Monoprice Monolith 7 Amplifier Review - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 292Likes
post #511 of 700 Old 12-05-2018, 06:45 PM
Stereodude's Avatar
Quoted: 4308 Post(s)
Liked: 3032
Is the 7 channel model discontinued? I see it's out of stock at Monoprice and they show the arrival of more stock is more than 1 year from now.
jsgrise likes this.
Stereodude is offline
post #512 of 700 Old 12-06-2018, 04:51 AM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Good question, I am very curious about it since I am about to order one from a Canadian reseller...
MAKE AUDIO GREAT AGAIN | Dedicated Sonus Faber HT 7.2.4 | FRONTS: Sonus Faber Venere 2.0 CENTER: Sonus Faber Venere Centre FRONT WIDES: Sonus Faber Venere 1.5 SURROUNDS: Sonus Faber Venere 1.5 TF/TR - ATMOS-DTS:X: Sonus Faber Venere Wall (4) | RECEIVER: Marantz SR7010 AMPLIFICATION: Monolith 7x200 | SUBWOOFERS: Dual 18" Dayton RSS460 Custom Build | Behringer iNuke 6000DSP | Velodyne SMS-1 DISPLAY: JVC D-ILA RS-46 w/ 128" 16:9 1.4 TREATMENT: Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #513 of 700 Old 12-06-2018, 05:21 AM
jsc79's Avatar
Quoted: 400 Post(s)
Liked: 479
I’m assuming it is just a arbitrary number and they don’t have a lead time from ATI in when the next shipment will be coming.
jsgrise likes this.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #514 of 700 Old 12-13-2018, 12:15 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Well I have received my Monolith 7X today, damn that thing is HEAVY. I have a 500lbs deadlift and still found it hard to bring down in the basement and lift it into the AV rack!
After hooking it up and spending about 45 minutes fixing a ground loop buzz issue, I finally fired it up. I was really sceptical about if it would make a difference in sound since most people here argue that all amps sound the same.
In my setup, it is a big step up in sound quality, soundstage and dynamics from my Marantz SR7010. It's like if the sound was held back before and distorted when things went loud (above -10dB). Now I can see the full potential of my Sonus Faber speakers. The soundstage is more 3 dimensional with better separation between instruments. Sound is much more detailed across the board. It is begging to go louder and when you crank it, the sound remains very clean, detailed and effortless.
Very happy with my purchase and if you are on the fence, just do it. It is worth it! You just cannot compare a 95lbs amp with a 30lbs receiver.
jsgrise is offline
post #515 of 700 Old 12-13-2018, 12:25 PM
indebtbassfreak's Avatar
Quoted: 1417 Post(s)
Liked: 2718
In my setup, it is a big step up in sound quality, loudness and dynamics from my Marantz SR7010. It's like it the sound was held back before and distorted when things went loud (above -10dB). Now I can see the full potential of my Sonus Faber speakers. The soundstage is more 3 dimensional with better separation between instruments. Sound is much more detailed across the board. It is begging to go louder and when you crank it, the sound remains very clean, detailed and effortless.
Glad to hear the sound quality and power is as good as you report and as you said it should be, coming from ATI and tipping the scales at 95lbs. Can you share what your ground loop source was and your fix?
jsgrise likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #516 of 700 Old 12-13-2018, 12:28 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
The ground loop was coming from my JVC projector not being plugged in the same outlet as my Monolith. I swap all my electronics from one outlet to the other and back and fort and finally realize it was the projector......... So I plugged it in the same power strip as my Monolith.
indebtbassfreak likes this.
jsgrise is offline
post #517 of 700 Old 12-13-2018, 12:40 PM
Liked: 2718
Oh ok, before with my last set of subs, i tried separate locations at the opposite ends of the room where i had to use separate ac outlets. Lots of ground loop hum in that configuration beyond the baseline hum that was there, now i have everything on a completely separate 2X 20a outlet which resolved that issue. It was challenging at that time figuring some things out as those subs were defective and had a hum no matter what.
Anyway,, it's nice when our expectations and hopes are met with an upgrade, glad the results were that much better.
jsgrise likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #518 of 700 Old 12-13-2018, 01:33 PM
madhuski's Avatar
Quoted: 1322 Post(s)
Liked: 857
light dimmer switches, i found, also can cause ground loops
jsgrise and indebtbassfreak like this.
madhuski is online now
post #519 of 700 Old 12-13-2018, 01:44 PM
Liked: 2718
Oh yeah,,,as well as flipped ac grounds,, most commonly are cable lines (boxes), among many other things. I cant count how many doesen hours i spent last year
jsgrise and madhuski like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #520 of 700 Old 12-13-2018, 03:29 PM
audioheaven's Avatar
Quoted: 21 Post(s)
anyone compare the 5ch to the 7ch --
any sound quality differences?
" Listen and you will see. "
audioheaven is offline
post #521 of 700 Old 12-13-2018, 04:27 PM
Stereodude's Avatar
Liked: 3032
Why do you think they would sound different?
post #522 of 700 Old 12-13-2018, 05:43 PM
madhuski's Avatar
Liked: 857
i’d imagine they’d sound exactly the same....
post #523 of 700 Old 12-13-2018, 07:21 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Each channel has it's own power supply, so 2-5-7 channels should sound the same.
jsgrise is offline
post #524 of 700 Old 12-14-2018, 04:58 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Is it normal to hear a slight buzz when you put your ear right next to the tweeters?
