more than a few seconds, that would indicate an exhaust fan of some sort is needed. There are numerous fan options to consider to include the AC Infinity T8 linked below.
https://www.amazon.com/Etekcity-Lase...ZV9EJPMJR5R9K1
https://www.acinfinity.com/component...ystem-17-inch/
bmcn and RetiredandLovingIt like this.
post #8442 of 17922 Old 08-08-2017, 05:09 AM
Quoted: 49 Post(s)
Which is normal operating temperature for a 4300?
I notice is much more hot than my previous 3300 (although it has aluminium heat sink)
And which temperature is needed to star internal coolin fans?
finitol is offline
post #8443 of 17922 Old 08-08-2017, 05:24 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13466
1. Will likely be warm to the touch. Ensure there is at least 2-3" clearance on the top and sides as well as open front/back for proper ventilation.
2. 158 degrees F
post #8444 of 17922 Old 08-08-2017, 05:25 AM
bigapp's Avatar
Quoted: 75 Post(s)
Liked: 75
Any max temp spec you get from a manufacture will be a little below the upper limit it can run at and not fail during the warranty. Heat is the enemy of long life for electronics. You're spending enough for the AVR drop a little more and get it some airflow to help out cooling.
bigapp is offline
post #8445 of 17922 Old 08-08-2017, 05:28 AM
StumpyBloke's Avatar
Quoted: 162 Post(s)
Liked: 113
Keeping my x4300 in Eco for everyday use keeps it very cool on top. I only use mine in non-eco when watching films
StumpyBloke is offline
post #8446 of 17922 Old 08-08-2017, 05:37 AM
Quoted: 49 Post(s)
Ok, i'm ready for some arragements on the sides of my furniture.... At the top i haven't problem with 5" now....
So, i understand is so important air flow on sides, right?
Enviado desde mi mini_3GS mediante Tapatalk
finitol is offline
post #8447 of 17922 Old 08-08-2017, 05:52 AM
Zaim's Avatar
Quoted: 54 Post(s)
Hi,
I have a question, I'm going to be upgrading from the 3300w to the 4300H shortly, I used the Audyssey app to run through room calibration, my question is can I use the same saved settings on the 4300H or would it be worth re-running the calibration from scratch? Nothing else has changed in my setup, just the amp.
TV: Sony KD55XD9305, AV Receiver: Denon AVR-X4300H, Speakers/Sub: Tannoy Mercury V4i / v1i (Rear) + Tannoy Mercury VCi (Center), SVS PB-1000 (Sub), ELAC Dolby Atmos Speakers Front+Rear 4K Blu-ray: Sony UBP-X800
Zaim is offline
post #8448 of 17922 Old 08-08-2017, 05:54 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13466
Yes.
post #8449 of 17922 Old 08-08-2017, 05:55 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13466
Originally Posted by Zaim View Post
Hi,
AFAIK, cannot be reused, so just rerun again.
Zaim likes this.
post #8450 of 17922 Old 08-08-2017, 05:59 AM
bigapp's Avatar
Quoted: 75 Post(s)
Liked: 75
any airflow is good. The idea is to get cool air in to absorb the heat and then push out the hotter air to get more cool air in. Heat rises so the best possible configuration is cool air from below exhaust from the top. The best will be to have air flow through the vents of the AVR, but having the air above or around the unit being exchanged is much better than nothing.
If your only choice is side to side, have the cool air come in down low on the AVR and output up towards the top of that 5". I think you'll be happy with that.
bigapp is offline
post #8451 of 17922 Old 08-08-2017, 10:12 AM
frankthetank966's Avatar
Quoted: 16 Post(s)
Hi there,
I recently setup a Denon AVR-X2300W with the Energy 5.1 Take Classic Home Theater System. I have 2 front speakers, 1 center speaker, a sub, and 2 rear speakers. I'm trying to configure this system to get the optimal sound settings when we watch movies and music.
Most of the time we stream movies through the Apple TV and PS4.
Normally, I play music through Airplay and have started to listen to the Internet Radio built-into the receiver.
