The "Official" Yamaha RX-A1060, RX-A2060 and RX-A3060 AVENTAGE AVR Thread - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 33132Likes
post #1201 of 7141 Old 09-29-2016, 03:30 PM
deviltaz's Avatar
Liked: 1
I don't understand the problem with the HD-DVD player. It should just output in the best mode/resolution, supported by your screen, it is capable of. It does not even have to upscale to 4K. But, I'm sure you are right, trying to get an updated set of firmware for that is likely to be lost cause![/QUOTE]
Hey thanks so much , i appreciate it.
Actually the Xbox has no problem displaying 4k in either mode it just won't do HDR in both modes.
The HD DVD Player i think might be a lost cause to get it to upscale to 4k.
You are right though it still gives a crisp image, before i bought the player i did some research and it apparently had a very decent chip in it for it's time that handled the video.
It certainly stands the test of time. I love the solid backlit remote with metal buttons it comes with.
I guess in the time of iphones now it is rather pointless a company spending much on a remote though.
The Xbox One Media remote is a little beauty though , it lights up when you touch the remote and goes out when you put it down.
deviltaz is offline
post #1202 of 7141 Old 09-29-2016, 03:39 PM
jong1's Avatar
Quoted: 510 Post(s)
Liked: 499
So, given my Samsung UHD Blu-ray appears to have no problem doing HDR in Mode 2 and Pio confirms the Yamaha can do 10-bit in that mode, it seems either there is an Xbox bug, just more work needed on the Xbox HDR implementation or, possibly, there is some long term architectural reason why it can only do HDR in 4:4:4. Let's hope it's one of the first 2 and it gets fixed quickly!
Honestly, there is a reason, other than just bandwidth, why even UHD Blu-ray uses 4:2:0. The visible difference is mightly small, especially at 4K, unless you have a 100" screen or sit with your face against it. So 10/12-bit 4:2:0 is pretty much all most of us need and that should be possible in Mode 2.
jong1 is online now
post #1203 of 7141 Old 09-29-2016, 04:01 PM
deviltaz's Avatar
Liked: 1
Hmm , i guess it's not impossible Xbox may fix it with firmware. The HDMI pass through on the new Xbox only accepts 1080p as well though Microsoft said they will continue to monitor the adaption of 4k. This seems odd they didn't just include a HDMI 2.0 pass through . Just to keep the cost down a bit i guess.
In any case once you use the Xbox with HDR for gaming it makes all other games look rather flat and lifeless by comparison.
In any case i can work around it , i was just trying to limit too many button presses.
I haven't mucked around with themes as yet on the Yamaha as you can set up 12 different themes for various activities.
It has 4 quick presets on the remote as well.
I am very happy with the amp overall and none of this would be an issue if Yamaha allowed me to mix and match mode 2 and mode 1 (Please yamaha fix it with a firmware update ) , i guess you just can't have everything the way you want it
deviltaz is offline
post #1204 of 7141 Old 09-29-2016, 04:15 PM
jong1's Avatar
Quoted: 510 Post(s)
Liked: 499
The mode switch is obviously a pretty low-level thing on the Yamaha, as it seems to need a reboot afterwards. Probably not possible to make that happen with a Scene change.
jong1 is online now
post #1205 of 7141 Old 09-30-2016, 12:17 AM
jdsmoothie's Avatar
Quoted: 22198 Post(s)
Liked: 12058
Originally Posted by xb243 View Post
Hi I'm new here. I just want to ask. In terms of sound quality, which one is better Yamaha RX-A3060 or Denon AVR-X4200w? TIA
Originally Posted by surfergr View Post
How about last year's models, 2050 and 3050 vs the 4200?
Thanks for the reply. What about the 2050 vs the 4200? Is one significantly better than the other or are they comparable models?
These are subjective calls very much based on whether you prefer YPAO (Yamaha) or Audyssey (Denon). Both brands have their pros. At this level you really can't go wrong either way. Best to choose the model that best meets your feature/input/output requirements.
Originally Posted by xalao View Post
how about Denon model 7200WA? This is a good adversary for the 3060?
