Question about maximum power output. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-22-2016, 06:28 PM - Thread Starter
svtfast's Avatar
Quoted: 12 Post(s)
When I read item descriptions they say, " 90 watts each channel etc etc etc."
When I look at the specs, I see this:
My speakers run on 6 ohms so should I pay attention to output on 6 ohms? I guess I need to read up on this.
Newbie to all of this.
svtfast is offline
post #2 of 5 Old 05-22-2016, 09:26 PM
Madmax67's Avatar
Quoted: 2320 Post(s)
Liked: 2608
Yeah, even that one is running a 1kHz signal only. You usually want to look for the 20-20kHz range with 2-channels driven but even that's not accurate because it's not all channels driven. I'd go by the 8 ohm speaker rating that has the 20-20kHz signal range and lower distortion percentage. Even then when in practice you'll be lucky to get half of that per speaker but that's should be enough to drive them fine. Where you can get into issues is trying to drive inefficient 4 ohm speakers at high SPL's. Then extra power may be needed. Normal 6 or 8 ohm efficient speakers should be fine. Remember it takes double the watts(power) to add 3 dB in SPL. Want double the perceived sound you need 10 times the power. Most speakers can run fine on most receivers. Running a powered subwoofer also takes a lot of the power load off of a receivers amps as well. Plus your almost never running all of the speakers at the same time in a soundtrack.
Sent from my 710C using Tapatalk
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #3 of 5 Old 05-23-2016, 07:38 AM
GIEGAR's Avatar
Quoted: 1006 Post(s)
Liked: 1698
Those are simply minimum continuous Sine wave (slang: "RMS") power ratings for various test scenarios. In your example there are four different test scenarios. Each scenario has various test conditions including the dummy resistive load (eg. 8Ω) the amp is hooked up to, the bandwidth of the test signal(s) (e.g. 20Hz - 20kHz; 1kHz) applied to the amps input, the distortion threshold at which the measurement is taken (eg. 0.08% THD) and the number of associated channels driven simultaneously. Different scenarios generally reflect accepted or mandated power rating conditions of various jurisdictions around the globe.
For AVR's sold in the US market, the manufacturer is obliged supply (somewhere in their product literature) at least the power rating scenario mandated by your FTC. In your example, those are the top two scenarios, with the only difference being the THD threshold. The manufacturer can then also supply other less stringent scenarios (eg. 6Ω; 1kHz; 1% THD; 1 channel) to yield higher power ratings. It's typically this figure that they multiply by the number of amp channels to produce a "headline" power figure for the unit (eg. 185W x 7 = 1295W!).
When comparing power ratings, I recommend you use the "FTC" ratings as at least they're consistent and mandated. Having said that, I think the rated power figures are among the least important specs to consider when choosing an AVR. More important are the features and connectivity you want/need and getting yourself as far up the manufacturer's auto EQ/room correction routine "food chain" as your budget will reasonably allow. Once you get to this level, the power rating will generally have taken care of itself.
For a good reality check if/when you begin to obsess about incremental increases in rated power, compare a few by inserting them into this calculator and seeing the differences in gain expressed as dBW (dB reference 1W). For example, the difference between 80W and 90W in your example is 0.5dBW of gain. That equates to an inaudible difference in SPL.
No, ignore them. Those are simply test scenarios that (while being acceptable somewhere around the world) are designed to extract the maximum power rating possible out of the amps and don't reflect the output of the amps at a given time during actual usage. They reflect unrealistic conditions, in particular a 10% THD threshold that would be totally intolerable in use playing program material and would also represent an very hazardous level of distortion for your speakers.
In addition, the 6Ω rating of your speakers is a nominal impedance assigned by the manufacturer to represent the speaker's frequency variant impedance. For example, below is an impedance trace for which the manufacturer specs the speaker as: "6Ω nom; 4Ω min.". The power dissipated by the speaker rapidly rises and falls with the program material and is a product of the voltage applied across the terminals and the current drawn by the (complex) load it presents to the amp (P = V x I).
Are you scoping out new model Denons? If you don't actually need the features of these new models, you can probably save some money &/or get further up the model lineup with older, superseded models.
Out of interest, what speakers will the AVR be driving?
GIEGAR is offline
post #4 of 5 Old 05-23-2016, 01:11 PM - Thread Starter
svtfast's Avatar
Quoted: 12 Post(s)
Aperion Verus Forte Tower (2)
Aperion Bravus II 8D subwoofer
Some point later this year after I move...
Aperion Verus Grand center channel speaker
svtfast is offline
post #5 of 5 Old 05-23-2016, 05:29 PM
A9X-308's Avatar
Quoted: 1823 Post(s)
Liked: 1521
I'll simply add a +1 to Giegars post above.
What I will add is that the all channels driven spec can safely be ignored, as it's not a condition the receiver will ever see in real use: it will never see all channels driven at the same amplitude in phase. I've been asking for spectrograms to back this up for years and no one has shown anything close yet. However, if someone did find a freak soundtrack or two that did it for a short period, would that be a reason to spend significantly more for a higher powered unit, or one with pre-outs so you could add external amps? For most people, I dare say the answer would be no, especially as listening during those periods you'd not likely be able to tell how much power/ch the AVR is putting out.
Car analogies are fraught, but if your hypersports car was listed with a 0-60 of 3 secs, would it be reasonable to complain to the manufacturer because it couldn't repeat that on a wet road towing a caravan?
A9X-308 is offline
