Yamaha Reveals RX-A 60 Series AVRs - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #31 of 228 Old 05-18-2016, 08:23 AM
djc11369's Avatar
Quoted: 292 Post(s)
Liked: 168
Originally Posted by WebEffect View Post
I wasn't aware that child workers in Asia build "high quality craftsmanship."
Besides, even Bose doesn't claim to have high quality craftsmanship and they're actually passionate about audio and only audio. Yamaha probably uses the same parts in their "audio" gear as they use in their toasters.
Yamaha doesn't make toasters, now Onkyo on the other hand could possibly pass for one if you put bread on top of one of their receivers. I know my 706 could probably brown it nicely.
djc11369 is offline
post #32 of 228 Old 05-18-2016, 08:31 AM
PioManiac's Avatar
Quoted: 3338 Post(s)
Liked: 8436
Originally Posted by action_jackson View Post
On the 3060, will an external amp be required to run 2 of the 4 presence speakers or will you be able to power your mains with an external amp and let the internal amp power all 4 presence speakers?
Also, lets say you have a flat screen with a drop down projection screen, will it be possible to output vide to either display while audio plays from the same speakers?
The 3060 has 11 channel processing and 9 internal amplifiers,
So yes, you need to add at least 2 channel external amplification.
You can add a 2 channel external amp to run 2 rear presence speakers (for a 7.2.4 setup)
or a more powerful 2 channel amp the run a pair of front towers (and let the 3060 run the rest)
or add a 4 channel external amp to run all 4 presence speakers.
There are pre-outs for all channels if you want to run external amps for all channels.
You could even use an older AVR with Multi-Channel inputs to act as an amp to drive the 4 presence speakers.
That's what I did with my RX-A3050 and an 8 y/o RX-V3900. (set up as 7.4.4)
I also run two displays, A 50" Pioneer Kuro and an Epson 1080UB projector (and drop down powered screen)
Both displays can work at the same time without issue...I was even doing that on my 8 y/o RX-V3900.
check out my build thread for details (link in my sig)
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #33 of 228 Old 05-18-2016, 08:40 AM
Quoted: 1889 Post(s)
Liked: 1085
I hope Yamaha is smart enough not to add boost at 15hz in its auto EQ. Not many subs could handle it. If there is a peak at 15-20hz or maybe up to 25hz I would probably leave it unless you listen at loud levels. At low to moderate volumes we are less sensitive to bass and a little bass boost is often recommended. There is very little music that goes that low, so for movies and TV a little more 'feel' in this frequency range would be welcome. So while these new receivers can go to15hz with EQ, it probably won't be used much except for people with very capable subs that add a little boost if there is no peak and want more 'feel' at low to moderate volumes. For most it won't be used.
Ellebob is offline
post #34 of 228 Old 05-18-2016, 08:42 AM
asere's Avatar
Quoted: 1924 Post(s)
Liked: 597
Having said that. Does audyssey eq down to 15?
Sent from my SM-G900P using Tapatalk
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #35 of 228 Old 05-18-2016, 08:43 AM
action_jackson's Avatar
Quoted: 353 Post(s)
Liked: 135
Thanks, I'll check out that build thread. My current receiver is 6 years old so it's about time for an upgrade. Would like to put a flat screen in the living room because the family wants to run the projector from sun up till sundown, and them bulbs are not cheap! Everything has to be simple enough that everything can be controlled by everyone. I'm thinking a new receiver may be the key.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is offline
post #36 of 228 Old 05-18-2016, 08:54 AM
Archaea's Avatar
Quoted: 3876 Post(s)
Liked: 3684
Originally Posted by asere View Post
(Furthermore, from the RX-A760 model on up the subwoofer parametric EQ operates down to 15.6 Hz)
Now does Audyssey EQ down to 15.6?
some answers in this thread.
https://www.avsforum.com/forum/90-rec...l#post44113218
Audyssey can calibrate down to 10hz with a capable system - but see the thread above for the specifics. Basically it won't calibrate below the F3 point.
https://audyssey.zendesk.com/entries...-ing-your-Subs
asere likes this.
Archaea is online now
post #37 of 228 Old 05-18-2016, 09:01 AM
asere's Avatar
Liked: 597
Has anyone has any experience with YPAO R.S.C and with YPAO R.S.C 3D?
