The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 437 - AVS Forum | Home Theater Discussions And Reviews
 281195Likes
post #13081 of 17076 Old 01-18-2018, 10:31 AM
Quoted: 146 Post(s)
Certainly not normal. Have you tried setting the <Mute Level> to something other than the factory default of "Full"? Also note, that a "soft reset" has better results if you pull the power cord for 10 minutes.
Just tried -20 and -40. Both result in the same issue. Also just thought to check across multiple platforms. The Issue can be created via cable, Netflix, Bluetooth audio and Blue Ray. Also took the time to stop watch it last night for 10 occurrences. The time mute stays active is narrow but not consistent. It occurs anywhere between 20 and 50 seconds but it’s never the same twice....
SuLax22 is online now
post #13082 of 17076 Old 01-18-2018, 10:32 AM
Quoted: 146 Post(s)
Thanks for the 45 minute intel. I’ll have to try that this evening when I get home from work
post #13083 of 17076 Old 01-18-2018, 10:37 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22012 Post(s)
Liked: 11935
If the "soft reset" doesn't resolve the issue, try doing about 10 microprocessor resets in a row (see post 5). If using Dynamic Volume or Dynamic EQ, try setting them both to OFF.
jdsmoothie is offline
post #13084 of 17076 Old 01-18-2018, 10:39 AM
blatz8's Avatar
Quoted: 308 Post(s)
Liked: 106
Originally Posted by jt323bd View Post
Dont use auto lipsync
Damn that was a lot of wasted time trying to figure out how to coordinate varying audio delays to compensate for that trash
I wasted a good bit of time myself attempting to set "Lip Synch" LOL. Turned it off and all is great now...
blatz8 is offline
post #13085 of 17076 Old 01-18-2018, 10:41 AM
bouda's Avatar
Quoted: 23 Post(s)
I would appreciate anyone's input on this - I have the chance to obtain either the Denon AVR-S710W or Denon AVR-S720W at a very good price. I cannot find online much difference between the two - is one year's model preferred to the other, if so why?
For reference, this will be replacing my Denon 2310, and will be used with 55" Samsung js8500, Apple TV 4K, and Sony UBP-X800 blu ray player, plus Energy Take speakers, subwoofer.
Thank you in advance.
bouda is offline
post #13086 of 17076 Old 01-18-2018, 10:47 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11935
Refer to post 1 of each of the 2015 and 2016 Owner's threads.
post #13087 of 17076 Old 01-18-2018, 10:58 AM
bouda's Avatar
Quoted: 23 Post(s)
I wasn't sure if one model was "built" better. Since I will not be using this for a complex set up, I didn't know if one year was preferred over the other in regards to people liking one year's model over the other, less issues, etc...
From reading the posts, it seems that if priced the same, to go with the newer model (720). Looks like the improvements that would affect my set up most would be:
- Dual band 802.11n Wifi (2.4Ghz, 5Ghz)
- RC Select (allows changing of an HDMI pass through source while the AVR is in Standby mode)
I actually purchased the 710 for $150, and the 720 for $100, but will sell the one I do not decide on keeping once I receive them.
bouda is offline
post #13088 of 17076 Old 01-18-2018, 12:18 PM
Quoted: 198 Post(s)
Liked: 105
Mute will not not stay active. It will initially mute all audio but then at some point between 29-48 seconds (without hitting any buttons on any remote) the sound will come back.
Disconnect all HDMI cables, then see what happens. If it still unmutes itself, it's probably an AVR issue. If it doesn't, there may be a device sending volume control commands on a regular basis via HDMI CEC.
ahblaza and Madmax67 like this.
mike.s is offline
post #13089 of 17076 Old 01-18-2018, 02:16 PM
hclmed's Avatar
Quoted: 52 Post(s)
Originally Posted by nater1 View Post
Well, tomorrow I say goodbye to my 6300h that has developed a horrid hiss through all channels after 3 months. My dealer gave me full credit plus a discount on a new marantz sr8012, which will be here tomorrow.
