Denon AVR X2200W troubleshooting with PS3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By JChin
  • 1 Post By 51dueller
post #1 of 7 Old 08-23-2016, 03:00 PM - Thread Starter
Liked: 0
I have been searching around to see if anyone has run into the same issue but have not found anything. I have a Denon X2200W (about two months old) that I am connecting a PS3 to via the HDMI "Game" input. When the input is selected the TV displays the Denon logo and the input information (video connection is working). Once I turn the PS3 on the TV reverts to a "no signal present" message. I can continue to hear the audio, but no video. If I hook the PS3 direct to the TV it works fine. If I hook it up to any HDMI port on the Denon, no video, just audio. Other devices work fine (DVD player, cable box). Different HDMI cables do not make a difference. Turned everything off and back on, no difference. I have looked at the Denon support site and the manual for the receiver, but those were no help. Does anyone have any thoughts?
Brian Murnane is offline
post #2 of 7 Old 08-23-2016, 03:12 PM
JChin's Avatar
Quoted: 457 Post(s)
Liked: 242
Hi Brian Murnane, try turning off Deep Color in the PS3 under Display Settings menu.
Brian Murnane likes this.
JChin is offline
post #3 of 7 Old 08-23-2016, 03:53 PM - Thread Starter
Liked: 0
Thanks, I will give that a try as soon as I get home.
post #4 of 7 Old 08-23-2016, 08:41 PM
51dueller's Avatar
I had a similar problem a few months ago with my X2200 AVR. Did the latest firmware update on my PS3 and when it restarted I just got a black screen with audio. I had to hold the PS3's power button on boot up to reset it to default settings. Once I did that I got picture again and then just set my picture settings back to what they were before the firmware update.
51dueller is offline
post #5 of 7 Old 08-24-2016, 08:03 AM - Thread Starter
Liked: 0
Thanks JChin and 51dueller for the quick feedback. Changing the setting on the Deep Color did the trick. I may try the PS3 reset as well at some point, just to see if that works too.
post #6 of 7 Old 01-04-2017, 09:31 AM
DanTou's Avatar
Quoted: 33 Post(s)
Liked: 24
A big "Thank you" from me as well. Short thread with right solution. I looked for hours in long threads where people try to guess things to do.
DanTou is offline
post #7 of 7 Old 01-04-2017, 09:36 AM
jdsmoothie's Avatar
Quoted: 22734 Post(s)
Liked: 12381
Consider reviewing the first 8 posts in the 2015 Denon AVR Owner's thread linked below as the solution has been listed in post 3 of that thread under "Troubleshooting" for the last 1.5 years.
https://www.avsforum.com/forum/90-rec...2-2-a.html#l17
jdsmoothie is offline
ps3 , x2200w
