Monoprice Monolith 7 Amplifier Review - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
post #481 of 856 Old 07-28-2018, 11:15 AM
Quoted: 61 Post(s)
Liked: 6
Great advice, I found the HDMI cable running from my cable box was causing the noise. When I removed the cable the noise stopped, but if I left the cable plugged up and removed the power cord on the cable box the noise remained. Do I need to ground the cable wire at some point?
Navyship is offline
post #482 of 856 Old 07-28-2018, 11:42 AM
jsc79's Avatar
Quoted: 520 Post(s)
Liked: 733
Comcast had the coax coming into the house grounded on my meter box. I rerouted the coax ground to my main house ground that was right by the meter. This put everything on the same ground and it eliminated my hum.
Might be worth checking out how the coax coming into the house is grounded.
Jensen transformers also makes an in-line transformer that is supposed to eliminate hum from cable tv.
jsc79 is offline
post #483 of 856 Old 07-31-2018, 09:00 PM
Quattro's Avatar
Quoted: 141 Post(s)
Liked: 33
I'll be looking at a 2-channel amp in a few months. The Monolith 2x is on my short list. Any thoughts on this versus a pair of Outlaw 2200 monoblocks for $760?
https://www.outlawaudio.com/products/2200.html
Also looked at Parasound Halo A23, but it's a model that has been around for years, so, I'm thinking the Monolith's new technology has probably passed it up.
Quattro is offline
post #484 of 856 Old 08-01-2018, 06:44 AM
Oppo Beta Group
RichB's Avatar
Quoted: 2098 Post(s)
Liked: 1549
I had the 2200 and they sound good but when pushed they got harsh driving my brother-in-laws Revel F206's.
He replaced it with a Parasound A21 4 years ago (or so). He listens loud and this amp does a great job.
I'd expect similar performance from the ATI built Monolith.
- Rich
jjackkrash likes this.
Oppo UPD-205 x 2 | UPD-203 | Sonica DAC | Emotiva RMC-1 | Revel Salon2s, Voice2, Studio2s | Benchmark AHB2 x 5 | ATI AT522NC | Velodyne HGS-15 | LG 77C9 | Lumagen 2020 | HDFury Vertex2 x 2
RichB is offline
post #485 of 856 Old 08-12-2018, 09:09 PM
Quoted: 61 Post(s)
Liked: 6
Hello
Since I was due an update, I replaced my Direct System and made sure it was grounded. I also purchased the device from Emotiva to stop the humming, but that also did not work. Does anyone have any further suggestions to stop the humming noise.
Navyship is offline
post #486 of 856 Old 08-26-2018, 05:54 PM
314carpenter's Avatar
Quoted: 27 Post(s)
Hello
I disconnected a 1st gen Chromecast and that eliminated one huge hum I had. I still have a quiet one in the right channel only. I can not hear it from 4 feet away, so not worth returning.
314carpenter is online now
post #487 of 856 Old 09-03-2018, 05:27 PM
jsc79's Avatar
Quoted: 520 Post(s)
Liked: 733
The specs for the new amps are on their website. 200x3 - 100x6 and 200x3 - 100x8. Kind of a cool way to power a 5.2.4 or 7.2.4 system with the surrounds needing less power than the front stage.
Appears to use the same chassis and similar weight to the 200x7 amp.
https://www.monoprice.com/product?p_id=33307
jsc79 is offline
post #488 of 856 Old 09-03-2018, 05:36 PM
Norris Kasey's Avatar
Quoted: 164 Post(s)
Liked: 76
Wow that's awesome all in one. I bet that gets warm
Sent from my Pixel XL using Tapatalk
Norris Kasey is offline
post #489 of 856 Old 09-03-2018, 05:44 PM
JediFonger's Avatar
Quoted: 210 Post(s)
Liked: 46
does it though? i'm not an expert... do the current 7.1.4 atmos config really require only the front 3 to be higher power while the rest of the speakers are less?
to the edge of eternity and depth of infinity, stupidity knows no bound.
JediFonger is offline
post #490 of 856 Old 09-03-2018, 05:46 PM
jsc79's Avatar
Quoted: 520 Post(s)
Liked: 733
I guess I’m no expert but I would most definitely think the surrounds require less power than the front 3 considering they are just playing background/ambiance type effects.
jsc79 is offline
post #491 of 856 Old 09-03-2018, 05:48 PM
JediFonger's Avatar
Quoted: 210 Post(s)
Liked: 46
Cool
i suppose it really depends on if you have full range or not right? i dont have full range all around only the front 3.
so it does make logical sense.
post #492 of 856 Old 09-03-2018, 05:51 PM
jsc79's Avatar
Quoted: 520 Post(s)
Liked: 733
I guess it is more of an amp for HT maybe? If you listene to multichannel music and had full range speakers all around it might not be the best, but I would say that’s the exception and not the norm for something like that.
jsc79 is offline
post #493 of 856 Old 09-06-2018, 08:59 PM
Quoted: 52 Post(s)
Liked: 9
Hey Guys,
What are the odd of a brand new Monolith 5ch arrive defective? Upon power up, it make one click, blue light turn on.... about 5 seconds later, hear two fast "click click" blue light increase brightness... seem all normal?
