Owner's Thread for Pioneer SC-LX701 / SC-801 / SC-LX901 Receviers - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 1681Likes
post #1591 of 2340 Old 11-25-2018, 12:59 PM
Quoted: 382 Post(s)
Liked: 133
Originally Posted by Egidio Concas View Post
As I saw in one video, the MCACC PRO makes you put the mic in 3 different spots, is it a big improvement compared to the standard MCACC?
3 positions are not required. But it is an option.
Good for creating an even fIeld across a large space (say a couch or split chairs) v/s a single sweet spot.
ST Dog is offline
post #1592 of 2340 Old 11-25-2018, 09:08 PM
Quoted: 36 Post(s)
Liked: 2
I have a very large couch, 3 meters long. I'm gonna give it a try.
Egidio Concas is offline
post #1593 of 2340 Old 11-25-2018, 09:55 PM
thumpermike's Avatar
Quoted: 37 Post(s)
What do you mean by 3 positions? Nothing in my manuals mentions 3 positions.
I am having a terrible time with my Atmos. I have up firing modules.. they used to sound like the were ceiling speakers with my SC 97... now they sound like speakers mounted on the wall higher than the main speakers, but not truly overhead like before. Maybe I’ll try this 3 position.
Are you just running MCACC 3 different times with the mic in a different spot and seeing what sounds best?
thumpermike is offline
post #1594 of 2340 Old 11-25-2018, 11:14 PM
Quoted: 382 Post(s)
Liked: 133
Look closer, it's part of MCACC Pro.
It's not likely to help with your Atmos issue though, unless you had the mic nowhere near where you actually sit.
thumpermike likes this.
ST Dog is offline
post #1595 of 2340 Old 11-25-2018, 11:22 PM
thomasphoenix's Avatar
Quoted: 255 Post(s)
Liked: 151
I have an SCLX 901 , had an SCLX 85 before , I have a 7.1.4 with sub optimal placement , front heights and mid upfiring .
Atmos is unbelievably good. My entertainment area is also not optimal it’s open on two sides . I use all ch adj in MCACC because of the room not being symmetrical and enable Dolby optimizer on the upfiring speakers. The skin on my scalp responds to overhead sound , it’s that good .
The 3 point calibration is for multiple listening areas . Sweet spot remains the same .
TV-Sony Bravia KD-65"A1, Pioneer SC-LX901 7.2.4 ATMOS/DTS-X, Polk DSW 660*2, Polk RTi A7*2, Pol Csi A6, Polk RtiA5*2, Polk Tsi300*2, Polk TSX 220B *2, Polk OWM 3*2, ZidooZ9s, Nvidia Shield Pro-19, Zappiti-4kHDROne, Oppo UDP-203, XboxOneX, PS4, Oppo BDP-83, Darbee DVP-5000s, ZidooX10, Sony Bravia HX925 55"
thomasphoenix is offline
post #1596 of 2340 Old 11-25-2018, 11:28 PM
Quoted: 37 Post(s)
I might try again with all channel adjust. My “theater room” is just the entry room in my home. Basically walls front, rear and right side.. open dining room on left side.
Just seems weird, since the 97 sounded amazing overhead right off the bat with a single MCACC run.
post #1597 of 2340 Old 11-26-2018, 02:26 AM
Liked: 0
Originally Posted by VisionxOrb View Post
my first step would be factory reset both receiver and tv, second step would try a new certified premium hdmi cable.
I've spent several hours setting up both TV and Receiver after factory reset and it didn't help.
What DID help is the last resort - I've plugged in blank HDMI cable to TV's HDMI 1/MHL and suddenly TV found Pioneer on HDMI 4/ARC channel. Before that I had PS4 on TV's HDMI 1. The only guess I have is that TV actually searched for MHL device on HDMI 1, rather then HDMI 4/ARC channel
German Gedgauds is offline
post #1598 of 2340 Old 11-26-2018, 03:57 AM
Quoted: 36 Post(s)
Liked: 2
post #1599 of 2340 Old 11-26-2018, 03:50 PM
Quoted: 37 Post(s)
Well hot damn. I’ll definitely be giving this a try, thanks.
I have just about every recommended Atmos Blu Ray out there and none have sounded as good overhead as the intro to Kong: Skull Island. Any other specific overhead media I should be keying in on?
post #1600 of 2340 Old 11-27-2018, 12:48 PM
Quoted: 36 Post(s)
Liked: 2
Well hot damn.