Better .. the A3060 likely more comparable to the X6300H.
jdsmoothie is offline
post #1206 of 7141 Old 09-30-2016, 06:48 AM
DTI
DTI's Avatar
Quoted: 34 Post(s)
purchased the 3060 a week ago replacing my SC-55 the sound on the 3060 is outstanding
Trying to figure out where this mode 1 & mode 2 are to change
DIY dust box / hush box / ceiling light... http://imagizer.imageshack.us/v2/640...633/7qBblE.jpg
DTI is offline
post #1207 of 7141 Old 09-30-2016, 07:01 AM
jong1's Avatar
Quoted: 510 Post(s)
Liked: 499
It's in the advanced setup menu. Press and hold the Straight button while you press the power button. Cycle through the various settings using the program button. Select an option using the straight button.
jong1 is online now
post #1208 of 7141 Old 09-30-2016, 07:36 AM
Bond 007's Avatar
Quoted: 3228 Post(s)
Liked: 2534
Yamaha doesnt make anything comparable to the 7200? What makes it better?
PioManiac likes this.
Bond 007 is offline
post #1209 of 7141 Old 09-30-2016, 08:24 AM
termite's Avatar
Quoted: 200 Post(s)
Liked: 56
I was wondering too..
Yamaha AVENTAGE RX-A3060, Altantic Tech System 350 THX
HSU VTF-3 MK5 HP Sub, Klipsch RP-140SA Atmos Height (x4)
Epson 5050UB, 120" 16:9 screen, Panasonic TC-P60ST50 Plasma
Dune HD Solo 4K, Popcorn Hour C-200, unRAID Server Pro OS 6
Oppo BDP-83, OPPO BDP-203, Sony BDP-BX520, Panasonic DMP‑BDT220
termite is offline
post #1210 of 7141 Old 09-30-2016, 08:43 AM
PioManiac's Avatar
Quoted: 3244 Post(s)
Liked: 8042
Spec's look pretty closely matched to last years RX-A3050
http://www.crutchfield.com/S-vbIeCxD...N-Command.html
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #1211 of 7141 Old 09-30-2016, 09:01 AM
richlife's Avatar
Quoted: 856 Post(s)
Liked: 1071
And let's not forget that the A3060 is actually a slight upgrade over the A3050.
http://faq.yamaha.com/us/en/article/...rent_page_id=1
Plus, should expect firmware updates for a year longer.
And looks like a significant price difference too.
Atmos/DTS:X HT in Vaulted Room -- LG OLED Settings Options
Yamaha RX-A3060: 7.2.4 or 7.2.2 + Zone2 (switchable); OPPO 203; LG OLED65B6P; Harmony 650 & Home Hub
Base: Mirage OM-6 (FLR), MC-si (C), OM-R2 (SLR), FRx-nine (BLR)
Presence: ELAC A4s (FP), RSL C34Es (RP); 2 aci Titan subs; RP amp: AudioSource AMP100VS
richlife is offline
post #1212 of 7141 Old 09-30-2016, 09:04 AM
gwsat's Avatar
Quoted: 4456 Post(s)
Liked: 5798
Yeah. I just compared the specs of the Denon AVR-K7200WA with those of the Yamaha RX-A3060BL and didn't see a dime's worth of difference. In fact, the Yamaha is bigger and heavier and has as much power as the Denon but the Denon costs $1,000 more. Maybe the Denon has some arcane features the Yamaha lacks but I don't know what they might be.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB and Terra Server 24 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is online now
post #1213 of 7141 Old 09-30-2016, 09:24 AM
PioManiac's Avatar
Liked: 8042
Originally Posted by gwsat View Post
... but the Denon costs $1,000 more. Maybe the Denon has some arcane features the Yamaha lacks but I don't know what they might be.
Multi-Channel Analogue inputs were removed on Yamaha AVR's after the RX-A*040 series (2014)
..but I don't think I'd pay an extra $1k to get them,
almost everything has gone to HDMI now.
post #1214 of 7141 Old 09-30-2016, 09:34 AM
dryasanne's Avatar
Quoted: 58 Post(s)
Liked: 25
Which PSB spkrs on 2060 to get atmos 5-1-4
Hi y all, greetings from Norway!
