The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ - Page 574 - AVS Forum | Home Theater Discussions And Reviews
 281439Likes
post #17191 of 17768 Old 09-19-2019, 10:41 AM
Liked: 0
I've been using an X4300h for exactly two years, and last night something went wrong with my system. I'm pretty sure it's an analog problem, but I'm not sure if it's the speaker, the AVR, or the wiring. Can anyone help me narrow it down?
When the volume is at 70% or above, the menu sound effects from my TiVo are distorted on the center speaker. The distortion is sort of a metallic twang or buzz, like sticking a piece of paper in fan blades... I'm sure an audio engineer would recognize it immediately, but that's the best I can do. Also, when I play white noise, it sounds very slightly choppy on the center speaker, like the volume is dipping for a few tenths of a second. I haven't noticed the problem on anything other source, but it's probably affecting everything.
I definitely did not have this problem twenty-four hours ago. I haven't changed anything in the meantime. In fact, I literally haven't touched any of the components. Interestingly, at the same moment that the problem started, an AC adapter died on the other side of my apartment, so there might have been some kind of power surge. The AVR is on a UPS, though, so that shouldn't have affected it.
I have two TiVos, and both are connected to the AVR through an HDMI switch. Both of the TiVos have the same problem. I've tried rebooting them. One of the TiVos is set to Dolby Digital, but the menu sounds are always PCM anyway. When I connected them to my other TVs (through the matrix switch,) they sound normal.
I have 9.1 speakers, with A+B front speakers. I've run Audyssey. The center speaker is a Polk TL3CC. My speaker wiring is really complicated, and I hope I don't have to mess with it... again, though, I literally had not touched it when the problem started. I don't know why it would suddenly fail now. I could rig up a bypass to the center speaker to test it, but that would be a pain.
Does this sound like a problem with the speaker, the AVR, the wiring, or something else? It may not seem like a big deal, but even if it only affects the TiVo menus, it's super annoying. Any suggestions?
kaphka is offline
post #17192 of 17768 Old 09-19-2019, 10:47 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 23720 Post(s)
Liked: 13061
Originally Posted by mappetti View Post
Is there a way to increase the volume of the center channel speaker on the Denon AVR-X3200W?
Tanks in advance.
Vhs
Two ways:
(1) MANUAL SETUP - LEVELS - TEST TONE START - CENTER (global for all sources)
(2) OPTION - CHANNEL LEVEL ADJUSTMENT - CENTER (source specific)
jdsmoothie is offline
post #17193 of 17768 Old 09-19-2019, 11:55 AM
patoberli's Avatar
Quoted: 183 Post(s)
Liked: 75
Send a message via Skype™ to patoberli
Just received another software update in Europe on my X4300H.
Version: 6461-1138-8402-0525
DTS Verrsion: 3.90.50.51
patoberli is offline
post #17194 of 17768 Old 09-19-2019, 08:46 PM
Madmax67's Avatar
Quoted: 2410 Post(s)
Liked: 2675
Originally Posted by Agent 7100 View Post
you suggest me to buy a newer Denon AV?! I do but not a Denon any more
Nope. It's...Click image for larger version
mrtickleuk likes this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #17195 of 17768 Old 09-19-2019, 09:07 PM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
Originally Posted by Madmax67 View Post
Nope. It's... just the facts...Attachment 2617756
.. but ultimately the same outcome!
Let's recall.. my 3yo AVR generation got stripped of (without replacement):
1) Pandora
2) Sirius
3) vTuner hence Internet radio in general (occasionally it still works)
..and Denon finds that okay leaving people with such castrated devices after 3 years?!
I am seriously unimpressed by such non existent customer 'service' attitude hence.... that's it!
Denon AVR-X1300w
Yamaha 7.1 Speaker System
OLED55C9PTA TV
Agent 7100 is offline
post #17196 of 17768 Old 09-19-2019, 09:08 PM
Madmax67's Avatar
Liked: 2675
If something presents itself on only one source then it's more than likely that source that is the problem. I had a similar issue a year or so back with a certain DirecTV news channel and only on one specific show. It was the sources audio that was the problem. Fixed itself on its own after a few months. You might swap out another speaker for the center just to make sure it's not the speaker itself but my money is on the source. Not much you can do other than maybe disable Dynamic EQ and mess with the manual tone control settings.
Depends on the clamping Voltage of the UPS.
