Home theater Application Marantz SR7010 vs. DENON AVRX7200WA - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By jdsmoothie
post #1 of 4 Old 06-19-2016, 07:39 AM - Thread Starter
MichiganTim's Avatar
Quoted: 105 Post(s)
Liked: 49
Hello Fellow AVS Forums,
Need some help please. Looking to upgrade my Pioneer elite SC-95 to Marantz SR7010 or DENON AVRX7200WA. Reason being these avr's are confirmed to work with my P series TV hdmi arc for DD+ and Atmos. Main application home theater use, sometimes music will be played as well.
1. What are the major differences between the 2 AVrs? I see significant cost difference between them.
2. I am interested in the one that will do 4k video up convert the best. While handling front/rear dolby atmos enabled speakers.
3. Why does this denon cost so much more then the marantz?
4. How are the amps in these avrs as far efficiency and electrical bil? I will not be running them in the eco friendly mode I believe.
Thank you for your time,
Tim
MichiganTim is offline
post #2 of 4 Old 06-19-2016, 01:17 PM
jdsmoothie's Avatar
Quoted: 22196 Post(s)
Liked: 12056
1. The Denon X7200WA is the current D+M flagship model so in addition to providing better audio quality provides more features as well.
2. Both use the same video chip, however, in most cases, simply passing the unprocessed signal to the TV results in as good as or better picture quality.
3. See #1. Also, it sits between the X4200W and X6200W in the pecking order of D+M AVRs.
4. Running in ECO mode will reduce power and core temp by about 10 degrees with no likely affect on SPL at even near reference volume levels.
Call for pricing and availability on either model if interested.
T100 and Madmax67 like this.
jdsmoothie is offline
post #3 of 4 Old 06-25-2016, 03:20 PM
Liked: 0
Marantz SR7010 vs. DENON AVRX6200W What did you choose?
Now that most of you have the new products I would like to know which one each of you have choose and what you like best about your receivers.
Thanks for your reply's.
Steve Gaither is offline
post #4 of 4 Old 06-25-2016, 05:19 PM
jdsmoothie's Avatar
Liked: 12056
Welcome to AVSForum.
You've posted in a thread comparing the SR7010 to the X7200WA.
You would be better served creating your own thread if you want to compare the SR7010 vs. X6200W.
