The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 519 - AVS Forum | Home Theater Discussions And Reviews
 281435Likes
post #15541 of 17756 Old 08-09-2018, 07:04 AM
LDBetaGuy's Avatar
Quoted: 356 Post(s)
Liked: 227
3.0 and DTS Neural X Question
As I understand DTS Neural X, it is used to add overhead sound information from soundtracks when one has overhead speakers in their system. I have a 3.0 system. When I engage the DTS Neural X mode on my Denon, the audio sounds really good! What exactly is it doing to the signal in this case?
LDBetaGuy is offline
post #15542 of 17756 Old 08-09-2018, 07:13 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 23675 Post(s)
Liked: 13037
DTS Neural:X simulates audio to speakers configured in addition to the source audio track (floor or height). With a 3.0 setup it's either upmixing a 2.0 signal or downmixing a 5.1/7.1 signal.
LDBetaGuy likes this.
jdsmoothie is offline
post #15543 of 17756 Old 08-09-2018, 07:33 AM
Dan in St. Louis's Avatar
Quoted: 394 Post(s)
Liked: 316
Originally Posted by sofakng View Post
Quick question ... can the AVR-X4300H be used a simple HDMI matrix?
For example, can I switch inputs for both ZONE1 and ZONE2 (using IP commands) without turning on the zones (amplifier), etc?
The Source Input commands turn on the relevant Zone automatically. For example, "SICD<CR>" turns on the Main Zone and selects CD as its input, while "Z2CD<CR>" turns on Zone 2 and selects CD as its input.
I see no IP commands that permit selecting a Source without energizing that Zone. Don't worry about the power amp being turned on. If you turn down the volume or mute that Zone the power consumption is minimal.
M = Mega, m = milli. K = Kelvin, k = kilo. B = Bytes, b = bits. G = Giga, g = gravity. Dan in Saint Louis
Dan in St. Louis is offline
post #15544 of 17756 Old 08-09-2018, 09:38 AM
Quoted: 394 Post(s)
Liked: 316
Originally Posted by Dan in St. Louis View Post
I have tried the "Search" feature but it keeps referring me to irrelevant pages about OPPOs and TVs. What is the iOS launch URL for the Denon 2016 AVR Remote app? My notes say it is "Denon2015AVRRemote://" but that seems out of sync with the name. Thank you!
Since even Denon would not respond re: their own app, I built both buttons for my IP-connected remote. It turns out the the above iOS launch URL is indeed correct, even though the app is advertised as 2016.
post #15545 of 17756 Old 08-09-2018, 02:14 PM
MikeyJBoca's Avatar
Quoted: 25 Post(s)
My 4300 got a firmware update today with Airplay 2 support. Now my iPhone has the O icon next to the denon when I see it in the airplay menu.
asabrag likes this.
MikeyJBoca is offline
post #15546 of 17756 Old 08-09-2018, 04:12 PM
rsonnens's Avatar
Quoted: 884 Post(s)
Liked: 683
This is great. I’ll have to check if mine got it’s update! Thanks.
Update: I can confirm that my 4300 now supports AirPlay 2. I’m not sure when I got the update (I have auto update on) but I am now running version 3.90.50.51.
asabrag likes this.
rsonnens is offline
post #15547 of 17756 Old 08-09-2018, 04:33 PM
MikeyJBoca's Avatar
Quoted: 25 Post(s)
I turned off auto-update just so I can get the fun surprise of seeing a new update
post #15548 of 17756 Old 08-09-2018, 04:37 PM
rsonnens's Avatar
Quoted: 884 Post(s)
Liked: 683
My ATV4k did detected a change because it required me to reverify that my video chain can support Dolby Vision (it still does.)
rsonnens is offline
post #15549 of 17756 Old 08-09-2018, 05:49 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13037
All HEOS "H" models (so then only the X4300H and X6300H in this thread) were recently updated with Airplay 2.
post #15550 of 17756 Old 08-10-2018, 08:14 AM
oldno7's Avatar
As an iPhone user and owner of a 4300H, HEOS3 and HEOS5, what exactly does Airplay 2 bring to my table?
oldno7 is offline
post #15551 of 17756 Old 08-10-2018, 08:35 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 355
the ability to stream audio to multiple airplay receiving devices at the same time.
if you live in an "apple" household where you have multiple airplay 2 receiving devices, it is useful.
if you do not, it is not useful.
it is their answer to sonos multi-room. tbh, as big an apple-head as i am, if i was starting from scratch for multi-room music, i'd go sonos.
oldno7 likes this.
- chris
https://www.avsforum.com/t/1332917/ccotenj-finally-gets-a-projector
ccotenj is offline
post #15552 of 17756 Old 08-10-2018, 10:32 AM
Fanboyz's Avatar
Quoted: 549 Post(s)
Liked: 167
Anybody having weird issues with switching back and fourth from DOLBY SURROUND on PCM stereo sources?
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
post #15553 of 17756 Old 08-10-2018, 12:18 PM
Quoted: 260 Post(s)
Liked: 105
What about the ALLM also included in the update?
asabrag is online now
post #15554 of 17756 Old 08-10-2018, 01:41 PM
Selden Ball's Avatar
Quoted: 4819 Post(s)
Liked: 2864
What kinds of weird issues? There are many things that can happen which aren't always obvious.
Selden
Selden Ball is online now
post #15555 of 17756 Old 08-11-2018, 08:13 AM
Fanboyz's Avatar
Quoted: 549 Post(s)
Liked: 167
Static in the front left and left front ATMOS speaker. Only with Dolby Surround upmixing of stereo pcm sources.
