The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 522 - AVS Forum | Home Theater Discussions And Reviews
 281228Likes
post #15631 of 17250 Old 08-24-2018, 03:32 PM
DougDingle's Avatar
Quoted: 1014 Post(s)
Liked: 664
Originally Posted by Selden Ball View Post
That's very unlikely. There was a botched firmware release about a month or so ago, but D&M quickly pulled it and replaced it by a working version
For any specific model(s), or across the entire line?
DougDingle is offline
post #15632 of 17250 Old 08-24-2018, 03:33 PM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
Originally Posted by JJ7 View Post
I got hit by the buggy August firmware. Suddenly the Dolby upmixer sounded terrible, especially the left speaker in my case.
Has a fixed firmware been released? I didn’t see a mention of it at the beginning of this thread.
For now I’m using dts upmixing instead, though I see others have rolled back to a prior release.
Sorry, since those features are irrelevant for my receiver, I haven't been following the firmware update saga as closely as I could. I did notice that quite a few people have reported being happy with the newest firmware updates and assumed (apparently mistakenly) that the bugs had been resolved.
Selden
Selden Ball is offline
post #15633 of 17250 Old 08-24-2018, 08:35 PM
Liked: 4
Question
Originally Posted by patoberli View Post
@karloy please open a ticket with your issue with Denon, so that they can have a look into it and maybe fix it.
Not sure how to submit it as ticket, but I sent it in as a question related to firmware upgrades. Hopefully they escalate and fix it.
karloy is offline
post #15634 of 17250 Old 08-24-2018, 08:52 PM
Liked: 4
I have a related issue, switched back to the May firmware release (see my summary on this thread).
karloy is offline
post #15635 of 17250 Old 08-25-2018, 09:55 AM
allisonok's Avatar
Quoted: 23 Post(s)
Originally Posted by karloy View Post
Wanted to share this experience and troubleshooting in case someone is running into a similar issue.
I have 7.1.4 setup with Dolby Surround upfiring speakers front and rear. One a sudden, whenever my receiver got a stereo input and it is set to Dolby Surround, the output became very distorted, and only the left and center speaker played.
All the other modes worked fine with stereo, e.g. DTS upmixing. Switching the HDMI output on the device to multi-channel worked. Switching then back to stereo and Dolby Surround worked. Switching then between modes with stereo and back to Dolby Surround broke it again. Also, this only happened in my specific 7.1.4 mode. Other AMP assignments worked.
Very erratic - I thought a recent thunderstorm broke something in the Dolby Surround part of the DSP. I brought it to Denon repair, they ran the tests and sent it back without a comment. I assume this means they thought it was resolved, but nothing changed.
As it turns out - it was the August firmware (was set to auto update). I rolled back to the May version via USB and it works now.
My gut feeling is this has to do with the low latency feature and someone missed properly testing my specific setup. Either way, not upgrading resolved it.
I have the same issue except mine only seems to be affected when Dolby Surround is applied to PCM input signals. I rolled back the firmware and contacted Denon.
JJ7 likes this.
Denon AVR-X6300H, LG OLED55B7A, Sony UPB-X1100ES, Oppo BDP-103, Tivo Roamio OTA, Panasonic DMR-ES46V, Proscan PSLD-43, Audio-Technica AT-LP120-USB
Klipsch R-820f fronts, C-2 center, R-620 surrounds and F-2 back, Quintet V for Atmos, Monoprice Monolith 10", Velodyne VRP-10
allisonok is offline
post #15636 of 17250 Old 08-25-2018, 10:06 AM
allisonok's Avatar
Quoted: 23 Post(s)
Has anyone had any issues connecting a PC to an X6300? I connected a 50 ft active HDMI cable to my computer but, it won't work on any of the rear HDMI inputs on my receiver. It works fine on the front HDMI input or plugged directly into my LG OLED.
post #15637 of 17250 Old 08-25-2018, 11:11 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22568 Post(s)
Liked: 12282
What resolution? 1080p? 4k? Try lowering the resolution to 720p. If it works, add an HDMI extender as 50' (active or not) is still a long distance.
ahblaza and Madmax67 like this.
jdsmoothie is online now
post #15638 of 17250 Old 08-26-2018, 04:34 AM
B Howard's Avatar
Quoted: 203 Post(s)
Liked: 141
I just received notice of a firmware update that includes adding DV passthrough for my x3200w. Just updated, will have to rewire my Apple TV to see if it works. Version 5400-6451-4472, DTS version 3.90.50.00. Will inform more later.
B Howard is offline
post #15639 of 17250 Old 08-26-2018, 05:31 AM
mike929's Avatar
Quoted: 145 Post(s)
Liked: 34
Originally Posted by mike929 View Post
What is the current version (x4300h)?