LoL!
post #1601 of 2340 Old 11-27-2018, 01:03 PM
Quoted: 37 Post(s)
Lol.. well.. I went through the process.. the low volume clarity sounds really good. I might try to turn off symmetry.
But my Atmos sounds worse during Kong than it did prior. Ugh. I’ll keep tuning.
post #1602 of 2340 Old 11-27-2018, 08:29 PM
Quoted: 255 Post(s)
Liked: 151
If you can get your hands on the Dolby Atmos demo 2014 disk( google is your friend ) you can use some of the demo sounds to check if Atmos is being rendered well . There is a particular one where the sound arcs all over and around you in a hemisphere, that was invaluable. Without that , most movies are front heavy and apart from better directionality and seamless travel of sound , it difficult to say if your upfiring speakers are working well .
post #1603 of 2340 Old 11-29-2018, 04:41 PM
Quoted: 36 Post(s)
Liked: 2
I'm confused about the Elite etiquette that I see in older images. Are these the same AVRs and they just lost the Elite status or what? LoL.
post #1604 of 2340 Old 11-30-2018, 04:37 AM
Quoted: 255 Post(s)
Liked: 151
I assume you are referring to the Elite logo, it was never used in EU & Asia. And the display is amber in the US while white in EU&Asia .
post #1605 of 2340 Old 11-30-2018, 06:58 AM
Quoted: 36 Post(s)
Liked: 2
Yes! Oh, okay. Got it. Thanks =)
post #1606 of 2340 Old 12-04-2018, 03:40 PM
Quoted: 16 Post(s)
Liked: 25
Read through this thread and (don't think) I saw this mentioned:
I had an SC-95 & just picked up a 901. I have noticed, and confirmed with Pioneer there is a difference with the upmixers (DSU/Neural:X) on the 901.
For reference I'm running a 5.1.4 setup.
With the SC-95, if left in AutoSurround mode, it would invoke the DSU or the DTS upmixer automatically depending on the source disc.
With the SC-LX901(and likely 701/801), the upmixer has to be manually selected every time a disc is played. Which means a manual intervention with every (non-atmos / non-DTS:X) disc in order to utilize height speakers.
This seems like a big miss IMO. And the Pio rep today (after confirming my results via bench tests on the SC-9X series and the current LX-X01's) seemed to agree this isn't an optimum firmware implementation.
So if I'm missing a setting or something, I'm all ears (pun intended).
John^Galt is online now
post #1607 of 2340 Old 12-04-2018, 03:52 PM
Quoted: 382 Post(s)
Liked: 133
Personally I'd prefer up-mixing not be the default. Ever.
Only the source given unless I specify different.
Don't convert 5.1 to 7.1, don't send 2 channel to surrounds, etc.
John^Galt likes this.
ST Dog is offline
post #1608 of 2340 Old 12-06-2018, 04:32 AM
Thomasdk1405's Avatar
Quoted: 62 Post(s)
Liked: 74
Originally Posted by bigmike39 View Post
Hi All
I am a new Pioneer 901 owner and so far I have been a happy camper but of late my Air Play and Spotify streaming have stopped working properly..I called support and they just keep telling me to unplug my unit for 60 seconds fort a reset..I would appreciate any help on this matter..thanks guys and I am enjoying the forum..
Hi
no need to unplug the unit ! If airplay will not work - for some reason - then just longpress the power button (turn it off and keep it pushed until the blue network lamp blink and it turns on). Then it will say initializing.... in display - and reconnects wifi, bluetooth and so on. My 901 did this often at some point in time - but now its all fine again. If this was apple's airplay or it was Pioneer to blame - no clue - anyway it has stopped !
Thomasdk1405 is offline
post #1609 of 2340 Old 12-06-2018, 12:10 PM
Quoted: 67 Post(s)
Liked: 24
Originally Posted by Thomasdk1405 View Post
Hi
This didn't work for me. Randomly the AirPlay would stop or not reconnect after it stopped at all. Reinitializing allowed it to reconnect, but it would stop working again. Resetting the entire unit to factory defaults did the trick.
I use Full Adjust btw, it sounds better and adjusts the subs. I keep hearing Audyssey does better with subs, how so?
BigART71 is offline
post #1610 of 2340 Old 12-06-2018, 12:45 PM
Liked: 0
Pioneer elite SC-LX901 remote control quit working
I bought this unit in February of 2018 and have been very happy with it until the remote just quit working. Changed the batteries and it still wont operate. Remote has not been dropped or damaged and infrared light works fine when pressing the buttons. Has anyone ever experienced this? I’m at a loss. Any advice would be greatly appreciated.