Can you tell the difference?
asere is offline
post #38 of 228 Old 05-18-2016, 09:18 AM
asere's Avatar
Liked: 597
I also see Onkyo has the 32 bit DAC on their entry level models vs Yamaha as they have only the 24 bit. Does it matter?
asere is offline
post #39 of 228 Old 05-18-2016, 09:22 AM
Archaea's Avatar
Liked: 3684
@asere ,
not to human ears IMO.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
post #40 of 228 Old 05-18-2016, 10:41 AM
Lethean's Avatar
Quoted: 163 Post(s)
Liked: 99
Honestly, I'm just glad they're finally including a phono input.
I bought an RX-A840 with 4K pass through but no HDR a couple of years ago and while I don't have a 4K tv or projector, it would be nice to have an AVR with HDR and Atmos. I may make the switch!
But do I go 1060 or 860. For my usage I feel 860 will be fine.
Lethean is offline
post #41 of 228 Old 05-18-2016, 11:03 AM
jdsmoothie's Avatar
Quoted: 22562 Post(s)
Liked: 12279
Originally Posted by RLBURNSIDE View Post
I tried reading the manual for the 2060 + 3060 and I couldn't find anywhere that states, unlike last year's model, that Cinema DSP and YPAO is not active during Atmos playback.
Can you provide a link?
It seems absurd to me that calibrating the speaker positions of your height channels wouldn't affect the audio that comes out of them during playback of material expressly designed for that purpose.
A simple question then : when DOES YPAO 3D calibration affect the sound? when you're feeding it 5.1 / 7.1 2D audio content? How about Atmos upconversion. I simply cannot believe this feature wouldn't be active. If it isn't, I ain't buyin. (nor am I any other AVR that doesn't have it, because I have a non-standard speaker layout and want an accurate 3D sound field to be produced from a 2000 dollar processor).
No major brand AVR mfr to date has taken into consideration the actual positioning of the Atmos speakers (re: EQ) whether 2015 or 2016 models. AFAIK, the angle measurements are only used with the Cinema DSP 3D.
asere and Madmax67 like this.
jdsmoothie is offline
post #42 of 228 Old 05-18-2016, 11:29 AM
GrandPixel's Avatar
Quoted: 302 Post(s)
Liked: 64
Yes, actually it could make your system sound worse if you have a subwoofer not capable of that frequency playback. (worse it could actually destroy an inexpensive, or improperly setup DIY subwoofer arrangement).
Except that the algorithm limits the amount of boost, and so if a sub is -3 dB at 30 Hz and is down 12 dB by 20 Hz, YPAO is not going to try and make it flat too much below it's natural cutoff.
basshead81 likes this.
GrandPixel is offline
post #43 of 228 Old 05-18-2016, 11:46 AM
GrandPixel's Avatar
Quoted: 302 Post(s)
Liked: 64
My question is regarding the 15.6 Hz sub EQ - is this referring to YPAO or manual EQ post-YPAO? Is the 3050 limited to 30 Hz in manual EQ only, YPAO, or both?
post #44 of 228 Old 05-18-2016, 12:42 PM
Quoted: 99 Post(s)
Liked: 106
Do they copy/paste management speak across all brands "as-is"? Sheesh... AVR manufacturers should also focus on fixing bugs in the existing receivers. Sometimes all we need is a stable and reliable receiver, not the cutting edge garbage.
choombak is offline
post #45 of 228 Old 05-18-2016, 01:31 PM
GrandPixel's Avatar
Quoted: 302 Post(s)
Liked: 64
Does anyone know, does the 64-bit EQ calculation have a different result, or just faster?
post #46 of 228 Old 05-18-2016, 04:22 PM
Quoted: 45 Post(s)
Liked: 1
Smile
Apart from additional DSP program I don't see any huge difference between this and A3050.. someone open that door in the dark tunnel for me
Dolby Atmos 7.2.4 setup powered by Yamaha RX-A3050 and Emotiva XPA-3; Fronts: 2 x Ascend Acoustics Sierra Towers with RAAL, satin espresso; Center: 1 x Ascend Acoustics Sierra Horizon with RAAL, satin espresso; Surrounds: 4 x Ascend Acoustics Sierra-2s with RAAL, satin espresso, on 27" Skylan stands; Subs: 2 x Rythmik Audio FV15HP, piano black; Ceiling: 4 x Tannoy AMS 6DC, black; TV: LG OLED65E6P; Players: OPPO-103D and UBD-K8500
Andrey Gorodnov is offline
post #47 of 228 Old 05-18-2016, 04:29 PM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1408
And when is Cinema DSP 3D activated...if not for movies with 3D sound tracks?