DTS Neural X is fine.
Also my previous settings won’t load, it straight up will not accept a reload.
JJ7 likes this.
Fanboyz is offline
post #15556 of 17756 Old 08-11-2018, 08:52 AM
Liked: 2864
If resets don't fix the problem, than I fear you have a defective or damaged unit. You should contact Denon about getting it repaired.
Sometimes the settings file doesn't get properly written, most often with all of the values set to zeros. You can use, for example, a Windows binary file editor to see if that might have happened. Otherwise, see my recommendation above.
Madmax67 likes this.
Selden
post #15557 of 17756 Old 08-11-2018, 10:59 AM
Fanboyz's Avatar
Quoted: 549 Post(s)
Liked: 167
Can maybe someone with the new firmware test the thing?
Fanboyz is offline
post #15558 of 17756 Old 08-11-2018, 11:44 AM
Dundas's Avatar
Quoted: 53 Post(s)
Liked: 32
Originally Posted by Dreamliner View Post
Is there a way to cycle through sound modes with a single button push? (Like Atmos, DTS:X, Direct, etc)
I have the Denon 6300 and a Harmony remote so if there is a way to program a command from this or another AVR remote that will do this, I’m very curious.
Thx.
There are 2 codes that cycle through the surround modes up or down including DSP modes:
Surround Next
0000 0070 0000 0032 0080 0040 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0ACE
Surround Previous
0000 0070 0000 0032 0080 0040 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0ACE
Dreamliner likes this.
Dundas is offline
post #15559 of 17756 Old 08-11-2018, 11:46 AM
Dreamliner's Avatar
Quoted: 1519 Post(s)
Liked: 800
This is excellent. How do I configure this on my Harmony Elite? Is there a way to add a command and assign it to a button with a copy/paste in code like this?
Dreamliner is offline
post #15560 of 17756 Old 08-11-2018, 01:13 PM
Dundas's Avatar
Quoted: 53 Post(s)
Liked: 32
I'm not a Harmony user but I believe that the only way with a Harmony is to send the codes to Harmony support and ask them to add them. Or you could find them already in the Harmony database by trying a different model Denon AVR. Also see if they have added them to your model since you originally setup your Harmony.
All the Denon AVRs and PrePros use the same codes.
You can find all the codes in the IR_CommandChart spreadsheet here:
https://usa.denon.com/us/product/hom...vers/avrx6300h
Madmax67 and asabrag like this.
Dundas is offline
post #15561 of 17756 Old 08-11-2018, 04:39 PM
Quoted: 260 Post(s)
Liked: 105
Where can I set up those codes?
Is the Status command available some way in the remote?
post #15562 of 17756 Old 08-11-2018, 08:30 PM
allisonok's Avatar
Quoted: 26 Post(s)
Yep, just noticed this from my front left speaker at the menu of The Saphead. If I switch it to any other surround mode, the static goes away.
JJ7 likes this.
Denon AVR-X6300H, LG OLED55B7A, Sony UPB-X1100ES, Oppo BDP-103, Tivo Roamio OTA, Panasonic DMR-ES46V, Proscan PSLD-43, Audio-Technica AT-LP120-USB
Klipsch R-820f fronts, C-2 center, R-620f surrounds, Quintet V for Atmos, Monoprice Monolith 10", Velodyne VRP-10
allisonok is offline
post #15563 of 17756 Old 08-11-2018, 09:26 PM
allisonok's Avatar
Quoted: 26 Post(s)
Luckily, Denon hasn't posted the latest firmware to their website so, I was able to download the older version and install it via USB on my 6300. Dolby Surround is now working properly again.
Fanboyz and mrtickleuk like this.
post #15564 of 17756 Old 08-12-2018, 04:43 AM
Liked: 2864
As I mentioned above, this usually is caused by a defect in the receiver which needs to be repaired. You can try the various resets (unplug from wall power for 10 minutes and/or a "return to factory settings" reset), but they usually don't help.
Selden
post #15565 of 17756 Old 08-12-2018, 05:16 AM
patoberli's Avatar
Quoted: 183 Post(s)
Liked: 75
Send a message via Skype™ to patoberli
I really like how Denon is still updating the Firmware for our units
A big THANK YOU from my side to @Denon !
mrtickleuk likes this.
patoberli is offline
post #15566 of 17756 Old 08-12-2018, 12:53 PM
Madmax67's Avatar
Quoted: 2410 Post(s)
Liked: 2674
Ditto.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #15567 of 17756 Old 08-12-2018, 01:06 PM
Liked: 2
The DSU distortion with 2CH PCM sources is happening on my AVR-X6400H, I don't think it's a HW defect since it only started the same day the latest AirPlay2 FW update was pushed to my unit.
JJ7 and Fanboyz like this.
gfgrimmjr is offline
post #15568 of 17756 Old 08-12-2018, 01:10 PM
Liked: 2
I think I have the same issue, started on 8/9 when the AirPlay2 FW update was pushed to my unit.
Reference to my reply on the 2017 post (I can't post links yet): 2794073-official-2017-denon-s-series-x-series-avr-owner-s-thread-faq-posts-1-8-a-247.html#post56627094
post #15569 of 17756 Old 08-12-2018, 02:31 PM
Quoted: 197 Post(s)
Liked: 86
Contact denon, make sure they know about the issue.
Sent from my Pixel 2 using Tapatalk
Mrjmc99 is offline
post #15570 of 17756 Old 08-12-2018, 03:15 PM
Liked: 2
For sure--I've already reached out to my contact and I'll pursue through a couple of different venues on Monday.
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
