The "Official" Yamaha RX-A1060, RX-A2060 and RX-A3060 AVENTAGE AVR Thread - Page 224 - AVS Forum | Home Theater Discussions And Reviews
 33130Likes
post #6691 of 7108 Old 10-02-2018, 07:32 PM
rdgrimes's Avatar
Quoted: 3743 Post(s)
Liked: 2941
Originally Posted by ghanley View Post
I appreciate the feedback. I did set the initial volume to -50db to ensure no ears or speakers are blown out as almost happened more than once. It seemed logical that there would be a simple 'resume where you left off yes/no' setting somewhere. Apparently the fine folks at Yamaha didn't consider the utility of such a setting.
Please read the manual where it explains what happens when you set "Initial Volume" to "off".
rdgrimes is online now
post #6692 of 7108 Old 10-02-2018, 07:50 PM
ghanley's Avatar
Quoted: 21 Post(s)
Right, got it. My original complaint is that I'd prefer the unit not be so helpful as to assume I want to continue with the media I was previously listening to the day before.
ghanley is offline
post #6693 of 7108 Old 10-02-2018, 10:01 PM
PioManiac's Avatar
Quoted: 3063 Post(s)
Liked: 7367
What input setting are you suggesting the AVR should intuitively know your preferred input to switch to at startup?
...and are you suggesting that all other brands can give you that option?
Still not sure you realize the scene buttons act as power-on buttons.
So technically you CAN power the unit on from standby mode to any input you want.
richlife and Matthew76 like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #6694 of 7108 Old 10-03-2018, 05:55 AM
ghanley's Avatar
Quoted: 21 Post(s)
No idea about other brands. It just seems logical to leave me to my choices after I power on. No configurations should be required.
I haven't played with the scene settings yet but I will try that.
Thanks again.
ghanley is offline
post #6695 of 7108 Old 10-03-2018, 06:10 AM
PioManiac's Avatar
Liked: 7367
Thanks again.
Logical?
Is this by chance your first AVR?
I don't understand how the AVR is supposed to magically know what input you want it to "start" with each time, if other than the last one you used.
Does your TV/Cable box not tune to the last channel you viewed after you turn it off?
How about the radio in your car, does it not go to the last station you were listening to?
or the last song you left off from your play list?
No, it picks up where you left off unless you change it to something else.
Matthew76 likes this.
post #6696 of 7108 Old 10-03-2018, 06:24 AM
PlasmaPZ80U's Avatar
Quoted: 2776 Post(s)
Liked: 966
I've scanned the manual and searched this thread and not found my answer. I've either missed what was blatantly obvious or maybe cleverly obfuscated.
QUESTION: For my RX-A1060, how do I disable the device from returning to the previous active media selection when the device was powered off?
In other words, I want to power it on and have it not immediately play any media by default.
Can anyone help a lost and confused user?
Not sure if anyone has mentioned this yet but you can disable autoplay for some of the streaming music apps (also with scene programming)
In the latter image you could turn on or off whether the saved content (like playlist or song) autoplays when you hit the scene button. In the former, you can toggle autoplay on or off when you select that source or simply power on after having listened to that source. I think you can do this in the avr menu too, not just web setup.
ID:	2463158   Click image for larger version
Samsung 55" MU8000
Yamaha RX-A2070
KEF Q150 Bookshelf x 5
Rythmik L12 Sealed Subwoofer
PlasmaPZ80U is offline
post #6697 of 7108 Old 10-04-2018, 01:54 AM
Craig Mecak's Avatar
Quoted: 313 Post(s)
Liked: 243
New firmware v2.60 is out.
Update at your own risk.
(I had to roll back v2.58 to v1.32 because it broke my AirPlay - constant dropouts and glitches).
Hopefully v2.60 fixes that.