My 6300 was from the serial number range that was supposed to be fixed, but apparently that did not work out for me. Denon tech support confirmed it's a known issue with no resolution (other than turning off room correction). Good dealer though!
Don't forget to record the serial no. before you send it out. Knowing its build date could help confirm or deny the update that fixes this if this is the same hissing problem found by others.
ahblaza and blatz8 like this.
hclmed is offline
post #13090 of 17076 Old 01-18-2018, 02:19 PM
Quoted: 196 Post(s)
Liked: 86
Do you have cec enabled? Maybe one of your devices is trying to set the volume.
Sent from my Pixel 2 using Tapatalk
Mrjmc99 is offline
post #13091 of 17076 Old 01-18-2018, 02:26 PM
Quoted: 146 Post(s)
What’s CEC?
Dynamic volume and dynamic EQ are both set to off if that matters...
Thanks for the tip. I’m at work till 11pm but I’ll try that when I get home
post #13092 of 17076 Old 01-18-2018, 02:26 PM
nater1's Avatar
Quoted: 54 Post(s)
Liked: 37
Excellent point, the serial number is amu1517050xxxx...
nater1 is offline
post #13093 of 17076 Old 01-18-2018, 02:44 PM
hclmed's Avatar
Quoted: 52 Post(s)
Ok, so that's a May 2017 build.
JD, wasn't the replacement DSP supposed to be in use as of March 2017?
My 6300 is AMU1517060..., around the same time. I was also wondering what the AMU meant, since there are other 3 letter prefixes on some X series AVRs, but the Denon support person wouldn't explain it. Anyone know?
hclmed is offline
post #13094 of 17076 Old 01-18-2018, 03:20 PM
Liked: 3
I'm sure this has been asked before but search has failed me. I have a 4300H - how does one get Alexa and Spotify to work? I have connected Spotify to the Alexa app, but when I say "Alexa, play <whatever> on Spotify on Theater (what my Denon 4300H is named) she says something like "I'm sorry, I can't play Spotify Music on that device". She has no problems playing Amazon Music on my receiver though.
got-haggis is offline
post #13095 of 17076 Old 01-18-2018, 03:29 PM
Liked: 3
Originally Posted by gsantosoliver View Post
Does anybody have the same problem? I read somewhere there will be an update this month for the AVR 4300 that will include further support to Alexa - is this still true? Does anybody know if this update would fix the problem I am having that prevents Alexa from playing Spotify on the AVR? Thank you!
ok, did a different search and found this post...I have the same exact problem, firmware is up to date. Is anyone actually able to use their echo to play spotify on their denon receiver?
post #13096 of 17076 Old 01-18-2018, 03:40 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
I too had the dreaded hiss issue; goes away when you turn off room correction. Apparently the issue is documented and well known in the US. Here in Australia it's another story. Two returns to different repair workshops, both found nothing wrong. Finally kicked up some stink and they replaced the HDMI board and something else.
All fixed and working brilliantly since then (touch wood he says).
blairy is offline
post #13097 of 17076 Old 01-18-2018, 05:16 PM - Thread Starter
jdsmoothie's Avatar
Liked: 11935
blatz8 likes this.
post #13098 of 17076 Old 01-18-2018, 05:59 PM
Liked: 3
hah of course the two services I attempted to use are 'coming soon'. doh. Thanks....I assume soon means 2019 at this point.
blatz8 likes this.
post #13099 of 17076 Old 01-19-2018, 03:31 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11935
The below note has been posted for a few months .... so 2018 is more likely.
http://denon.custhelp.com/app/answer...nment-skill%3F
post #13100 of 17076 Old 01-19-2018, 06:47 AM
hclmed's Avatar
Quoted: 52 Post(s)
Just curious if this issue was addressed by replacing both the HDMI board and if the something else was a DSP board. Still can't tell which 6300 systems are at risk. Do you know, from your serial no., if your's was built before or after March 2017?
hclmed is offline
post #13101 of 17076 Old 01-19-2018, 06:52 AM
hancox's Avatar
Quoted: 103 Post(s)
Liked: 92
Originally Posted by stevekaden View Post
Help also.....I have an AVR-X4200. It periodically Chirps. Think a cricket or a bird or a screech. All inputs, seem to map scene-audio transitions but not in any way that I can see a patterns.