Madmax67 is offline
post #17197 of 17768 Old 09-19-2019, 09:13 PM
Madmax67's Avatar
Liked: 2675
1) Pandora
2) Sirius
I agree. This should be it.Click image for larger version
Madmax67 is offline
post #17198 of 17768 Old 09-20-2019, 02:28 AM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
I agree. This should be it.Attachment 2617760
... yawns a Denon representative? very pointy image!
Denon AVR-X1300w
OLED55C9PTA TV
post #17199 of 17768 Old 09-20-2019, 08:34 AM
Dan in St. Louis's Avatar
Quoted: 394 Post(s)
Liked: 316
Tanks in advance.
Vhs
I don't have an X3200 Owners manual handy, but this page from its predecessor X3100 shows two ways: Dialog Level and Center Channel Level.
M = Mega, m = milli. K = Kelvin, k = kilo. B = Bytes, b = bits. G = Giga, g = gravity. Dan in Saint Louis
Dan in St. Louis is offline
post #17200 of 17768 Old 09-20-2019, 10:21 AM
mappetti's Avatar
Liked: 0
Two ways:
thank you!!!!!!
mappetti is offline
post #17201 of 17768 Old 09-20-2019, 10:22 AM
mappetti's Avatar
Liked: 0
thank you!!!!!!!
mappetti is offline
post #17202 of 17768 Old 09-20-2019, 10:34 AM
Liked: 0
There was also the choppy white noise, and after I posted, I confirmed that I could hear the problem on my Roku too. However, it's all gone today. I'm still a little worried, but I'll keep my fingers crossed.
kaphka is offline
post #17203 of 17768 Old 09-20-2019, 12:19 PM
afrogt's Avatar
Quoted: 2330 Post(s)
Liked: 1523
1) Pandora
2) Sirius
I have the x3300 and I still have Pandora and Internet radio. I never used Sirius.
Afro GT
afrogt is offline
post #17204 of 17768 Old 09-20-2019, 02:05 PM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
That's good for you but my AVR got Pandora/Sirius removed a long time ago (I have latest firmware) and internet radio is very patchy here - I am under the impression the bandwidth provided by vTuner is very limited. In the morning vTuner can load but middays when I like to have it during lunch... usually nada, or when lucky it works!
Unfortunately I have no option to manually change music providers in the AVR
Denon AVR-X1300w
OLED55C9PTA TV
post #17205 of 17768 Old 09-20-2019, 02:08 PM
afrogt's Avatar
Liked: 1523
^^I see you're in Australia, maybe it that is a factor?
Afro GT
afrogt is offline
post #17206 of 17768 Old 09-20-2019, 02:20 PM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
You are probably right there but who cares anyway?
Denon AVR-X1300w
OLED55C9PTA TV
post #17207 of 17768 Old 09-21-2019, 03:35 AM
mrtickleuk's Avatar
Quoted: 5730 Post(s)
Liked: 8279
1) Pandora
2) Sirius
Let's recall the WHOLE story, not just half of it, shall we? That would be fairer than your list.
Your AVR also had added, features which were not in the original spec and were not promised.
1) Passthrough of Dolby Vision over HDMI
2) Passthrough of HLG over HDMI
3) Support for Auto Low Latency Mode of HDMI 2.1 (since Samsung 2018 TVs crashed when connected to it).
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #17208 of 17768 Old 09-21-2019, 07:07 AM
kcgr's Avatar
Quoted: 90 Post(s)
Liked: 87
I have a 4300 and think I have a dead HDMI port. Things were great until yesterday.
Note .. I've rebooted everthing a few times
I have my directv box plugged into the far left port (looking at rear). No output.
If I move the cable to aux on the front panel ... it works
if I move the cable to the right, one or two ports, it works.
If I try my 4k player in the 'dead port' .. no output.
tried a different cable .... same behavior. Looks like the port is dead. Anything else I can try?