None of the channels output any sound... Must be my wiring right? I have check 20 times by now... My system with my Denon X6200 and was running a Niles 275 for the FR, FL. It make absolutely no noise at all, not even humming.
I swap back to my Niles amp, all work fine. What the heck? I did purchase the new RCA cable (shorter 1ft length) But I have swap to the old cable that's working with the Niles and no difference.
There's no crazy trick or hidden button somewhere that changes the input from RCA to XLR <whatever this is right? No fuse either right?
All 5channels DOA? I can't believe it.
jimmyaz is offline
post #494 of 856 Old 09-07-2018, 04:13 AM
jsc79's Avatar
Quoted: 520 Post(s)
Liked: 733
There is a small switch below the rca input where you select rca or xlr. Maybe look at that. If that isn’t it I’d contact Monoprice and get a new one.
tipsymcstaggers and bdcody01 like this.
jsc79 is offline
post #495 of 856 Old 09-07-2018, 07:35 AM
Quoted: 52 Post(s)
Liked: 9
Thank you... got to excited and stick it right on the cabinet in a dark room.. never saw that switch below the XLR/RCA, lol. Work now!
jsc79 and bdcody01 like this.
jimmyaz is offline
post #496 of 856 Old 09-10-2018, 12:13 AM
Quoted: 90 Post(s)
Liked: 5
I saw on monoprice's amplifier page there will be newer versions of the monolith amp (9 and 11 channel versions with lower 100 watts for surround speakers). wondering if it's cheaper than their regular 7 channel (7x200W) amp.
Monolith by Monoprice 9 Channel (3x200 Watts + 6x100 Watts) Multi-Channel Home Theater Power Amplifier with XLR Inputs
https://www.monoprice.com/product?c_...seq=1&format=2
Monolith by Monoprice 11 Channel (3x200 + 8x100 Watts) Multi-Channel Home Theater Power Amplifier with XLR Inputs
Right now i'm just using a denon x4400h and dayton audio apa102 to run my 7.1.4 setup
canadadry is offline
post #497 of 856 Old 09-16-2018, 07:29 PM
hdash's Avatar
Quoted: 22 Post(s)
Liked: 58
Monolith power cord
I just received my Monolith 7, bought a refurb to keep the price down, and after connecting everything I attempted to plug in the power cord. It is a “t-blade” 20amp plug....so it will not just plug in to my wall outlets.
Can I use an adapter to convert the plug? Amazon has one for $10. I do not have a dedicated 20amp outlet but the house circuits are 20amp, just regular 3 prong receptacles.
I don’t want to cause damage or start a fire, I just want to enjoy my amp.
“The world's intelligence is a constant, the population is growing.”
HT: Smsng 82Q70R | Ymha CX-A5100 | Monolith 7x200 | PSA V1800 | PSB Spkrs | Sony UBPX800 | BlueJeans cbls | 2-channel: Rotel RA-1570 | Project Carbon Espirit DC | Bluesound Node 2i | Qacoustics 3050 | BlueJeans cbls
Last edited by hdash; 09-16-2018 at 07:33 PM. Reason: Did not mean to quote the previous post
hdash is offline
post #498 of 856 Old 09-16-2018, 08:56 PM
bigguyca's Avatar
Quoted: 1356 Post(s)
Liked: 1206
If the circuits are really 20 amp circuits (breaker and wiring, 12 gauge copper minimum) then a nicer solution would be to replace the current receptacle with a 20 amp, 120 V receptacle. Either a 15 amp or 20 amp plug will fit in a 20 amp receptacle. Using a licensed electrician or the equivalent would be best, although the work is simple. An adapter should work, but it's never clear how well these devices are made no matter how they are listed on Amazon or what certifications are claimed.
bdcody01 likes this.
bigguyca is offline
post #499 of 856 Old 09-17-2018, 06:41 AM
hdash's Avatar
Quoted: 22 Post(s)
Liked: 58
I guess I should have also asked if everone else who bought this amp also received the same power cord and plug. I see folks posting about plugging theirs into surge suppressors which I don’t believe have that kind of plug.
hdash is offline
post #500 of 856 Old 09-17-2018, 07:27 AM
jsc79's Avatar
Quoted: 520 Post(s)
Liked: 733
My 7X had the standard 3 prong power cord.
I’d call Monoprice and have them send out a new cord. Easy fix.
jsc79 is offline
post #501 of 856 Old 09-17-2018, 09:58 AM
Quoted: 428 Post(s)
Liked: 46
Looking at the 200x7 refurb.
You guys happy with your monolith amps? Why did you choose it versus the emotivas and outlaws? Price, performance?
Asgard1an is offline
post #502 of 856 Old 09-17-2018, 12:11 PM
hdash's Avatar
Quoted: 22 Post(s)
Liked: 58
I called them this morning and they are shipping the correct power cord.
You were right, easy fix.
Now I sit in anticipation.....
hdash is offline
post #503 of 856 Old 10-03-2018, 09:31 AM
Jrunr's Avatar
Quoted: 233 Post(s)
Liked: 41
This is a good question. Why did you chose the Monolith over the price equivalent competition?
