Setup of speakers for 7.1.4 or 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-13-2016, 03:53 PM - Thread Starter
Liked: 4
I am contemplating putting large speakers at surround back left and right. My question is if I set set the surround back left and right to Large on my preamp/processor, the information below 80hz for SB speakers will go to these speakers but not to the SUB? In other words when you set any speaker to Large that base information for that particular speaker is diverted from the SUB to that speaker. So if one sets up all large speakers in a 7.1 setup, the .1 (SUB) would get no base info? Or does the base info get duplicated in both the SUB and speakers set to Large?
Thanks for any help.
sal7of9 is offline
post #2 of 9 Old 07-13-2016, 04:02 PM
Oilmanmojo's Avatar
Quoted: 92 Post(s)
Liked: 47
my avr (marantz sr9600) allows for large setting on any channel without impacting LFE. You should be able find out via your op manual
Oilmanmojo is offline
post #3 of 9 Old 07-13-2016, 05:06 PM
jdsmoothie's Avatar
Quoted: 24608 Post(s)
Liked: 13833
Correct. Those speakers set to LARGE will not pass any info to the sub; however, as the LFE (ie. 0.1) only passes to the sub, it would still pass to the sub.
jdsmoothie is offline
post #4 of 9 Old 07-13-2016, 05:33 PM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 2011 Post(s)
Liked: 1020
The sub is still likely is able to play lower frequencies than the large speakers so maybe just set your crossover at a lower frequency and set all your other speakers to small. Thats what I do. If your speakers can play lower frequencies than your sub or contain higher quality woofers, maybe just unplug the sub.
| 7.2.4 Photos (Updated Photos 1/5) | Frequency Response | Visual: LG 65” B7A OLED | Sony VPL-HW45ES |
| AVR/Amps: Marantz SR-6011 9C | Audio Source AMP-100VS | iNuke 1000DSP; TTs: 4x AuraSound Pro |
| Center: B&W CM Center 2 S2 Ed | Fronts: 2x B&W 684 S1s | Side Surrounds: 2x B&W 685 S1 |
| Front/Rear Heights: 4x Polk T15 | In-Ceiling: 2x Micca M-8C | Subs: 2x Rythmik FV15HP |
citsur86 is offline
post #5 of 9 Old 07-13-2016, 10:03 PM - Thread Starter
Liked: 4
Sounds like if ALL the speakers are set to large, the SUB will still get LFE info specifically for the SUB and not any other speaker.
sal7of9 is offline
post #6 of 9 Old 07-14-2016, 03:54 AM
jdsmoothie's Avatar
Liked: 13833
Correct, although you're likely confusing LFE (0.1 in DD/DTS 5.1/7.1) with the lower frequency audio sent to the speakers, which is different. The LFE only goes to the sub regardless of the speaker LARGE/SMALL setting, while the lower frequency audio sent to the speakers only goes to the sub when set to SMALL, although with some brands, the FL/FR lower frequencies can be sent to the sub even when set to LARGE (ie. using LFE+MAIN on Denon/Marantz models).
post #7 of 9 Old 07-14-2016, 03:05 PM - Thread Starter
Liked: 4
I was wondering do you know if. the signal going to the surrounds and the surround back speakers ever goes below 50hz. The reason I'm asking is that I have two large speakers (Infinity RS III) with two 10'' woofers each that I'm not using and thinking about using them as surround back speakers. But if the signal never goes below 50hz then there's really no point.
My other speakers are:Paradigm Reference Studio 100 v.3 , CC-570 v.3 , ADP-470 v.3 , Servo-15 and Monitor Audio ASW 210 Subwoofer.
sal7of9 is offline
post #8 of 9 Old 07-14-2016, 03:13 PM
jdsmoothie's Avatar
Liked: 13833
That will depend on the mixer of that particular audio you're passing to the AVR as it can be 20Hz - 20kHz.
post #9 of 9 Old 07-14-2016, 03:15 PM
Liked: 6
Have anyone tried those 50.1 stuff?
af2000 is offline
