The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 281390Likes
post #61 of 17652 Old 05-18-2016, 09:11 AM
TH3_FRB's Avatar
Quoted: 164 Post(s)
Liked: 31
The X4300 looks interesting. I was planning to go with a recertified X6200 but had some unexpected bills come up so put a temporary hold on the purchase. Other than the 2 additional amps, uprated power output, and ability to expand to 11ch, what would I be giving up with the X4300 compared to the X6200? Is there any significant gain with the X4300?
TH3_FRB is offline
post #62 of 17652 Old 05-18-2016, 04:06 PM
shae's Avatar
Quoted: 101 Post(s)
Originally Posted by energizerfellow View Post
Except that the 2015 models can't. They can scale and have a GUI screen overlay at 2160p60, yes, but only with 4:2:0 color. You can get 4:4:4 color, but only at 24/30/50 FPS on the 2015 models. 4:4:4 color at 60 FPS is important for the gamers among us (4:2:0 ravages text).
Any problems with 2160p60-4:4:4 if you disable the GUI overlay?
shae is offline
post #63 of 17652 Old 05-18-2016, 04:38 PM
batpig's Avatar
Quoted: 5021 Post(s)
Liked: 5478
Since these 2016 models are nearly the same as their 2015 counterparts, there isn't really anything gained by going with the 4300 vs the previous year's model. I have to imagine the 6200 closeout pricing will be similar to the 4300 new pricing when released, so it seems like a smart move to go with the 6200 and get the beefier amps and build quality, and 9 built-in amp channels.
Mikenificent1, Shniks and yanks1 like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #64 of 17652 Old 05-18-2016, 06:45 PM
coolcat4843's Avatar
Quoted: 285 Post(s)
Liked: 111
When does closeout pricing for the 6200 happen?
September/October?
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #65 of 17652 Old 05-19-2016, 05:56 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 23457 Post(s)
Liked: 12897
September/October?
Whenever dealers want to start moving out the previous year's models to make room for the current year's models ... for the X6200W, likely Aug/Sep.
Madmax67 likes this.
jdsmoothie is offline
post #66 of 17652 Old 05-19-2016, 07:29 AM
Quoted: 32 Post(s)
Liked: 4
1. The new delay setting simply provides additional delay.
2. I actually say "No analog --> HDMI conversion"
[QUOTE=shae;43840938]Thanks JD.
Can you elaborate on "Auto Lip sync delay (increase from 200ms to 500ms)"?
QUOTE]
I have one more question about this in general; The HDMI feature on my 2015 receiver is simply called "auto lip-sync" the audio delay in AUDIO settings is a manual version lip-syncing right? are these features independant or each other or do they combine, resulting in a total delay; (auto+manual=delay)?
i suppose the audio delay has been increased and the hdmi feature is stil an on/off switch?
Louike is offline
post #67 of 17652 Old 05-19-2016, 11:40 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12897
Correct. They can be used independently or together. Personally, I've never had to use the delay feature as the "Auto Lip Sync" has done it's job perfectly.
If the "Auto Lip Sync" feature does not correct the delay, the "Delay" setting can be used to fine tune the adjustment.
post #68 of 17652 Old 05-19-2016, 12:37 PM
shae's Avatar
Quoted: 101 Post(s)
I think "auto sync" is for when a downstream device, like a TV, reports its latency. Then the upstream device, the receiver, can delay the audio to match. But I think TVs don't necessarily report the correct value. Another problem is that the delay can change depending on your TV settings, and I think dynamically changing the delay is only a feature of HDMI 2.
Manual audio delay is useful when you're sitting far away from the speakers, and for badly synced broadcasts.
shae is offline
post #69 of 17652 Old 05-19-2016, 05:14 PM
Andrew_B's Avatar
Quoted: 52 Post(s)
Liked: 58
Are any 2016 Denon owners interfacing with one of the new 4k Vizio P-series displays?
My Denon 3808 can only do HDMI 1.3 so I need to upgrade my receiver too.
Because I won't be relying on the receiver to scale anything to 4k, it looks like I can get away with something cheaper like the S-720 or 920.
Any other opinions? Upgrading to the equivalent X series doesn't seem to add much at the low end.
jsmiddleton4 likes this.
Andrew_B is offline
post #70 of 17652 Old 05-19-2016, 05:29 PM
batpig's Avatar
Liked: 5478
Upgrading to the X series does add a couple of important things -- besides the 3rd year of warranty, you get the superior XT version of Audyssey to match that on your 3808. The S models have regular MultEQ.
Setup Guide and FAQ
batpig is offline
post #71 of 17652 Old 05-20-2016, 12:41 AM
Liked: 0
I'm thinking about getting the 720w (never owned a receiver before), and was trying to find what the differences between the 720 (2016) and the 710 (2015) were. The post at the beginning of the thread did not state any differences (was blank); I wasn't sure if it meant that there weren't any or if they are yet to be noticed. It would be amazing if someone could shed some light into this.
roshanman is offline
post #72 of 17652 Old 05-20-2016, 10:09 AM
batpig's Avatar
Liked: 5478
To be honest, there appears to be basically no important differences. The 2014>2015 model change was very significant with the addition of HDCP 2.2, full 4K/UHD support and Atmos/DTS:X, whereas the 2015-2016 change appears to be extremely minimal. So if you can find the S710W for a better price then go for it.
iatacs19, Shniks and yanks1 like this.