I tired everything, disconnecting everything and only having the Monolith plug straight into the wall and still do it.
jsgrise is offline
post #525 of 700 Old 12-14-2018, 05:25 PM
Quoted: 53 Post(s)
I noticed the same and just got a Furman elite 20 pfi im installing this weekend... Ill keep you posted if this resolves the issue.
Was using a CHEAP power strip and have multiple components on different outlets. Last step to getting this setup right.
jsgrise likes this.
bdcody01 is offline
post #526 of 700 Old 12-14-2018, 05:32 PM
Quoted: 53 Post(s)
Any word on a 400w version coming out? Need a bit more juice up front for my 707 LSIM's..
How would a DSONIC mix with the monolith 7x up front?
bdcody01 is offline
post #527 of 700 Old 12-14-2018, 05:37 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Thanks mate for making me thinking of using my Furman Elite-15. Will try that out and get back to you.
jsgrise is offline
post #528 of 700 Old 12-14-2018, 05:49 PM
Norris Kasey's Avatar
Quoted: 141 Post(s)
Liked: 67
I thought with a power amp you should run it directly to the outlet and not use any power conditioners or surge protectors
Sent from my Pixel XL using Tapatalk
dwaleke likes this.
Norris Kasey is offline
post #529 of 700 Old 12-14-2018, 07:24 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
I heard about that, it would be interesting to read the pros and cons from knowledgeable people on that Mather.
jsgrise is offline
post #530 of 700 Old 12-14-2018, 07:40 PM
jsc79's Avatar
Quoted: 400 Post(s)
Liked: 479
I think some surge/power conditioners limit current and that is the reasoning. On another note, pretty sure it says to plug it right into the wall in the manual. That’s how I have mine.
dwaleke and Norris Kasey like this.
jsc79 is online now
post #531 of 700 Old 12-14-2018, 08:31 PM
madhuski's Avatar
Liked: 857
I think you’d do fine mixing. I had a d-sonic for a while paired with a different brand (nad) without any issues
post #532 of 700 Old 12-20-2018, 04:06 PM
Quoted: 141 Post(s)
Liked: 67
Who makes a decent quality 7 channel RCA cable snake? Need about 6ft in length.
post #533 of 700 Old 12-20-2018, 05:40 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1923 Post(s)
Liked: 1416
Here you go:
https://www.bluejeanscable.com/store/6channel/index.htm
- Rich
Oppo UPD-205 x 2 | UPD-203 | Sonica DAC | Emotiva XMC-1 (v3) | Revel Salon2s, Voice2, Studio2s | Benchmark AHB2 x 4 | ATI AT522NC | Velodyne HGS-15 | LG 77C9 | Lumagen 2020 | HDFury Vertex x 2
RichB is online now
post #534 of 700 Old 12-20-2018, 06:18 PM
Quoted: 141 Post(s)
Liked: 67
Originally Posted by RichB View Post
Any other options besides bluejeans
post #535 of 700 Old 12-20-2018, 08:17 PM
DOC1963's Avatar
Quoted: 127 Post(s)
Liked: 171
Try proaudiola.com. Custom made, excellent quality and reasonable prices.
Here’s a link to their 7 channel snake...
https://www.proaudiola.com/category-s/889.htm
Pick your length and whatever ends you want. The “premium finish” is a little higher in price, but well worth it IMO.
jsgrise and Norris Kasey like this.
DOC1963 is offline
post #536 of 700 Old 12-21-2018, 07:30 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
I have question for you .I need 7chanels ,ITS possible to take center to the 7x200 and collect 1speaker ,I no need center and the monlith 7x200watts,and other question ,
the monolith 7x200watts you collect whit wall plug 15 a or 20 a.
thank you for answer.
marantz av 8805, 13 chanels, emotiva 2 xpa 5 gen1,1 emotiva xpa3 gen3, 7.4.6,4 speakers monitor 11 ,2 paradigm studio 100 v2,4 ceillings speakers ss82w sweet spot earthquake ,2 earthquake ecs-8.0,1 center Paradigm cc390,4 subs klipsch r-sw112 sw.antimod 8033 perfect bass kit paradigm, Buttkicker amplificateur lfe 1000 watts, , tv oled 65e6p,, room 12x25x7,bluray player oppo bdp 203,4coolers ac infinity s9 fan.
zimmo is offline
post #537 of 700 Old 12-21-2018, 01:11 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
I'm having a hard time understanding your question, you can PM me in french if it helps you, I'm from Montreal too
jsgrise is offline
post #538 of 700 Old 01-04-2019, 08:12 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
I buy MONOLITH 5x200watts, this amplifier replace my émotiva xpa5.I out same place same plug ,same cable.
When I start the monolith wow I have in my speakers immidiately some hum and some noise from all speaker ,that not normal ,my émotiva I have 3 amplifier have never
hum or noise ,yes the power is better from monolith but the problem to fix this noise is to mutch for me.
I put in the box and send to the company and I reput my xpa in the place to monolith and silencio comming immidiately,some thing wrong in the monolith amplifier.
zimmo is offline
post #539 of 700 Old 01-09-2019, 01:13 PM
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
The Emotiva uses a 2-prong power cable, so it will not be subject to ground loop issues like the Monolith.
jsgrise is offline
post #540 of 700 Old 01-10-2019, 03:58 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
JSGRISE
I see in internet some power bar conditonner whit filter furnam or émotiva cmx-2 ,is good for hum .
zimmo is offline
amplifier , monolith 7 , Monoprice