What PSB speakers do I need to get the "real thing" Atmos 5.1.4
Well I did it ... Bought a nice rx-a2060
My old 2030 needed badly an upgrade, with roku 4, samsung UDH 4 k tv and soon samsung UHD bluray, there was no way than a new 2060 :-)
So my setup at present;
Front PsB Imagine B
Centre PSB Imagine Mini center
Rear PSB Imagine mini
Rear surr PSB Image B4
Subs: 2 - two - SVS Pc 2000
I am VERY happy with this, even the neighbors were dancing along last night when playin ID4 - Resurgence
Sorry, I havent any dedicated room, so them ceiling spkrs will be mounted side by side with my crystal chandeliers.....
dryasanne is offline
post #1215 of 7141 Old 09-30-2016, 11:35 AM
marklivia's Avatar
Quoted: 97 Post(s)
Liked: 53
Okay, I'm gonna say forgive me from the get go. I just had emergency oral surgery this morning but I had to make sure my 3060 that showed up yesterday isn't DOA for CP. Hooked up everything and I get pic but only sound out of center channel.
Do I have to have this thing hooked up to the internet for setup? What little paperwork that comes with this beauty is pathetic. Can someone help me get started? Just p[oint me in the right direction. Thanks, Mark
marklivia is offline
post #1216 of 7141 Old 09-30-2016, 11:52 AM
Bond 007's Avatar
Liked: 2534
Run YPAO.
Bond 007 is offline
post #1217 of 7141 Old 09-30-2016, 12:11 PM
PioManiac's Avatar
Liked: 8042
I would start with downloading the manual (under the support tab)
http://usa.yamaha.com/products/audio...ge/rx-a3060_u/
I always do this before I even make a purchase,
1) so I know what I'm actually buying
2) so I know what the capabilities are
3) so I don't flood the forum with dumb questions
gwsat and aflorida like this.
post #1218 of 7141 Old 09-30-2016, 01:26 PM
marklivia's Avatar
Quoted: 97 Post(s)
Liked: 53
Thanks guys. Making headway.
post #1219 of 7141 Old 10-01-2016, 06:35 AM
deviltaz's Avatar
Liked: 1
Thanks to all , i did some investigations since i posted last and the Xbox One S in order to use 10 bit 4k HDR (It will still do non HDR 4k upscale on Xbox one otherwise) requires extended HDMI mode at least at the moment .(this may change with a future update).
I decided for the short time i am using my HD DVD Player at any given time it's not that big a deal to switch the mode over anyway.
At the moment there is also only a couple of games that use HDR on the Xbox One being Forza Horizon 3 and the soon to be released Gears of War 4 out of the ones i own or soon will own anyway. I did some comparisons between using the HD DVD player in 1080p 24 compared to 4k running The Matrix movie and it is noticably sharper upscaled to 4k so i prefer to use it in upscaled instead of native 1080p. This movie has quite alot of noise in it anyway so it's probably not the movie to test upscaling on from what i can gather.
I am so impressed with the sound Quality of this 3060 amp though . I'd recommend it to anyone who doesn't want to spend a fortune in upgrade their home cinema amp.
There is just such a beautiful clarity that seems perfectly matched to my Dali speakers.
healthnut likes this.
deviltaz is offline
post #1220 of 7141 Old 10-01-2016, 01:26 PM
Quoted: 56 Post(s)
Is the RX-Axx60 series ready to passthrough Dolby Vision metadata to TV when Dolby Vision UHD BD appear?
_voyager_ is offline
post #1221 of 7141 Old 10-01-2016, 02:00 PM
rdgrimes's Avatar
Quoted: 3802 Post(s)
Liked: 2998
That's an unknown, since DV doesn't yet exist in any playback devices. In theory if the AVR passes HDR-10 (it does) it should be able to do the other. But Dolby hasn't even released specs, much less certified any devices. The A-series are supposed to be able to pass 12 bit color. Dolby might decide they need to have licensing fees paid before an AVR can touch their precious bits.
rdgrimes is online now
post #1222 of 7141 Old 10-02-2016, 06:16 AM
Liked: 2
Hi,
I am getting a price quote of $1500 for a brand new a3060 from a wholesale distributor. Do you think distributors have that much margin to play with ?
