The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 515 - AVS Forum | Home Theater Discussions And Reviews
 281267Likes
post #15421 of 17361 Old 07-16-2018, 10:13 PM
Quoted: 156 Post(s)
Liked: 65
I noticed after the last upgrade that once I turn the 4300 on, no sound is heard from whatever input signal was pre-selected.
Example: Turn On: Cabl/Sat: no sound. I have to switch to other input and go back to Cabl/Sat to hear that input.
Anyone noticed this behavior after the last update? Or this behavior at all?
Thks in advance!
asabrag is online now
post #15422 of 17361 Old 07-16-2018, 10:23 PM
afrogt's Avatar
Quoted: 2209 Post(s)
Liked: 1460
Originally Posted by guitarguy316 View Post
so i went into speakers and the "zone2" is actually set to "top middle" since i'm running 5.1.2 atmos. does that mean i can't use the zone2 hdmi output? i just want to use it for video only to hdmi2 on tv for when i'm gaming with headphones (i.e. don't need audio from the AVR).
That's has nothing to do with it. I have an Atmos 5.2.2 setup and can still watch a second HDMI source in zone 2. Just press the Zone 2 button on the remote and then select your HDMI source. Video should come thru with no problem.
If often watch 2 HDMI sources at the same time on two different TV's.
Afro GT
afrogt is offline
post #15423 of 17361 Old 07-17-2018, 10:01 AM
rizorith's Avatar
Quoted: 65 Post(s)
Liked: 27
Setup advice for PC Games/Home theater X1300
I've had the X1300 for about 6 months and like it but I certainly haven't touched much beyond the basics. I've learned a ton reading this forum so had I asked this half a year ago I would have 20 questions. But, I'd love some advice on the best way to wire and configure the Denon. I watch movies with a 5.1.2 setup, primarily through Plex. I play PC video games, and listen to stereo music by casting google play music via wifi (chromecast audio) to the denon. My setup is as follows:
Windows 10 PC (HTPC) connected to X1300 via HDMI, HDMI from X1300 connected to 60" Samsung TV. X1300 is connected to the 5.1.2 speakers (3 across, 2 heights, 2 sides and 1 sub).
It works well enough but I do have a few problems:
1. When I watch a movie or play games on the PC, I always get the source audio. I have it setup as passthrough so if I have an atmos track I do see atmos on my receiver. But I was told this will upconvert lower audio signals automatically i.e. stereo to false surround sound. How do I set this up?
2. If I'm using the PC I can't listen to music through the stereo because I have to change to a different input, and when I do that, I lose video signal. I do not use the 2nd zone and I'm wondering if that's the key? Not sure how to set it up though.
3. In general, atmos is a PIA on a windows 10 machine. Whenever there is an update I have to reconfigure it. Someone on another forum said I should not have atmos activated on windows 10 but when it's not activated I do not see atmos on the denon. What is the best way to setup windows?
Thanks in advance!
rizorith is offline
post #15424 of 17361 Old 07-17-2018, 10:11 AM
afrogt's Avatar
Liked: 1460
1. if you press the Movie sound mode button on the remote and select Dolby Surround it will upmix the two channel or other source audio to all of your speakers.
2. When you select your music source, then press the Option button on the remote. Choose Video Select and then toggle to whatever input you're using to play games. Then you can listen to music and play games at the same time. I use this feature to listen to music and watch sports at the same time.
3. Don't know, don't use a computer with my AVR.
rizorith likes this.
Afro GT
afrogt is offline
post #15425 of 17361 Old 07-17-2018, 10:36 AM
Liked: 4
Originally Posted by Samcor_NZ View Post
With my X2300W, I've recently found that when playing a multi-channel uncompressed audio track from an earlier Blu-ray disc (I'm using Sony UHP-H1 player), the receiver outputs the audio to the speakers faster than if it's decoding a bitstreamed track (such as Dolby Digital, Dolby TrueHD etc). What this means is that I have a video/audio sync issue with those uncompressed tracks specifically that requires me to add a delay. Unfortunatly I then have to turn the delay back off when I switch back to encoded audio tracks as they then become out of sync. I'm guessing the extra decoding time the receiver takes to output Dolby tracks (etc) is absent with unencoded/uncompressed tracks and thus a delay difference occurs with the audio, where the time taken to display the video on the tv is consistent. Has anyone else noticed this?. Luckily I don't have many uncompressed (LPCM) tracks in my Blu-ray collection as the majority are encoded so it's not a big deal but annoying none the less. If I send both the video and audio to the tv for testing then uncompressed tracks are in sync with the image without a delay required (which makes sense).
