The "Official" Yamaha RX-A1060, RX-A2060 and RX-A3060 AVENTAGE AVR Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 33131Likes
post #61 of 7127 Old 07-17-2016, 08:48 PM
videofx's Avatar
Quoted: 278 Post(s)
Liked: 147
Originally Posted by Bond 007 View Post
Can anybody suggest, then, any reason why I should consider either the RX-A2060 or 3060 instead of the 1060?
I can tell you why I am considering the 2060. The 3060 is 11.2 and the 2060 9.2 channels. I need front and rear Dolby Atmos configuration. The 1060 is only 7.2 so you can only get 2 front Dolby Atmos and no rear. To get the rear Atmos speakers you need at a minimum 9.2, so thats why I am looking at the 2060. If you dont care about Atmos then the 1060 is a good choice.
Comcast Xfinity with 150MB/s download speed
LG OLED65E6P 65" OLED 4K 3D DISPLAY
Panasonic DMP-UB900 4K UHD Bluray player / Pioneer HLD-X9 Laserdisc
Marantz SR-6011 AVR
Playstation 4/Blu-Ray 3D/Playstation 3/Playstation 2/Playstation
Xbox One/Xbox 360 with HD-DVD/Xbox
videofx is offline
post #62 of 7127 Old 07-17-2016, 10:20 PM
huddadudda's Avatar
Quoted: 26 Post(s)
Posted in the other thread but I got my A3060 Friday and set it up today. Not sure whats going on but I had it turned up to about vol 4 and the receiver shutoff twice. Wondering if anyone else has seen this. Running it in 6 ohms with Snell Acoustic speakers. Was using the Dolby Atmos demo disc. Soon Ill be moving to Klipsh Atmos and selling my Snell 7.2 setup. I also noticed if using the iOS Yamaha app to calibrate the speakers when changing position it freezes and "enter" doesn't work. Seems like a app bug.
huddadudda is offline
post #63 of 7127 Old 07-18-2016, 12:27 AM
jdsmoothie's Avatar
Quoted: 22007 Post(s)
Liked: 11930
Originally Posted by gwsat View Post
I have had an RX-V3900 for 7 years and had an RX-V2400 for 5 years before that. My 3900 has been wonderful but I am getting ready to upgrade my HT system by adding a 4K HDTV and other 4K compatible components, including a new Yamaha receiver. The 3900, of course, is not 4K compatible. The model who's specs are closest to the 3900 is the RX-A1160. My current speakers, a 7.1 system from Hsu, are terrific so I see no reason to replace or add to them. I'm not ready to undertake the hassle of putting in an Atmos system. Can anybody suggest, then, any reason why I should consider either the RX-A2060 or 3060 instead of the 1060? Any feedback will be gratefully considered.
Depends on your feature/input/output requirements. If you never expect to expand beyond 7.1 (adding either heights or a second sub) and don't need Zones 3/4 capability, the A1060 would meet your needs. If you do want to add Zones 3/4 support, heights, and/or a second sub, the A2060 would be required. And if you want the previously listed features and/or the best audio quality, the "flagship" A3060 would be your best choice.
jdsmoothie is online now
post #64 of 7127 Old 07-18-2016, 01:38 AM
Bond 007's Avatar
Quoted: 3215 Post(s)
Liked: 2528
Switch 3060 back to 8 ohm.
Madmax67 likes this.
Bond 007 is offline
post #65 of 7127 Old 07-18-2016, 06:54 AM
gwsat's Avatar
Quoted: 4434 Post(s)
Liked: 5762
Originally Posted by Craig Mecak View Post
If I recall, The RX-V3900 was Yamaha's top-of-the-line receiver at the time. So the equivalent now is the RX-A3060. No question.
Cheers,
Craig.
Thanks for the reminder that the RX-V3900 was Yamaha's top of the line. This caused me to go back and check the 3900'a specs. This revealed that it was a 140W receiver, not 100, which had been my recollection. Consequently, I will definitely be getting the RX-A3060.