Of course Monday morning I am going to check with Yamaha about distributor authenticity (distributor not listed as dealer under Yamaha page).
Distributor is very big company with good 1000+ employees and 3 locations on west coast of US.
Please do let me know your thoughts.
caryav is offline
post #1223 of 7141 Old 10-02-2016, 07:29 AM
jong1's Avatar
Quoted: 510 Post(s)
Liked: 499
Sounds very suspect to be honest.
jong1 is online now
post #1224 of 7141 Old 10-02-2016, 07:48 AM
blackangst's Avatar
Quoted: 117 Post(s)
Liked: 104
If that distributor isnt listed by Yamaha as an authorized dealer I wouldnt buy from them. Period.
My system: Yamaha RX-A3060, Emotiva XPA-2, Salk Song3, Salk Songcenter RT, Polk FXiA6, Rythmik FV15HP, Intel i7 HTPC running JRiver Media Center
blackangst is offline
post #1225 of 7141 Old 10-02-2016, 08:22 AM
richlife's Avatar
Quoted: 856 Post(s)
Liked: 1071
One reason for this is that Yamaha could deny any warranty claim if not purchased from an authorized dealer.
You may want to consider getting in touch with @jdsmoothie -- a member here who works with an authorized dealer.
I also got a low ball offer from a local different dealer. Although he claimed to be an authorized Yamaha dealer, if I did not also pay for install/setup service from him (condition of the low ball offer), he also would not provide any warranty assistance. Now I think that may well be legitimate, but I chose to work with JD, get a good price and have his support both as a rep of AV Science and here in the AVS Forums.
gwsat and hdfonz like this.
richlife is offline
post #1226 of 7141 Old 10-02-2016, 09:43 AM
Quoted: 16 Post(s)
Liked: 1
I have an RX-A3060, and I'm having some problems with the multi-zone outputs. Hopefully someone can help. Zone 1 on HDMI Out#1 and Zone 4 via HDMI Out #2 are working just fine. However, I can't seem to get either Zone 2 or Zone 3 to output anything from the zone pre-outs. My setup is a simple 5.1 speaker layout, and I have the speaker pattern set to "Basic." All of my sources are HDMI. Perhaps the 3060 won't output HDMI sources on the Zone 2/3 stereo pre-outs?
Does anyone have any ideas that might help me troubleshoot?
brianshowers is offline
post #1227 of 7141 Old 10-02-2016, 11:23 AM
Liked: 2
I believe tomorrow if Yamaha confirms are they are indeed a distributor then I guess should be ok
caryav is offline
post #1228 of 7141 Old 10-02-2016, 12:04 PM
gwsat's Avatar
Liked: 5798
Originally Posted by caryav View Post
Hi,
I share the negative reactions expressed by other posters about this deal. When something seems too good to be true, it usually is.
gwsat is online now
post #1229 of 7141 Old 10-02-2016, 12:29 PM
Liked: 2
It is the same with avscience who are not listed as dealer on Yamaha site, and JD procrures it from other dealers and gives to us. It is the same the other person is doing and I also do not understand how even Avscience(JD) is also able to give discounted price ? Do they have such margins????
For me if the piece arrives in manufacturers package I guess it should be ok.
Based on all the reviews from this forum so far indicating Yamaha is rock solid I am going with it. Unless people are talking something not true about Yamaha here.
caryav is offline
post #1230 of 7141 Old 10-02-2016, 12:45 PM
gwsat's Avatar
Liked: 5798
I hope it works out for you. If you buy from the outfit you have told us about, please let us know what your experience turns out to be.
gwsat is online now
1060 , arc , computer , dolby atmos , lgtv , OLED65C6P , RX-A1060 , RX-A3060 , savant , Sonos , Yamaha , yamaha 1060
