*Official* Marantz 2016 NR-1607, SR-5011/6011/7011 owner's thread - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 7317Likes
post #2371 of 5089 Old 06-17-2017, 01:10 AM
jdsmoothie's Avatar
Quoted: 23210 Post(s)
Liked: 12737
Originally Posted by citsur86 View Post
Was playing with the channel levels today and realized I could turn the volume up and down on the AVR while doing this. Doesn?t that defeat the purpose? Shouldn?t the post Audyssey calibration play the levels as they were set to = 0 (reference)? Little confused on this point.
You are able to adjust the volume levels of the speakers/sub after running Audyssey to suit your preference in either Manual Setup - Levels - Test Tones (global changes across all sources) or using Option - Channel Level Adjust (single source only).
jdsmoothie is offline
post #2372 of 5089 Old 06-17-2017, 12:00 PM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1992 Post(s)
Liked: 987
That makes sense, thanks. In preparation for the 2 ceiling speakers that I am going to use I drew a diagram of how I understand it will hook up from AVR to AMP to Speakers. Could you (or anyone familiar with the SR-6011) confirm this is correct?
I plan to make the rear heights act as surround backs (which I realize isn't to Dolby spec, but worked well in my previous AVR setup). Would this amp assign work for my purposes?
| 7.2.4 Photos (Updated Photos 1/5) | Frequency Response | Visual: LG 65” B7A OLED | Elite VMAX-2 Electric 120" | Optoma GT1080 Proj |
| AVR/Amps: Marantz SR-6011 9C | Audio Source AMP-100VS | iNuke 1000DSP; TTs: 4x AuraSound Pro |
| Center: B&W CM Center 2 S2 Ed | Fronts: 2x B&W 684 S1s | Side Surrounds: 2x B&W 685 S1 |
| Front/Rear Heights: 4x Polk T15 | In-Ceiling: 2x Micca M-8C | Subs: 2x Rythmik FV15HP |
citsur86 is offline
post #2373 of 5089 Old 06-17-2017, 12:08 PM
jdsmoothie's Avatar
Liked: 12737
You'll note the AudioSource Amp100VS is able to connect two sets of speakers, A+B. You only have one set, yet have one speaker connected to speaker B so move them over to the other speaker A posts.
post #2374 of 5089 Old 06-17-2017, 12:11 PM
citsur86's Avatar
Liked: 987
You'll note the AudioSource Amp!00VS is able to connect two sets of speakers, A+B. You only have one set, yet have one speaker connected to speaker B so move them over to the other speaker A posts.
Oh I thought it only did 2 speakers, not 2 sets. So would this be right? (Left and Right would be correctly placed)
citsur86 is offline
post #2375 of 5089 Old 06-17-2017, 12:13 PM
jdsmoothie's Avatar
Liked: 12737
Correct, as speakers B, however, you'll have to check the Owner's manual to determine whether Speakers A is recommended when only using one pair of speakers.
post #2376 of 5089 Old 06-17-2017, 12:17 PM
citsur86's Avatar
Liked: 987
Good point. No reason to use b really - so fixed it up. I'll hook it up like this.
citsur86 is offline
post #2377 of 5089 Old 06-17-2017, 02:35 PM
Azekecse's Avatar
Quoted: 146 Post(s)
Liked: 95
You also might to switch the button to stereo mode on the amp.
Peace and blessings,
Azeke
Azekecse is offline
post #2378 of 5089 Old 06-17-2017, 03:30 PM
Quoted: 112 Post(s)
Liked: 52
New Power Cord
What type of female connector do I need on a replacement power cord from Shunyata Research or Transparent???
TIA
Dave
dave2002ti is offline
post #2379 of 5089 Old 06-18-2017, 05:07 AM
citsur86's Avatar
Liked: 987
Is it possible that the 2016 models will have Dolby vision at any time as an update or does that require some proprietary Dolby hardware?
citsur86 is offline
post #2380 of 5089 Old 06-18-2017, 10:10 AM
Quoted: 30 Post(s)
Thumbs up
http://marantz-uk.custhelp.com/app/a...-compatibility
For the following models, Marantz will issue a firmware update to additionally support Dolby Vision and HLG (Hybrid Log Gamma) HDR pass-through:
NR1607, SR5011, SR6011, SR7011 and AV7703. It will happen either later this year or early next but it's coming regardless, which is good news.