Don't grok the worth of this feature at all if not for Atmos. Ok, well, yes, actually for 5.1 and 7.1 the speakers could be at different heights and positions than their default 5.1/7.1 locations, but in that case, why wouldn't it work on height channels.
In the 3060 manual, it does refer to enabling the height speakers before doing YPAO 3D which doesn't make sense at all if it's not for Atmos, since that's the only time height is used (DSU notwithstanding, which is really a pre-step that Atmos-ifies 2.0/5.1/7.1 tracks prior to redecoding them).
Mark or Scott, is there an actual Yamaha rep who frequents these boards who could chime in with an actual answer? I'm ready to plunk down cash if this feature works as advertised. 3D speaker calibration being only used for 2D sound track play back = non compos mentis.
michaelweare1 likes this.
RLBURNSIDE is offline
post #48 of 228 Old 05-18-2016, 04:30 PM
Quoted: 112 Post(s)
Liked: 31
Any word yet on the video scaler in the 2016 models? I assume lessor sources (e.g. 1080p) are scaled up to 2160p60 @ 4:2:0 color and not true 4:4:4 (e.g. lots of loss on video game video and text)? Is 2160p60 @ 4:4:4 strictly pass-through (i.e. lose on-screen GUI)?
energizerfellow is offline
post #49 of 228 Old 05-19-2016, 03:41 AM
Norixone's Avatar
Quoted: 164 Post(s)
Liked: 94
I am wondering if Yamaha will provide a firmware up-date for the 5100 and for the complete Aventage series to apply the new Eq. I do not think the mic will be any different in the new series from the older one. It would be a nice feature to have and make owners of the x50 and last year's preamps very happy.
Is anyone able to find out?
Norixone is offline
post #50 of 228 Old 05-19-2016, 06:15 AM
Quoted: 121 Post(s)
kherman is offline
post #51 of 228 Old 05-19-2016, 06:30 AM
djc11369's Avatar
Quoted: 292 Post(s)
Liked: 168
Originally Posted by kherman View Post
Not surprising, Amazon had the 3050 listed at $2,200 for the first few weeks of it's release also.
djc11369 is offline
post #52 of 228 Old 05-19-2016, 07:48 AM
gene4ht's Avatar
Quoted: 1984 Post(s)
Liked: 2681
Not to be facetious but just curious...does anyone know the meaning or definition of Aventage? It's an uncommon word in the English language and seems to be constantly misspelled in forums and threads as Advantage, Avantage, Adventage, etc.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #53 of 228 Old 05-19-2016, 09:49 AM
jdsmoothie's Avatar
Liked: 12279
I got my response info from an "actual" Yamaha rep.
post #54 of 228 Old 05-19-2016, 12:26 PM
Liked: 2
Aventage is a french word, means advantage in english. I think its used in tennis.
gene4ht likes this.
coaxy is offline
post #55 of 228 Old 05-19-2016, 01:31 PM
billmich's Avatar
Quoted: 375 Post(s)
Liked: 74
no HD radio. I'm thinking that feature will NEVER return
billmich is offline
post #56 of 228 Old 05-19-2016, 02:33 PM
Archaea's Avatar
Liked: 3684
Denon/Marantz has it.
pgwalsh likes this.
post #57 of 228 Old 05-19-2016, 05:26 PM
gene4ht's Avatar
Liked: 2681
Ahh...makes sense now...thanks!
post #58 of 228 Old 05-19-2016, 05:41 PM
PioManiac's Avatar
Liked: 8436
The French word for Advantage is actually Avantage
...the only difference is the "d" is dropped
Aventage, with an "e" after the v, is not the same thing,
sorry but it's just a name Yamaha added to their top line in 2010
but it does sound just like "Avantage" when spoken in French.
http://forvo.com/word/avantage/#fr
post #59 of 228 Old 05-20-2016, 06:59 AM
Wiscane's Avatar
Quoted: 14 Post(s)
Yamaha site $$$ change
Here is something unusual on the "Yamaha" official site. The price for the new 2060 was $1599 and the 3060 was $1999 . A little discount ! They wanted potential customers to sign up for release date information. Today I went on the Yamaha site and the price was 2060 @$1699 and the [email protected]$2199. Has anyone else noticed that ?
Wiscane is offline
post #60 of 228 Old 05-20-2016, 02:24 PM
jocedeg's Avatar
Quoted: 91 Post(s)
Liked: 94
I hear they make the best toasters.
jocedeg is offline
aventage , avr , Yamaha
