Wireless Mic recommendations? Shure vs anything else? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-12-2016, 04:44 PM - Thread Starter
kelemvor's Avatar
Howdy,
I'm looking to get a wireless microphone for a church setup. Didn't see any forums regarding mics but they seems like they'd be Audio so here goes...
I have some experience with the Shure combo kits that have 1 wireless handheld mic and 1 wireless lapel mic. Those kits are about $550 so I'm wondering if there are comparable alternatives that might be less expensive but accomplish the same objective.
We don't need anything with fancy feature or anything. We just need one handheld mic and one clip on type mic that are both wireless.
Any recommendations would be great.
kelemvor is offline
post #2 of 5 Old 09-13-2016, 07:40 AM
Wayne A. Pflughaupt's Avatar
Quoted: 410 Post(s)
Liked: 333
Sennheiser is another great brand you might consider, but you really can’t cut corners on a good wireless mic system. It has nothing to do with “fancy.” Cheap ones are prone to drop-outs, static, obnoxious bursts of RF noise when the transmitter is turned off, and generating noise just by handling the mic that is audible in the sound system. If you’re looking to save money, find a used one.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 5 Old 09-13-2016, 07:59 AM
M Code's Avatar
Quoted: 1092 Post(s)
Liked: 703
We have done multiple church system installs, and usually use the Audio-Technica wireless microphones. Excellent range and clarity, plus bullet-proof reliability..
Just my $0.02...
M Code is offline
post #4 of 5 Old 09-13-2016, 08:03 AM - Thread Starter
kelemvor's Avatar
Just my $0.02...
Thanks. Could you provide me any model numbers (or links) from which ones you've used in the past so I can go take a look? Found a bunch on Amazon but not sure which are ones to look at.
kelemvor is offline
post #5 of 5 Old 09-13-2016, 11:12 AM
M Code's Avatar
Liked: 703
Here is the 1 I like to use...
Audio Technica ATW-2129AD
I have installed many, many of these not a single failure to date.
Just my $0.02...
M Code is offline