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is offline
post #6698 of 7108 Old 10-04-2018, 02:15 AM
tom886's Avatar
Quoted: 57 Post(s)
Liked: 41
Code:
This firmware includes
  1. A improvement in AirPlay® stability
  2. A improvement in DSD file playback
Cheers
Tom
Craig Mecak likes this.
tom886 is offline
post #6699 of 7108 Old 10-04-2018, 04:43 AM
ghanley's Avatar
Quoted: 21 Post(s)
Logical?
Let me try to simplify the point:
1: Power up.
2: Don't start playing anything.
ghanley is offline
post #6700 of 7108 Old 10-04-2018, 04:58 AM
ghanley's Avatar
Quoted: 21 Post(s)
Thank you, PlasmaP! I knew about pulling up the basic settings by calling the device IP in a browser but didn't know about the /setup option.
ghanley is offline
post #6701 of 7108 Old 10-04-2018, 05:28 AM
Liked: 966
There is also a way to do this in the avr menu on screen... I think in the option menu of those streaming apps and also under scene, detail, source, right arrow on or off.
Samsung 55" MU8000
Yamaha RX-A2070
post #6702 of 7108 Old 10-04-2018, 10:27 AM
gwsat's Avatar
Quoted: 4420 Post(s)
Liked: 5721
I just checked my 3060 and confirmed that it is still running Firmware V 2.58, although I have not yet been prompted that a later version is now available. Can anyone suggest what may be going on here?
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB and Terra Server 24 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is offline
post #6703 of 7108 Old 10-04-2018, 11:31 PM
ro2207's Avatar
Quoted: 26 Post(s)
I updated via USB. Yamaha emailed me 2.60 FW a few days ago. You can now download the file from their website. Copy the .bin file to a USB thumbdrive (small storage preferred, fat32) and load it from the advanced menu. After a 15 min update, airplay is now working properly on my RXV781. I will update my dad's RXA1060 when I get the chance.
ro2207 is offline
post #6704 of 7108 Old 10-05-2018, 01:43 AM
Quoted: 313 Post(s)
Liked: 243
I just updated to v2.60 and I'm sad to report that my AirPlay dropouts/mutes have returned.
v2.60 is just as bad as v2.58.
I will now roll back to v1.32 which has no issues with AirPlay dropouts/mutes.
Why can't they get this right and just apply whatever code worked with v1.32 and roll it into the current code?
**Annoyed**
post #6705 of 7108 Old 10-05-2018, 03:54 AM
Bond 007's Avatar
Quoted: 3196 Post(s)
Liked: 2511
Be patient.
Bond 007 is offline
post #6706 of 7108 Old 10-05-2018, 05:13 AM
VARTV's Avatar
Quoted: 139 Post(s)
Liked: 80
It would be nice if they were much more transparent about these updates...
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: [email protected]
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
post #6707 of 7108 Old 10-05-2018, 05:41 AM
bwillcox's Avatar
Quoted: 832 Post(s)
Liked: 480
I've installed it on several of my AVRs, including my 2060 and my 2070 and all is well but I never have used AirPlay. They are listing these changes:
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X700, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X700, Roku Ultra
bwillcox is offline
post #6708 of 7108 Old 10-05-2018, 09:10 AM
VARTV's Avatar
Quoted: 139 Post(s)
Liked: 80
Had some issues with AirPlay after update BUT seems steady for over an hour now (streaming SiriusXM Internet Radio)...
Robert F Corbin
VARTV is offline
post #6709 of 7108 Old 10-05-2018, 02:53 PM
gwsat's Avatar
Liked: 5721
Originally Posted by Bond 007 View Post
Be patient.
I plan to be. My unwavering policy is to not download new firmware until it becomes available via my 3060's Internet connection.
gwsat is offline
post #6710 of 7108 Old 10-05-2018, 05:18 PM
Quoted: 192 Post(s)
Liked: 97
Technically it is... it's just not popping up on the amps GUI.
The new AVR's have a small envelope that appears on the front display.