Is there a way to reset that port (don't think so)
I do have a fan on top after my last repairs to the video board and things seem very cool. I have not tried any resets. I cannot see how that would help. At this point it looks like it is back to the factory center.
kcgr is offline
post #17209 of 17768 Old 09-21-2019, 10:32 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13061
Warranty repair.
post #17210 of 17768 Old 09-21-2019, 12:49 PM
kcgr's Avatar
Quoted: 90 Post(s)
Liked: 87
Warranty repair.
yea, that's what I reluctantly concluded. Back to the shop. At least it is under warranty.
kcgr is offline
post #17211 of 17768 Old 09-21-2019, 02:20 PM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
I believe my oldish Samsung F7100 (2013) is not using any of those 3 features
Denon AVR-X1300w
OLED55C9PTA TV
post #17212 of 17768 Old 09-21-2019, 02:57 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
1) Pandora
2) Sirius
I miss vtuner as well, the web interface for control/adjustments, I much rather have that back and drop HEOS
007james is offline
post #17213 of 17768 Old 09-21-2019, 11:42 PM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
I heard the web interface is back on newer Denons (18/19 models) but I have no details
Denon AVR-X1300w
OLED55C9PTA TV
post #17214 of 17768 Old 09-21-2019, 11:49 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13061
Correct, it is.
post #17215 of 17768 Old 09-23-2019, 06:31 PM
Agent 7100's Avatar
Quoted: 74 Post(s)
Liked: 24
Thank you....
... to whoever looked into my vTuner problem - the last 3 days I could listen to my lunchtime radio station without any loading issues!
Spoiler!
Denon AVR-X1300w
OLED55C9PTA TV
post #17216 of 17768 Old 09-30-2019, 08:04 AM
Liked: 0
Purchasing Denon AVR-X4300H
Hello, I am looking at purchasing a used Denon X4300H unit but would like some input from everyone.
I would like to know the following:
1. Is it still a good unit in 2019 to purchase?
2. If not what would you recommend as an alternative. Please keep in mind I am looking at spending less then $1000.00 Canadian (Around 750 US)
Any help would be greatly appreciated.
Thanks in advanced for your help.
George Poncho is offline
post #17217 of 17768 Old 09-30-2019, 08:49 AM
patoberli's Avatar
Quoted: 183 Post(s)
Liked: 75
Check the 2018 models like the X4400H. Currently they are above your price point, but if you can wait till black Friday, you might get a unit for that price. If I remember correctly, it was the same last year with the X4300H. Pro is, you have a brand new unit with warranty.
post #17218 of 17768 Old 09-30-2019, 10:15 AM
tom703's Avatar
Quoted: 107 Post(s)
Liked: 108
During the end of year closeouts or Black Friday, there should be some really good offers of the previous year models. In the 2017 closeout sales, I picked up my Denon X4300H for $799 US. Just watch for the sales, usually in November, to get the best prices.
Samsung UN55HU8550/SEK-3500U 4K TV, and UBD-K8500 BR Player. Receivers: Denon AVR-X4300H - 5.1.4., JBL Spearkers: Center Studio 235C, 2 - Studio 590 - L&R, ES250PBK Sub, 2 - ES90 Towers - L&R surround, 2 - Studio 230 - front height, 2 - ES20 - rear height. Video production: Resolve Studio 16.1, Win 10 Pro, CPU i9 9940X, MSI X299 Carbon MB, EVGA RTX 2080, 128GB (4x16) DDR4 3200, S1H camera, GH5 camera, Zhiyun Crane 2 Gimble
tom703 is offline
post #17219 of 17768 Old 09-30-2019, 11:18 AM
Liked: 0
Update to my email. I spoke to the person and he is willing to sell me the unit for $800 Canadian which is around $605 US with no tax (no warranty).
Question:
1. Is it a good price
2. Should I leave it and wait for Black Friday (which is Canada is not as big as the US)
3. Is the 4300 still relevant (given the intro duction to HDMI 2.1 and I think that this unit is 2.0b. Please correct me if I am wrong)
My concern is that if I buy it I would like to have it for years to come without worrying that I need to upgrade 2 years down the road?
Thanks for any input
post #17220 of 17768 Old 09-30-2019, 01:26 PM
patoberli's Avatar
Quoted: 183 Post(s)
Liked: 75
The 4400 also hasn't HDMI 2.1, I think no model does yet. Anyway, I would wait till the November sales start.
6300h , 6400h , 6500h , arc , atmos , avr , avr-3300 , AVR-x2300W , avr-x3300w , connection , Denon , denon 3300 , denon avr x2300w , denon avr-x1300w , dlna , hdmi , issue , JS8500 , media player input , multi-zone , network , nexus player , OLED65E6P , pass-through , preamp , receiver problem , slingbox m1 , smart tv arc , spdif , speaker setup , video/audio , x4300h , x6300h , xbr-65x900e , zone 2 , zone 3