Anybody heard this??
Are you watching CBS programming, specifically sports? They've been adding a cricket chirp intentionally to programming, and it's exceedingly annoying.
stevekaden likes this.
hancox is offline
post #13102 of 17076 Old 01-19-2018, 09:51 AM
Quoted: 33 Post(s)
X4300H Problem?
Using Home Theater PC to drive Audio.
When I play a movie in Atmos or DTS X and then play another source type like a game or youtube audio receiver does not auto find the next source it just stays displaying Atmos or DTS X or Neural X or Dolby Surround. It can be fixed by manually switching to the type of source material by pressing movie button or equivalent.
My old receiver did not have a problem switching between source material. I would hear the "click" and then sound would be heard.
Jeigh07 is offline
post #13103 of 17076 Old 01-19-2018, 10:04 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11935
Can't speak for Australia, but the units mfr'd after May 2017 in the USA should have the replacement HDMI board that resolves the hiss issue that was noted on some units mfr'd prior to that date.
post #13104 of 17076 Old 01-19-2018, 10:07 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11935
Originally Posted by Jeigh07 View Post
X4300H Problem?
If you want it to AUTO switch, you must select the AUTO surround mode (ie. press the PURE button on the remote and select AUTO).
post #13105 of 17076 Old 01-19-2018, 10:12 AM
Quoted: 27 Post(s)
Liked: 2
Denon X3300W with Echo Dot Bluetooth Issues
I have a Denon X3300W and an Echo Dot. I have to re-pair the devices every time I try to listen to music through the echo dot on my Denon receiver. Anyone else having similar issues? I don't want to have to connect it with a cable as that will mean I always have to have the receiver on and on the right input to use the dot for simple things like weather forecast.
Brian
b-bartel is offline
post #13106 of 17076 Old 01-19-2018, 10:13 AM
Quoted: 27 Post(s)
Liked: 2
BTW, I also updated the firmware on the receiver last time it notified me there was an update a month or 2 ago.
b-bartel is offline
post #13107 of 17076 Old 01-19-2018, 11:00 AM
Quoted: 146 Post(s)
Well Mike I think you nailed it.... I was able to narrow it down that I can only get the mute issue to happen when the HDMI cable from the Blu Ray player is plugged into the receiver. Which is both a sigh of relief and extremely frustrated. Glad to hear the AVR isn’t malfunctioning but don’t really want to have to plug and unplug the Blu Ray based on usage :/
post #13108 of 17076 Old 01-19-2018, 11:10 AM
raistline's Avatar
Quoted: 187 Post(s)
Liked: 170
Most BD-Players that have HDMI-CEC will have the option to turn it off. It may be named Anynet+ (Samsung), or something similar-ish in the settings menu. Just go through all of them and look for something that describes control over HDMI.
raistline is offline
post #13109 of 17076 Old 01-19-2018, 11:47 AM
hclmed's Avatar
Quoted: 52 Post(s)
Good point. As well intended as CEC is, and useful for simple installations, it's mainly obsoleted by smart remotes that can group commands, and more the cause of unexpected results.
hclmed is offline
post #13110 of 17076 Old 01-19-2018, 12:53 PM
steveknj's Avatar
Quoted: 52 Post(s)
This is what I've found. As long as I can run ARC without having to do CEC, I do that. Sometimes they are co-dependent (as was the case with my PIO AVR and my LG TV).
Steve
steveknj is offline
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