P.S. Just talked to my AV contractor and changed the receiver spec to the RX-A3060 from the 2060. Thanks again for your input.
gwsat is offline
post #66 of 7127 Old 07-18-2016, 08:05 AM
Bond 007's Avatar
Liked: 2528
Wattage is the last spec to be considered (if at all) when choosing a receiver. But if you can easily afford the 3060 there should never have been any question.
Bond 007 is offline
post #67 of 7127 Old 07-18-2016, 08:12 AM
gwsat's Avatar
Liked: 5762
You are right that wattage is just one spec among many to be considered. I looked at it simply because wattage is generally a decent indicator of the other capabilities of a receiver. Anyway, I talked to my AV guy and had him put the 3060 in his bid, which I have accepted.
I have had a lot of good AV gear over many years but most of it added to my system on my own. My new system will not only be a turn key job done by a contractor, it will be the most grand I have ever had. I am excited.
gwsat is offline
post #68 of 7127 Old 07-18-2016, 08:16 AM
Bond 007's Avatar
Liked: 2528
Congrats and enjoy.
gwsat likes this.
Bond 007 is offline
post #69 of 7127 Old 07-18-2016, 09:59 AM
Anton G A's Avatar
Quoted: 25 Post(s)
You won't be disappointed. Enjoy !
gwsat likes this.
Anton G A is offline
post #70 of 7127 Old 07-18-2016, 11:00 AM
huddadudda's Avatar
Quoted: 26 Post(s)
Thats my thought too but then it seems a bit underwhelming as the volume needs to be -5db just to get decent volume. Snells need some power to really make them open up.
post #71 of 7127 Old 07-18-2016, 01:05 PM
Bond 007's Avatar
Liked: 2528
Get an external amp.
Bond 007 is offline
post #72 of 7127 Old 07-18-2016, 01:56 PM
healthnut's Avatar
Quoted: 922 Post(s)
Liked: 908
I'm also looking at the new Yammies, but I believe you need to 3060 to get front and rear Atmos.
healthnut is offline
post #73 of 7127 Old 07-18-2016, 02:20 PM
Bond 007's Avatar
Liked: 2528
2060 will do 5.1.4 but 3060 will do 7.1.4.
Bond 007 is offline
post #74 of 7127 Old 07-18-2016, 02:21 PM
jdsmoothie's Avatar
Liked: 11930
Only if you want 7.1.4, otherwise, the A2060 can do 5.1.4.
post #75 of 7127 Old 07-18-2016, 02:32 PM
Anton G A's Avatar
Quoted: 25 Post(s)
Another distinction of the 3060 is it's ability to do Virtual Rear Presence reproduction.
post #76 of 7127 Old 07-18-2016, 02:37 PM
gwsat's Avatar
Liked: 5762
That's neat! I'm glad I am getting the 3060 because, setting up a 7.1.4 Atmos system will just be a matter of having my AV guy install 4 in-ceiling Atmos speakers. Not easy and not cheap but doable. I'm still not sure I will ever do it but it's nice to know how.
gwsat is offline
post #77 of 7127 Old 07-18-2016, 02:54 PM
healthnut's Avatar
Quoted: 922 Post(s)
Liked: 908
Thanks for the clarification. How much of an enhancement are the rear surrounds? Has anyone tested them with and without and discerned a meaningful difference?
post #78 of 7127 Old 07-18-2016, 03:17 PM
gwsat's Avatar
Liked: 5762
I have had a 7.1 system for a number of years and love it. With a 7.1 HD audio track on a BD movie, it is spectacular. I also like it when I use DD PLIIx on my 3900 to matrix 5.1 audio to virtual 7.1. PLIIx works well. My AV guy suggested that I might want to use the rear surrounds in my current setup as rear Atmos speakers. That way, I would only have to buy 2 new Atmos speakers for the front. I don't want to do that, though. I plan to just wait and when the time comes, spring for 4 new in-ceiling Atmos speakers.
gwsat is offline
post #79 of 7127 Old 07-18-2016, 03:20 PM
Bond 007's Avatar
Liked: 2528
Lots of people have. With the proper source and setup the difference should be significant.