Braveheart_NZ is offline
post #2381 of 5089 Old 06-18-2017, 10:33 AM
Sharp1080's Avatar
Quoted: 1071 Post(s)
Liked: 772
TIA
Dave
Have you contacted either company for their recommendation? They might be a better source.
Sharp1080 is offline
post #2382 of 5089 Old 06-18-2017, 11:06 AM
Quoted: 112 Post(s)
Liked: 52
That was my next step.
Just its easier to price shop if I have the right connectors
post #2383 of 5089 Old 06-18-2017, 12:18 PM
z3540's Avatar
Hello all, I have a dying Pioneer Elite SC-57 and a Sony XBR 65X900A that is forming small bubbles between the glass and led. Well, I took the dive and bought the Marantz SR7011 and one of the last two LG OLED77G6P at the local Best Buy. However, I am considering returning the SR7011 because I hear that the SR7012 is coming out in Sept/Oct. Anyone know if the 7012 will have HDMI 2.1? I know the G6P is HDMI 2.0 so 2.1 will be useless now. I wanted to future proof the receiver as much as possible especially if it will have 2.1 in Sep/Oct. I considered waiting for 2.1 on TVs too but I wanted OLED with passive 3D. The G6P is the last of its kind so I have no other choice (have lots of 3D Blue Rays).
z3540 is offline
post #2384 of 5089 Old 06-18-2017, 12:20 PM
jdsmoothie's Avatar
Liked: 12737
It wont ... the HDMI 2.1 spec hasn't even been released to the AVR mfr's yet. Look for the 2018 models to possibly be HDMI 2.1.
Keith Zuehlke likes this.
post #2385 of 5089 Old 06-18-2017, 12:41 PM
z3540's Avatar
Wow, thanks for the quick reply, jdsmotthie! I guess I'll be keeping it then. Can't wait till I put everything together.
z3540 is offline
post #2386 of 5089 Old 06-19-2017, 10:57 AM
Severin's Avatar
Speaker B question
Hi
Just orderd a SR 6011. Is it able to switch between a 7.1.2 set up and speaker B depending on input and channels, thats how I interpreted the manual see attachment? I would like to use speaker B in pure direct mode for 2 ch audio.
Severin is offline
post #2387 of 5089 Old 06-19-2017, 12:49 PM
jdsmoothie's Avatar
Liked: 12737
Originally Posted by Severin View Post
Hi
Yes. You can select Front Speaker = B for STEREO only listening.
post #2388 of 5089 Old 06-19-2017, 12:57 PM
Severin's Avatar
Perfect Thanks jdsmoothie.
Severin is offline
post #2389 of 5089 Old 06-19-2017, 05:41 PM
Mrbonus's Avatar
Quoted: 55 Post(s)
Hello looking to buy my first receiver either martanz or denon. Here is my setup..looking for a 7.1.2.
14x14 room
Klipsch
Rp260
440c
2 240s (sourround)
2Polk mc80 ceiling Dolby atmos
I'll be watching movies and gaming on this. I also might want a 9 channel receiver if someone can recommend me. Thanks!
Mrbonus is offline
post #2390 of 5089 Old 06-20-2017, 12:02 AM
CBdicX's Avatar
Quoted: 1689 Post(s)
Liked: 405
14x14 room
Klipsch
Rp260
440c
2 240s (sourround)
Used both brands, no real differents in "sound", both are good.
Have now a SR7011 but like the "no need to flip down door" design more from Denon, if you like to see the big display.
Also like the Dialog Enhancer from Denon, but think the Audyssey app can do the same for Marantz who has no Dialog Enhancer.