I'm running 6451-5087-8491-6564
-DTS Version 3.90.50.51
Audy IFVer: 00.08
Sent from my SM-N950U using Tapatalk
Can anyone answer this??
Origin - mrmike929
PSN - mrmike929
Steam - mike929
Xbox - mrmike929
mike929 is offline
post #15640 of 17250 Old 08-26-2018, 08:48 AM
B Howard's Avatar
Quoted: 203 Post(s)
Liked: 141
The new firmware will pass Apple TV DolbyVision 4K from NetFlix through my Denon X3200W. It does work. I have my ATV set to 4k SRD with match range and frame rate both on. Long wait but it now passes DolbyVision.
B Howard is offline
post #15641 of 17250 Old 08-26-2018, 12:43 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
Oops! Wrong thread. This is the 2016 thread, while you want the 2015 thread.
post #15642 of 17250 Old 08-26-2018, 07:10 PM
Liked: 0
I have a dumb question about HEOS support. I've got an x4300H, and I'd like to set up a second zone with video and audio in my office for days when I work from home. Denon is marketing HEOS as music streaming, but can I use HEOS as just a set of Zone 2 speakers? As in, can I run an HDMI cable out of the Zone 2 output and use HEOS as the speakers for that source? I guess I could just do audio passthrough on the HDMI, but it would be nice to have a better audio solution than crappy TV speakers, and without running the audio cables to a separate amp at the same time.
The only thing I can see about this is that I would have to make sure the audio is sent as PCM 2.0, which I can probably finagle in the setup. I've got a Harmony Hub, so line of sight for controlling the TV source won't be a problem.
aaronburro is offline
post #15643 of 17250 Old 08-27-2018, 03:04 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
Yes, although the HEOS speakers wouldn't be considered Zone 2 speakers as you can have up to 32 independent HEOS zones (in addition to the AVR's Zone 2 and Zone 3). Additionally, if you purchase 2 HEOS speakers of the same model number (eg. HEOS 3 + HEOS 3), you can group them as a STEREO L/R pair. The HDMI source would pass to the Zone 2 TV via the Zone 2 HDMI monitor output. With the source set to PCM 2.0 (ie. not DD), you could also select this HDMI source to pass to the HEOS speaker pair (as the X4300H can pass a PCM 2.0 over HDMI to both Zone 2 and HEOS speakers as well).
post #15644 of 17250 Old 08-27-2018, 06:07 AM
Liked: 0
Audyssey MultEQ XT causing bottoming out
I currently have a very simple setup with 2 front stereo speakers (no sub):
Denon AVR-X2300W
Wharfedale Diamond 220
I have the audyssey DEQ enabled and overall movies/tv shows sound a lot better, but I noticed at very low frequencies with the eq enabled the speakers are bottoming out.
Is there a solution to this? Will adding a sub resolve the issue somehow?
nsmarks is offline
post #15645 of 17250 Old 08-27-2018, 07:24 AM
Panic 66's Avatar
Quoted: 53 Post(s)
Liked: 36
No DD+ through ARC with S720W and TCL 6-Series
I purchased my TCL 6-Series about 5 weeks ago and this was the first time I have used the ARC feature with my Denon 720. When I first set things up I was not getting any sound when trying to use ARC. After some trial and error I realized that the only way I could get audio though ARC was to change the format to Dolby Digital or PCM. If I set it to Auto or to one of the DD+ options I get nothing. I have tried 3 different certified HDMI cables so I do not believe that is the problem. I tried setting the HDMI control to both on and off in the Denon (ARC is on of course). I also tried a factory reset on both devices as well as disconnecting the power and cables. The TCL see's the Denon as a connected device and controls the volume properly. I wasted a good amount of time on the phone with TCL today and they were of no help. I called Denon a few weeks ago and they suggested I send my receiver in for repair. I am about to just throw in the towel and live with DD but I do have an Atmos setup. I can also just use my Nvidia Shield if I want DD+/Atmos but then I lose Dolby Vision. Any ideas? Thanks
Panic 66 is offline
post #15646 of 17250 Old 08-27-2018, 08:17 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
Denon AVR-X2300W
Yes. As those are only small bookshelf speakers which don't have a very low frequency extension, adding a dedicated subwoofer will indeed help.
post #15647 of 17250 Old 08-27-2018, 08:20 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
Perhaps another S720W owner can chime in re: DD+ over ARC issues?
Otherwise, you can use either Dolby Surround or DTS Neural:X to simulate the DD audio to your Atmos speakers with likely very little difference in audio quality.
post #15648 of 17250 Old 08-27-2018, 09:54 AM
Panic 66's Avatar
Quoted: 53 Post(s)
Liked: 36
Thanks jdsmoothie. I do use the up-convert feature pretty much 100% for non Atmos 5.1. It sounds really good and at times sounds better than some of the true Atmos soundtracks I have heard.