Bond 007 is offline
post #80 of 7127 Old 07-18-2016, 03:23 PM
Bond 007's Avatar
Liked: 2528
That is wise.
Bond 007 is offline
post #81 of 7127 Old 07-18-2016, 03:29 PM
Quoted: 335 Post(s)
Liked: 143
Speaking of; I got my 2060 running over the weekend.
Sure enough, DPLII is no longer on the list of Sur Decoders
DSU might be a great all-around upmixer, but I wonder if it correctly detects and accurately upmixes specifically PLII-encoded materials? I still play plenty of PlayStation 2 games that have specific modes for PLII surround.
kitti is offline
post #82 of 7127 Old 07-18-2016, 03:41 PM
gwsat's Avatar
Liked: 5762
That is wise.
I was first an audiophile and then a home theater fanatic and have been for more than 50 years. The new system I am buying marks the first time I have ever used an AV contractor to design and install a system. I had decided on a 4K HDTV and HT receiver before I brought my AV guy onboard but he has put together the system for me. The result is several ultra high end components, which I would never have bought on my own but the benefit is that everything will be turn key and will have capabilities I never dreamed of before. For the first time, I won't have to worry about connecting components, programming remotes, and a zillion other details. That's what I'm paying my AV guy premium prices for. At the end of the day, we get what we pay for.
gwsat is offline
post #83 of 7127 Old 07-18-2016, 03:49 PM
gwsat's Avatar
Liked: 5762
I just texted my AV guy and asked him to try to find out why Yamaha has dropped DD PLIIx from its 2016 RX-A lineup. I can't imagine why Yamaha would do that but there it is. Will report what I find out.
gwsat is offline
post #84 of 7127 Old 07-18-2016, 03:52 PM
healthnut's Avatar
Quoted: 922 Post(s)
Liked: 908
Appreciate your thoughts
post #85 of 7127 Old 07-18-2016, 04:06 PM
Bond 007's Avatar
Liked: 2528
Good luck getting a sensible answer.
They dropped it in 2015.
Bond 007 is offline
post #86 of 7127 Old 07-18-2016, 04:08 PM
Bond 007's Avatar
Liked: 2528
Seems unlikely. PLII is for upmixing 2.0.
No loss really with DSU.
Bond 007 is offline
post #87 of 7127 Old 07-18-2016, 04:09 PM
Bond 007's Avatar
Liked: 2528
The benefits of years of hard work.
Bond 007 is offline
post #88 of 7127 Old 07-18-2016, 04:22 PM
Quoted: 335 Post(s)
Liked: 143
Well...
PLII upmixer in AVRs is for upmixing either plain 2ch or upmixing matrix-encoded 2ch soundtracks.
Materials can be matrix-encoded from a 5.1 soundtrack (technically only 4.0, but whatever) down to 2ch before distribution, specifically to be accurately and predictably upmixed from 2ch back up to 5.1 in people's homes. This is what many PlayStation 2 games do internally, on the fly. Somewhat confusingly, the encoder part of PLII is traditionally called "Dolby Surround". No joke!
Some PS2 games output DD or DTS directly on the S/PDIF, but most are either stereo or PLII matrix-encoded.
Also, they didn't drop it in 2015. It was dropped in 2016. They had it in 2015. I know because my 1050 has it.
kitti is offline
post #89 of 7127 Old 07-18-2016, 04:44 PM
Bond 007's Avatar
Liked: 2528
My bad.
This thread has been around so long I thought I had read about it in the 50 series thread.
Bond 007 is offline
post #90 of 7127 Old 07-18-2016, 04:57 PM
gwsat's Avatar
Liked: 5762
That and getting so old, the price didn't bother me much anymore.
gwsat is offline
1060 , arc , computer , dolby atmos , lgtv , OLED65C6P , RX-A1060 , RX-A3060 , savant , Sonos , Yamaha , yamaha 1060