For me personal its more the looks then sound that make the differents between D&M.
CBdicX is online now
post #2391 of 5089 Old 06-20-2017, 12:07 AM
jdsmoothie's Avatar
Liked: 12737
14x14 room
Klipsch
Rp260
440c
2 240s (sourround)
The following current models will meet your 9CH use case requirement: Marantz SR6011/SR7011; Denon X4300H/X6300H
Select the appropriate model based on your other feature/input/output requirements.
post #2392 of 5089 Old 06-20-2017, 01:45 AM
Liked: 0
Hi,
I've just bought biwiring speakers, does anyone know how to bi-wire them on marantz? My sistem is only front speakers (Dynavoice DF-6) and some back ceiling speakers (Bang&Olufsen Celestial BOC86). I have no experience in Hi-Fi thus i have no idea how to connect fron speakers with bi-wires to my SR5011...
Kristijonas Valius is offline
post #2393 of 5089 Old 06-20-2017, 01:58 AM
jdsmoothie's Avatar
Liked: 12737
Originally Posted by Kristijonas Valius View Post
Hi,
A waste of time as doing so provides no benefit.
post #2394 of 5089 Old 06-20-2017, 03:12 AM
CBdicX's Avatar
Liked: 405
Hi,
I also bi-wire/bi-amp my front speakers, think it will not make them sound any better, but i will not harm them ither !
I like the idea of using one amp for Hight/Middle and one amp for the Woofers.
For the Woofer i use a 100% OFC cable, for H/M i use a Silver/copper cable.
So if you have 2 amps to spare, just do it.
Set the (9 channel) receiver to 7.x Bi-amp.
This way you can use 5.1 Bi-amp and 2 Height speakers.....
To be honest, i can not detect any sound differents, Bi-amp or not, but i have the cables and have (for this moment) 2 not used amps in my 7011, this is why i do it......
post #2395 of 5089 Old 06-20-2017, 07:18 AM
Quoted: 428 Post(s)
Liked: 46
Finally fired up the SR-5011 yesterday and tried to play some songs.
I have the HSU MK5 sub that I just bought and unless I put the mode on DTS neural X? (by pressing on the 'music' button couple of times on the remote), the subwoofer would not activate. What am I doing wrong?
Asgard1an is offline
post #2396 of 5089 Old 06-20-2017, 07:41 AM
Ladeback's Avatar
Quoted: 1457 Post(s)
Liked: 541
Send a message via MSN to Ladeback
I don't know much about the 5011, but on another thread someone was having an issue I think with a 6011 and getting the subs to work and reran Audyssey to get the subs to work.
You might try that.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is online now
post #2397 of 5089 Old 06-20-2017, 07:42 AM
Quoted: 428 Post(s)
Liked: 46
You might try that.
Ok i will try that later today and report. Thanks
post #2398 of 5089 Old 06-20-2017, 12:15 PM
jdsmoothie's Avatar
Liked: 12737
Before you run Audyssey again, simply go into Manual Setup and reset any speakers set to LARGE to SMALL/80Hz and also go to Manual Setup - Levels - Test Tones - Subwoofer and raise the volume up about +5db (unless it's at -12db than you'll need to lower the gain/volume on the sub to about 10 o'clock and run Audyssey again and then raise it +5db in Manual Setup).
post #2399 of 5089 Old 06-20-2017, 02:36 PM
Quoted: 428 Post(s)
Liked: 46
Now my 2 front speakers are big towers, do i still set them to small.
1 thing i forgot to mention is that when the subwoofer worked (music set to neural ..) the big towers were doing some weird noises and the music was playing center speaker.
post #2400 of 5089 Old 06-20-2017, 03:42 PM
jdsmoothie's Avatar
Liked: 12737
Yup. Doesn't matter the size .. the subwoofer can likely still handle the lower frequencies much better.
analog or toslink headphones sr6011 , audio outputs , big bang sound when turned on , front speakers won't play sound , gui selection mismatch , marantz receiver ethernet playback noise , NR-1607