Panic 66 is offline
post #15649 of 17250 Old 08-27-2018, 09:55 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
Denon AVR-X2300W
yes.
you are asking your speakers to do things they just cannot do (as you have found out).
- chris
https://www.avsforum.com/t/1332917/ccotenj-finally-gets-a-projector
ccotenj is offline
post #15650 of 17250 Old 08-27-2018, 03:20 PM
mike929's Avatar
Quoted: 145 Post(s)
Liked: 34
bump
Origin - mrmike929
PSN - mrmike929
Steam - mike929
Xbox - mrmike929
mike929 is offline
post #15651 of 17250 Old 08-27-2018, 04:01 PM
DougDingle's Avatar
Liked: 664
Audy IFVer: 00.08
I have the same firmware and DTS versions here. I don't see any of the other stuff like Audy or anything in the photo. What screen are those from?
post #15652 of 17250 Old 08-27-2018, 04:23 PM
mike929's Avatar
Quoted: 145 Post(s)
Liked: 34
Thank you very much for the reply. I was wondering if anyone was going to.
The Audy version comes on the screen of the receiver. If you do not have your tv on ( even if you do ) you can still cycle thru all of the ones on the screen of your receiver, however i noticed the Audy one only shows on the receiver itself ( does not show on the tv or monitor )
Origin - mrmike929
PSN - mrmike929
Steam - mike929
Xbox - mrmike929
mike929 is offline
post #15653 of 17250 Old 08-27-2018, 04:53 PM
DougDingle's Avatar
Liked: 664
The info on the screen you show must be HEOS info. I don't have HEOS enabled, so it's likely that's why I don't see any of it.
ahblaza likes this.
post #15654 of 17250 Old 08-27-2018, 05:02 PM
mike929's Avatar
Quoted: 145 Post(s)
Liked: 34
Ok, I do have a Heos 1 speaker.
Origin - mrmike929
PSN - mrmike929
Steam - mike929
Xbox - mrmike929
mike929 is offline
post #15655 of 17250 Old 08-28-2018, 07:33 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
The HEOS info listed in the STATUS panel refers to the HEOS module on board the AVR (ie. nothing to do with external HEOS speakers).
This panel can be displayed by powering on the AVR while holding the SETUP and OPTION buttons ….then press the STATUS button to make the info appear on the TV.
post #15656 of 17250 Old 08-28-2018, 09:10 AM
mike929's Avatar
Quoted: 145 Post(s)
Liked: 34
If my firmware is current. Why am I reading this forum seeing people talking about getting a new firmware notice. I don't think anyone has posted the firmware version, which is why I even asked my question. Of course I could have missed it, if it was mentioned.
Origin - mrmike929
PSN - mrmike929
Steam - mike929
Xbox - mrmike929
mike929 is offline
post #15657 of 17250 Old 08-28-2018, 05:27 PM
Nathan_R's Avatar
I've been prompted about (and have installed) the Airplay 2 firmware version four times now on my 6300h. After completing the update, I check if there's a new version, and it of course says I'm current. Then a couple of days later, I'll get prompted to install the same firmware version again. I've disabled firmware notification multiple times, but it of course ignores my wishes and notifies me anyway.
ahblaza likes this.
PSN: KyFriedNate
Nathan_R is online now
post #15658 of 17250 Old 08-28-2018, 06:45 PM
mike929's Avatar
Quoted: 145 Post(s)
Liked: 34
That would be beyond frustrating. I don't know if I have that update or not. My unit does not show an available update.
Origin - mrmike929
PSN - mrmike929
Steam - mike929
Xbox - mrmike929
mike929 is offline
post #15659 of 17250 Old 08-29-2018, 03:09 PM
Liked: 1
Denon responded today about my latest firmware update/distortion issue. Ironically, it was already sent to a service center before with "no issue found" :-). Hopefully everyone is complaining enough for them to fix it in a future update, staying on the May firmware for now.
"Thank you for contacting Sound United, we value you as a Sound United customer and appreciate the opportunity to be of assistance!
This needs service if it was calibrated by audyssey."
Jens Loeffler is offline
post #15660 of 17250 Old 08-31-2018, 12:49 PM
Liked: 0
Sorry if this was already asked, but through the search I couldn't find a proper answer:
I can pair the bluetooth between my x1300 and my computer (after a reset I did) but when I play music from the computer now I can't hear anything. With other devices is fine, there must be something with the AVR (though keeps saying it is playing from my computer).
thanks
charliebarcelona is offline
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