Gardenia63 is offline
post #1611 of 2340 Old 12-06-2018, 12:55 PM
Liked: 0
Pioneer Elite SC-LX901
post #1612 of 2340 Old 12-13-2018, 06:51 AM
mogrub's Avatar
Quoted: 272 Post(s)
Liked: 272
The topic has come up in the past because this cycle has lasted so long, but does anybody have any news on when the 701/801/901 line will be replaced? I'm trying to decide whether to buy in now or hold out until that happens. Thanks and cheers.  🌲
"Get me a scotch. I'm starving." JVC DLA RS-540U, Stewart ST 130 G3, Yamaha RX-A3080, Emotiva XPA-3, Panasonic UB820, Oppo 103D, Xfinity X1, Roku, ATV, Harmony 900.  Atmos 7.2.4 via Martin Logan Stage-X, Martin Logan Theos x2, Martin Logan FX x2, Sonance VP69 x2, Sonance VP66 x4, SVS PC12-NSD x2. Viewer's choice between Palliser recliners x7 or Great Dane beds x2.
mogrub is offline
post #1613 of 2340 Old 12-13-2018, 10:35 AM
Liked: 0
Guys, I need your help with SC-LX502 in regards of subwoofer connection.
I've got 2.1 system (pair of Dynavoice Challenger M-65) and Focal Chorus SW700S subwoofer.
Speakers connected using Bi-Wiring, subwoofer connected via LFE channel
Question 1: should I connect through LFE or using Left/Right Line inputs? (since it's 2.1 system, not 5.1)
Question 2: Subwoofer works ONLY when playing Full HD cinema with decent audio track), when I play Spotify/Tv Stream/Youtube receiver doesn't show that sub is connected. Only choice I've found to turn it on always is to use "double bass" function in amp setting.
Am I doing anything wrong?
post #1614 of 2340 Old 12-13-2018, 12:02 PM
RickyDeg's Avatar
Quoted: 382 Post(s)
Liked: 364
There's been no official word and hardly a single rumour, so... it's anybody's guess at this point.
NAD M17 (processor) + NAD M27 (multichannel amp)
REVEL CONCERTA2 (5.0 speakers) + SVS SB-2000 LIMITED EDITION (dual subwoofers)
PIONEER UDP-LX500 (uhd bd player)
LG OLED65C8 (oled tv)
RickyDeg is offline
post #1615 of 2340 Old 12-13-2018, 12:16 PM
Quoted: 382 Post(s)
Liked: 133
Does the 50x have a separate thread?
Not sure what might be different from the 7/8/901.
For sure use the sub out/LFE connection.
What are you fronts set as, large or small?
What crossover frequency?
My guess is large and only thing going to sub is LFE channel from multichannel sources (x.1 signals)
Set to small and reasonable crossover. Then everything below crossover goes to sub (along with the dedicated LFE stuff)
ST Dog is offline
post #1616 of 2340 Old 12-13-2018, 12:25 PM
Liked: 0
Speakers are set to "Large"
Crossover - 80 Hz
So you are saying only choice is either "double bass" or choose speakers as "Small" and reasonable crossover like 80 Hz?
post #1617 of 2340 Old 12-13-2018, 03:48 PM
Quoted: 382 Post(s)
Liked: 133
Yes.
If set to large all frequencies go to the speaker. Crossover is ignored/not used.
The large/small naming is unfortunate as it confuses many.
ST Dog is offline
post #1618 of 2340 Old 12-15-2018, 02:32 PM
Liked: 0
here is my simple issue pioneer 801 or pioneer 901 i read somewhere the 801 sounds better than the 901 anybody can clear this up thank you...
pioneer 501 is offline
post #1619 of 2340 Old 12-15-2018, 02:45 PM
Quoted: 37 Post(s)
I have an 801. If it wasn’t sent to me as a warranty unit for my SC-97... I would have went 901. But I have Atmos and hate have a second amp.
post #1620 of 2340 Old 12-15-2018, 08:23 PM
Quoted: 382 Post(s)
Liked: 133
Where did you read that?
The 901 should sound better og any differences are noticed. I doubt most would notice a difference in a blind test.
But if you need the extra features or power the 901 offers that would matter.
ST Dog is offline
5.1.4 , 590 , 7.1.4 , 701 , atmos , av receivers , jbl studio , Pioneer , pioneer receiver , pioneer sc-lx801 , receiver , sc lx 801 , sc lx 901