I've been able to measure the difference between playing an uncompressed multi-channel blu-ray track vs an encoded multi-channel track and can confirm on my X2300W that the difference is around 40ms. I have to add an additional 40ms to the receiver audio delay setting when playing an uncompressed multi-channel blu-ray track vs an encoded (think DolbyTrueHD, DTS-HD Master etc) to get perfect audio sync with the image displaying on my TV, as the uncompressed track is heard from the speakers faster (The actual total delay I use for getting perfect audio sync with my model tv Sony x850c is 60ms delay for encoded and 100ms for unencoded). This suggests that Denon send the video signal down the HDMI cable to the TV before decoding the encoded audio tracks when outputting the audio to the speakers. If they decoded the audio first and then sent the audio to the speakers and the video to the tv at the same time then there would be no need for a different delay between the two types of audio tracks.
Samcor_NZ is offline
post #15426 of 17361 Old 07-17-2018, 10:57 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22761 Post(s)
Liked: 12417
Thks in advance!
When something unusual like this occurs ... the first troubleshooting step is to do a "soft reset" by simply powering off the AVR and unplugging the power cord for 10 minutes.
jdsmoothie is offline
post #15427 of 17361 Old 07-17-2018, 11:08 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12417
As noted in post 8, the Manual Setup - Speakers - AMP ASSIGN setting is set to "Zone 2" when the Surround Back speaker posts are being used for Zone 2. As you are using them for "Top Middle" it is set to "Top Middle.
post #15428 of 17361 Old 07-17-2018, 11:18 AM
rizorith's Avatar
Quoted: 65 Post(s)
Liked: 27
Thanks for the suggestions. I'm having difficulty in finding "video select" on the remote. When i push the option button on screen I see chanel level select and all zone stereo.
rizorith is offline
post #15429 of 17361 Old 07-17-2018, 11:23 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12417
Note what he said in "red."
Also review p. 117 in your Owner's manual.
post #15430 of 17361 Old 07-17-2018, 04:10 PM
Quoted: 156 Post(s)
Liked: 65
Thanks! Just arrived home.
Wife watching cab/sat with the Denon off (=audio through TV speakers).
-I turned on the Denon.
-Cab/Sat lits up--> no sound via TV Speaker nor Denon.
-Turned off Denon --> audio through TV speakers
-Turned on Denon --> no sound (via TV Speaker nor Denon).
-Turned off Denon.
-Denon Unplugged
Waiting 10 mins
Wife hates me, the forum and the Denon...she missed the TV show she was watching
Will update in 10'
Edit Update:
Solved. Not just that, now it works better than before the upgrade. Before all the times turned the Denon On it went to the Stream Box Input (Chrome Cast Ultra). Now it stays where it was before turbing it off! 🤩
post #15431 of 17361 Old 07-17-2018, 04:31 PM
Bamafan35611's Avatar
Quoted: 118 Post(s)
I just bought the Denon avr s530bt to replace my old Denon avr 591 due to the Dolby digital plus issue with Netflix. Anyone know if this avr s530bt has the same issue??
Sent from my SAMSUNG-SM-G891A using Tapatalk
Bamafan35611 is offline
post #15432 of 17361 Old 07-17-2018, 04:44 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12417
-Turned off Denon.
-Denon Unplugged
Waiting 10 mins
Will update in 10'
Yeh ... bad timing on your part. Guessing you missed the training on "A Happy Wife is a Happy Life".
mrtickleuk and asabrag like this.
post #15433 of 17361 Old 07-17-2018, 04:55 PM
Quoted: 156 Post(s)
Liked: 65
LOL Thanks man:
Edit Update:
Solved. Not just that, now it works better than before the upgrade. Before the update: all the times I turned the Denon On it went to the Stream Box Input (Chrome Cast Ultra). Now it stays where it was before turning it off! 🤩
post #15434 of 17361 Old 07-17-2018, 07:45 PM
powerdubs's Avatar
Quoted: 207 Post(s)
Liked: 147
If still no joy, replace your HDMI cables with "Premium" certified cables.
Just ordered 3 blue jean cables. Hope it works. Thanks.
ahblaza likes this.
powerdubs is offline
post #15435 of 17361 Old 07-18-2018, 06:09 AM
kunz's Avatar
AVR-X4300h Bug
Originally Posted by kunz View Post
Dear Friends, I have noticed a strange behavior with my AVR-X4300h related to Zone 2/3 operation. I want my receiver to send to Zone 2/3 always the present listened source, and then I set Zone 2/3 to "Source". It works weel except when listening the Online source, when it forces Zone 2/3 to change to Online option. If I select any other input, Zone 2/3 keeps Online and I'm obliged to set manualy Zone 2/3 to Source. In my opinion it is a bug. Anyone noticed this behavior? Thanks.
Confirmed, it's a bug in the AVR-X4300h software.
kunz is offline
post #15436 of 17361 Old 07-18-2018, 07:23 AM
guitarguy316's Avatar
Quoted: 2117 Post(s)
Liked: 795
hmm, i plugged in a 2nd cable from zone2 hdmi output on the AVR into HDMI2 on my tv and got no video. you referenced pressing zone2 button...do you have to press that every time to allow hdmi output to zone2 or can you just turn it on permanently? i'm using an x3300 btw
guitarguy316 is offline
post #15437 of 17361 Old 07-18-2018, 07:41 AM
afrogt's Avatar
Liked: 1460
I have the x3300. you have to press Zone 2, then the desired input you want to use. it will stay on that input until you change it again.
you have to press the Main button to go back to normal use of the remote.