Jrunr is online now
post #504 of 856 Old 10-03-2018, 10:04 AM
audioheaven's Avatar
Quoted: 23 Post(s)
I think it depends on your needs, and what other equipment you have. Each amp has its own sound signature ( highly debated topic - but it remains true regardless of the keyboard commandos that don't care to notice the difference ).
The ATI monoprice clones are fantastic. The outlaw amps built by ATI ( when they actually built by ATI ) are great too... EMO... questionable reliability over the years. But only you can make the choice given a your budget and short and long term goals.
But there are lots of other options. An actual ATI amp would be a good choice but it will cost you more. But will be built to ATI's specs and not someone else's
From a purely design perspective. The MP ATI amps far exceed anything EMO puts out. QC and the parts used are of better quality.
However, if you are up to check out other mfg's - there are dozens of other amp companies that are better than all three for reasonable jumps in cost. Here are just a few that are absolutely fantastic. Some are very expensive, but you can get them on the used market for steep discount
MCormack
Dsonic
Vincent
BelCanto
NAD
Acurus
Aragon
Hope this didn't muddy the water too much. For the record. I just purchased an MP 5ch and I am auditioning it currently. FOR THE MONEY --- I don't think there is a better built or better sounding amplifier. My buddy's EMO... sounds thin weak and lifeless in comparison.
tipsymcstaggers likes this.
" Listen and you will see. "
audioheaven is offline
post #505 of 856 Old 11-07-2018, 08:41 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 115
AUDIOHEAVEN
when you put in the web monoliht 5x200 vs xpa gen3 ,many peoples said émotiva is better,give me sériously why Inside or power the monolith is better then émotiva.
éventually I need monolith 5x200 or émotiva xpa5gen3 .
same power but monolith is very heavy and not have ventilator Inside that very important and I have 3 power amplifier émotiva ,you need give me good very good reason
to choice monolith.
marantz av 8805, 13 chanels, emotiva 2 xpa 5 gen1,1 emotiva xpa3 gen3, 7.4.6,4 speakers monitor 11 ,2 paradigm studio 100 v2,4 ceillings speakers ss82w sweet spot earthquake ,2 earthquake ecs-8.0,1 center Paradigm cc390,4 subs klipsch r-sw112 sw.antimod 8033 perfect bass kit paradigm, Buttkicker amplificateur lfe 1000 watts, , tv oled 65e6p,, room 12x25x7,bluray player oppo bdp 203,4coolers ac infinity s9 fan.
zimmo is offline
post #506 of 856 Old 11-07-2018, 02:08 PM
MakeMineVinyl's Avatar
From my experience with the MP amps, they are far better built than the EMO amps. Just take a look at a picture of the insides; the EMO comes across as cheaper built. Quality build is important for reliability, as are high quality parts. I know the MP uses high quality parts.
MakeMineVinyl is offline
post #507 of 856 Old 11-19-2018, 02:29 PM
gallico916's Avatar
gallico916 is offline
post #508 of 856 Old 11-28-2018, 12:08 PM
jsgrise's Avatar
Quoted: 830 Post(s)
Liked: 784
I am looking to purchase an external amp to complete a 7.2.4 system. The options I am looking at:
- Monolith 7x200
- Marantz MM8077
Monolith (ATI) is unknown to me, so I don't know what to expect. I like the Marantz sound, so it would be a safe choice.
Is there any audible hiss to the Monolith when you bring your ear close to the tweeter?
Dedicated Sonus faber HT 7.2.4 | FRONTS: Sonus Faber Venere 2.0 CENTER: Sonus Faber Venere Centre FRONT WIDES: Sonus Faber Venere 1.5 SURROUNDS: Sonus Faber Venere 1.5 TF/TR - ATMOS-DTS:X: Sonus Faber Venere Wall (4) | RECEIVER: Marantz SR7010 AMPLIFICATION: Monolith 7x200 | SUBWOOFERS: Dual 18" Dayton RSS460 Custom Build | Behringer iNuke 6000DSP | Velodyne SMS-1 DISPLAY: JVC D-ILA RS-46 w/ 128" 16:9 1.4 TREATMENT: Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #509 of 856 Old 11-28-2018, 06:02 PM
Stereojeff's Avatar
Quoted: 252 Post(s)
Liked: 162
- Monolith 7x200
- Marantz MM8077
Morris Kessler, president and chief engineer at ATI has been building top-notch amps in the US since 1967. Most of ATI's work is OEM for other brands. His customer list is a who's who of high end audio. With a rated signal-to-noise ratio of 120 dB referenced to rated output the amp should be dead quiet even with your ear pressed up against the tweeter.
Jeff
jsgrise and yanks1 like this.
Stereojeff is offline
post #510 of 856 Old 11-29-2018, 04:40 AM
jsgrise's Avatar
Quoted: 830 Post(s)
Liked: 784
Jeff
Thank you so much for reassuring me. I believe the Monolith 7x will be in my rack for Christmas (I hope Santa has a strong deadlift)
jsgrise is offline
amplifier , monolith 7 , Monoprice