Setup Guide and FAQ
batpig is offline
post #73 of 17652 Old 05-20-2016, 10:17 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12897
Post 1 lists the changes for the 2016 models.
post #74 of 17652 Old 05-20-2016, 11:44 AM
Mikenificent1's Avatar
Quoted: 166 Post(s)
Liked: 46
Do you guys know if any receivers such as Denon/Marantz (not Onkyo/Pioneer) that will be supporting MQA?
Mikenificent1 is offline
post #75 of 17652 Old 05-20-2016, 12:44 PM
Andrew_B's Avatar
Quoted: 52 Post(s)
Liked: 58
This is a good point about not sacrificing audio quality.
I also notice the X2300W starts coming with 2 HDMI outputs. Do you know if I can setup this receiver in "mirror mode" to drive 2 displays? That would be a feature worth having for the TV I am looking at since it has multiple inputs with different levels of latency/processing.
Andrew_B is offline
post #76 of 17652 Old 05-20-2016, 12:49 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12897
Yes, Video Monitor settings are Auto (dual), Monitor 1, Monitor 2.
post #77 of 17652 Old 05-20-2016, 12:50 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12897
AFAIK, not for 2016.
post #78 of 17652 Old 05-20-2016, 03:13 PM
Brien's Avatar
Quoted: 116 Post(s)
Liked: 29
Glad I didn't wait for the 2016 models... looks like there isn't much new on the 4300 that I would want/need.
yanks1 likes this.
Brien is offline
post #79 of 17652 Old 05-20-2016, 03:51 PM
Madmax67's Avatar
Quoted: 2385 Post(s)
Liked: 2665
I'm looking at these models as well. X6200 gives you dual fans (on the bottom) better amps ,HD radio, gold binding posts and it's still built in Japan for what that's worth . If your gong to run a 5.1.4 setup eventually to me it would be worth it over the X4300. Still mulling it over though.
Sent from my 710C using Tapatalk
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #80 of 17652 Old 05-20-2016, 04:13 PM
jsmiddleton4's Avatar
Quoted: 1038 Post(s)
Liked: 374
If the x300 series really are no better than the x200 series there's going to be a blood bath trying to grab the x200's off Amazon, etc., when their prices drop.
jsmiddleton4 is offline
post #81 of 17652 Old 05-25-2016, 09:09 AM
shae's Avatar
Quoted: 101 Post(s)
I don't know. Most people just buy based on "higher model numbers".
iatacs19 likes this.
shae is offline
post #82 of 17652 Old 05-25-2016, 12:15 PM
Liked: 374
I can assure you if I can get a 6200 near the price of a 4300, I'll be getting that old outdated obsolete last year's model.....
post #83 of 17652 Old 05-25-2016, 12:19 PM
batpig's Avatar
Liked: 5478
seems like a no-brainer to me. The 6200 is more powerful, has slightly better build quality and features, 9 amps built in and can expand to 11ch....
Setup Guide and FAQ
batpig is offline
post #84 of 17652 Old 05-25-2016, 01:24 PM
shae's Avatar
Quoted: 101 Post(s)
You're of the small percentage of buyers that researches beforehand.
Also, 6200 is a higher number than 4300.
shae is offline
post #85 of 17652 Old 05-25-2016, 02:27 PM
Liked: 374
At this level of cost? One would hope some research is done.
post #86 of 17652 Old 05-25-2016, 08:19 PM
shae's Avatar
Quoted: 101 Post(s)
You mentioned initially the whole of the X#200 and X#300 series. And anyway, true audiophiles don't research, no matter the cost.
shae is offline
post #87 of 17652 Old 05-26-2016, 09:48 AM
aoshiken's Avatar
Do we have any info about the fans on the X6300W?
Perhaps it's more suitable for using inside cabinets/furniture...
aoshiken is offline
post #88 of 17652 Old 05-26-2016, 09:50 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12897
The fans will go on when the internal temp reaches 158 degrees F. Ideally you'll still want an open front and back for proper ventilation.
post #89 of 17652 Old 05-26-2016, 10:04 AM
Sekosche's Avatar
Quoted: 1457 Post(s)
Liked: 3686
Originally Posted by Mr. Wonderful View Post
Whoa! The X3300W is getting Audyssey MultEQ XT32? That's awesome.
Do we have any idea when in June it's coming? Does anyone have a compelling reason why I should consider the X4300W? On paper, the step-up features don't seem that great to me.
I'd love to know X3300 availability too, because I'm looking to buy a new receiver very soon or a closeout/refurb X4200. MultEQ XT32 and SubEQ-HT are the only features I really want to add, so I couldn't justify the extra expense of the 4xxx series. I'm using an antimode 8033s-ii for my dual subwoofer 5.1 setup, but I'm about to add a 3rd sub and possibly 2 atmos speakers.
Sekosche is offline
post #90 of 17652 Old 05-26-2016, 10:18 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12897
Only info currently available is "June."
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