What are the best listening modes for this setup? Do you suggest Dolby, Stereo....
frankthetank966 is offline
post #8452 of 17922 Old 08-08-2017, 11:04 AM
bigapp's Avatar
Quoted: 75 Post(s)
Liked: 75
Originally Posted by frankthetank966 View Post
Hi there,
personal preference and that might change by song or by artist, however if the source is 2 channel stereo 99 percent of the time it's played back in stereo with sub for me.
bigapp is offline
post #8453 of 17922 Old 08-08-2017, 07:48 PM
Quoted: 197 Post(s)
Liked: 86
That's science for you
Sent from my STV100-2 using Tapatalk
Mrjmc99 is offline
post #8454 of 17922 Old 08-08-2017, 07:50 PM
Quoted: 197 Post(s)
Liked: 86
Hi,
You can reuse, but you will need to hack the file to change the avr model. This can be done in notepad, I've done it once for testing. There will be an entry that states the model name, just change to x4300h and you should be good.
Mrjmc99 is offline
post #8455 of 17922 Old 08-08-2017, 07:56 PM
Quoted: 197 Post(s)
Liked: 86
It can be done, you just need to edit the file. I applied a 6011 Audyssey file into my x4300h just by editing the model number in the beginning of the file with notepad.
I'm assuming that you cannot take a 9 or 11 channel file and apply to a 7 channel avr. Haven't tested that though. I may test this one day, my brother picked up an x3300w I can see what happens when I try to apply a 9 or 11 channel config to it, I can't think of a way that it would let you do that though.
Mrjmc99 is offline
post #8456 of 17922 Old 08-08-2017, 09:24 PM
confinoj's Avatar
Liked: 1312
subwoofer distance problem
I just re-ran Audyssey on my x4300h as I moved speaker positions a bit. I have dual subs with one wireless. Audyssey set the wireless sub at 31.1 feet which it had before. Post Audyssey I wanted to tweak my atmos module distance as it was incorrectly measuring directly to speaker and not taking into account ceiling bounce. When I make the changes and back out of the menu it tells me speaker distance is invalid and changes the wireless sub distance from 31.1 to 28.5. I can not change it back to 31.1 (or anything more than 28.5) without restoring audyssey settings but then I can't fix my atmos distances. Does the Denon have a max manual subwoofer distance setting of 28.5? Why the discrepancy between what Audyssey sets and what I can set manually? I don't get it.
post #8457 of 17922 Old 08-09-2017, 07:44 AM
Quoted: 394 Post(s)
Liked: 113
Please can anyone tell/estimate the power draw on the Denon X4300H powering just 4 speakers?
Theater: JVC-RS440 & Elite 120". 7.2.4:T1, CS2, FXiA4, RTiA1, 620-RT & Dual 18" DIY Cyclops Subs. Marantz AV7704, Crown XLS(x5), UPA-700, UBP-X800, DP-UB424, ATV 4K & Shield.
Lounge: Benq HT1075, Elite 106" & Sony 75X900F. 7.2.4:RTiA3, CSi5, 65-RT(x4), MC60, RBH I-12 & SVS PB12-NSD. Denon X4300H, Crown XLS(x2), Amp 100v2(x2) & Shield.
shyyour is offline
post #8458 of 17922 Old 08-09-2017, 07:51 AM
imureh's Avatar
Quoted: 3499 Post(s)
Liked: 4715
Depends on the speakers. The more efficient they are the less power needed to drive them at a given volume level.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #8459 of 17922 Old 08-09-2017, 08:23 AM
Quoted: 65 Post(s)
Liked: 179
Hi there,
For music I strongly prefer multi-channel stereo; it makes the music surround you, without any gimmicky processing. This also can make any video with a stereo soundtrack easier to understand.
Ultimately, though, what sounds best will depend on your hardware, your media, and your ears. Try different settings, and find out what works for you.
bigapp likes this.
LG OLED 65C7P <- Oppo UDP-203 -> Denon AVR-X4300H; Dish Hopper; Apple TV 4K; Paradigm speakers
GordonBlu is offline
post #8460 of 17922 Old 08-09-2017, 08:24 AM
Quoted: 394 Post(s)
Liked: 113
Polk 620-RT, they are 89 db. I will be using it in an atmos setup. I'm trying to get a step down transformer for the Denon X4300H, hence why im trying to get the power draw.
shyyour is offline
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