Afro GT
afrogt is offline
post #15438 of 17361 Old 07-18-2018, 10:06 AM
dr_gallup's Avatar
Quoted: 64 Post(s)
Liked: 47
Volume change speed
I have a Denon AVRX4300H. When I change the volume with either the remote or the dial, at first it changes slowly and then after a second or two it changes so fast I always go way past where I want to go. The only way I have found to be able to control it with the remote is to just hit the up/down buttons with many very short pushes. This changes the Zone 1 in 0.5 dB increments so going up 10 dB takes 20 pushes. Is there anyway to adjust the rate of change in the volume control? I would like a nice linear change rather than the exponential response I get now. The same thing goes for the knob, turn it a little and I get a small change, turn some more and it's off the charts.
I don't have this problem when I am watching TV sourced from the cable box. The cable box remote will change the volume on the Denon in a nice linear fashion so it can be done.
Greg TB likes this.
dr_gallup is offline
post #15439 of 17361 Old 07-18-2018, 10:06 AM
Quoted: 372 Post(s)
Liked: 176
x4300H sound cuts out after a couple of hours
Hi guys,
my less than a year old x4300H (running 7.2.4 with additional external amps to power two additional speakers) recently developed an issue, where after about an hour or two of watching or listening content, sound would stop playing.. we can watch a movie (and volume is fairly low too), and all of a sudden we realize that sound is gone, but movie keeps playing. Switching to different source doesn't help - we get video there too but no sound. The only way to get sound back is to power cycle the unit. Anyone experienced anything like this? I'm on the latest firmware. Any ideas on how to possibly fix it?
LG OLED 55C6P | LG OLED 65B7A | Denon AVR X6200W | Denon AVR X4300H | Parasound 2125 and ATI 1506 Amps | Definitive Technology Speakers /w Earthquake SuperNova MKV-12 with 7.1.4 Atmos | LG UP970 and Oppo 203 UHD Players | Nvidia Shield | ATV4K | Roku Ultra | Amazon FireTV
TohaLA is offline
post #15440 of 17361 Old 07-18-2018, 10:27 AM
DougDingle's Avatar
Quoted: 1037 Post(s)
Liked: 671
ALL Denon and Marantz AVRs I've owned behave this way, whether I use the OEM remote or the one for my TiVo. It's kind of annoying.
ccotenj likes this.
DougDingle is offline
post #15441 of 17361 Old 07-18-2018, 10:30 AM
DougDingle's Avatar
Liked: 671
Originally Posted by TohaLA View Post
Hi guys,
If you touch the top of the cabinet, does the unit feel very hot when it shuts down? "After an hour or two" seems to indicate a thermal problem. Or maybe not.
Madmax67 likes this.
post #15442 of 17361 Old 07-18-2018, 11:38 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
yup. the only way around this is to use rs-232.
- chris
https://www.avsforum.com/t/1332917/ccotenj-finally-gets-a-projector
ccotenj is offline
post #15443 of 17361 Old 07-18-2018, 02:10 PM
dsv4's Avatar
Quoted: 33 Post(s)
Use the Denon Remote App.
ccotenj likes this.
Denon X4300H
dsv4 is offline
post #15444 of 17361 Old 07-18-2018, 02:28 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12417
Nope. This is the way Denon remotes have always worked. You'll get used to it.
post #15445 of 17361 Old 07-18-2018, 02:31 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12417
Hi guys,
Could be a ventilation issue. Do you have at least 3-4" clearance on the top and sides with open front/back?
post #15446 of 17361 Old 07-18-2018, 02:36 PM
Madmax67's Avatar
Quoted: 2263 Post(s)
Liked: 2568
Every remote I've used for my Denon X4300H(factory remote, Harmony home Companion, DirecTV) for every source works the same annoying way. I just practiced using it and I've adapted. Wish I had a fix for it but I don't.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #15447 of 17361 Old 07-18-2018, 03:37 PM
Quoted: 372 Post(s)
Liked: 176
Not hot at all.. just warm. It sits in open cabinet with room all around.
TohaLA is offline
post #15448 of 17361 Old 07-18-2018, 03:38 PM
Quoted: 372 Post(s)
Liked: 176
Yes, it's in the open cabinet and there is plenty of room all around.
TohaLA is offline
post #15449 of 17361 Old 07-18-2018, 04:36 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12417
Then refer to post 5 and do a "soft reset" first and if no joy, a "microprocessor reset."
post #15450 of 17361 Old 07-18-2018, 05:45 PM
Quoted: 372 Post(s)
Liked: 176
Thanks! I'm going to try it tonight...
TohaLA is offline
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