In your case, simply go into your AVR's 'advanced menu' and select 'network update' and there you have it!
dunnersfella is offline
post #6711 of 7108 Old 10-06-2018, 12:09 PM
VARTV's Avatar
Quoted: 139 Post(s)
Liked: 80
As soon as I pushed the "On Screen" button on the remote, the message came up...
Robert F Corbin
VARTV is offline
post #6712 of 7108 Old 10-06-2018, 05:40 PM
gwsat's Avatar
Liked: 5721
When I reported that my 3060 hadn't given me notice of a firmware upgrade it was after I had pressed the On Screen button. That time there was no info about a firmware update. When I saw @VARTV 's post, though, I tried it again. This time when I pressed the On Screen button I was notified that a firmware update was available. I am downloading and installing it now. Thanks for the reminder!
gwsat is offline
post #6713 of 7108 Old 10-09-2018, 02:58 AM
Bond 007's Avatar
Liked: 2511
Good deal.
gwsat likes this.
Bond 007 is offline
post #6714 of 7108 Old 10-10-2018, 08:20 AM
Quoted: 67 Post(s)
Liked: 46
another thank you for the /setup knowledge !!!
I've always hated the auto-play on SERVER input!
ghanley likes this.
SinGA is offline
post #6715 of 7108 Old 10-14-2018, 10:02 PM
richlife's Avatar
Quoted: 856 Post(s)
Liked: 1070
Been using my 3060 remotely and for tv, but tonight got the Update message when starting Spotify directly. Update successful and appears fine. Just happy to see continuing firmware updates and no play problems. (Been involved in hurricanes and other home concerns recently and just have not kept up to date. But fortunately all is well!)
gwsat likes this.
Atmos/DTS:X HT in Vaulted Room -- LG OLED Settings Options
Yamaha RX-A3060: 7.2.4 or 7.2.2 + Zone2 (switchable); OPPO 203; LG OLED65B6P; Harmony 650 & Home Hub
Base: Mirage OM-6 (FLR), MC-si (C), OM-R2 (SLR), FRx-nine (BLR)
Presence: ELAC A4s (FP), RSL C34Es (RP); 2 aci Titan subs; RP amp: AudioSource AMP100VS
richlife is offline
post #6716 of 7108 Old 10-20-2018, 09:24 AM
Liked: 0
RX-A2060 Firmware failed - Looking for previous version
Dear team member,
Many thanks for your welcoming today in your forum - I was enjoying my Yamaha RX-A2060 yesterday when I realized new firmware rev. 260 was available - It's not the first up date but today I'm facing message : ERROR! 020000 - I did try Wifi, Ethernet and USB - Try to reset AVS … no way!
Does somebody would share previous version as rev. 260 is only available?
Thanks in advance
Tonny
Ftonny is offline
post #6717 of 7108 Old 10-20-2018, 09:30 AM
signmastr's Avatar
Quoted: 16 Post(s)
Originally Posted by Ftonny View Post
Dear team member,
Thanks in advance
Tonny
Did you try this? Worked for me.
https://europe.yamaha.com/en/support.../58066_en.html
signmastr is offline
post #6718 of 7108 Old 10-22-2018, 02:47 PM
Liked: 0
Dear all,
Update failed again with ERROR! 020000 - Who can help me to understand error code? Does somebody have firmware prior 260 to share?
Thanks for your extra mile
rgds
Tonny
Ftonny is offline
post #6719 of 7108 Old 10-25-2018, 03:51 AM
Bond 007's Avatar
Liked: 2511
Dear all,
rgds
Tonny
Call Yamaha.
gwsat likes this.
Bond 007 is offline
post #6720 of 7108 Old 10-27-2018, 09:51 PM
sonicviewelite's Avatar
Quoted: 34 Post(s)
Liked: 7
My A1060 stopped working today all of sudden, no light, no display. I opened and checked fuse and it is showing continuity. What should I do now? Any fix?
sonicviewelite is offline
1060 , arc , computer , dolby atmos , lgtv , OLED65C6P , RX-A1060 , RX-A3060 , savant , Sonos , Yamaha , yamaha 1060
